Stoppppppppppppppp adding my iGPU back on every reboot
CaptainHalon
Post by CaptainHalon »
I want to fold on my 9060 XT only, not the iGPU in my 7600X3D. Arghhhhhhhhh.
Re: Stoppppppppppppppp adding my iGPU back on every reboot
Which client do you use ?
On v7, add gpu = false to the config file to disable GPU auto-detection.
CaptainHalon
Thanks, gpu = false works well.
Post by muziqaz »
Use V8 and you won't have that issue. Or better, go to the BIOS and disable that iGPU, which will also free a bit of thermal headroom for your CPU :)
FAH Omega tester
CaptainHalon
muziqaz wrote: Wed Aug 13, 2025 10:14 am Use V8 and you won't have that issue. Or better, go to the BIOS and disable that iGPU, which will also free a bit of thermal headroom for your CPU :)
Disabling in BIOS is a lot of work. I'd have to haul a monitor and keyboard to that room and hook it up. Seems too much like a Greek Odyssey in my mind.
Post by muziqaz »
CaptainHalon wrote: Wed Aug 13, 2025 10:35 am
But you only need to do it once. And it is for the greater good :D
FAH Omega tester
