GPU not supported in Linux
nada391
Post by nada391 »
Hello ,
am having trouble getting the GPU supportedi n Ubuntu 24.04.'2 LTS
have previously installed via NVIDA-570.run file , but resulted in "unsupported".
now have installed the driver via
https://documentation.ubuntu.com/server ... a-drivers/
sudo ubuntu-drivers install --gpgpu
and this has resulted in CUDA being recognized shortly, but after reboot, the whole triade is still shown "unsupported" (Opencl, Cuda, HIP).
Hostname
ubuntu24server
OS
linux
Client Version
8.4.9
OS Version
6.8
Build Mode
Release
Revision
360fe71b1bd05bb89814bfb97b73a5bda84802d6
Has Battery
false
On Battery
false
CPU
Description
Intel(R) Xeon(R) CPU E3-1220 v5 @ 3.00GHz
Cores
4
Type
amd64
gpu:03:00:00
Description
TU117GLM [Quadro T400 Mobile]
Vendor
nvidia
Supported
false
UUID
PCI Device ID
0x1fb2
PCI Vendor ID
0x10de
OpenCL
unsupported
CUDA
unsupported
HIP
unsupported
glad to be corrected, thanks.
Re: GPU not supported in Linux
Post by muziqaz »
Have you installed ICD loader?
FAH Omega tester
nada391
Post by nada391 »
no, just the drivers that got "auto-installed".
Post by muziqaz »
Install ICD loader, please
FAH Omega tester
nada391
Post by nada391 »
cannot seem to find the package needed on ubuntu server
sudo apt install openc
opencamlib-doc            opencl-headers            opencpn
opencc                    openclipart               opencpn-data
opencfu                   openclipart-libreoffice   opencryptoki
openchrome-tool           openclipart-png           openctm-doc
opencity                  openclipart-svg           openctm-tools
opencity-data             openclonk                 opencu
opencl-1.2-html-doc       openclonk-data            opencubicplayer
opencl-1.2-man-doc        opencollada-dev           opencubicplayer-doc
opencl-c-headers          opencollada-tools         opencv-data
opencl-clhpp-headers      opencolorio-tools         opencv-doc
opencl-clhpp-headers-doc  openconnect
there is no "icd-loader" neither.
however, also CUDA should get enabled.
Post by muziqaz »
I don't do Nvidia, so not sure of exact package name, but Ubuntu does have it for sure.
FAH Omega tester
bollix47
Post by bollix47 »
Try the following:
A reboot won't hurt and sometimes doing so can solve a problem when drivers are involved.
Also, in the future, always install the nvidia drivers via Software Sources > Additional drivers
nada391
Post by nada391 »
bollix47 wrote: Thu Jun 26, 2025 4:58 pm
thanks,
it wouldn't make a difference;
since it is ubuntu-server, thought auto-install is the proper way, there won't be GUI, so it not feasible what you propose via software>additional.
these are the options provided if manual selecction instead
nvidia-driver-570-open, (kernel modules provided by linux-modules-nvidia-570-open-generic)
nvidia-driver-535, (kernel modules provided by linux-modules-nvidia-535-generic)
nvidia-driver-535-open, (kernel modules provided by linux-modules-nvidia-535-open-generic)
nvidia-driver-570-server, (kernel modules provided by linux-modules-nvidia-570-server-generic)
nvidia-driver-535-server-open, (kernel modules provided by linux-modules-nvidia-535-server-open-generic)
nvidia-driver-550-open, (kernel modules provided by linux-modules-nvidia-550-open-generic)
nvidia-driver-535-server, (kernel modules provided by linux-modules-nvidia-535-server-generic)
nvidia-driver-470, (kernel modules provided by linux-modules-nvidia-470-generic)
nvidia-driver-550, (kernel modules provided by linux-modules-nvidia-550-generic)
nvidia-driver-470-server, (kernel modules provided by linux-modules-nvidia-470-server-generic)
nvidia-driver-570-server-open, (kernel modules provided by linux-modules-nvidia-570-server-open-generic)
nvidia-driver-570, (kernel modules provided by linux-modules-nvidia-570-generic)
maybe should try again via Nvidia-570.run + ocl-icd-opencl-dev
DocJonz
Post by DocJonz »
You want '570-open', see GPU not Folding
nada391
Post by nada391 »
have installed then
sudo ubuntu-drivers install --gpgpu nvidia:570-server-open
pluse the packages you suggested
sudo apt install ocl-icd-opencl-dev nvidia-cuda-dev
but there is no luck today with this
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
do i need to blacklist nouveau or something, or is "570-open" better choice?
sudo ubuntu-drivers list
udevadm hwdb is deprecated. Use systemd-hwdb instead.
ERROR:root:aplay command not found
EDIT: switched to 570-open , now folding, thanks!
please mark solved.
