NVIDIA GeForce RTX 5060
jabasaba
Post by jabasaba »
10DE 2D05 - 1462 5371
13:10:23:I1: Version: 8.4.9
13:10:23:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:10:23:I1: Org: foldingathome.org
13:10:23:I1: Copyright: 2023-2024, foldingathome.org
13:10:23:I1: Homepage: https://foldingathome.org/
13:10:23:I1: License: GPL-3.0-or-later
13:10:23:I1: URL: https://v8-4.foldingathome.org/
13:10:23:I1: Date: Nov 20 2024
13:10:23:I1: Time: 14:47:46
13:10:23:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
13:10:23:I1: Branch: master
13:10:23:I1: Compiler: Visual C++
13:10:23:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
13:10:23:I1: /Zc:throwingNew /MT
13:10:23:I1: Platform: win32 10
13:10:23:I1: Bits: 64
13:10:23:I1: Mode: Release
13:10:23:I1: Args: --open-web-control
13:10:23:I1:****************************** CBang ******************************
13:10:23:I1: Version: 1.7.2
13:10:23:I1: Org: Cauldron Development
13:10:23:I1: Copyright: Cauldron Development, 2003-2024
13:10:23:I1: Homepage: https://cauldrondevelopment.com/
13:10:23:I1: License: LGPL-2.1-or-later
13:10:23:I1: Time: 09:04:40
13:10:23:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
13:10:23:I1:***************************** System ******************************
13:10:23:I1: CPU: AMD Ryzen 9 7900X 12-Core Processor
13:10:23:I1: CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
13:10:23:I1: CPUs: 8
13:10:23:I1: Memory: 31.96GiB
13:10:23:I1:Free Memory: 20.92GiB
13:10:23:I1: OS Version: 6.2
13:10:23:I1:Has Battery: false
13:10:23:I1: On Battery: false
13:10:23:I1: Hostname: DESKTOP-7JOVAIG
13:10:23:I1: UTC Offset: -4
13:10:23:I1: PID: 5324
13:10:23:I1: CWD: C:\ProgramData\FAHClient
13:10:23:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
13:10:23:I1:*******************************************************************
13:10:23:I2:<config/>
13:10:23:I1:Opening Database
13:10:23:I1:F@H ID = 8lRTL7ExRMe9MW9tarY3oSqePs7oEsIt8JUMYITiqXo
13:10:23:I3:Loading default resource group
13:10:23:I1:Listening for HTTP on 127.0.0.1:7396
13:10:23:I3:Loaded 0 wus.
13:10:23:I1:Started Windows systray control
13:10:23:I1:OUT2:> GET https://api.foldingathome.org/gpus HTTP/1.1
13:10:23:I1:OUT1:> GET https://api.foldingathome.org/machine/8lRTL7ExRMe9MW9tarY3oSqePs7oEsIt8JUMYITiqXo HTTP/1.1
13:10:23:I1:OUT1:< HTTP/1.1 200 HTTP_OK
13:10:23:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
13:10:23:I1:OUT2:< HTTP/1.1 200 HTTP_OK
13:10:24:I3:gpus = {
13:10:24:I3: "gpu:01:00:00": {
13:10:24:I3: "vendor": 4318,
13:10:24:I3: "type": "nvidia",
13:10:24:I3: "description": "NVIDIA GeForce RTX 5060",
13:10:24:I3: "uuid": "dda6a137-8a2d-39b3-4fd6-8d0d3fc478a0",
13:10:24:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "576.52"},
13:10:24:I3: "cuda": {"platform": 0, "device": 0, "compute": "12.0", "driver": "12.9"},
13:10:24:I3: "device": 11525,
13:10:24:I3: "supported": false
13:10:24:I3: }
13:10:24:I3:}
13:10:24:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
13:10:24:I1:Logging into node account
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: NVIDIA GeForce RTX 5060
Post by BobWilliams757 »
When you get it folding, please give us a performance update on the below link. I'm sure people want to see where this GPU falls in the performance category.
https://foldingforum.org/viewtopic.php?t=42426
Thanks!
Fold them if you get them!
Post by muziqaz »
It has been added. Give it half an hour or so, restart fahclient, and see what's happening then
FAH Omega tester
jabasaba
Post by jabasaba »
Started folding! Thanks!
Screenshot of PPD for reference:
