Make a post about your issue on https://foldingforum.org/ to get more help
Mactin
Post by Mactin »
Hello,
My "new" folding PC just had an issue. It just dumped 3 WUs across both CPU and GPU instances. Luckily I was arround at the moment and my reflex was to pause everything and reboot the PC (running Windows 11). Before rebooting I cut and pasted the log file from the browser in order to save it (a long process).
From what I can see in the log :
- The CPU instance (WU96, p18806-r38-c1-g495, 0xa9) stalled at 17%, dumped and reloaded a new WU (WU98, p18496-r1-c7-g32, 0xa8). It's still running OK.
- 37 minutes later, the GPU instance (WU97, p16781-r25-c3-g270, 0x23) failled at 28%.
- It loaded a new WU (WU99, p18224-r16-c8-g89, 0x23), it failled immediately with very few entries in the log.
- It loaded another WU (WU100, p18230-r206-c7-g65, 0x24), before it could fail, I paused every thing. After rebooting, I restarted the folding manualy (I dont know how the restart folding automaticaly on reboot). It has been folding without problems for about an hour without problema
- These three failled WUs might be 2 (or 3) unrelated issues or not. Or the PC might be showing unstability. I posted this because the message "Make a post about your issue on https://foldingforum.org/ to get more help" appeared in the log.
It would be very usefull to know where the log file is, Google has not been much help so far.
Thanks for listening to my story.
18:49:56:I1:WU96:Completed 27500 out of 250000 steps (11%)
18:51:26:I1:WU97:Completed 200000 out of 2500000 steps (8%)
18:51:29:I1:WU97:Checkpoint completed at step 200000
18:54:12:I1:WU96:Completed 30000 out of 250000 steps (12%)
18:54:26:W :WU96:Visualization frame 12 unchanged, skipping
18:54:34:I1:WU97:Completed 225000 out of 2500000 steps (9%)
18:57:40:I1:WU97:Completed 250000 out of 2500000 steps (10%)
18:57:43:I1:WU97:Checkpoint completed at step 250000
18:58:33:I1:WU96:Completed 32500 out of 250000 steps (13%)
19:00:48:I1:WU97:Completed 275000 out of 2500000 steps (11%)
19:02:53:I1:WU96:Completed 35000 out of 250000 steps (14%)
19:03:53:I1:WU97:Completed 300000 out of 2500000 steps (12%)
19:03:56:I1:WU97:Checkpoint completed at step 300000
19:07:01:I1:WU97:Completed 325000 out of 2500000 steps (13%)
19:07:14:I1:WU96:Completed 37500 out of 250000 steps (15%)
19:10:06:I1:WU97:Completed 350000 out of 2500000 steps (14%)
19:10:10:I1:WU97:Checkpoint completed at step 350000
19:11:34:I1:WU96:Completed 40000 out of 250000 steps (16%)
19:13:15:I1:WU97:Completed 375000 out of 2500000 steps (15%)
19:15:53:I1:WU96:Completed 42500 out of 250000 steps (17%)
19:16:20:I1:WU97:Completed 400000 out of 2500000 steps (16%)
19:16:23:I1:WU97:Checkpoint completed at step 400000
19:16:37:I1:WU96:Watchdog triggered, requesting soft shutdown down
19:16:42:I1:WU96:Folding@home Core Shutdown: WU_STALLED
19:16:42:E :WU96:Core returned WU_STALLED (127)
19:16:42:E :WU96:Run did not produce any results. Dumping WU
19:16:42:I1:Default:Added new work unit: cpus:14 gpus:
19:16:42:I1:WU96:Sending dump report
19:16:42:I1:WU98:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:16:43:I1:OUT44:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
19:16:43:I1:OUT43:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
19:16:43:I1:OUT43:< HTTP/1.1 200 HTTP_OK
19:16:43:I1:WU96:Dumped
19:16:45:I1:OUT44:< HTTP/1.1 200 HTTP_OK
19:16:45:I1:WU98:Received WU assignment 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM
19:16:45:I1:WU98:Downloading WU
19:16:45:I1:OUT45:> POST https://vav21.fah.temple.edu/api/assign HTTP/1.1
19:16:46:I1:OUT45:< HTTP/1.1 200 HTTP_OK
19:16:46:I1:WU98:Received WU P18496 R1 C7 G32
19:16:46:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01 -version 8.4.9 -lifeline 21064 -np 14
19:16:46:I3:WU98:Started FahCore on PID 7592
19:16:46:I1:WU98:*********************** Log Started 2025-07-12T19:16:46Z ***********************
19:16:46:I1:WU98:************************** Gromacs Folding@home Core ***************************
19:16:46:I1:WU98: Core: Gromacs
19:16:46:I1:WU98: Type: 0xa8
19:16:46:I1:WU98: Version: 0.0.12
19:16:46:I1:WU98: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:16:46:I1:WU98: Copyright: 2020 foldingathome.org
19:16:46:I1:WU98: Homepage: https://foldingathome.org/
19:16:46:I1:WU98: Date: Jan 16 2021
19:16:46:I1:WU98: Time: 12:29:40
19:16:46:I1:WU98: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:16:46:I1:WU98: Branch: master
19:16:46:I1:WU98: Compiler: Visual C++ 2019 16.7
19:16:46:I1:WU98: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:16:46:I1:WU98: Platform: win32 10
19:16:46:I1:WU98: Bits: 64
19:16:46:I1:WU98: Mode: Release
19:16:46:I1:WU98: SIMD: avx2_256
19:16:46:I1:WU98: OpenMP: ON
19:16:46:I1:WU98: CUDA: OFF
19:16:46:I1:WU98: Args: -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01
19:16:46:I1:WU98: -version 8.4.9 -lifeline 21064 -np 14
19:16:46:I1:WU98:************************************ libFAH ************************************
19:16:46:I1:WU98: Time: 11:24:13
19:16:46:I1:WU98:************************************ CBang *************************************
19:16:46:I1:WU98: Time: 11:23:53
19:16:46:I1:WU98:************************************ System ************************************
19:16:46:I1:WU98: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:16:46:I1:WU98: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:16:46:I1:WU98: CPUs: 16
19:16:46:I1:WU98: Memory: 15.60GiB
19:16:46:I1:WU98:Free Memory: 8.19GiB
19:16:46:I1:WU98: Threads: WINDOWS_THREADS
19:16:46:I1:WU98: OS Version: 6.2
19:16:46:I1:WU98:Has Battery: false
19:16:46:I1:WU98: On Battery: false
19:16:46:I1:WU98: UTC Offset: -4
19:16:46:I1:WU98: PID: 7592
19:16:46:I1:WU98: CWD: C:\ProgramData\FAHClient\work
19:16:46:I1:WU98:********************************************************************************
19:16:46:I1:WU98:Project: 18496 (Run 1, Clone 7, Gen 32)
19:16:46:I1:WU98:Unit: 0x00000000000000000000000000000000
19:16:46:I1:WU98:Reading tar file core.xml
19:16:46:I1:WU98:Reading tar file frame32.tpr
19:16:46:I1:WU98:Digital signatures verified
19:16:46:I1:WU98:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpt 5 -nt 14 -ntmpi 1
19:16:46:I1:WU98:Steps: first=160000000 total=165000000
19:16:47:I1:WU98:Completed 1 out of 5000000 steps (0%)
19:19:19:I1:WU97:Completed 425000 out of 2500000 steps (17%)
19:19:36:I1:WU98:Completed 50000 out of 5000000 steps (1%)
19:22:15:I1:WU97:Completed 450000 out of 2500000 steps (18%)
19:22:18:I1:WU97:Checkpoint completed at step 450000
19:22:26:I1:WU98:Completed 100000 out of 5000000 steps (2%)
19:25:14:I1:WU97:Completed 475000 out of 2500000 steps (19%)
19:25:15:I1:WU98:Completed 150000 out of 5000000 steps (3%)
19:28:04:I1:WU98:Completed 200000 out of 5000000 steps (4%)
19:28:11:I1:WU97:Completed 500000 out of 2500000 steps (20%)
19:28:13:I1:WU97:Checkpoint completed at step 500000
19:30:53:I1:WU98:Completed 250000 out of 5000000 steps (5%)
19:31:10:I1:WU97:Completed 525000 out of 2500000 steps (21%)
19:33:43:I1:WU98:Completed 300000 out of 5000000 steps (6%)
19:34:06:I1:WU97:Completed 550000 out of 2500000 steps (22%)
19:34:09:I1:WU97:Checkpoint completed at step 550000
19:36:33:I1:WU98:Completed 350000 out of 5000000 steps (7%)
19:37:05:I1:WU97:Completed 575000 out of 2500000 steps (23%)
19:39:22:I1:WU98:Completed 400000 out of 5000000 steps (8%)
19:40:01:I1:WU97:Completed 600000 out of 2500000 steps (24%)
19:40:04:I1:WU97:Checkpoint completed at step 600000
19:42:12:I1:WU98:Completed 450000 out of 5000000 steps (9%)
19:43:00:I1:WU97:Completed 625000 out of 2500000 steps (25%)
19:45:01:I1:WU98:Completed 500000 out of 5000000 steps (10%)
19:45:57:I1:WU97:Completed 650000 out of 2500000 steps (26%)
19:45:59:I1:WU97:Checkpoint completed at step 650000
19:47:52:I1:WU98:Completed 550000 out of 5000000 steps (11%)
19:48:56:I1:WU97:Completed 675000 out of 2500000 steps (27%)
19:50:48:I1:WU98:Completed 600000 out of 5000000 steps (12%)
19:51:53:I1:WU97:Completed 700000 out of 2500000 steps (28%)
19:51:55:I1:WU97:Checkpoint completed at step 700000
19:53:31:I1:WU97:An exception occurred at step 713395: Error invoking kernel: CUDA_ERROR_UNKNOWN (999)
19:53:31:I1:WU97:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
19:53:31:I1:WU97:Folding@home Core Shutdown: CORE_RESTART
19:53:38:E :WU97:Core exited with Windows unhandled exception code 0xc0000409. See https://bit.ly/2CXgWkZ for more information.
19:53:38:E :WU97:Core returned FAILED_1 (0)
19:53:38:E :WU97:Run did not produce any results. Dumping WU
19:53:38:I1:Default:Added new work unit: cpus:0 gpus:gpu:01:00:00
19:53:38:I1:WU97:Sending dump report
19:53:38:I1:WU99:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:53:38:I1:OUT46:> POST https://huangfolding1.chem.wisc.edu/api/results HTTP/1.1
19:53:38:I1:OUT47:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
19:53:38:I1:WU98:WARNING:Console control signal 1 on PID 7592
19:53:38:I1:WU98:Exiting, please wait. . .
19:53:38:I1:OUT46:< HTTP/1.1 200 HTTP_OK
19:53:38:I1:WU97:Dumped
19:53:39:I1:OUT47:< HTTP/1.1 200 HTTP_OK
19:53:39:I1:WU99:Received WU assignment w_GjjaPmxg2KJq7taYSPT1edCZGPG21CflbLzhlzK1E
19:53:39:I1:WU99:Downloading WU
19:53:39:I1:WU98:Core returned INTERRUPTED (102)
19:53:39:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01 -version 8.4.9 -lifeline 21064 -np 15
19:53:39:I3:WU98:Started FahCore on PID 2832
19:53:39:I1:OUT48:> POST https://highland3.seas.upenn.edu/api/assign HTTP/1.1
19:53:39:I1:WU98:*********************** Log Started 2025-07-12T19:53:39Z ***********************
19:53:39:I1:WU98:************************** Gromacs Folding@home Core ***************************
19:53:39:I1:WU98: Core: Gromacs
19:53:39:I1:WU98: Type: 0xa8
19:53:39:I1:WU98: Version: 0.0.12
19:53:39:I1:WU98: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:53:39:I1:WU98: Copyright: 2020 foldingathome.org
19:53:39:I1:WU98: Homepage: https://foldingathome.org/
19:53:39:I1:WU98: Date: Jan 16 2021
19:53:39:I1:WU98: Time: 12:29:40
19:53:39:I1:WU98: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:53:39:I1:WU98: Branch: master
19:53:39:I1:WU98: Compiler: Visual C++ 2019 16.7
19:53:39:I1:WU98: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:53:39:I1:WU98: Platform: win32 10
19:53:39:I1:WU98: Bits: 64
19:53:39:I1:WU98: Mode: Release
19:53:39:I1:WU98: SIMD: avx2_256
19:53:39:I1:WU98: OpenMP: ON
19:53:39:I1:WU98: CUDA: OFF
19:53:39:I1:WU98: Args: -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01
19:53:39:I1:WU98: -version 8.4.9 -lifeline 21064 -np 15
19:53:39:I1:WU98:************************************ libFAH ************************************
19:53:39:I1:WU98: Time: 11:24:13
19:53:39:I1:WU98:************************************ CBang *************************************
19:53:39:I1:WU98: Time: 11:23:53
19:53:39:I1:WU98:************************************ System ************************************
19:53:39:I1:WU98: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:53:39:I1:WU98: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:53:39:I1:WU98: CPUs: 16
19:53:39:I1:WU98: Memory: 15.60GiB
19:53:39:I1:WU98:Free Memory: 9.59GiB
19:53:39:I1:WU98: Threads: WINDOWS_THREADS
19:53:39:I1:WU98: OS Version: 6.2
19:53:39:I1:WU98:Has Battery: false
19:53:39:I1:WU98: On Battery: false
19:53:39:I1:WU98: UTC Offset: -4
19:53:39:I1:WU98: PID: 2832
19:53:39:I1:WU98: CWD: C:\ProgramData\FAHClient\work
19:53:39:I1:WU98:********************************************************************************
19:53:39:I1:WU98:Project: 18496 (Run 1, Clone 7, Gen 32)
19:53:39:I1:WU98:Unit: 0x00000000000000000000000000000000
19:53:39:I1:WU98:Digital signatures verified
19:53:39:I1:WU98:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpi state.cpt -cpt 5 -nt 15 -ntmpi 1
19:53:39:I1:WU98:Steps: first=160000000 total=165000000
19:53:40:I1:WU98:Completed 641124 out of 5000000 steps (12%)
19:53:42:I1:OUT48:< HTTP/1.1 200 HTTP_OK
19:53:42:I1:WU99:Received WU P18224 R16 C8 G89
19:53:43:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/FahCore_23.exe -dir w_GjjaPmxg2KJq7taYSPT1edCZGPG21CflbLzhlzK1E -suffix 01 -version 8.4.9 -lifeline 21064 -gpu-uuid 996e09c3-3e66-2269-16e6-95fd5488b2a7 -gpu-platform cuda -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
19:53:43:I3:WU99:Started FahCore on PID 2876
19:53:43:I1:WU98:WARNING:Console control signal 1 on PID 2832
19:53:43:I1:WU98:Exiting, please wait. . .
19:53:43:I1:WU98:Folding@home Core Shutdown: INTERRUPTED
19:53:44:I1:WU98:Core returned INTERRUPTED (102)
19:53:44:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01 -version 8.4.9 -lifeline 21064 -np 14
19:53:44:I3:WU98:Started FahCore on PID 11392
19:53:44:I1:WU98:*********************** Log Started 2025-07-12T19:53:44Z ***********************
19:53:44:I1:WU98:************************** Gromacs Folding@home Core ***************************
19:53:44:I1:WU98: Core: Gromacs
19:53:44:I1:WU98: Type: 0xa8
19:53:44:I1:WU98: Version: 0.0.12
19:53:44:I1:WU98: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:53:44:I1:WU98: Copyright: 2020 foldingathome.org
19:53:44:I1:WU98: Homepage: https://foldingathome.org/
19:53:44:I1:WU98: Date: Jan 16 2021
19:53:44:I1:WU98: Time: 12:29:40
19:53:44:I1:WU98: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:53:44:I1:WU98: Branch: master
19:53:44:I1:WU98: Compiler: Visual C++ 2019 16.7
19:53:44:I1:WU98: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:53:44:I1:WU98: Platform: win32 10
19:53:44:I1:WU98: Bits: 64
19:53:44:I1:WU98: Mode: Release
19:53:44:I1:WU98: SIMD: avx2_256
19:53:44:I1:WU98: OpenMP: ON
19:53:44:I1:WU98: CUDA: OFF
19:53:44:I1:WU98: Args: -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01
19:53:44:I1:WU98: -version 8.4.9 -lifeline 21064 -np 14
19:53:44:I1:WU98:************************************ libFAH ************************************
19:53:44:I1:WU98: Time: 11:24:13
19:53:44:I1:WU98:************************************ CBang *************************************
19:53:44:I1:WU98: Time: 11:23:53
19:53:44:I1:WU98:************************************ System ************************************
19:53:44:I1:WU98: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:53:44:I1:WU98: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:53:44:I1:WU98: CPUs: 16
19:53:44:I1:WU98: Memory: 15.60GiB
19:53:44:I1:WU98:Free Memory: 9.63GiB
19:53:44:I1:WU98: Threads: WINDOWS_THREADS
19:53:44:I1:WU98: OS Version: 6.2
19:53:44:I1:WU98:Has Battery: false
19:53:44:I1:WU98: On Battery: false
19:53:44:I1:WU98: UTC Offset: -4
19:53:44:I1:WU98: PID: 11392
19:53:44:I1:WU98: CWD: C:\ProgramData\FAHClient\work
19:53:44:I1:WU98:********************************************************************************
19:53:44:I1:WU98:Project: 18496 (Run 1, Clone 7, Gen 32)
19:53:44:I1:WU98:Unit: 0x00000000000000000000000000000000
19:53:44:I1:WU98:Digital signatures verified
19:53:44:I1:WU98:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpi state.cpt -cpt 5 -nt 14 -ntmpi 1
19:53:44:I1:WU98:Steps: first=160000000 total=165000000
19:53:45:I1:WU98:Completed 641984 out of 5000000 steps (12%)
19:54:09:I1:WU98:Completed 650000 out of 5000000 steps (13%)
19:54:44:W :Core did not shutdown gracefully, killing process
19:54:45:E :WU99:Core exited with Windows unhandled exception code 0xffffffff. See https://bit.ly/2CXgWkZ for more information.
19:54:45:E :WU99:Core returned FAILED_1 (0)
19:54:45:E :WU99:The folding core did not produce any log output. This indicates that the core is not functional on your system. Check for missing libraries or GPU drivers. Make a post about your issue on https://foldingforum.org/ to get more help.
19:54:45:E :WU99:Run did not produce any results. Dumping WU
19:54:45:I1:Default:Added new work unit: cpus:0 gpus:gpu:01:00:00
19:54:45:I1:WU99:Sending dump report
19:54:45:I1:WU100:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:54:45:I1:OUT49:> POST https://highland3.seas.upenn.edu/api/results HTTP/1.1
19:54:45:I1:OUT50:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
19:54:45:I1:WU98:WARNING:Console control signal 1 on PID 11392
19:54:45:I1:WU98:Exiting, please wait. . .
19:54:45:I1:OUT50:< HTTP/1.1 200 HTTP_OK
19:54:45:I1:WU100:Received WU assignment 8e54HeLYGy98KVgJgtoJexjc_qa28Plchwi07KjoFFQ
19:54:45:I1:WU100:Downloading WU
19:54:45:I1:OUT49:< HTTP/1.1 200 HTTP_OK
19:54:45:I1:WU99:Dumped
19:54:45:I1:WU98:Core returned INTERRUPTED (102)
19:54:45:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01 -version 8.4.9 -lifeline 21064 -np 15
19:54:45:I3:WU98:Started FahCore on PID 5084
19:54:45:I1:OUT51:> POST https://highland3.seas.upenn.edu/api/assign HTTP/1.1
19:54:46:I1:WU98:*********************** Log Started 2025-07-12T19:54:45Z ***********************
19:54:46:I1:WU98:************************** Gromacs Folding@home Core ***************************
19:54:46:I1:WU98: Core: Gromacs
19:54:46:I1:WU98: Type: 0xa8
19:54:46:I1:WU98: Version: 0.0.12
19:54:46:I1:WU98: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:46:I1:WU98: Copyright: 2020 foldingathome.org
19:54:46:I1:WU98: Homepage: https://foldingathome.org/
19:54:46:I1:WU98: Date: Jan 16 2021
19:54:46:I1:WU98: Time: 12:29:40
19:54:46:I1:WU98: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:54:46:I1:WU98: Branch: master
19:54:46:I1:WU98: Compiler: Visual C++ 2019 16.7
19:54:46:I1:WU98: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:54:46:I1:WU98: Platform: win32 10
19:54:46:I1:WU98: Bits: 64
19:54:46:I1:WU98: Mode: Release
19:54:46:I1:WU98: SIMD: avx2_256
19:54:46:I1:WU98: OpenMP: ON
19:54:46:I1:WU98: CUDA: OFF
19:54:46:I1:WU98: Args: -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01
19:54:46:I1:WU98: -version 8.4.9 -lifeline 21064 -np 15
19:54:46:I1:WU98:************************************ libFAH ************************************
19:54:46:I1:WU98: Time: 11:24:13
19:54:46:I1:WU98:************************************ CBang *************************************
19:54:46:I1:WU98: Time: 11:23:53
19:54:46:I1:WU98:************************************ System ************************************
19:54:46:I1:WU98: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:54:46:I1:WU98: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:54:46:I1:WU98: CPUs: 16
19:54:46:I1:WU98: Memory: 15.60GiB
19:54:46:I1:WU98:Free Memory: 9.96GiB
19:54:46:I1:WU98: Threads: WINDOWS_THREADS
19:54:46:I1:WU98: OS Version: 6.2
19:54:46:I1:WU98:Has Battery: false
19:54:46:I1:WU98: On Battery: false
19:54:46:I1:WU98: UTC Offset: -4
19:54:46:I1:WU98: PID: 5084
19:54:46:I1:WU98: CWD: C:\ProgramData\FAHClient\work
19:54:46:I1:WU98:********************************************************************************
19:54:46:I1:WU98:Project: 18496 (Run 1, Clone 7, Gen 32)
19:54:46:I1:WU98:Unit: 0x00000000000000000000000000000000
19:54:46:I1:WU98:Digital signatures verified
19:54:46:I1:WU98:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpi state.cpt -cpt 5 -nt 15 -ntmpi 1
19:54:46:I1:WU98:Steps: first=160000000 total=165000000
19:54:46:I1:WU98:Completed 661942 out of 5000000 steps (13%)
19:54:49:I1:OUT51:< HTTP/1.1 200 HTTP_OK
19:54:50:I1:WU100:Received WU P18230 R206 C7 G65
19:54:50:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe -dir 8e54HeLYGy98KVgJgtoJexjc_qa28Plchwi07KjoFFQ -suffix 01 -version 8.4.9 -lifeline 21064 -gpu-uuid 996e09c3-3e66-2269-16e6-95fd5488b2a7 -gpu-platform cuda -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
19:54:50:I3:WU100:Started FahCore on PID 9432
19:54:50:I1:WU100:*********************** Log Started 2025-07-12T19:54:50Z ***********************
19:54:50:I1:WU100:*************************** Core24 Folding@home Core ***************************
19:54:50:I1:WU100: Core: Core24
19:54:50:I1:WU100: Type: 0x24
19:54:50:I1:WU100: Version: 8.1.4
19:54:50:I1:WU100: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:50:I1:WU100: Copyright: 2022 foldingathome.org
19:54:50:I1:WU100: Homepage: https://foldingathome.org/
19:54:50:I1:WU100: Date: Jul 25 2024
19:54:50:I1:WU100: Time: 05:42:49
19:54:50:I1:WU100: Revision: cf9f0139862b8945a2091772770e4631aac37792
19:54:50:I1:WU100: Branch: HEAD
19:54:50:I1:WU100: Compiler: Visual C++
19:54:50:I1:WU100: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
19:54:50:I1:WU100: /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
19:54:50:I1:WU100: Platform: win32 10
19:54:50:I1:WU100: Bits: 64
19:54:50:I1:WU100: Mode: Release
19:54:50:I1:WU100:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:54:50:I1:WU100: <peastman@stanford.edu>
19:54:50:I1:WU100: Args: -dir 8e54HeLYGy98KVgJgtoJexjc_qa28Plchwi07KjoFFQ -suffix 01
19:54:50:I1:WU100: -version 8.4.9 -lifeline 21064 -gpu-uuid
19:54:50:I1:WU100: 996e09c3-3e66-2269-16e6-95fd5488b2a7 -gpu-platform cuda -gpu-vendor
19:54:50:I1:WU100: nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0
19:54:50:I1:WU100: -cuda-device 0 -gpu 0
19:54:50:I1:WU100:************************************ libFAH ************************************
19:54:50:I1:WU100: Time: 05:23:50
19:54:50:I1:WU100: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
19:54:50:I1:WU100: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:54:50:I1:WU100:************************************ CBang *************************************
19:54:50:I1:WU100: Version: 1.7.2
19:54:50:I1:WU100: Org: Cauldron Development LLC
19:54:50:I1:WU100: Copyright: Cauldron Development LLC, 2003-2024
19:54:50:I1:WU100: Homepage: https://cauldrondevelopment.com/
19:54:50:I1:WU100: License: LGPL-2.1-or-later
19:54:50:I1:WU100: Time: 05:22:43
19:54:50:I1:WU100: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
19:54:50:I1:WU100:************************************ System ************************************
19:54:50:I1:WU100: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:54:50:I1:WU100: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:54:50:I1:WU100: CPUs: 16
19:54:50:I1:WU100: Memory: 15.60GiB
19:54:50:I1:WU100:Free Memory: 9.84GiB
19:54:50:I1:WU100: OS Version: 10.0
19:54:50:I1:WU100:Has Battery: false
19:54:50:I1:WU100: On Battery: false
19:54:50:I1:WU100: Hostname: PC_de_Martin
19:54:50:I1:WU100: UTC Offset: -4
19:54:50:I1:WU100: PID: 9432
19:54:50:I1:WU100: CWD: C:\ProgramData\FAHClient\work
19:54:50:I1:WU100: Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
19:54:50:I1:WU100:************************************ OpenMM ************************************
19:54:50:I1:WU100: Version: 8.1.1
19:54:50:I1:WU100:********************************************************************************
19:54:50:I1:WU100:Project: 18230 (Run 206, Clone 7, Gen 65)
19:54:50:I1:WU100:Reading tar file core.xml
19:54:50:I1:WU100:Reading tar file integrator.xml
19:54:50:I1:WU100:Reading tar file state.xml.bz2
19:54:50:I1:WU100:Reading tar file system.xml.bz2
19:54:50:I1:WU100:Digital signatures verified
19:54:50:I1:WU100:Folding@home GPU Core24 Folding@home Core
19:54:50:I1:WU100:Version 8.1.4
19:54:51:I1:WU100: Checkpoint write interval: 25000 steps (2%) [50 total]
19:54:51:I1:WU100: JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:54:51:I1:WU100: XTC frame write interval: 10000 steps (0.8%) [125 total]
19:54:51:I1:WU100: TRR frame write interval: disabled
19:54:51:I1:WU100: Global context and integrator variables write interval: disabled
19:54:51:I1:WU100:There are 4 platforms available.
19:54:51:I1:WU100:Platform 0: Reference
19:54:51:I1:WU100:Platform 1: CPU
19:54:51:I1:WU100:Platform 2: OpenCL
19:54:51:I1:WU100: opencl-device 0 specified
19:54:51:I1:WU100:Platform 3: CUDA
19:54:51:I1:WU100: cuda-device 0 specified
19:54:53:I1:WU100:WARNING:Console control signal 1 on PID 9432
19:54:53:I1:WU100:Exiting, please wait. . .
19:54:53:I1:WU98:WARNING:Console control signal 1 on PID 5084
19:54:53:I1:WU98:Exiting, please wait. . .
19:54:54:I1:WU98:Folding@home Core Shutdown: INTERRUPTED
19:54:54:I1:WU98:Core returned INTERRUPTED (102)
19:54:54:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01 -version 8.4.9 -lifeline 21064 -np 14
19:54:54:I3:WU98:Started FahCore on PID 11032
19:54:55:I1:WU98:*********************** Log Started 2025-07-12T19:54:54Z ***********************
19:54:55:I1:WU98:************************** Gromacs Folding@home Core ***************************
19:54:55:I1:WU98: Core: Gromacs
19:54:55:I1:WU98: Type: 0xa8
19:54:55:I1:WU98: Version: 0.0.12
19:54:55:I1:WU98: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:55:I1:WU98: Copyright: 2020 foldingathome.org
19:54:55:I1:WU98: Homepage: https://foldingathome.org/
19:54:55:I1:WU98: Date: Jan 16 2021
19:54:55:I1:WU98: Time: 12:29:40
19:54:55:I1:WU98: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:54:55:I1:WU98: Branch: master
19:54:55:I1:WU98: Compiler: Visual C++ 2019 16.7
19:54:55:I1:WU98: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:54:55:I1:WU98: Platform: win32 10
19:54:55:I1:WU98: Bits: 64
19:54:55:I1:WU98: Mode: Release
19:54:55:I1:WU98: SIMD: avx2_256
19:54:55:I1:WU98: OpenMP: ON
19:54:55:I1:WU98: CUDA: OFF
19:54:55:I1:WU98: Args: -dir 2lV2KQ_h1X9aUoROkQKMKLVls2LjeXgFB9c2m-UOZCM -suffix 01
19:54:55:I1:WU98: -version 8.4.9 -lifeline 21064 -np 14
19:54:55:I1:WU98:************************************ libFAH ************************************
19:54:55:I1:WU98: Time: 11:24:13
19:54:55:I1:WU98:************************************ CBang *************************************
19:54:55:I1:WU98: Time: 11:23:53
19:54:55:I1:WU98:************************************ System ************************************
19:54:55:I1:WU98: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:54:55:I1:WU98: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:54:55:I1:WU98: CPUs: 16
19:54:55:I1:WU98: Memory: 15.60GiB
19:54:55:I1:WU98:Free Memory: 9.23GiB
19:54:55:I1:WU98: Threads: WINDOWS_THREADS
19:54:55:I1:WU98: OS Version: 6.2
19:54:55:I1:WU98:Has Battery: false
19:54:55:I1:WU98: On Battery: false
19:54:55:I1:WU98: UTC Offset: -4
19:54:55:I1:WU98: PID: 11032
19:54:55:I1:WU98: CWD: C:\ProgramData\FAHClient\work
19:54:55:I1:WU98:********************************************************************************
19:54:55:I1:WU98:Project: 18496 (Run 1, Clone 7, Gen 32)
19:54:55:I1:WU98:Unit: 0x00000000000000000000000000000000
19:54:55:I1:WU98:Digital signatures verified
19:54:55:I1:WU98:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpi state.cpt -cpt 5 -nt 14 -ntmpi 1
19:54:55:I1:WU98:Steps: first=160000000 total=165000000
19:54:55:I1:WU98:Completed 663811 out of 5000000 steps (13%)
19:55:27:I1:WU100:ERROR:102: Core startup was interrupted by client.
19:55:27:I1:WU100:Folding@home Core Shutdown: INTERRUPTED
19:55:27:I1:WU100:Core returned INTERRUPTED (102)
19:55:27:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe -dir 8e54HeLYGy98KVgJgtoJexjc_qa28Plchwi07KjoFFQ -suffix 01 -version 8.4.9 -lifeline 21064 -gpu-uuid 996e09c3-3e66-2269-16e6-95fd5488b2a7 -gpu-platform cuda -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
19:55:27:I3:WU100:Started FahCore on PID 8116
19:55:28:I1:WU100:*********************** Log Started 2025-07-12T19:55:27Z ***********************
19:55:28:I1:WU100:*************************** Core24 Folding@home Core ***************************
19:55:28:I1:WU100: Core: Core24
19:55:28:I1:WU100: Type: 0x24
19:55:28:I1:WU100: Version: 8.1.4
19:55:28:I1:WU100: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:28:I1:WU100: Copyright: 2022 foldingathome.org
19:55:28:I1:WU100: Homepage: https://foldingathome.org/
19:55:28:I1:WU100: Date: Jul 25 2024
19:55:28:I1:WU100: Time: 05:42:49
19:55:28:I1:WU100: Revision: cf9f0139862b8945a2091772770e4631aac37792
19:55:28:I1:WU100: Branch: HEAD
19:55:28:I1:WU100: Compiler: Visual C++
19:55:28:I1:WU100: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
19:55:28:I1:WU100: /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
19:55:28:I1:WU100: Platform: win32 10
19:55:28:I1:WU100: Bits: 64
19:55:28:I1:WU100: Mode: Release
19:55:28:I1:WU100:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:55:28:I1:WU100: <peastman@stanford.edu>
19:55:28:I1:WU100: Args: -dir 8e54HeLYGy98KVgJgtoJexjc_qa28Plchwi07KjoFFQ -suffix 01
19:55:28:I1:WU100: -version 8.4.9 -lifeline 21064 -gpu-uuid
19:55:28:I1:WU100: 996e09c3-3e66-2269-16e6-95fd5488b2a7 -gpu-platform cuda -gpu-vendor
19:55:28:I1:WU100: nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0
19:55:28:I1:WU100: -cuda-device 0 -gpu 0
19:55:28:I1:WU100:************************************ libFAH ************************************
19:55:28:I1:WU100: Time: 05:23:50
19:55:28:I1:WU100: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
19:55:28:I1:WU100: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:55:28:I1:WU100:************************************ CBang *************************************
19:55:28:I1:WU100: Version: 1.7.2
19:55:28:I1:WU100: Org: Cauldron Development LLC
19:55:28:I1:WU100: Copyright: Cauldron Development LLC, 2003-2024
19:55:28:I1:WU100: Homepage: https://cauldrondevelopment.com/
19:55:28:I1:WU100: License: LGPL-2.1-or-later
19:55:28:I1:WU100: Time: 05:22:43
19:55:28:I1:WU100: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
19:55:28:I1:WU100:************************************ System ************************************
19:55:28:I1:WU100: CPU: AMD Ryzen 7 8700F 8-Core Processor
19:55:28:I1:WU100: CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
19:55:28:I1:WU100: CPUs: 16
19:55:28:I1:WU100: Memory: 15.60GiB
19:55:28:I1:WU100:Free Memory: 9.89GiB
19:55:28:I1:WU100: OS Version: 10.0
19:55:28:I1:WU100:Has Battery: false
19:55:28:I1:WU100: On Battery: false
19:55:28:I1:WU100: Hostname: PC_de_Martin
19:55:28:I1:WU100: UTC Offset: -4
19:55:28:I1:WU100: PID: 8116
19:55:28:I1:WU100: CWD: C:\ProgramData\FAHClient\work
19:55:28:I1:WU100: Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
19:55:28:I1:WU100:************************************ OpenMM ************************************
19:55:28:I1:WU100: Version: 8.1.1
19:55:28:I1:WU100:********************************************************************************
19:55:28:I1:WU100:Project: 18230 (Run 206, Clone 7, Gen 65)
19:55:28:I1:WU100:Digital signatures verified
19:55:28:I1:WU100:Folding@home GPU Core24 Folding@home Core
19:55:28:I1:WU100:Version 8.1.4
19:55:28:I1:WU100: Checkpoint write interval: 25000 steps (2%) [50 total]
19:55:28:I1:WU100: JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:55:28:I1:WU100: XTC frame write interval: 10000 steps (0.8%) [125 total]
19:55:28:I1:WU100: TRR frame write interval: disabled
19:55:28:I1:WU100: Global context and integrator variables write interval: disabled
19:55:28:I1:WU100:There are 4 platforms available.
19:55:28:I1:WU100:Platform 0: Reference
19:55:28:I1:WU100:Platform 1: CPU
19:55:28:I1:WU100:Platform 2: OpenCL
19:55:28:I1:WU100: opencl-device 0 specified
19:55:28:I1:WU100:Platform 3: CUDA
19:55:28:I1:WU100: cuda-device 0 specified
19:55:51:I1:Machine state pause
19:55:51:I1:WU98:WARNING:Console control signal 1 on PID 11032
19:55:51:I1:WU98:Exiting, please wait. . .
19:55:51:I1:WU98:Folding@home Core Shutdown: INTERRUPTED
19:55:51:I1:WU100:WARNING:Console control signal 1 on PID 8116
19:55:51:I1:WU100:Exiting, please wait. . .
19:55:52:I1:WU98:Core returned INTERRUPTED (102)
19:56:00:I1:WU100:ERROR:102: Core startup was interrupted by client.
19:56:00:I1:WU100:Folding@home Core Shutdown: INTERRUPTED
19:56:01:I1:WU100:Core returned INTERRUPTED (102)
appepi
Hardware configuration: HP Z600 (5) HP Z800 (3) HP Z440 (3) HP Z4G4 (3) ASUS Turbo GTX 1060, 1070, 1080, RTX 2060 (3) Dell GTX 1080 NVIDIA P1000 (2) K1200
Re: Make a post about your issue on https://foldingforum.org/ to get more help
Post by appepi »
Well, according to this shortcut with the creative title "logs-Shortcut" on my W10 desktop here,
C:\ProgramData\FAHClient\logs, with the most recent one in C:\ProgramData\FAHClient .
Post by muziqaz »
Logs or no logs, if everything is failing around the same period of time, your PC is the culprit. If one thing fails, then it can be attributed to something broken on FAH side, but when you have several different devices fail at the same time, then it is the system's fault, most likely.
It is imperative to make sure that any PCs you have are 101% stable before folding. Game stable or internet browsing stable is not FAH stable.
FAH Omega tester
What did I already wrote here : viewtopic.php?p=370625#p370625 ?
Mactin
Post by Mactin »
toTOW wrote: Mon Jul 14, 2025 1:07 pm What did I already wrote here : viewtopic.php?p=370625#p370625 ?
Yes I did, I responded,
Did you read my message ?
I followed the instructions in the log to post here !
I did not expect the (unsatisfactory) responses I got.
If the support forums will help me (like it did in the past), I will gladly enthusiasticaly accept the help.
If folding does not work, I will stop folding.
If my new PC (5 july) is unstable, what do I tell the store (BestBuy) where I buy it ? It is a HP brand direct out of the box.
Ten years ago, I built and overlocked PCs and GPUs for folding. I know what an unstable is. This time, NO.
I get the feeling of being treated like a child.
All is not unstability. I get WUs all the time that have failled elsewhre (once two times).
I will stop now my rant.
Have a nice day.
Thank you appepi. I found it now.
Post by muziqaz »
If your GPU and CPU fail at the same time, that is not FAH's fault. Basically CPU and GPU fahcores are different pieces of software. Child or not child, look at your own corner first. Tell bestbuy to learn how to build PCs, they are far from "best"
FAH Omega tester
Mactin
Post by Mactin »
miziqaz
This kind of answer IS OF NO HELP at all.
Post by muziqaz »
Mactin wrote: Mon Jul 14, 2025 7:32 pm miziqaz
I will repeat: make sure your GPU, RAM, and CPU are 100% stable.
Your logs are showing typical errors when system is unstable
Hope this helps
Regards
FAH Omega tester
arisu
Post by arisu »
The issues you are seeing appear to be related to stability. This isn't something we're able to help with. The computer is probably faulty, but you only found out when trying FAH. A faulty (unstable) computer might be able to browse the web or play games fine, but might not be able to run FAH.
For now, stop GPU folding and try CPU folding only. If you can turn off turbo boost, that might make the system more stable. Try that and see if it helps.
appepi
Post by appepi »
A possible test regime:
If it is a new PC and (apparently) only "unstable" on FaH WUs, then presumably you can make a claim on the supplier, warranty etc. The snag is that FaH is an unusual thing to do. I am assuming that you are running a CPU with only 1 type of core and letting the Fah 8.4.9 app set up the clients, in which case it is probably assigning 1 core to deal with the GPU's needs and grabbing every other core to run 100% as the CPU client. Clearly this would be a stress test for all the hardware, which might operate without problems in ordinary use. If I have doubts about my own elderly HP hardware, I do a number of things to check them out, and many of them have run for years without any "instability" causing problems. It would be helpful if you can post the CPU type and GPU, however. New is not always good. Also, it would be a good idea to test CPU jobs alone for a while; and if CPU jobs don't fail, then add the GPU without any major concurrent CPU work other than GPU support.
1. Geekbench 6. This is free to use unless you want to have an account and save results, and then it is only a few dollars and supports Ontarian industry. There is an irrelevant debate about how good/fair etc it is, but that's not the point, so long as it makes the device jump through relevant hoops. When I am thinking of buying devices I always look at the CPU benchmarks, and when I buy them I run the same tests to check them out. This is certainly a good guide to relative performance on Statistical software like STATA. My account goes back to Geekbench 3 so I also have a history over time for the same device and can see if it is continuing to perform as usual. GB will run all logical CPUs at 100% in the multicore tests, though you would need to do repeated runs for hours on end to emulate the stress of FaH CPU jobs. Earlier versions of Geekbench had separate CUDA compute tasks but now it seems only to offer openCL and Vulkan for my GPUs which always use CUDA for FaH. But that is just the API and we are concerned here with checking out the hardware.
2. Cinebench is a good stress test for a CPU when run at 100% utilisation for hours and widely used, so if you had Cinebench data showing problems your supplier should accept the evidence.
3. Unigine Superposition (also free or a small price for an account) will test your GPU for normal video-type use, and you can look up benchmarks. Be aware that the more extraordinary results on leaderboards may involve liquid nitrogen cooling and other exotic stuff. Again this is relatively short-term stress, so passing may not indicate much, though failing definitely would.
4. If you run HWInfo (also free for personal use ) with data logging switched on during a Fah job you might get documentation of what was happening when an error occurred.
5. It would be good to run something like ASUS Geekbench 3 or other GPU management utilities so you can see what sort of stress is being applied to the GPU, and if need be limit it. I keep my GPUs temperature limited to 70 deg C with aggressive fan profiles since fans are a lot cheaper than GPUs.
I only fold with GPUs in HP workstations these days so some of the HP workstation utilities I used to use to control CPU core usage and temperatures are probably not relevant, except to note that both Fah 7.6.21 and 8.4.9 don't fuss if you limit their access to cores by means other than the 8.4.9 slider. In my experience memory rarely fails but sometimes needs reminding that it is plugged in by re-seating it. It would also be a good idea to separately test CPU jobs, because GPU jobs are always GPU+(some) CPU and problems with CPU would affect both.
Lastly, it would be helpful if the FaH enterprise could set up a small set of CPU and GPU WU's with current production cores, across a range of "Stress" demand, that folk could use as testware in situations like this.
Post by muziqaz »
At the moment FAH is not in the business of providing test software. Maybe in far future, maybe.
For a moment, any stress testing software which makes use of AVX2+ instruction set is good enough for CPU stress testing. I use y-cruncher, and set it to stress testing: launch y-cruncher, type 2, press enter, then 0 and enter. Close all the apps to clear out as much RAM as possible before start stress testing. Leave stress test running for few hours or until error/system instability occurs. y-cruncher loads RAM as well as CPU. Problem with that though is that it will not load RAM reserved/used by Windows.
For GPUs, well unigine or any other benchmarking suite could show potential issues.
I'm still leaning towards RAM instability in above case
FAH Omega tester
Benchmarks are not stability testing tools ... try StressCPU v2, Furmark or OCCT.
You should also check memory for error, these can be surprising.
nada391
Post by nada391 »
on my computer with AMD ryzen 9000 and last gen mobo x670 i found out that if i would enable AMD EXPO in BIOS, eg. boosting RAM that is supposed to run at 6400 MHZ to that frequency, otherwise it would run at 4800 Mhz only<
that this option in BIOS would nearly every time causeing AMDGPU to fail to build correctly, resulting in sorts of error. never found out what would cause it, until after disabling this and then AMDGPU would magically build without error.
The computer would otherwise not show any error or signs of instability, but apparently even without showing signs of instability, the AMD EXPO caused it, although the memory supposed to be certified to run at 6400 Mhz. Maybe this also because it is a combination of Ryzen 9000 and X670 and not newer X870<
Post by muziqaz »
Memory is not certified to run at 6400mt/s.
Very few 9000 series CPU can achieve that for 100% stability.
What I would suggest is dropping the speeds to 6000mt/s, which every 9000 series CPU can achieve with 100% stability even with 64GB of RAM.
6400 and 6200MT/s speeds are just for "gamers" who need gaming stability and not actual stability
FAH Omega tester
nada391
Post by nada391 »
you are right about not being certified, but the memory is supported in ASUS Memory support list at this frequency (which then again would not mean it is supposed to run at this frequency, as now learned supposed).
Also, the KIT i got, is not the one with the label AMD EXPO on it, just Intel XMP 3.0 supported, so probably it is not the ideal match for the AMD system.
What i did is to actually just turn on the lever in BIOS frontpage setting , and this automatically sets frequency , timing etc. , eg. from "disabled" to "enabled" and this made go from 4800 to 6400 and is such recognized, but then as stated got me into trouble with AMDGPU real.
will see if can get to up to 6000 or 6200 as suggested.
