With the upcoming HIP 7.0 release in second half of 2025, we’re taking a bold step toward simplifying cross-platform programming by aligning HIP C++ even more closely with CUDA. AMD tightly integrates our automatic HIPIFY conversion tool with our HIP runtime and compiler. Users can quickly port CUDA code into HIP C++ with HIPIFY to target AMD GPUs. However, small differences between our implementation of the HIP C++ programming model and CUDA C++ often require manual intervention to adjust your code base. This causes additional work for software developers targeting GPU families from both providers. We understand this and are making changes to ROCm to reduce this friction based on customer requests. We also know adopting changes in our programming model requires early notification. We don’t take API breaking changes lightly and for your benefit, we are making an early prototype available to assist in porting to the new HIP 7.0 API
AMD Rocm7.0 Beta
boboviz
- Hardware configuration: Radeon RX6400
AMD Rocm7.0 Beta
ROcm 7.0 Beta
Re: AMD Rocm7.0 Beta
Thanks, but this is in no benefit to FAH.
Saying that: threads like that are welcome for general discussion
boboviz
Maybe this will help with HIP development (maybe)
HIP 7.0 is designed to enhance GPU code portability and simplify cross-vendor GPU development. By aligning HIP more closely with CUDA semantics, refining error handling, and streamlining header structures, the HIP 7.0 release reduces the effort needed to maintain portable codebases.
No, we are not porting code from CUDA. Hip compiler does that behind the scenes.boboviz wrote: ↑Fri Jun 06, 2025 8:30 amMaybe this will help with HIP development (maybe)HIP 7.0 is designed to enhance GPU code portability and simplify cross-vendor GPU development. By aligning HIP more closely with CUDA semantics, refining error handling, and streamlining header structures, the HIP 7.0 release reduces the effort needed to maintain portable codebases.
Also, while I appreciate the enthusiasm and community engagement in regards to new releases of ROCm, we have it covered
Any updates to ROCm, will not require FAHcore re-development, as HIP FAHcore just tells whatever hip libraries come with the driver to start computing.
So if there are some performance or feature improvements in your new drivers, FAHcore will probably utilise that
boboviz
A new page of ROCm, ROCm-LS (Life Science):
"The early access release of ROCm-LS enables you to experiment with accelerating your life science workloads, such as digital pathology, automated medical image analysis, and feature extraction and enhancement in large TIFF files on AMD Instinct GPUs. Join us in exploring this tantalizing glimpse into the future capabilities of ROCm-LS, setting the stage for the next evolution in life science computing."
ROCm-LS looks like a toolkit for "AI-enhanced" image processing for things like medical images. It's interesting for sure and I'm happy that AMD is expanding their software ecosystem (they need to do that to be competitive against AMD in the HPC sphere), but it doesn't seem like it will do anything for FAH.
boboviz
Now OpenMM supports Rocm7
As said before, for end user any performance improvements (if any) coming from rocm development will translate through the drivers, and not what openmm might or might not support.
Even if whatever openmm implements did give us some sort of advantage, FAH update cycles are in decades, so we won't see any benefits (if any) for long time
Don't worry, performance improvements are in driver updates, and not what version openmm supports
AI bundle has nothing to do with actual workloads FAH uses
