Detailed individual donor stats?
enroscado
Post by enroscado »
I have been thinking of running a script locally on each of my computers folding in order to keep detailed track of my folding contribution as well as performance. Also, running it locally would allow me to keep historical records for as long as I want.
I recently learnt about the possibility of viewing team statistics accessing https://apps.foldingathome.org/teamstats/team0.txt
Is there something equivalent but for individual donors?
I am looking to get detailed information like the one accessible on https://apps.foldingathome.org/cpu but without having to go through a search, so that I can parse it something like once or twice a day.
If it were on txt like the teams stats, I would be even easier.
Any help or ideas?
Thanks in advance.
Re: Detailed individual donor stats?
Post by muziqaz »
Extremeoc stat page does detailed stats. Probably worth checking out how they get their stats
FAH Omega tester
enroscado
Post by enroscado »
Yes, I am familiar with folding.extremeoverclocking.com
However, there is one main (understandable due to constrains) limitation: It is only possible to see detailed daily info for the past 1.5 days, detailed weekly info for the past 13 days, and son on. As time goes on, detailed info is not longer visible / available. This is exaclt what I want to preserve, and I can only do it locally.
Post by muziqaz »
enroscado wrote: Mon Aug 18, 2025 9:46 am Yes, I am familiar with folding.extremeoverclocking.com
Contact Jason, the admin for the page, he will be able to tell you what he is using for his stats
FAH Omega tester
JWhy
Post by JWhy »
Hello,
If you only want your own stats, maybe go the API way : https://api2.foldingathome.org/user/JWhy and https://api2.foldingathome.org/cpus?query=JWhy ?
I think Jason is using the huge file with all (?) users available in https://foldingathome.org/statistics/ (item menu "Donor list (txt)" )
