Fah-client arm64 8.4 not function on Sbc
nada391
Post by nada391 »
Hello ,
tested this version
https://download.foldingathome.org/rele ... _arm64.deb
on a sbc Pine A64+
but it would not function;
installing the versin fah-client 8.2 would only function it seems, but the the SBC seems not doing anything with the fah-client.
(armbian is running headless)
systemctl status --no-pager -l fah-client
● fah-client.service - Folding@home Client
     Loaded: loaded (/etc/systemd/system/fah-client.service; enabled; preset: enabled)
     Active: active (running) since Sun 2025-03-09 22:26:09 CET; 23s ago
   Main PID: 271272 (fah-client)
      Tasks: 1 (limit: 2132)
     Memory: 4.5M
        CPU: 202ms
     CGroup: /system.slice/fah-client.service
             └─271272 /usr/bin/fah-client --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/
mar 09 22:26:09 pine64 systemd[1]: Started fah-client.service - Folding@home Client.
pine64:~$ fah-client --version
8.2
the error for 8.4 would be like this
× fah-client.service - Folding@home Client
     Loaded: loaded (/lib/systemd/system/fah-client.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Sun 2025-03-09 22:31:19 CET; 42s ago
   Duration: 103ms
    Process: 276415 ExecStart=/usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/ (code=exited, status=1/FAILURE)
   Main PID: 276415 (code=exited, status=1/FAILURE)
        CPU: 102ms
mar 09 22:31:19 pine64 systemd[1]: fah-client.service: Scheduled restart job, restart counter is at 5.
mar 09 22:31:19 pine64 systemd[1]: Stopped fah-client.service - Folding@home Client.
mar 09 22:31:19 pine64 systemd[1]: fah-client.service: Start request repeated too quickly.
mar 09 22:31:19 pine64 systemd[1]: fah-client.service: Failed with result 'exit-code'.
mar 09 22:31:19 pine64 systemd[1]: Failed to start fah-client.service - Folding@home Client.
mar 09 22:31:26 pine64 systemd[1]: fah-client.service: Start request repeated too quickly.
mar 09 22:31:26 pine64 systemd[1]: fah-client.service: Failed with result 'exit-code'.
mar 09 22:31:26 pine64 systemd[1]: Failed to start fah-client.service - Folding@home Client.
8.4.9
maybe you can help pinpint the error;
nada391
Re: Fah-client arm64 8.4 not function on Sbc
Post by nada391 »
i have also attempted to link this sbc to the web-folding@home-client,
please check if the syntax correct, it would not show up (maybe because i am using the 8.2 version?)
<config/>
<account-token v=“rH9AKrH8niy3oniyEWHWMEWHfGMIjfGMOcmouOcmq7c”/>
  <machine-name v="PineA64+"/>
</config>
Post by muziqaz »
Please report this to github. Dev does not read this forum :)
FAH Omega tester
Post by calxalot »
First line of config should be
<config>
You should try manually launching the client from command line to see more errors.
Post by calxalot »
You should treat your account token as confidential.
Post by calxalot »
I don’t know if that “+” is allowed in machine name.
nada391
Post by nada391 »
thank you, got it to run with the help of this post here
https://pifoldingguide.wordpress.com/
now it runs v7, but the setup was much easier, since the headless client asks for "username" "team" "passkey" which v8 seems to forgo.
it does not show up in webclient folding v8.4, but hope it will contribute some nevertheless.
Post by muziqaz »
V7 is not compatible with V8 webview
FAH Omega tester
nada391
Post by nada391 »
practically it is easier to install first v7 -arm64 and setup there by inserting the data into the questions in terminal, afterwards could install over it v8, and the setup-data is copied over, and it functions now.
all i did then was to edit the config to include the additional info of "account token" which v7 does not ask for.
v7 can be found here
