14957,1,7,46 - first fail 2023, then recently ~150 fails
MYZTaEHdBDnapS
Post by MYZTaEHdBDnapS »
https://apps.foldingathome.org/wu#proje ... e=7&gen=46
First fail is 2023, then last several months in 2025 has spawned a lot of fails.
02:05:37:I1:WU523:ERROR:exception: Particle coordinate is nan
02:05:37:I1:WU523:Folding@home Core Shutdown: BAD_WORK_UNIT
Stock 1070 power throttled w/ good cooling, but I don't think it's me. Cursed unit coming back from the dead?
Re: 14957,1,7,46 - first fail 2023, then recently ~150 fails
Post by muziqaz »
I think it is you, causing all those computers to fail :D :D
Thanks for the heads up
FAH Omega tester
There was a forgotten script that was resetting the error count every times the server was restarted. It has been removed.
MYZTaEHdBDnapS
Thanks for the quick followup and closure toTOW and crew.
