Stuck at Downloading core
SuNiKy
Post by SuNiKy »
Trying to fold and the status gets to Downloading core and has been stuck there for half an hour.
I've tried to restart the process by dumping the work unit twice but that hasn't helped.
How do I fix this?
Here is the machine log of the last attempt in case this helps to find a solution:
09:27:14:I1:WU3:Requesting WU assignment for user SuNiKy team 1066076
09:27:15:I1:OUT17:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
09:27:15:I1:OUT17:< HTTP/1.1 200 HTTP_OK
09:27:15:I1:WU3:Received WU assignment LewCfqkt3kkDyVNAeKBszidRb0Csk7IYTBAnDQAnsbs
09:27:15:I1:WU3:Downloading WU
09:27:15:I1:OUT18:> POST https://ds01.scs.illinois.edu/api/assign HTTP/1.1
09:27:17:I1:OUT18:< HTTP/1.1 200 HTTP_OK
09:27:17:I1:WU3:Received WU P19228 R9270 C5 G4
Thanks in advance!
kellanphil
Re: Stuck at Downloading core
Post by kellanphil »
I have the same problem.
SuNiKy
Post by SuNiKy »
UPDATE:
Now, when opening the client. It says my pc is disconnected and the fold and pause buttons aren't doing anything.
Post by calxalot »
What OS and version?
What fah version?
SuNiKy
Post by SuNiKy »
I have v8.3.18 running on windows 11 pro version 23H2. My pc has a 64-bit operating system.
Post by calxalot »
Please try upgrading to beta v8.4.9
It has some bug fixes that may help.
https://foldingathome.org/beta/
SuNiKy
Post by SuNiKy »
The new beta version seems to run smoothly. Thank you!
This does show my pc twice. One with v8.4.9, the other is disconnected and says 'no resources'.
Do I need to worry about this?
Post by calxalot »
One is probably your old computer. If not using it, you can remove the machine from your account by clicking its gear icon and clicking unlink.
sirthuc
Post by sirthuc »
tried v8.4.9 and beta version, both say No resources, unlinked no work.
evga 3080ti no detected in client setting, but ok in window management, working well in window 11 and games.
i9 7920x appear in client, but no folding.
how to solve this bros?
Post by muziqaz »
sirthuc wrote: Thu Jan 23, 2025 6:45 am tried v8.4.9 and beta version, both say No resources, unlinked no work.
Screenshots of your computer settings withing FAH web UI as well as main page of your web ui
FAH Omega tester
sirthuc
Post by sirthuc »
how to upload the photos?
Post by muziqaz »
You need to store it in the 3rd party website and post a link. I don't think forum supports photo storing, unfortunately
FAH Omega tester
sirthuc
Post by sirthuc »
it's here, thank for helps
Post by muziqaz »
You need to get physical access to ADL3U1J. Go to web UI settings and you should see this broken chain icon on right hand side next to your computer name. Click on it, and it should link it to your account.
Then if resources still don't show up, take few screenshots again.
Thanks
FAH Omega tester
sirthuc
Post by sirthuc »
im already on that PC, clicking on the chain but nothing happened.
as you can see, it shows CPUs 24, but no GPU at all.
even i drag CPU to 24 of 24, then save, then click on Fold, then nothing works
and no GPU detected, while im using evga 3080ti, working well in win11 and games
