Project: 12472 (Run 9, Clone 7, Gen 0) failed
Ikaar
Post by Ikaar »
Hi,
dont know if this was posted before, but today for me the Gromac A8 Project 12472 failed after 8%
Using the new V8.4.9 client.
System PopOs 22.04 LTS, Kernel 6.9
CPU: Intel 8700K (4 cores activated, 1 for GPU)
Full log:
10:57:34:I1:WU1805:Requesting WU assignment for user skruuz_GRC_4cc882b82c83626566f95317cda3076a team 224497
10:57:35:I1:WU1805:Received WU assignment nILbTlG6eAVNk3OLnOyD1mbt7KUb7UofjT0dPPS3UYw
10:57:35:I1:WU1805:Downloading WU
10:57:36:I1:WU1805:DOWNLOAD 100% 632.63KiB of 632.63KiB
10:57:36:I1:WU1805:Received WU P12472 R9 C7 G0
10:57:36:I3:WU1805:Started FahCore on PID 75588
10:57:37:I1:WU1805:*********************** Log Started 2025-01-13T10:57:36Z ***********************
10:57:37:I1:WU1805:************************** Gromacs Folding@home Core ***************************
10:57:37:I1:WU1805: Core: Gromacs
10:57:37:I1:WU1805: Type: 0xa8
10:57:37:I1:WU1805: Version: 0.0.12
10:57:37:I1:WU1805: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:57:37:I1:WU1805: Copyright: 2020 foldingathome.org
10:57:37:I1:WU1805: Homepage: https://foldingathome.org/
10:57:37:I1:WU1805: Date: Jan 16 2021
10:57:37:I1:WU1805: Time: 19:24:44
10:57:37:I1:WU1805: Compiler: GNU 8.3.0
10:57:37:I1:WU1805: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
10:57:37:I1:WU1805: -fdata-sections -O3 -funroll-loops -fno-pie
10:57:37:I1:WU1805: Platform: linux2 4.15.0-128-generic
10:57:37:I1:WU1805: Bits: 64
10:57:37:I1:WU1805: Mode: Release
10:57:37:I1:WU1805: SIMD: avx2_256
10:57:37:I1:WU1805: OpenMP: ON
10:57:37:I1:WU1805: CUDA: OFF
10:57:37:I1:WU1805: Args: -dir nILbTlG6eAVNk3OLnOyD1mbt7KUb7UofjT0dPPS3UYw -suffix 01
10:57:37:I1:WU1805: -version 8.4.9 -lifeline 68249 -np 3
10:57:37:I1:WU1805:************************************ libFAH ************************************
10:57:37:I1:WU1805: Time: 19:21:38
10:57:37:I1:WU1805:************************************ CBang *************************************
10:57:37:I1:WU1805: Time: 19:21:24
10:57:37:I1:WU1805: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
10:57:37:I1:WU1805:************************************ System ************************************
10:57:37:I1:WU1805: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
10:57:37:I1:WU1805: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:57:37:I1:WU1805: CPUs: 12
10:57:37:I1:WU1805: Memory: 31.28GiB
10:57:37:I1:WU1805:Free Memory: 5.83GiB
10:57:37:I1:WU1805: Threads: POSIX_THREADS
10:57:37:I1:WU1805: OS Version: 6.9
10:57:37:I1:WU1805:Has Battery: false
10:57:37:I1:WU1805: On Battery: false
10:57:37:I1:WU1805: UTC Offset: 1
10:57:37:I1:WU1805: PID: 75588
10:57:37:I1:WU1805: CWD: /media/dataxt/folding/working/work
10:57:37:I1:WU1805:********************************************************************************
10:57:37:I1:WU1805:Project: 12472 (Run 9, Clone 7, Gen 0)
10:57:37:I1:WU1805:Unit: 0x00000000000000000000000000000000
10:57:37:I1:WU1805:Reading tar file core.xml
10:57:37:I1:WU1805:Reading tar file frame0.tpr
10:57:37:I1:WU1805:Digital signatures verified
10:57:37:I1:WU1805:Calling: mdrun -c frame0.gro -s frame0.tpr -x frame0.xtc -cpt 5 -nt 3 -ntmpi 1
10:57:37:I1:WU1805:Steps: first=0 total=5000000
10:57:37:I1:WU1805:Completed 1 out of 5000000 steps (0%)
11:07:25:I1:WU1805:Completed 50000 out of 5000000 steps (1%)
11:17:34:I1:WU1805:Completed 100000 out of 5000000 steps (2%)
11:27:21:I1:WU1805:Completed 150000 out of 5000000 steps (3%)
11:37:02:I1:WU1805:Completed 200000 out of 5000000 steps (4%)
11:46:59:I1:WU1805:Completed 250000 out of 5000000 steps (5%)
11:56:45:I1:WU1805:Completed 300000 out of 5000000 steps (6%)
12:07:55:I1:WU1805:Completed 350000 out of 5000000 steps (7%)
12:22:42:I1:WU1805:Completed 400000 out of 5000000 steps (8%)
12:36:08:I1:WU1805:Caught signal SIGINT(2) on PID 75588
12:36:08:I1:WU1805:Exiting, please wait. . .
12:36:08:I1:WU1805:Folding@home Core Shutdown: INTERRUPTED
12:36:09:I1:WU1805:Core returned INTERRUPTED (102)
12:36:09:I3:WU1805:Started FahCore on PID 82883
12:36:10:E :WU1805:Core was killed
12:36:10:E :WU1805:Core returned FAILED_1 (0)
12:36:10:E :WU1805:The folding core did not produce any log output. This indicates that the core is not functional on your system. Check for missing libraries or GPU drivers. Make a post about your issue on https://foldingforum.org/ to get more help.
12:36:10:E :WU1805:Run did not produce any results. Dumping WU
12:36:10:I1:WU1805:Sending dump report
12:36:14:I1:WU1805:Dumped
BR
Ikaar
Ikaar
Re: Project: 12472 (Run 9, Clone 7, Gen 0) failed
Post by Ikaar »
Got the same thing today with
Project: 12473 (Run 38, Clone 0, Gen 1)
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Both of those projects are still in beta testing. If you have access you should be posting in the beta forum concerning any failures.
If you never volunteered to be a beta tester you really shouldn't expect any further support in the main forum. By nature any beta work units could possibly be less stable before it is released from beta testing.
Fold them if you get them!
Ikaar
Post by Ikaar »
Ah, okay. Understood.
Was wondering, why i got those errors (in the meantime 5 more aborts on Projects 12471-73).
I just recently put beta projects to "ON" just to try it out.
Any chance to see in the protocol, if a project is beta or not?
Thanks
These projects are announced in beta here : viewtopic.php?t=42378
There's no public announcement yet : viewforum.php?f=24
