I recently set up an old desktop of mine as a Linux test box running Kubuntu 25.04. Whenever I try to install the most recent FAH install package from the .deb file i get a "Dependency resolution failed" error with no other explanations or hints as to what dependencies are required. I have run the standard sudo apt upgrade and install, ensured all repositories seem to be enabled and no luck. anyone have any tips? FYI I am a Linux beginner so please make sure all instructions are clear and not assume I will know to perform a certain action by default.
Other system specs in case relevant. AMD fx8320 cpu, 16gb ram nvidia 950 gpu (with drivers installed)
Ubuntu 25.04 instillation error
Re: Ubuntu 25.04 instillation error
Please, for the love of everything Linus, do not use bleeding edge distro versions on your ancient hardware. Please
None of us in FAH run 25.04 yet, let alone testing FAHclient installation.
Drop to 24.04 at least, please
Nicolas_orleans
You can proceed as explained by arisu in this forum
viewtopic.php?t=42864
Or just use the tarball from fah download page that works out of the box on 25.04
