GPU Disabled on Arch Linux (after Reboot)
AlterFalter101
Post by AlterFalter101 »
Hello,
directly after installation FaH works fine, folds on Cpu and Gpu, i disable cpu because its very slow and takes to long to complete Tasks. ( Slots/Edit/Click the GPU Option for the CPU Slot) .
BUT after Restart GPU is disabled all the time and i have to uninstall and reinstall FaH to fold again with GPU .
The Error must be wrong because direct after Reinstallation GPU folding worked fine. (100% GPU Utilitation)
I only could imagine that FaH is losing some Access rights to Cuda/OpenCL after Reboot.
Kind Regards
*********************** Log Started 2025-01-03T08:36:49Z ***********************
08:36:49:WARNING:FS00:No CUDA or OpenCL 1.2+ support detected for GPU slot 00: gpu:1:0 AD104 [GeForce RTX 4070 Ti]. Disabling.
08:36:49:******************************* libFAH ********************************
08:36:49: Date: Oct 20 2020
08:36:49: Time: 20:36:39
08:36:49: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:36:49: Branch: master
08:36:49: Compiler: GNU 8.3.0
08:36:49: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
08:36:49: -fdata-sections -O3 -funroll-loops -fno-pie
08:36:49: Platform: linux2 5.8.0-1-amd64
08:36:49: Bits: 64
08:36:49: Mode: Release
08:36:49:****************************** FAHClient ******************************
08:36:49: Version: 7.6.21
08:36:49: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:36:49: Copyright: 2020 foldingathome.org
08:36:49: Homepage: https://foldingathome.org/
08:36:49: Time: 20:39:00
08:36:49: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:36:49: Bits: 64
08:36:49: Args: -v --chdir /var/snap/folding-at-home-fcole90/common
08:36:49: Config: /var/snap/folding-at-home-fcole90/common/config.xml
08:36:49:******************************** CBang ********************************
08:36:49: Time: 18:37:59
08:36:49: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:36:49: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
08:36:49: Bits: 64
08:36:49:******************************* System ********************************
08:36:49: CPU: 12th Gen Intel(R) Core(TM) i5-12400F
08:36:49: CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
08:36:49: CPUs: 12
08:36:49: Memory: 31.16GiB
08:36:49:Free Memory: 29.93GiB
08:36:49: Threads: POSIX_THREADS
08:36:49: OS Version: 6.12
08:36:49:Has Battery: false
08:36:49: On Battery: false
08:36:49: UTC Offset: 1
08:36:49: PID: 876
08:36:49: CWD: /var/snap/folding-at-home-fcole90/613
08:36:49: OS: Linux 6.12.8-2-cachyos x86_64
08:36:49: OS Arch: AMD64
08:36:49: GPUs: 1
08:36:49: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:9 AD104 [GeForce RTX 4070 Ti]
08:36:49: CUDA: Not detected: cuInit() returned 100
08:36:49: OpenCL: Not detected: clGetPlatformIDs() returned -1001
08:36:49:***********************************************************************
PaulTV
Re: GPU Disabled on Arch Linux (after Reboot)
Post by PaulTV »
Welcome to the forum :D
Is F@h started after network target is up?
At start the client tries to get the list of GPUs (at least it does on v7 client, I assume on v8 as well); if it can't get that, it'll result in that same situation (of disabling the GPU)
Paul
Ryzen 9800X3D / RTX 4090
Ryzen 5800X / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti
All running Fedora 43 with folding client v8.5.6
AlterFalter101
Iḿ on 7.6.21 client. Seems it got the GPU list, because the last Error is the missing OpenCL and it says "4070ti" in it.
I wonder a little bit why the Logging Time is 1 Hour off (im already 1 hour later)
*********************** Log Started 2025-01-03T10:09:43Z ***********************
10:09:43:******************************* libFAH ********************************
10:09:43: Date: Oct 20 2020
10:09:43: Time: 20:36:39
10:09:43: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
10:09:43: Branch: master
10:09:43: Compiler: GNU 8.3.0
10:09:43: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
10:09:43: -fdata-sections -O3 -funroll-loops -fno-pie
10:09:43: Platform: linux2 5.8.0-1-amd64
10:09:43: Bits: 64
10:09:43: Mode: Release
10:09:43:****************************** FAHClient ******************************
10:09:43: Version: 7.6.21
10:09:43: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:09:43: Copyright: 2020 foldingathome.org
10:09:43: Homepage: https://foldingathome.org/
10:09:43: Time: 20:39:00
10:09:43: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
10:09:43: Bits: 64
10:09:43: Args: -v --chdir /var/snap/folding-at-home-fcole90/common
10:09:43: Config: /var/snap/folding-at-home-fcole90/common/config.xml
10:09:43:******************************** CBang ********************************
10:09:43: Time: 18:37:59
10:09:43: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
10:09:43: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
10:09:43: Bits: 64
10:09:43:******************************* System ********************************
10:09:43: CPU: 12th Gen Intel(R) Core(TM) i5-12400F
10:09:43: CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
10:09:43: CPUs: 12
10:09:43: Memory: 31.16GiB
10:09:43:Free Memory: 29.90GiB
10:09:43: Threads: POSIX_THREADS
10:09:43: OS Version: 6.12
10:09:43:Has Battery: false
10:09:43: On Battery: false
10:09:43: UTC Offset: 1
10:09:43: PID: 847
10:09:43: CWD: /var/snap/folding-at-home-fcole90/613
10:09:43: OS: Linux 6.12.8-2-cachyos x86_64
10:09:43: OS Arch: AMD64
10:09:43: GPUs: 1
10:09:43: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:9 AD104 [GeForce RTX 4070 Ti]
10:09:43: CUDA: Not detected: cuInit() returned 100
10:09:43: OpenCL: Not detected: clGetPlatformIDs() returned -1001
10:09:43:***********************************************************************
10:09:43:<config>
10:09:43: <!-- Client Control -->
10:09:43: <client-threads v='6'/>
10:09:43: <cycle-rate v='4'/>
10:09:43: <cycles v='-1'/>
10:09:43: <disable-sleep-when-active v='true'/>
10:09:43: <exit-when-done v='false'/>
10:09:43: <fold-anon v='false'/>
10:09:43: <idle-seconds v='300'/>
10:09:43: <open-web-control v='false'/>
10:09:43: <update-gpus-txt v='true'/>
10:09:43:
10:09:43: <!-- Configuration -->
10:09:43: <config-rotate v='true'/>
10:09:43: <config-rotate-dir v='configs'/>
10:09:43: <config-rotate-max v='16'/>
10:09:43:
10:09:43: <!-- Debugging -->
10:09:43: <assignment-servers>
10:09:43: assign1.foldingathome.org assign2.foldingathome.org assign3.foldingathome.org assign4.foldingathome.org
10:09:43: </assignment-servers>
10:09:43: <auth-as v='true'/>
10:09:43: <capture-directory v='capture'/>
10:09:43: <capture-on-error v='false'/>
10:09:43: <capture-packets v='false'/>
10:09:43: <capture-requests v='false'/>
10:09:43: <capture-responses v='false'/>
10:09:43: <capture-sockets v='false'/>
10:09:43: <debug-sockets v='false'/>
10:09:43: <exception-locations v='true'/>
10:09:43: <stack-traces v='false'/>
10:09:43:
10:09:43: <!-- Error Handling -->
10:09:43: <max-slot-errors v='10'/>
10:09:43: <max-unit-errors v='5'/>
10:09:43:
10:09:43: <!-- Folding Core -->
10:09:43: <checkpoint v='15'/>
10:09:43: <core-priority v='idle'/>
10:09:43: <cpu-usage v='100'/>
10:09:43: <gpu-usage v='100'/>
10:09:43: <no-assembly v='false'/>
10:09:43:
10:09:43: <!-- Folding Slot Configuration -->
10:09:43: <cause v='COVID_19'/>
10:09:43: <client-subtype v='LINUX'/>
10:09:43: <client-type v='normal'/>
10:09:43: <cpu-species v='X86_PENTIUM_II'/>
10:09:43: <cpu-type v='AMD64'/>
10:09:43: <cpus v='-1'/>
10:09:43: <disable-viz v='false'/>
10:09:43: <gpu v='true'/>
10:09:43: <gpu-beta v='false'/>
10:09:43: <max-packet-size v='normal'/>
10:09:43: <os-species v='UNKNOWN'/>
10:09:43: <os-type v='LINUX'/>
10:09:43: <project-key v='0'/>
10:09:43: <smp v='true'/>
10:09:43:
10:09:43: <!-- GUI -->
10:09:43: <gui-enabled v='true'/>
10:09:43:
10:09:43: <!-- HTTP Server -->
10:09:43: <allow v='127.0.0.1'/>
10:09:43: <connection-timeout v='60'/>
10:09:43: <deny v='0/0'/>
10:09:43: <http-addresses v='0:7396'/>
10:09:43: <https-addresses v=''/>
10:09:43: <max-connect-time v='900'/>
10:09:43: <max-connections v='800'/>
10:09:43: <max-request-length v='52428800'/>
10:09:43: <min-connect-time v='300'/>
10:09:43:
10:09:43: <!-- Logging -->
10:09:43: <log v='log.txt'/>
10:09:43: <log-color v='true'/>
10:09:43: <log-crlf v='false'/>
10:09:43: <log-date v='false'/>
10:09:43: <log-date-periodically v='21600'/>
10:09:43: <log-domain v='false'/>
10:09:43: <log-header v='true'/>
10:09:43: <log-level v='true'/>
10:09:43: <log-no-info-header v='true'/>
10:09:43: <log-redirect v='false'/>
10:09:43: <log-rotate v='true'/>
10:09:43: <log-rotate-dir v='logs'/>
10:09:43: <log-rotate-max v='16'/>
10:09:43: <log-short-level v='false'/>
10:09:43: <log-simple-domains v='true'/>
10:09:43: <log-thread-id v='false'/>
10:09:43: <log-thread-prefix v='true'/>
10:09:43: <log-time v='true'/>
10:09:43: <log-to-screen v='true'/>
10:09:43: <log-truncate v='false'/>
10:09:43: <verbosity v='3'/>
10:09:43:
10:09:43: <!-- Network -->
10:09:43: <proxy v=':8080'/>
10:09:43: <proxy-enable v='false'/>
10:09:43: <proxy-pass v='*****'/>
10:09:43: <proxy-user v=''/>
10:09:43:
10:09:43: <!-- Process Control -->
10:09:43: <child v='false'/>
10:09:43: <daemon v='false'/>
10:09:43: <fork v='false'/>
10:09:43: <pid v='false'/>
10:09:43: <pid-file v='FAHClient.pid'/>
10:09:43: <respawn v='false'/>
10:09:43: <service v='false'/>
10:09:43:
10:09:43: <!-- Slot Control -->
10:09:43: <auto-conf v='true'/>
10:09:43: <idle v='false'/>
10:09:43: <max-shutdown-wait v='60'/>
10:09:43: <pause-on-battery v='true'/>
10:09:43: <pause-on-start v='false'/>
10:09:43: <paused v='false'/>
10:09:43: <power v='medium'/>
10:09:43:
10:09:43: <!-- Web Server -->
10:09:43: <web-allow v='127.0.0.1'/>
10:09:43: <web-deny v='0/0'/>
10:09:43: <web-enable v='true'/>
10:09:43:
10:09:43: <!-- Web Server Sessions -->
10:09:43: <session-cookie v='sid'/>
10:09:43: <session-lifetime v='86400'/>
10:09:43: <session-timeout v='3600'/>
10:09:43:
10:09:43: <!-- Work Unit Control -->
10:09:43: <dump-after-deadline v='true'/>
10:09:43: <max-queue v='16'/>
10:09:43: <max-units v='0'/>
10:09:43: <next-unit-percentage v='99'/>
10:09:43: <stall-detection-enabled v='false'/>
10:09:43: <stall-percent v='5'/>
10:09:43: <stall-timeout v='1800'/>
10:09:43:
10:09:43: <!-- Folding Slots -->
10:09:43: <slot id='0' type='GPU'>
10:09:43: <pci-bus v='1'/>
10:09:43: <pci-slot v='0'/>
10:09:43: </slot>
10:09:43:</config>
10:09:43:Trying to access database...
10:09:43:Successfully acquired database lock
10:09:43:WARNING:FS00:No CUDA or OpenCL 1.2+ support detected for GPU slot 00: gpu:1:0 AD104 [GeForce RTX 4070 Ti]. Disabling.
10:09:43:ERROR:No valid folding configuration
PaulTV
Post by PaulTV »
F@h logs in GMT, not in the local time zone.
Yes, you're right, the no CUDA / OpenCL support isn't as it should be.
Did you by any chance reboot because of a kernel patch? Every time the kernel is patched, the nvidia drivers have to be recompiled. This can be done automatically by dkms, and having the nvidia driver register itself with dkms when it's installed.
pcwolf
Hardware configuration: Manjaro Linux - AsRock B550 Taichi - Ryzen 5950X - NVidia RTX 4070ti
FAH v8-4.3
Post by pcwolf »
I have been folding on Manjaro for a number of years now, starting with AUR version you are running (fahcontrol 7.6.21) and updating to latest web-based control AUR version (foldingathome 8.4.9) early in 2024. I might suggest trying that update.
Additionally, from time to time I would have a reboot and FAH failed to restart. I wrote an ALIAS for bash.rc:
alias refold='systemctl restart fah-client'
which always manages to restart folding *without* losing current work in progress.
I have had no CUDA / OCL errors that you posted. If you think my FAH logs would be helpful to compare, let me know and I post here in this thread. Good luck
AlterFalter101
PaulTV wrote: Fri Jan 03, 2025 10:37 am Did you by any chance reboot because of a kernel patch? Every time the kernel is patched, the nvidia drivers have to be recompiled. This can be done automatically by dkms, and having the nvidia driver register itself with dkms when it's installed.
I checked specially that yesterday. Uninstall FaH, reinstall, fold an instance with the GPU successfully. Than shut down PC, have done NO updates, nothing. Wanted to try to fold today with GPU and again, GPU disabled Error.
11:41:00: <!-- Folding Slots -->
11:41:00: <slot id='0' type='CPU'>
11:41:00: <paused v='true'/>
11:41:00: </slot>
11:41:00: <slot id='1' type='GPU'>
11:41:00: <pci-bus v='1'/>
11:41:00: <pci-slot v='0'/>
11:41:00: </slot>
11:41:00:</config>
11:41:00:Trying to access database...
11:41:00:Successfully acquired database lock
11:41:00:FS00:Initialized folding slot 00: cpu:10
11:41:00:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti]. Disabling.
AlterFalter101
For comparison yesterday when i was succesfully folding with the GPU after reinstalling:
*********************** Log Started 2025-01-03T11:26:40Z ***********************
11:26:40:******************************* libFAH ********************************
11:26:40: Date: Oct 20 2020
11:26:40: Time: 20:36:39
11:26:40: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
11:26:40: Branch: master
11:26:40: Compiler: GNU 8.3.0
11:26:40: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
11:26:40: -fdata-sections -O3 -funroll-loops -fno-pie
11:26:40: Platform: linux2 5.8.0-1-amd64
11:26:40: Bits: 64
11:26:40: Mode: Release
11:26:40:****************************** FAHClient ******************************
11:26:40: Version: 7.6.21
11:26:40: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:26:40: Copyright: 2020 foldingathome.org
11:26:40: Homepage: https://foldingathome.org/
11:26:40: Time: 20:39:00
11:26:40: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
11:26:40: Bits: 64
11:26:40: Args: -v --chdir /var/snap/folding-at-home-fcole90/common
11:26:40:******************************** CBang ********************************
11:26:40: Time: 18:37:59
11:26:40: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
11:26:40: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
11:26:40: Bits: 64
11:26:40:******************************* System ********************************
11:26:40: CPU: 12th Gen Intel(R) Core(TM) i5-12400F
11:26:40: CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
11:26:40: CPUs: 12
11:26:40: Memory: 31.16GiB
11:26:40: Free Memory: 24.54GiB
11:26:40: Threads: POSIX_THREADS
11:26:40: OS Version: 6.12
11:26:40: Has Battery: false
11:26:40: On Battery: false
11:26:40: UTC Offset: 1
11:26:40: PID: 4718
11:26:40: CWD: /var/snap/folding-at-home-fcole90/613
11:26:40: OS: Linux 6.12.8-2-cachyos x86_64
11:26:40: OS Arch: AMD64
11:26:40: GPUs: 1
11:26:40: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:9 AD104 [GeForce RTX 4070 Ti]
11:26:40: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.9 Driver:12.7
11:26:40:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:565.77
11:26:40:***********************************************************************
11:26:40:<config>
11:26:40: <!-- Client Control -->
11:26:40: <client-threads v='6'/>
11:26:40: <cycle-rate v='4'/>
11:26:40: <cycles v='-1'/>
11:26:40: <disable-sleep-when-active v='true'/>
11:26:40: <exit-when-done v='false'/>
11:26:40: <fold-anon v='false'/>
11:26:40: <idle-seconds v='300'/>
11:26:40: <open-web-control v='false'/>
11:26:40: <update-gpus-txt v='true'/>
11:26:40:
11:26:40: <!-- Configuration -->
11:26:40: <config-rotate v='true'/>
11:26:40: <config-rotate-dir v='configs'/>
11:26:40: <config-rotate-max v='16'/>
11:26:40:
11:26:40: <!-- Debugging -->
11:26:40: <assignment-servers>
11:26:40: assign1.foldingathome.org assign2.foldingathome.org assign3.foldingathome.org assign4.foldingathome.org
11:26:40: </assignment-servers>
11:26:40: <auth-as v='true'/>
11:26:40: <capture-directory v='capture'/>
11:26:40: <capture-on-error v='false'/>
11:26:40: <capture-packets v='false'/>
11:26:40: <capture-requests v='false'/>
11:26:40: <capture-responses v='false'/>
11:26:40: <capture-sockets v='false'/>
11:26:40: <debug-sockets v='false'/>
11:26:40: <exception-locations v='true'/>
11:26:40: <stack-traces v='false'/>
11:26:40:
11:26:40: <!-- Error Handling -->
11:26:40: <max-slot-errors v='10'/>
11:26:40: <max-unit-errors v='5'/>
11:26:40:
11:26:40: <!-- Folding Core -->
11:26:40: <checkpoint v='15'/>
11:26:40: <core-priority v='idle'/>
11:26:40: <cpu-usage v='100'/>
11:26:40: <gpu-usage v='100'/>
11:26:40: <no-assembly v='false'/>
11:26:40:
11:26:40: <!-- Folding Slot Configuration -->
11:26:40: <cause v='ANY'/>
11:26:40: <client-subtype v='LINUX'/>
11:26:40: <client-type v='normal'/>
11:26:40: <cpu-species v='X86_PENTIUM_II'/>
11:26:40: <cpu-type v='AMD64'/>
11:26:40: <cpus v='-1'/>
11:26:40: <disable-viz v='false'/>
11:26:40: <gpu v='true'/>
11:26:40: <gpu-beta v='false'/>
11:26:40: <max-packet-size v='normal'/>
11:26:40: <os-species v='UNKNOWN'/>
11:26:40: <os-type v='LINUX'/>
11:26:40: <project-key v='0'/>
11:26:40: <smp v='true'/>
11:26:40:
11:26:40: <!-- GUI -->
11:26:40: <gui-enabled v='true'/>
11:26:40:
11:26:40: <!-- HTTP Server -->
11:26:40: <allow v='127.0.0.1'/>
11:26:40: <connection-timeout v='60'/>
11:26:40: <deny v='0/0'/>
11:26:40: <http-addresses v='0:7396'/>
11:26:40: <https-addresses v=''/>
11:26:40: <max-connect-time v='900'/>
11:26:40: <max-connections v='800'/>
11:26:40: <max-request-length v='52428800'/>
11:26:40: <min-connect-time v='300'/>
11:26:40:
11:26:40: <!-- Logging -->
11:26:40: <log v='log.txt'/>
11:26:40: <log-color v='true'/>
11:26:40: <log-crlf v='false'/>
11:26:40: <log-date v='false'/>
11:26:40: <log-date-periodically v='21600'/>
11:26:40: <log-domain v='false'/>
11:26:40: <log-header v='true'/>
11:26:40: <log-level v='true'/>
11:26:40: <log-no-info-header v='true'/>
11:26:40: <log-redirect v='false'/>
11:26:40: <log-rotate v='true'/>
11:26:40: <log-rotate-dir v='logs'/>
11:26:40: <log-rotate-max v='16'/>
11:26:40: <log-short-level v='false'/>
11:26:40: <log-simple-domains v='true'/>
11:26:40: <log-thread-id v='false'/>
11:26:40: <log-thread-prefix v='true'/>
11:26:40: <log-time v='true'/>
11:26:40: <log-to-screen v='true'/>
11:26:40: <log-truncate v='false'/>
11:26:40: <verbosity v='3'/>
11:26:40:
11:26:40: <!-- Network -->
11:26:40: <proxy v=''/>
11:26:40: <proxy-enable v='false'/>
11:26:40: <proxy-pass v='*****'/>
11:26:40: <proxy-user v=''/>
11:26:40:
11:26:40: <!-- Process Control -->
11:26:40: <child v='false'/>
11:26:40: <daemon v='false'/>
11:26:40: <fork v='false'/>
11:26:40: <pid v='false'/>
11:26:40: <pid-file v='FAHClient.pid'/>
11:26:40: <respawn v='false'/>
11:26:40: <service v='false'/>
11:26:40:
11:26:40: <!-- Remote Command Server -->
11:26:40: <command-address v='0.0.0.0'/>
11:26:40: <command-allow-no-pass v='127.0.0.1'/>
11:26:40: <command-deny-no-pass v='0/0'/>
11:26:40: <command-enable v='true'/>
11:26:40: <command-port v='36330'/>
11:26:40:
11:26:40: <!-- Slot Control -->
11:26:40: <auto-conf v='true'/>
11:26:40: <idle v='false'/>
11:26:40: <max-shutdown-wait v='60'/>
11:26:40: <pause-on-battery v='true'/>
11:26:40: <pause-on-start v='false'/>
11:26:40: <paused v='false'/>
11:26:40: <power v='medium'/>
11:26:40:
11:26:40: <!-- User Information -->
11:26:40: <machine-id v='0'/>
11:26:40: <passkey v='*****'/>
11:26:40: <team v='0'/>
11:26:40: <user v='Anonymous'/>
11:26:40:
11:26:40: <!-- Web Server -->
11:26:40: <web-allow v='127.0.0.1'/>
11:26:40: <web-deny v='0/0'/>
11:26:40: <web-enable v='true'/>
11:26:40:
11:26:40: <!-- Web Server Sessions -->
11:26:40: <session-cookie v='sid'/>
11:26:40: <session-lifetime v='86400'/>
11:26:40: <session-timeout v='3600'/>
11:26:40:
11:26:40: <!-- Work Unit Control -->
11:26:40: <dump-after-deadline v='true'/>
11:26:40: <max-queue v='16'/>
11:26:40: <max-units v='0'/>
11:26:40: <next-unit-percentage v='99'/>
11:26:40: <stall-detection-enabled v='false'/>
11:26:40: <stall-percent v='5'/>
11:26:40: <stall-timeout v='1800'/>
11:26:40:
11:26:40: <!-- Folding Slots -->
11:26:40:</config>
11:26:40:Trying to access database...
11:26:41:Successfully acquired database lock
11:26:41:FS00:Initialized folding slot 00: cpu:10
11:26:41:FS01:Initialized folding slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti]
11:27:13:FS00:Paused
11:27:42:Saving configuration to config.xml
11:27:42:<config>
11:27:42: <!-- Folding Slots -->
11:27:42: <slot id='0' type='CPU'>
11:27:42: <paused v='true'/>
11:27:42: </slot>
11:27:42: <slot id='1' type='GPU'>
11:27:42: <pci-bus v='1'/>
11:27:42: <pci-slot v='0'/>
11:27:42: </slot>
11:27:42:</config>
11:27:42:Set client configured
11:27:43:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:27:44:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:27:45:WU00:FS01:Assigned to work server 158.130.118.23
11:27:45:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
11:27:45:WU00:FS01:Connecting to 158.130.118.23:8080
11:27:46:WU00:FS01:Downloading 10.84MiB
11:27:52:WU00:FS01:Download 9.80%
11:27:58:WU00:FS01:Download 14.41%
11:28:04:WU00:FS01:Download 20.18%
11:28:10:WU00:FS01:Download 25.36%
11:28:14:FS00:Unpaused
11:28:14:WU01:FS00:Connecting to assign1.foldingathome.org:80
11:28:15:WU01:FS00:Assigned to work server 144.121.86.56
11:28:15:WU01:FS00:Requesting new work unit for slot 00: cpu:10 from 144.121.86.56
11:28:15:WU01:FS00:Connecting to 144.121.86.56:8080
11:28:15:WU01:FS00:Downloading 397.50KiB
11:28:16:WU00:FS01:Download 30.55%
11:28:19:WU01:FS00:Download complete
11:28:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18820 run:1075 clone:0 gen:18 core:0xa9 unit:0x12000000000000003304000084490000
11:28:19:WU01:FS00:Downloading core from http://cores.foldingathome.org/gromacs- ... ore_a9.fah
11:28:19:WU01:FS00:Connecting to cores.foldingathome.org:80
11:28:19:WU01:FS00:FahCore a9: Downloading 8.48MiB
11:28:22:WU00:FS01:Download 32.86%
11:28:27:WU01:FS00:FahCore a9: 5.16%
11:28:29:WU00:FS01:Download 34.59%
11:28:32:FS00:Paused
11:28:33:WU01:FS00:FahCore a9: 8.84%
11:28:36:WU00:FS01:Download 37.47%
11:28:42:WU01:FS00:FahCore a9: 11.79%
11:28:42:WU00:FS01:Download 40.35%
11:28:43:Saving configuration to config.xml
11:28:43:<config>
11:28:43: <!-- Network -->
11:28:43: <proxy v=':8080'/>
11:28:43:
11:28:43:
11:28:43: <!-- Folding Slots -->
11:28:43: <slot id='0' type='CPU'>
11:28:43: <paused v='true'/>
11:28:43: </slot>
11:28:43: <slot id='1' type='GPU'>
11:28:43: <pci-bus v='1'/>
11:28:43: <pci-slot v='0'/>
11:28:43: </slot>
11:28:43:</config>
11:28:49:WU00:FS01:Download 43.81%
11:28:52:WU01:FS00:FahCore a9: 14.00%
11:28:56:WU00:FS01:Download 45.54%
11:28:58:WU01:FS00:FahCore a9: 16.21%
11:29:03:WU00:FS01:Download 47.85%
11:29:04:WU01:FS00:FahCore a9: 21.36%
11:29:10:WU00:FS01:Download 51.31%
11:29:10:WU01:FS00:FahCore a9: 24.31%
11:29:16:WU01:FS00:FahCore a9: 26.52%
11:29:18:WU00:FS01:Download 54.19%
11:29:22:WU01:FS00:FahCore a9: 27.99%
11:29:24:WU00:FS01:Download 58.22%
11:29:28:WU01:FS00:FahCore a9: 31.68%
11:29:30:WU00:FS01:Download 61.68%
11:29:37:WU00:FS01:Download 63.99%
11:29:37:WU01:FS00:FahCore a9: 34.62%
11:29:44:WU01:FS00:FahCore a9: 36.83%
11:29:44:WU00:FS01:Download 66.29%
11:29:50:WU01:FS00:FahCore a9: 40.52%
11:29:50:WU00:FS01:Download 68.02%
11:29:58:WU01:FS00:FahCore a9: 42.73%
11:29:58:WU00:FS01:Download 70.33%
11:30:04:WU00:FS01:Download 72.06%
11:30:04:WU01:FS00:FahCore a9: 44.94%
11:30:10:WU00:FS01:Download 73.79%
11:30:10:WU01:FS00:FahCore a9: 47.88%
11:30:16:WU00:FS01:Download 76.67%
11:30:17:WU01:FS00:FahCore a9: 51.57%
11:30:22:WU00:FS01:Download 78.98%
11:30:23:WU01:FS00:FahCore a9: 54.51%
11:30:28:WU00:FS01:Download 81.86%
11:30:30:WU01:FS00:FahCore a9: 58.20%
11:30:36:WU00:FS01:Download 84.74%
11:30:36:WU01:FS00:FahCore a9: 61.14%
11:30:43:WU01:FS00:FahCore a9: 64.83%
11:30:43:WU00:FS01:Download 87.05%
11:30:45:Saving configuration to config.xml
11:30:45:<config>
11:30:45: <!-- Folding Slot Configuration -->
11:30:45: <cause v='COVID_19'/>
11:30:45:
11:30:45: <!-- Network -->
11:30:45: <proxy v=':8080'/>
11:30:45:
11:30:45:
11:30:45: <!-- Folding Slots -->
11:30:45: <slot id='0' type='CPU'>
11:30:45: <paused v='true'/>
11:30:45: </slot>
11:30:45: <slot id='1' type='GPU'>
11:30:45: <pci-bus v='1'/>
11:30:45: <pci-slot v='0'/>
11:30:45: </slot>
11:30:45:</config>
11:30:51:WU00:FS01:Download 91.08%
11:30:51:WU01:FS00:FahCore a9: 69.25%
11:30:57:WU01:FS00:FahCore a9: 72.19%
11:30:58:WU00:FS01:Download 94.54%
11:31:04:WU01:FS00:FahCore a9: 74.40%
11:31:05:WU00:FS01:Download 96.27%
11:31:10:WU01:FS00:FahCore a9: 76.61%
11:31:11:WU00:FS01:Download 99.73%
11:31:12:WU00:FS01:Download complete
11:31:12:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18237 run:930 clone:4 gen:17 core:0x24 unit:0x00000004000000110000473d000003a2
11:31:12:WU00:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
11:31:12:WU00:FS01:Connecting to cores.foldingathome.org:80
11:31:12:WU00:FS01:FahCore 24: Downloading 202.97MiB
11:31:18:WU01:FS00:FahCore a9: 81.03%
11:31:18:WU00:FS01:FahCore 24: 0.12%
11:31:24:WU00:FS01:FahCore 24: 0.28%
11:31:24:WU01:FS00:FahCore a9: 85.45%
11:31:31:WU01:FS00:FahCore a9: 87.66%
11:31:32:WU00:FS01:FahCore 24: 0.40%
11:31:37:WU01:FS00:FahCore a9: 90.61%
11:31:40:WU00:FS01:FahCore 24: 0.55%
11:31:45:WU01:FS00:FahCore a9: 92.08%
11:31:48:WU00:FS01:FahCore 24: 0.68%
11:31:53:WU01:FS00:FahCore a9: 94.29%
11:31:55:WU00:FS01:FahCore 24: 0.83%
11:32:01:WU01:FS00:FahCore a9: 96.50%
11:32:01:WU00:FS01:FahCore 24: 0.92%
11:32:09:WU00:FS01:FahCore 24: 1.02%
11:32:09:WU01:FS00:FahCore a9: 99.45%
11:32:11:WU01:FS00:FahCore a9: Download complete
11:32:11:WU01:FS00:Valid core signature
11:32:11:WU01:FS00:Unpacked 18.90MiB to cores/cores.foldingathome.org/gromacs-core-a9/debian-stable-64bit/cpu-avx2_256-release/0xa9-0.0.12/Core_a9.fah/FahCore_a9
11:32:16:WU00:FS01:FahCore 24: 1.14%
11:32:22:WU00:FS01:FahCore 24: 1.26%
11:32:29:WU00:FS01:FahCore 24: 1.35%
11:32:35:WU00:FS01:FahCore 24: 1.42%
11:32:41:WU00:FS01:FahCore 24: 1.57%
11:32:48:WU00:FS01:FahCore 24: 1.66%
11:32:56:WU00:FS01:FahCore 24: 1.76%
11:33:03:WU00:FS01:FahCore 24: 1.85%
11:33:10:WU00:FS01:FahCore 24: 1.88%
11:33:16:WU00:FS01:FahCore 24: 1.94%
11:33:22:WU00:FS01:FahCore 24: 2.09%
11:33:28:WU00:FS01:FahCore 24: 2.22%
11:33:34:WU00:FS01:FahCore 24: 2.25%
11:33:40:WU00:FS01:FahCore 24: 2.37%
11:33:46:WU00:FS01:FahCore 24: 2.56%
11:33:53:WU00:FS01:FahCore 24: 2.86%
11:34:00:WU00:FS01:FahCore 24: 2.99%
11:34:06:WU00:FS01:FahCore 24: 3.23%
11:34:12:WU00:FS01:FahCore 24: 3.39%
11:34:19:WU00:FS01:FahCore 24: 3.51%
11:34:25:WU00:FS01:FahCore 24: 3.73%
11:34:31:WU00:FS01:FahCore 24: 3.94%
11:34:38:WU00:FS01:FahCore 24: 4.06%
11:34:44:WU00:FS01:FahCore 24: 4.25%
11:34:50:WU00:FS01:FahCore 24: 4.50%
11:34:56:WU00:FS01:FahCore 24: 4.65%
11:35:03:WU00:FS01:FahCore 24: 4.87%
11:35:09:WU00:FS01:FahCore 24: 5.02%
11:35:15:WU00:FS01:FahCore 24: 5.08%
11:35:21:WU00:FS01:FahCore 24: 5.42%
11:35:27:WU00:FS01:FahCore 24: 5.60%
11:35:33:WU00:FS01:FahCore 24: 5.73%
11:35:40:WU00:FS01:FahCore 24: 5.94%
11:35:46:WU00:FS01:FahCore 24: 6.10%
11:35:52:WU00:FS01:FahCore 24: 6.34%
11:35:58:WU00:FS01:FahCore 24: 6.74%
11:36:04:WU00:FS01:FahCore 24: 6.90%
11:36:11:WU00:FS01:FahCore 24: 7.14%
11:36:17:WU00:FS01:FahCore 24: 7.24%
11:36:23:WU00:FS01:FahCore 24: 7.42%
11:36:29:WU00:FS01:FahCore 24: 7.67%
11:36:35:WU00:FS01:FahCore 24: 7.82%
11:36:41:WU00:FS01:FahCore 24: 7.98%
11:36:49:WU00:FS01:FahCore 24: 8.13%
11:36:55:WU00:FS01:FahCore 24: 8.31%
11:37:03:WU00:FS01:FahCore 24: 8.47%
11:37:09:WU00:FS01:FahCore 24: 8.65%
11:37:16:WU00:FS01:FahCore 24: 8.81%
11:37:22:WU00:FS01:FahCore 24: 8.96%
11:37:28:WU00:FS01:FahCore 24: 9.11%
11:37:34:WU00:FS01:FahCore 24: 9.33%
11:37:41:WU00:FS01:FahCore 24: 9.48%
11:37:47:WU00:FS01:FahCore 24: 9.70%
11:37:53:WU00:FS01:FahCore 24: 9.88%
11:37:59:WU00:FS01:FahCore 24: 10.13%
11:38:06:WU00:FS01:FahCore 24: 10.41%
11:38:16:WU00:FS01:FahCore 24: 10.50%
11:38:23:WU00:FS01:FahCore 24: 10.53%
11:38:31:WU00:FS01:FahCore 24: 10.69%
11:38:37:WU00:FS01:FahCore 24: 10.81%
11:38:43:WU00:FS01:FahCore 24: 10.99%
11:38:50:WU00:FS01:FahCore 24: 11.21%
11:38:56:WU00:FS01:FahCore 24: 11.33%
11:39:02:WU00:FS01:FahCore 24: 11.61%
11:39:09:WU00:FS01:FahCore 24: 11.79%
11:39:16:WU00:FS01:FahCore 24: 11.89%
11:39:30:WU00:FS01:FahCore 24: 11.98%
11:39:36:WU00:FS01:FahCore 24: 12.07%
11:39:44:WU00:FS01:FahCore 24: 12.13%
11:39:51:WU00:FS01:FahCore 24: 12.16%
11:39:59:WU00:FS01:FahCore 24: 12.19%
11:40:07:WU00:FS01:FahCore 24: 12.22%
11:40:26:WU00:FS01:FahCore 24: 12.26%
11:40:33:WU00:FS01:FahCore 24: 12.32%
11:40:45:WU00:FS01:FahCore 24: 12.35%
11:41:01:WU00:FS01:FahCore 24: 12.44%
11:41:09:WU00:FS01:FahCore 24: 12.50%
11:41:16:WU00:FS01:FahCore 24: 12.53%
11:41:23:WU00:FS01:FahCore 24: 12.59%
11:41:31:WU00:FS01:FahCore 24: 12.66%
11:41:37:WU00:FS01:FahCore 24: 12.69%
11:41:45:WU00:FS01:FahCore 24: 12.78%
11:42:05:WU00:FS01:FahCore 24: 12.81%
11:42:19:WU00:FS01:FahCore 24: 12.84%
11:42:28:WU00:FS01:FahCore 24: 12.87%
11:42:34:WU00:FS01:FahCore 24: 12.90%
11:42:41:WU00:FS01:FahCore 24: 12.93%
11:42:50:WU00:FS01:FahCore 24: 12.96%
11:42:58:WU00:FS01:FahCore 24: 12.99%
11:43:10:WU00:FS01:FahCore 24: 13.03%
11:43:20:WU00:FS01:FahCore 24: 13.06%
11:43:42:WU00:FS01:FahCore 24: 13.12%
11:43:52:WU00:FS01:FahCore 24: 13.15%
11:44:01:WU00:FS01:FahCore 24: 13.21%
11:44:31:WU00:FS01:FahCore 24: 13.24%
11:44:52:WU00:FS01:FahCore 24: 13.27%
11:45:12:WU00:FS01:FahCore 24: 13.30%
11:45:23:WU00:FS01:FahCore 24: 13.33%
11:45:29:WU00:FS01:FahCore 24: 13.36%
11:45:36:WU00:FS01:FahCore 24: 13.43%
11:45:42:WU00:FS01:FahCore 24: 13.52%
11:45:59:WU00:FS01:FahCore 24: 13.61%
11:46:22:WU00:FS01:FahCore 24: 13.64%
11:46:44:WU00:FS01:FahCore 24: 13.67%
11:46:58:WU00:FS01:FahCore 24: 13.76%
11:47:04:WU00:FS01:FahCore 24: 13.83%
11:47:12:WU00:FS01:FahCore 24: 13.89%
11:47:18:WU00:FS01:FahCore 24: 14.01%
11:47:24:WU00:FS01:FahCore 24: 14.20%
11:47:30:WU00:FS01:FahCore 24: 14.35%
11:47:36:WU00:FS01:FahCore 24: 14.50%
11:47:46:WU00:FS01:FahCore 24: 14.72%
11:47:53:WU00:FS01:FahCore 24: 14.84%
11:48:01:WU00:FS01:FahCore 24: 14.87%
11:49:42:WU00:FS01:FahCore 24: 14.90%
11:49:48:WU00:FS01:FahCore 24: 15.00%
11:49:51:ERROR:WU00:FS01:Exception: Transfer failed
11:49:52:WU00:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
11:49:52:WU00:FS01:Connecting to cores.foldingathome.org:80
11:49:53:WU00:FS01:FahCore 24: Downloading 202.97MiB
11:50:09:WU00:FS01:FahCore 24: 0.12%
11:50:18:WU00:FS01:FahCore 24: 0.34%
11:50:24:WU00:FS01:FahCore 24: 0.37%
11:50:30:WU00:FS01:FahCore 24: 0.40%
11:51:19:WU00:FS01:FahCore 24: 0.49%
11:51:25:WU00:FS01:FahCore 24: 0.65%
11:51:31:WU00:FS01:FahCore 24: 0.86%
11:51:37:WU00:FS01:FahCore 24: 0.95%
11:51:46:WU00:FS01:FahCore 24: 1.08%
11:52:52:WU00:FS01:FahCore 24: 1.11%
11:52:55:ERROR:WU00:FS01:Exception: Transfer failed
11:52:55:WU00:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
11:52:55:WU00:FS01:Connecting to cores.foldingathome.org:80
11:52:56:WU00:FS01:FahCore 24: Downloading 202.97MiB
11:53:02:WU00:FS01:FahCore 24: 0.68%
11:53:08:WU00:FS01:FahCore 24: 1.20%
11:53:18:WU00:FS01:FahCore 24: 1.91%
11:53:40:WU00:FS01:FahCore 24: 2.16%
11:53:50:WU00:FS01:FahCore 24: 2.22%
11:54:06:WU00:FS01:FahCore 24: 2.25%
11:54:12:WU00:FS01:FahCore 24: 3.33%
11:54:18:WU00:FS01:FahCore 24: 4.50%
11:54:24:WU00:FS01:FahCore 24: 5.05%
11:54:35:WU00:FS01:FahCore 24: 6.31%
11:54:41:WU00:FS01:FahCore 24: 6.84%
11:54:47:WU00:FS01:FahCore 24: 7.94%
11:54:53:WU00:FS01:FahCore 24: 8.38%
11:54:59:WU00:FS01:FahCore 24: 11.27%
11:55:09:WU00:FS01:FahCore 24: 12.16%
11:55:15:WU00:FS01:FahCore 24: 14.29%
11:55:24:WU00:FS01:FahCore 24: 15.67%
11:55:30:WU00:FS01:FahCore 24: 16.66%
11:55:42:WU00:FS01:FahCore 24: 17.95%
11:55:49:WU00:FS01:FahCore 24: 18.78%
11:55:55:WU00:FS01:FahCore 24: 20.72%
11:56:01:WU00:FS01:FahCore 24: 21.74%
11:56:11:WU00:FS01:FahCore 24: 23.40%
11:56:17:WU00:FS01:FahCore 24: 23.53%
11:56:26:WU00:FS01:FahCore 24: 23.80%
11:56:37:WU00:FS01:FahCore 24: 24.11%
11:56:43:WU00:FS01:FahCore 24: 25.40%
11:56:49:WU00:FS01:FahCore 24: 26.73%
11:56:55:WU00:FS01:FahCore 24: 27.99%
11:57:04:WU00:FS01:FahCore 24: 29.31%
11:57:10:WU00:FS01:FahCore 24: 29.44%
11:57:16:WU00:FS01:FahCore 24: 29.68%
11:57:22:WU00:FS01:FahCore 24: 30.42%
11:57:28:WU00:FS01:FahCore 24: 31.19%
11:57:34:WU00:FS01:FahCore 24: 32.89%
11:57:40:WU00:FS01:FahCore 24: 35.07%
11:57:52:WU00:FS01:FahCore 24: 36.12%
11:57:58:WU00:FS01:FahCore 24: 37.60%
11:58:04:WU00:FS01:FahCore 24: 39.45%
11:58:15:WU00:FS01:FahCore 24: 39.94%
11:58:21:WU00:FS01:FahCore 24: 40.34%
11:58:27:WU00:FS01:FahCore 24: 41.42%
11:58:34:WU00:FS01:FahCore 24: 41.69%
11:58:40:WU00:FS01:FahCore 24: 42.37%
11:58:47:WU00:FS01:FahCore 24: 42.80%
11:59:00:WU00:FS01:FahCore 24: 44.25%
11:59:10:WU00:FS01:FahCore 24: 45.23%
11:59:16:WU00:FS01:FahCore 24: 47.67%
11:59:24:WU00:FS01:FahCore 24: 48.41%
11:59:41:WU00:FS01:FahCore 24: 48.50%
11:59:47:WU00:FS01:FahCore 24: 49.39%
11:59:56:WU00:FS01:FahCore 24: 50.84%
12:00:02:WU00:FS01:FahCore 24: 50.93%
12:00:14:WU00:FS01:FahCore 24: 52.72%
12:00:27:WU00:FS01:FahCore 24: 54.01%
12:00:33:WU00:FS01:FahCore 24: 55.21%
12:00:42:WU00:FS01:FahCore 24: 55.43%
12:00:48:WU00:FS01:FahCore 24: 56.04%
12:00:54:WU00:FS01:FahCore 24: 56.63%
12:01:00:WU00:FS01:FahCore 24: 57.55%
12:01:06:WU00:FS01:FahCore 24: 59.34%
12:01:12:WU00:FS01:FahCore 24: 60.29%
12:01:18:WU00:FS01:FahCore 24: 61.62%
12:01:26:WU00:FS01:FahCore 24: 61.96%
12:01:32:WU00:FS01:FahCore 24: 64.14%
12:01:40:WU00:FS01:FahCore 24: 65.31%
12:01:53:WU00:FS01:FahCore 24: 65.34%
12:01:59:WU00:FS01:FahCore 24: 66.79%
12:02:05:WU00:FS01:FahCore 24: 68.48%
12:02:14:WU00:FS01:FahCore 24: 69.90%
12:02:20:WU00:FS01:FahCore 24: 71.13%
12:02:26:WU00:FS01:FahCore 24: 73.26%
12:02:32:WU00:FS01:FahCore 24: 75.38%
12:02:38:WU00:FS01:FahCore 24: 77.17%
12:02:46:WU00:FS01:FahCore 24: 77.41%
12:02:52:WU00:FS01:FahCore 24: 78.58%
12:02:59:WU00:FS01:FahCore 24: 79.94%
12:03:05:WU00:FS01:FahCore 24: 81.94%
12:03:11:WU00:FS01:FahCore 24: 83.54%
12:03:17:WU00:FS01:FahCore 24: 86.90%
12:03:23:WU00:FS01:FahCore 24: 87.54%
12:03:34:WU00:FS01:FahCore 24: 88.56%
12:03:45:WU00:FS01:FahCore 24: 89.48%
12:03:55:WU00:FS01:FahCore 24: 90.35%
12:04:01:WU00:FS01:FahCore 24: 90.90%
12:04:08:WU00:FS01:FahCore 24: 91.27%
12:04:15:WU00:FS01:FahCore 24: 91.33%
12:04:23:WU00:FS01:FahCore 24: 91.39%
12:04:29:WU00:FS01:FahCore 24: 91.42%
12:04:35:WU00:FS01:FahCore 24: 91.49%
12:04:42:WU00:FS01:FahCore 24: 91.64%
12:04:49:WU00:FS01:FahCore 24: 91.79%
12:04:56:WU00:FS01:FahCore 24: 92.01%
12:05:02:WU00:FS01:FahCore 24: 92.13%
12:05:08:WU00:FS01:FahCore 24: 92.32%
12:05:14:WU00:FS01:FahCore 24: 92.41%
12:05:24:WU00:FS01:FahCore 24: 92.47%
12:05:30:WU00:FS01:FahCore 24: 92.53%
12:05:36:WU00:FS01:FahCore 24: 92.69%
12:05:46:WU00:FS01:FahCore 24: 92.75%
12:05:52:WU00:FS01:FahCore 24: 92.87%
12:05:58:WU00:FS01:FahCore 24: 93.15%
12:06:08:WU00:FS01:FahCore 24: 93.21%
12:06:14:WU00:FS01:FahCore 24: 93.24%
12:06:24:WU00:FS01:FahCore 24: 93.30%
12:06:32:WU00:FS01:FahCore 24: 93.43%
12:06:39:WU00:FS01:FahCore 24: 93.49%
12:06:46:WU00:FS01:FahCore 24: 93.61%
12:06:52:WU00:FS01:FahCore 24: 93.73%
12:06:58:WU00:FS01:FahCore 24: 93.89%
12:07:06:WU00:FS01:FahCore 24: 94.10%
12:07:14:WU00:FS01:FahCore 24: 94.20%
12:07:20:WU00:FS01:FahCore 24: 94.38%
12:07:26:WU00:FS01:FahCore 24: 94.93%
12:07:32:WU00:FS01:FahCore 24: 95.21%
12:07:38:WU00:FS01:FahCore 24: 95.43%
12:07:46:WU00:FS01:FahCore 24: 97.80%
12:07:53:WU00:FS01:FahCore 24: 97.92%
12:07:59:WU00:FS01:FahCore 24: 99.86%
12:07:59:WU00:FS01:FahCore 24: Download complete
12:07:59:WU00:FS01:Valid core signature
12:07:59:WU00:FS01:Unpacked 2.03MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24
12:07:59:WU00:FS01:Unpacked 889.88KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMAmoebaOpenCL.so
12:07:59:WU00:FS01:Unpacked 3.14MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libcrypto.so.1.1
12:07:59:WU00:FS01:Unpacked 64.30KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMDrudeReference.so
12:07:59:WU00:FS01:Unpacked 729.73KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMCPU.so
12:07:59:WU00:FS01:Unpacked 133.53KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMDrude.so
12:07:59:WU00:FS01:Unpacked 224.88KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libbz2.so.1.0
12:07:59:WU00:FS01:Unpacked 120.36KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMRPMDOpenCL.so
12:07:59:WU00:FS01:Unpacked 2.25MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libfftw3f.so.3
12:07:59:WU00:FS01:Unpacked 993.16KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMAmoebaCUDA.so
12:07:59:WU00:FS01:Unpacked 469.13KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMAmoeba.so
12:07:59:WU00:FS01:Unpacked 41.04KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libfftw3f_threads.so.3
12:07:59:WU00:FS01:Unpacked 13.34MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libstdc++.so.6
12:07:59:WU00:FS01:Unpacked 2.32MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMCUDA.so
12:07:59:WU00:FS01:Unpacked 118.96KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMRPMDCUDA.so
12:07:59:WU00:FS01:Unpacked 7.36MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libnvrtc-builtins.so.11.8
12:07:59:WU00:FS01:Unpacked 660.64KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libssl.so.1.1
12:07:59:WU00:FS01:Unpacked 10.90MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMM.so.8.1
12:07:59:WU00:FS01:Unpacked 2.91MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMOpenCL.so
12:07:59:WU00:FS01:Unpacked 802.98KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMAmoebaReference.so
12:07:59:WU00:FS01:Unpacked 104.01KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMDrudeCUDA.so
12:07:59:WU00:FS01:Unpacked 96.81KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMRPMD.so
12:07:59:WU00:FS01:Unpacked 384.45KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMPME.so
12:07:59:WU00:FS01:Unpacked 67.66KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenCL.so.1
12:07:59:WU00:FS01:Unpacked 105.41KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMDrudeOpenCL.so
12:07:59:WU00:FS01:Unpacked 261.05KiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libOpenMMRPMDReference.so
12:08:00:WU00:FS01:Unpacked 266.23MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libcufft.so.10
12:08:02:WU00:FS01:Unpacked 51.89MiB to cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/libnvrtc.so.11.2
12:08:02:WU00:FS01:Starting
12:08:02:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:08:02:WU00:FS01:Started FahCore on PID 7747
12:08:02:WU00:FS01:Core PID:7751
12:08:02:WU00:FS01:FahCore 0x24 started
12:08:02:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:08:03:WU00:FS01:Starting
12:08:03:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:08:03:WU00:FS01:Started FahCore on PID 7752
12:08:03:WU00:FS01:Core PID:7756
12:08:03:WU00:FS01:FahCore 0x24 started
12:08:03:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:09:03:WU00:FS01:Starting
12:09:03:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:09:03:WU00:FS01:Started FahCore on PID 8432
12:09:03:WU00:FS01:Core PID:8436
12:09:03:WU00:FS01:FahCore 0x24 started
12:09:03:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:10:03:WU00:FS01:Starting
12:10:03:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:10:03:WU00:FS01:Started FahCore on PID 9752
12:10:03:WU00:FS01:Core PID:9756
12:10:03:WU00:FS01:FahCore 0x24 started
12:10:03:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:11:03:WU00:FS01:Starting
12:11:03:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:11:03:WU00:FS01:Started FahCore on PID 9868
12:11:03:WU00:FS01:Core PID:9872
12:11:03:WU00:FS01:FahCore 0x24 started
12:11:03:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:11:03:WARNING:WU00:FS01:Too many errors, failing
12:11:04:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18237 run:930 clone:4 gen:17 core:0x24 unit:0x00000004000000110000473d000003a2
12:11:04:WU00:FS01:Connecting to 158.130.118.23:8080
12:11:04:WU02:FS01:Connecting to assign1.foldingathome.org:80
12:11:04:WU00:FS01:Server responded WORK_ACK (400)
12:11:04:WU00:FS01:Cleaning up
12:11:05:WU02:FS01:Assigned to work server 158.130.118.23
12:11:05:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
12:11:05:WU02:FS01:Connecting to 158.130.118.23:8080
12:11:06:WU02:FS01:Downloading 10.84MiB
12:11:12:WU02:FS01:Download 13.26%
12:11:18:WU02:FS01:Download 44.38%
12:11:24:WU02:FS01:Download 79.55%
12:11:26:WU02:FS01:Download complete
12:11:26:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18237 run:47 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d0000002f
12:11:26:WU02:FS01:Starting
12:11:26:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:11:26:WU02:FS01:Started FahCore on PID 9929
12:11:26:WU02:FS01:Core PID:9933
12:11:26:WU02:FS01:FahCore 0x24 started
12:11:27:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:11:27:WU02:FS01:Starting
12:11:27:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:11:27:WU02:FS01:Started FahCore on PID 9934
12:11:27:WU02:FS01:Core PID:9938
12:11:27:WU02:FS01:FahCore 0x24 started
12:12:27:WU02:FS01:Starting
12:12:27:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:12:27:WU02:FS01:Started FahCore on PID 10018
12:12:27:WU02:FS01:Core PID:10022
12:12:27:WU02:FS01:FahCore 0x24 started
12:12:27:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:13:27:WU02:FS01:Starting
12:13:27:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:13:27:WU02:FS01:Started FahCore on PID 10150
12:13:27:WU02:FS01:Core PID:10154
12:13:27:WU02:FS01:FahCore 0x24 started
12:13:28:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:14:27:WU02:FS01:Starting
12:14:27:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:14:27:WU02:FS01:Started FahCore on PID 10273
12:14:27:WU02:FS01:Core PID:10277
12:14:27:WU02:FS01:FahCore 0x24 started
12:14:28:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:14:28:WARNING:WU02:FS01:Too many errors, failing
12:14:28:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:18237 run:47 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d0000002f
12:14:28:WU02:FS01:Connecting to 158.130.118.23:8080
12:14:28:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:14:28:WU02:FS01:Server responded WORK_ACK (400)
12:14:28:WU02:FS01:Cleaning up
12:14:29:WU00:FS01:Assigned to work server 158.130.118.23
12:14:29:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
12:14:29:WU00:FS01:Connecting to 158.130.118.23:8080
12:14:30:WU00:FS01:Downloading 10.85MiB
12:14:36:WU00:FS01:Download 42.06%
12:14:43:WU00:FS01:Download 97.37%
12:14:44:WU00:FS01:Download complete
12:14:44:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18237 run:71 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d00000047
12:14:44:WU00:FS01:Starting
12:14:44:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:14:44:WU00:FS01:Started FahCore on PID 10289
12:14:44:WU00:FS01:Core PID:10293
12:14:44:WU00:FS01:FahCore 0x24 started
12:14:45:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:14:45:WU00:FS01:Starting
12:14:45:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:14:45:WU00:FS01:Started FahCore on PID 10294
12:14:45:WU00:FS01:Core PID:10298
12:14:45:WU00:FS01:FahCore 0x24 started
12:14:46:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:15:45:WU00:FS01:Starting
12:15:45:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:15:45:WU00:FS01:Started FahCore on PID 10439
12:15:45:WU00:FS01:Core PID:10443
12:15:45:WU00:FS01:FahCore 0x24 started
12:15:46:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:16:45:WU00:FS01:Starting
12:16:45:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:16:45:WU00:FS01:Started FahCore on PID 10975
12:16:45:WU00:FS01:Core PID:10979
12:16:45:WU00:FS01:FahCore 0x24 started
12:16:46:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:17:45:WU00:FS01:Starting
12:17:45:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:17:45:WU00:FS01:Started FahCore on PID 12201
12:17:45:WU00:FS01:Core PID:12205
12:17:45:WU00:FS01:FahCore 0x24 started
12:17:46:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:17:46:WARNING:WU00:FS01:Too many errors, failing
12:17:46:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18237 run:71 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d00000047
12:17:46:WU00:FS01:Connecting to 158.130.118.23:8080
12:17:47:WU02:FS01:Connecting to assign1.foldingathome.org:80
12:17:47:WU00:FS01:Server responded WORK_ACK (400)
12:17:47:WU00:FS01:Cleaning up
12:17:48:WU02:FS01:Assigned to work server 158.130.118.23
12:17:48:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
12:17:48:WU02:FS01:Connecting to 158.130.118.23:8080
12:17:48:WU02:FS01:Downloading 10.85MiB
12:17:55:WU02:FS01:Download 6.91%
12:18:01:WU02:FS01:Download 32.84%
12:18:10:WU02:FS01:Download 58.76%
12:18:16:WU02:FS01:Download 64.52%
12:18:20:WU02:FS01:Download complete
12:18:21:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18237 run:99 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d00000063
12:18:21:WU02:FS01:Starting
12:18:21:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:18:21:WU02:FS01:Started FahCore on PID 12949
12:18:21:WU02:FS01:Core PID:12953
12:18:21:WU02:FS01:FahCore 0x24 started
12:18:21:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:18:21:WU02:FS01:Started FahCore on PID 12956
12:18:21:WU02:FS01:Core PID:12960
12:18:22:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:19:21:WU02:FS01:Starting
12:19:21:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:19:21:WU02:FS01:Started FahCore on PID 13064
12:19:21:WU02:FS01:Core PID:13068
12:19:21:WU02:FS01:FahCore 0x24 started
12:19:22:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:20:21:WU02:FS01:Starting
12:20:21:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:20:21:WU02:FS01:Started FahCore on PID 13138
12:20:21:WU02:FS01:Core PID:13142
12:20:21:WU02:FS01:FahCore 0x24 started
12:20:22:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:21:21:WU02:FS01:Starting
12:21:21:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:21:21:WU02:FS01:Started FahCore on PID 13164
12:21:21:WU02:FS01:Core PID:13168
12:21:21:WU02:FS01:FahCore 0x24 started
12:21:22:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:21:22:WARNING:WU02:FS01:Too many errors, failing
12:21:22:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:18237 run:99 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d00000063
12:21:22:WU02:FS01:Connecting to 158.130.118.23:8080
12:21:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:21:23:WU02:FS01:Server responded WORK_ACK (400)
12:21:23:WU02:FS01:Cleaning up
12:21:24:WU00:FS01:Assigned to work server 158.130.118.23
12:21:24:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
12:21:24:WU00:FS01:Connecting to 158.130.118.23:8080
12:21:25:WU00:FS01:Downloading 10.84MiB
12:21:38:WU00:FS01:Download 3.46%
12:21:45:WU00:FS01:Download 6.92%
12:21:51:WU00:FS01:Download 12.69%
12:21:59:WU00:FS01:Download 17.30%
12:22:05:WU00:FS01:Download 19.61%
12:22:11:WU00:FS01:Download 24.80%
12:22:18:WU00:FS01:Download 25.95%
12:22:24:WU00:FS01:Download 28.84%
12:22:30:WU00:FS01:Download 33.45%
12:22:36:WU00:FS01:Download 39.22%
12:22:42:WU00:FS01:Download 43.83%
12:22:48:WU00:FS01:Download 47.29%
12:22:54:WU00:FS01:Download 49.60%
12:23:00:WU00:FS01:Download 50.17%
12:23:08:WU00:FS01:Download 51.33%
12:23:14:WU00:FS01:Download 52.48%
12:23:20:WU00:FS01:Download 54.21%
12:23:26:WU00:FS01:Download 57.09%
12:23:32:WU00:FS01:Download 61.71%
12:23:39:WU00:FS01:Download 63.44%
12:23:45:WU00:FS01:Download 65.17%
12:23:51:WU00:FS01:Download 69.20%
12:23:57:WU00:FS01:Download 72.09%
12:24:03:WU00:FS01:Download 75.55%
12:24:10:WU00:FS01:Download 81.89%
12:24:18:WU00:FS01:Download 84.20%
12:24:26:WU00:FS01:Download 88.24%
12:24:34:WU00:FS01:Download 89.97%
12:24:40:WU00:FS01:Download 91.70%
12:24:46:WU00:FS01:Download 95.16%
12:24:54:WU00:FS01:Download 97.46%
12:24:57:WU00:FS01:Download complete
12:24:57:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18237 run:117 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d00000075
12:24:57:WU00:FS01:Starting
12:24:57:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:24:57:WU00:FS01:Started FahCore on PID 13294
12:24:57:WU00:FS01:Core PID:13298
12:24:57:WU00:FS01:FahCore 0x24 started
12:24:58:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:24:58:WU00:FS01:Starting
12:24:58:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:24:58:WU00:FS01:Started FahCore on PID 13299
12:24:58:WU00:FS01:Core PID:13303
12:24:58:WU00:FS01:FahCore 0x24 started
12:25:58:WU00:FS01:Starting
12:25:58:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:25:58:WU00:FS01:Started FahCore on PID 13325
12:25:58:WU00:FS01:Core PID:13329
12:25:58:WU00:FS01:FahCore 0x24 started
12:25:58:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:26:58:WU00:FS01:Starting
12:26:58:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:26:58:WU00:FS01:Started FahCore on PID 13353
12:26:58:WU00:FS01:Core PID:13357
12:26:58:WU00:FS01:FahCore 0x24 started
12:26:58:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:27:58:WU00:FS01:Starting
12:27:58:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:27:58:WU00:FS01:Started FahCore on PID 13380
12:27:58:WU00:FS01:Core PID:13384
12:27:58:WU00:FS01:FahCore 0x24 started
12:27:58:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:27:58:WARNING:WU00:FS01:Too many errors, failing
12:27:58:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18237 run:117 clone:4 gen:18 core:0x24 unit:0x00000004000000120000473d00000075
12:27:58:WU00:FS01:Connecting to 158.130.118.23:8080
12:28:00:WU02:FS01:Connecting to assign1.foldingathome.org:80
12:28:01:WU00:FS01:Server responded WORK_ACK (400)
12:28:01:WU00:FS01:Cleaning up
12:28:02:WU02:FS01:Assigned to work server 158.130.118.23
12:28:02:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
12:28:02:WU02:FS01:Connecting to 158.130.118.23:8080
12:28:04:WU02:FS01:Downloading 10.84MiB
12:28:11:WU02:FS01:Download 1.15%
12:28:18:WU02:FS01:Download 5.19%
12:28:24:WU02:FS01:Download 8.65%
12:28:30:WU02:FS01:Download 10.38%
12:28:36:WU02:FS01:Download 13.26%
12:28:43:WU02:FS01:Download 16.15%
12:28:49:WU02:FS01:Download 18.45%
12:28:55:WU02:FS01:Download 25.37%
12:29:02:WU02:FS01:Download 27.68%
12:29:08:WU02:FS01:Download 32.29%
12:29:14:WU02:FS01:Download 35.75%
12:29:21:WU02:FS01:Download 39.21%
12:29:28:WU02:FS01:Download 42.10%
12:29:34:WU02:FS01:Download 46.13%
12:29:40:WU02:FS01:Download 51.32%
12:29:46:WU02:FS01:Download 55.36%
12:29:52:WU02:FS01:Download 59.97%
12:29:59:WU02:FS01:Download 65.16%
12:30:05:WU02:FS01:Download 67.47%
12:30:11:WU02:FS01:Download 70.93%
12:30:17:WU02:FS01:Download 74.97%
12:30:23:WU02:FS01:Download 78.43%
12:30:31:WU02:FS01:Download 80.15%
12:30:37:WU02:FS01:Download 82.46%
12:30:44:WU02:FS01:Download 85.34%
12:30:50:WU02:FS01:Download 88.23%
12:30:56:WU02:FS01:Download 93.99%
12:31:02:WU02:FS01:Download 97.45%
12:31:06:WU02:FS01:Download complete
12:31:06:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18237 run:1154 clone:3 gen:73 core:0x24 unit:0x00000003000000490000473d00000482
12:31:06:WU02:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... x24-8.1.4/
AlterFalter101
Post by AlterFalter101 »
Core_24.fah
12:31:06:WU02:FS01:Connecting to cores.foldingathome.org:80
12:31:07:WU02:FS01:FahCore 24: Downloading 202.97MiB
12:31:13:WU02:FS01:FahCore 24: 0.34%
12:31:19:WU02:FS01:FahCore 24: 0.49%
12:31:25:WU02:FS01:FahCore 24: 0.65%
12:31:31:WU02:FS01:FahCore 24: 0.86%
12:31:37:WU02:FS01:FahCore 24: 1.08%
12:31:43:WU02:FS01:FahCore 24: 1.29%
12:31:49:WU02:FS01:FahCore 24: 1.54%
12:31:56:WU02:FS01:FahCore 24: 1.66%
12:32:02:WU02:FS01:FahCore 24: 1.82%
12:32:09:WU02:FS01:FahCore 24: 2.12%
12:32:15:WU02:FS01:FahCore 24: 2.40%
12:32:21:WU02:FS01:FahCore 24: 2.68%
12:32:28:WU02:FS01:FahCore 24: 2.96%
12:32:35:WU02:FS01:FahCore 24: 3.05%
12:32:41:WU02:FS01:FahCore 24: 3.20%
12:32:47:WU02:FS01:FahCore 24: 3.33%
12:32:53:WU02:FS01:FahCore 24: 3.45%
12:32:59:WU02:FS01:FahCore 24: 3.57%
12:33:07:WU02:FS01:FahCore 24: 3.73%
12:33:13:WU02:FS01:FahCore 24: 3.94%
12:33:19:WU02:FS01:FahCore 24: 4.16%
12:33:25:WU02:FS01:FahCore 24: 4.28%
12:33:31:WU02:FS01:FahCore 24: 4.43%
12:33:37:WU02:FS01:FahCore 24: 4.59%
12:33:44:WU02:FS01:FahCore 24: 4.71%
12:33:50:WU02:FS01:FahCore 24: 4.83%
12:33:56:WU02:FS01:FahCore 24: 4.99%
12:34:02:WU02:FS01:FahCore 24: 5.11%
12:34:09:WU02:FS01:FahCore 24: 5.23%
12:34:15:WU02:FS01:FahCore 24: 5.36%
12:34:21:WU02:FS01:FahCore 24: 5.48%
12:34:27:WU02:FS01:FahCore 24: 5.60%
12:34:33:WU02:FS01:FahCore 24: 5.73%
12:34:40:WU02:FS01:FahCore 24: 5.91%
12:34:47:WU02:FS01:FahCore 24: 6.10%
12:34:55:WU02:FS01:FahCore 24: 6.16%
12:35:01:WU02:FS01:FahCore 24: 6.28%
12:35:07:WU02:FS01:FahCore 24: 6.44%
12:35:16:WU02:FS01:FahCore 24: 6.53%
12:35:22:WU02:FS01:FahCore 24: 6.68%
12:35:29:WU02:FS01:FahCore 24: 6.81%
12:35:35:WU02:FS01:FahCore 24: 6.93%
12:35:41:WU02:FS01:FahCore 24: 7.21%
12:35:48:WU02:FS01:FahCore 24: 7.45%
12:35:54:WU02:FS01:FahCore 24: 7.70%
12:36:01:WU02:FS01:FahCore 24: 7.85%
12:36:07:WU02:FS01:FahCore 24: 8.01%
12:36:16:WU02:FS01:FahCore 24: 8.16%
12:36:24:WU02:FS01:FahCore 24: 8.25%
12:36:31:WU02:FS01:FahCore 24: 8.44%
12:36:37:WU02:FS01:FahCore 24: 8.59%
12:36:43:WU02:FS01:FahCore 24: 8.78%
12:36:50:WU02:FS01:FahCore 24: 8.93%
12:36:56:WU02:FS01:FahCore 24: 9.11%
12:37:02:WU02:FS01:FahCore 24: 9.33%
12:37:09:WU02:FS01:FahCore 24: 9.52%
12:37:15:WU02:FS01:FahCore 24: 9.64%
12:37:21:WU02:FS01:FahCore 24: 9.82%
12:37:27:WU02:FS01:FahCore 24: 9.95%
12:37:33:WU02:FS01:FahCore 24: 10.25%
12:37:39:WU02:FS01:FahCore 24: 10.53%
12:37:47:WU02:FS01:FahCore 24: 10.65%
12:37:54:WU02:FS01:FahCore 24: 10.72%
12:38:00:WU02:FS01:FahCore 24: 10.87%
12:38:07:WU02:FS01:FahCore 24: 11.05%
12:38:15:WU02:FS01:FahCore 24: 11.24%
12:38:21:WU02:FS01:FahCore 24: 11.36%
12:38:30:WU02:FS01:FahCore 24: 11.55%
12:38:36:WU02:FS01:FahCore 24: 11.67%
12:38:42:WU02:FS01:FahCore 24: 11.92%
12:38:48:WU02:FS01:FahCore 24: 12.01%
12:38:54:WU02:FS01:FahCore 24: 12.16%
12:39:00:WU02:FS01:FahCore 24: 12.38%
12:39:08:WU02:FS01:FahCore 24: 12.59%
12:39:14:WU02:FS01:FahCore 24: 12.72%
12:39:20:WU02:FS01:FahCore 24: 12.90%
12:39:26:WU02:FS01:FahCore 24: 13.06%
12:39:32:WU02:FS01:FahCore 24: 13.27%
12:39:38:WU02:FS01:FahCore 24: 13.49%
12:39:45:WU02:FS01:FahCore 24: 13.61%
12:39:51:WU02:FS01:FahCore 24: 13.80%
12:39:57:WU02:FS01:FahCore 24: 14.01%
12:40:04:WU02:FS01:FahCore 24: 14.23%
12:40:10:WU02:FS01:FahCore 24: 14.50%
12:40:16:WU02:FS01:FahCore 24: 14.72%
12:40:23:WU02:FS01:FahCore 24: 14.90%
12:40:29:WU02:FS01:FahCore 24: 15.00%
12:40:37:WU02:FS01:FahCore 24: 15.09%
12:40:43:WU02:FS01:FahCore 24: 15.24%
12:40:50:WU02:FS01:FahCore 24: 15.52%
12:40:57:WU02:FS01:FahCore 24: 15.64%
12:41:03:WU02:FS01:FahCore 24: 15.74%
12:41:09:WU02:FS01:FahCore 24: 15.89%
12:41:15:WU02:FS01:FahCore 24: 16.17%
12:41:21:WU02:FS01:FahCore 24: 16.29%
12:41:32:WU02:FS01:FahCore 24: 16.32%
12:41:39:WU02:FS01:FahCore 24: 16.35%
12:41:45:WU02:FS01:FahCore 24: 16.41%
12:41:51:WU02:FS01:FahCore 24: 16.54%
12:41:57:WU02:FS01:FahCore 24: 16.84%
12:42:03:WU02:FS01:FahCore 24: 16.94%
12:42:09:WU02:FS01:FahCore 24: 17.03%
12:42:15:WU02:FS01:FahCore 24: 17.15%
12:42:21:WU02:FS01:FahCore 24: 17.34%
12:42:29:WU02:FS01:FahCore 24: 17.55%
12:42:35:WU02:FS01:FahCore 24: 17.68%
12:42:41:WU02:FS01:FahCore 24: 17.86%
12:42:47:WU02:FS01:FahCore 24: 18.01%
12:42:53:WU02:FS01:FahCore 24: 18.17%
12:43:01:WU02:FS01:FahCore 24: 18.41%
12:43:07:WU02:FS01:FahCore 24: 18.60%
12:43:13:WU02:FS01:FahCore 24: 18.72%
12:43:22:WU02:FS01:FahCore 24: 18.75%
12:43:28:WU02:FS01:FahCore 24: 18.81%
12:43:34:WU02:FS01:FahCore 24: 18.91%
12:43:40:WU02:FS01:FahCore 24: 19.12%
12:43:46:WU02:FS01:FahCore 24: 19.28%
12:43:52:WU02:FS01:FahCore 24: 19.52%
12:43:58:WU02:FS01:FahCore 24: 19.65%
12:44:04:WU02:FS01:FahCore 24: 19.80%
12:44:10:WU02:FS01:FahCore 24: 20.02%
12:44:16:WU02:FS01:FahCore 24: 20.11%
12:44:22:WU02:FS01:FahCore 24: 20.29%
12:44:28:WU02:FS01:FahCore 24: 20.45%
12:44:34:WU02:FS01:FahCore 24: 20.60%
12:44:42:WU02:FS01:FahCore 24: 20.75%
12:44:48:WU02:FS01:FahCore 24: 21.00%
12:44:55:WU02:FS01:FahCore 24: 21.46%
12:45:02:WU02:FS01:FahCore 24: 21.59%
12:45:09:WU02:FS01:FahCore 24: 21.80%
12:45:15:WU02:FS01:FahCore 24: 21.96%
12:45:21:WU02:FS01:FahCore 24: 22.11%
12:45:27:WU02:FS01:FahCore 24: 22.29%
12:45:34:WU02:FS01:FahCore 24: 22.39%
12:45:40:WU02:FS01:FahCore 24: 22.51%
12:45:46:WU02:FS01:FahCore 24: 22.76%
12:45:52:WU02:FS01:FahCore 24: 22.94%
12:45:58:WU02:FS01:FahCore 24: 23.19%
12:46:04:WU02:FS01:FahCore 24: 23.37%
12:46:10:WU02:FS01:FahCore 24: 23.59%
12:46:16:WU02:FS01:FahCore 24: 23.68%
12:46:22:WU02:FS01:FahCore 24: 23.83%
12:46:28:WU02:FS01:FahCore 24: 24.02%
12:46:35:WU02:FS01:FahCore 24: 24.33%
12:46:41:WU02:FS01:FahCore 24: 24.48%
12:46:47:WU02:FS01:FahCore 24: 24.73%
12:46:53:WU02:FS01:FahCore 24: 24.88%
12:46:59:WU02:FS01:FahCore 24: 25.10%
12:47:05:WU02:FS01:FahCore 24: 25.40%
12:47:11:WU02:FS01:FahCore 24: 25.62%
12:47:18:WU02:FS01:FahCore 24: 25.74%
12:47:24:WU02:FS01:FahCore 24: 25.93%
12:47:30:WU02:FS01:FahCore 24: 26.14%
12:47:36:WU02:FS01:FahCore 24: 26.27%
12:47:42:WU02:FS01:FahCore 24: 26.42%
12:47:48:WU02:FS01:FahCore 24: 26.67%
12:47:54:WU02:FS01:FahCore 24: 27.04%
12:48:00:WU02:FS01:FahCore 24: 27.31%
12:48:06:WU02:FS01:FahCore 24: 27.47%
12:48:12:WU02:FS01:FahCore 24: 27.62%
12:48:18:WU02:FS01:FahCore 24: 27.84%
12:48:25:WU02:FS01:FahCore 24: 27.96%
12:48:32:WU02:FS01:FahCore 24: 28.02%
12:48:38:WU02:FS01:FahCore 24: 28.14%
12:48:44:WU02:FS01:FahCore 24: 28.30%
12:48:50:WU02:FS01:FahCore 24: 28.45%
12:48:57:WU02:FS01:FahCore 24: 28.73%
12:49:04:WU02:FS01:FahCore 24: 28.88%
12:49:10:WU02:FS01:FahCore 24: 29.01%
12:49:16:WU02:FS01:FahCore 24: 29.19%
12:49:22:WU02:FS01:FahCore 24: 29.31%
12:49:30:WU02:FS01:FahCore 24: 29.53%
12:49:36:WU02:FS01:FahCore 24: 29.78%
12:49:43:WU02:FS01:FahCore 24: 29.96%
12:49:49:WU02:FS01:FahCore 24: 30.08%
12:49:55:WU02:FS01:FahCore 24: 30.33%
12:50:02:WU02:FS01:FahCore 24: 30.64%
12:50:08:WU02:FS01:FahCore 24: 30.85%
12:50:15:WU02:FS01:FahCore 24: 30.98%
12:50:21:WU02:FS01:FahCore 24: 31.04%
12:50:27:WU02:FS01:FahCore 24: 31.19%
12:50:34:WU02:FS01:FahCore 24: 31.35%
12:50:40:WU02:FS01:FahCore 24: 31.56%
12:50:48:WU02:FS01:FahCore 24: 31.75%
12:50:54:WU02:FS01:FahCore 24: 32.02%
12:51:02:WU02:FS01:FahCore 24: 32.18%
12:51:08:WU02:FS01:FahCore 24: 32.33%
12:51:14:WU02:FS01:FahCore 24: 32.64%
12:51:23:WU02:FS01:FahCore 24: 32.79%
12:51:29:WU02:FS01:FahCore 24: 32.89%
12:51:35:WU02:FS01:FahCore 24: 33.07%
12:51:42:WU02:FS01:FahCore 24: 33.26%
12:51:48:WU02:FS01:FahCore 24: 33.53%
12:51:54:WU02:FS01:FahCore 24: 33.63%
12:52:00:WU02:FS01:FahCore 24: 33.78%
12:52:06:WU02:FS01:FahCore 24: 33.96%
12:52:12:WU02:FS01:FahCore 24: 34.18%
12:52:19:WU02:FS01:FahCore 24: 34.37%
12:52:25:WU02:FS01:FahCore 24: 34.55%
12:52:31:WU02:FS01:FahCore 24: 34.92%
12:52:37:WU02:FS01:FahCore 24: 35.20%
12:52:43:WU02:FS01:FahCore 24: 35.32%
12:52:50:WU02:FS01:FahCore 24: 35.41%
12:52:56:WU02:FS01:FahCore 24: 35.66%
12:53:02:WU02:FS01:FahCore 24: 35.84%
12:53:08:WU02:FS01:FahCore 24: 36.00%
12:53:14:WU02:FS01:FahCore 24: 36.15%
12:53:21:WU02:FS01:FahCore 24: 36.37%
12:53:28:WU02:FS01:FahCore 24: 36.58%
12:53:35:WU02:FS01:FahCore 24: 36.67%
12:53:41:WU02:FS01:FahCore 24: 36.80%
12:53:49:WU02:FS01:FahCore 24: 36.95%
12:53:56:WU02:FS01:FahCore 24: 37.11%
12:54:04:WU02:FS01:FahCore 24: 37.20%
12:54:10:WU02:FS01:FahCore 24: 37.29%
12:54:16:WU02:FS01:FahCore 24: 37.51%
12:54:23:WU02:FS01:FahCore 24: 37.69%
12:54:29:WU02:FS01:FahCore 24: 37.84%
12:54:35:WU02:FS01:FahCore 24: 38.09%
12:54:41:WU02:FS01:FahCore 24: 38.24%
12:54:47:WU02:FS01:FahCore 24: 38.43%
12:54:53:WU02:FS01:FahCore 24: 38.65%
12:54:59:WU02:FS01:FahCore 24: 38.80%
12:55:05:WU02:FS01:FahCore 24: 39.01%
12:55:11:WU02:FS01:FahCore 24: 39.17%
12:55:19:WU02:FS01:FahCore 24: 39.42%
12:55:25:WU02:FS01:FahCore 24: 39.45%
12:55:31:WU02:FS01:FahCore 24: 39.63%
12:55:37:WU02:FS01:FahCore 24: 39.78%
12:55:44:WU02:FS01:FahCore 24: 40.03%
12:55:50:WU02:FS01:FahCore 24: 40.25%
12:55:56:WU02:FS01:FahCore 24: 40.40%
12:56:02:WU02:FS01:FahCore 24: 40.89%
12:56:08:WU02:FS01:FahCore 24: 41.05%
12:56:14:WU02:FS01:FahCore 24: 41.29%
12:56:21:WU02:FS01:FahCore 24: 41.54%
12:56:27:WU02:FS01:FahCore 24: 41.66%
12:56:33:WU02:FS01:FahCore 24: 41.85%
12:56:39:WU02:FS01:FahCore 24: 42.03%
12:56:49:WU02:FS01:FahCore 24: 42.12%
12:56:55:WU02:FS01:FahCore 24: 42.31%
12:57:01:WU02:FS01:FahCore 24: 42.59%
12:57:07:WU02:FS01:FahCore 24: 42.83%
12:57:15:WU02:FS01:FahCore 24: 42.99%
12:57:21:WU02:FS01:FahCore 24: 43.20%
12:57:27:WU02:FS01:FahCore 24: 43.51%
12:57:33:WU02:FS01:FahCore 24: 43.70%
12:57:39:WU02:FS01:FahCore 24: 43.82%
12:57:47:WU02:FS01:FahCore 24: 44.00%
12:57:53:WU02:FS01:FahCore 24: 44.19%
12:57:59:WU02:FS01:FahCore 24: 44.37%
12:58:05:WU02:FS01:FahCore 24: 44.62%
12:58:11:WU02:FS01:FahCore 24: 44.93%
12:58:17:WU02:FS01:FahCore 24: 45.11%
12:58:25:WU02:FS01:FahCore 24: 45.27%
12:58:31:WU02:FS01:FahCore 24: 45.42%
12:58:37:WU02:FS01:FahCore 24: 45.70%
12:58:43:WU02:FS01:FahCore 24: 46.00%
12:58:49:WU02:FS01:FahCore 24: 46.16%
12:58:55:WU02:FS01:FahCore 24: 46.34%
12:59:01:WU02:FS01:FahCore 24: 46.65%
12:59:07:WU02:FS01:FahCore 24: 46.93%
12:59:14:WU02:FS01:FahCore 24: 47.11%
12:59:20:WU02:FS01:FahCore 24: 47.21%
12:59:26:WU02:FS01:FahCore 24: 47.48%
12:59:33:WU02:FS01:FahCore 24: 47.67%
12:59:40:WU02:FS01:FahCore 24: 47.79%
12:59:46:WU02:FS01:FahCore 24: 48.07%
12:59:52:WU02:FS01:FahCore 24: 48.38%
12:59:58:WU02:FS01:FahCore 24: 48.78%
13:00:04:WU02:FS01:FahCore 24: 48.99%
13:00:10:WU02:FS01:FahCore 24: 49.18%
13:00:16:WU02:FS01:FahCore 24: 49.42%
13:00:22:WU02:FS01:FahCore 24: 49.55%
13:00:28:WU02:FS01:FahCore 24: 49.88%
13:00:34:WU02:FS01:FahCore 24: 50.16%
13:00:41:WU02:FS01:FahCore 24: 50.41%
13:00:47:WU02:FS01:FahCore 24: 50.69%
13:00:54:WU02:FS01:FahCore 24: 50.87%
13:01:00:WU02:FS01:FahCore 24: 50.99%
13:01:08:WU02:FS01:FahCore 24: 51.05%
13:01:14:WU02:FS01:FahCore 24: 51.27%
13:01:20:WU02:FS01:FahCore 24: 51.55%
13:01:27:WU02:FS01:FahCore 24: 51.64%
13:01:34:WU02:FS01:FahCore 24: 51.73%
13:01:40:WU02:FS01:FahCore 24: 51.92%
13:01:46:WU02:FS01:FahCore 24: 52.13%
13:01:52:WU02:FS01:FahCore 24: 52.32%
13:01:59:WU02:FS01:FahCore 24: 52.44%
13:02:05:WU02:FS01:FahCore 24: 52.72%
13:02:12:WU02:FS01:FahCore 24: 52.87%
13:02:18:WU02:FS01:FahCore 24: 53.18%
13:02:24:WU02:FS01:FahCore 24: 53.49%
13:02:30:WU02:FS01:FahCore 24: 53.73%
13:02:36:WU02:FS01:FahCore 24: 53.92%
13:02:42:WU02:FS01:FahCore 24: 54.20%
13:02:48:WU02:FS01:FahCore 24: 54.41%
13:02:54:WU02:FS01:FahCore 24: 54.66%
13:03:00:WU02:FS01:FahCore 24: 55.00%
13:03:06:WU02:FS01:FahCore 24: 55.34%
13:03:12:WU02:FS01:FahCore 24: 55.49%
13:03:18:WU02:FS01:FahCore 24: 55.67%
13:03:26:WU02:FS01:FahCore 24: 55.80%
13:03:32:WU02:FS01:FahCore 24: 56.01%
13:03:40:WU02:FS01:FahCore 24: 56.23%
13:03:46:WU02:FS01:FahCore 24: 56.51%
13:03:53:WU02:FS01:FahCore 24: 56.78%
13:03:59:WU02:FS01:FahCore 24: 56.91%
13:04:06:WU02:FS01:FahCore 24: 57.15%
13:04:13:WU02:FS01:FahCore 24: 57.34%
13:04:20:WU02:FS01:FahCore 24: 57.46%
13:04:26:WU02:FS01:FahCore 24: 57.61%
13:04:33:WU02:FS01:FahCore 24: 57.71%
13:04:46:WU02:FS01:FahCore 24: 57.74%
13:04:52:WU02:FS01:FahCore 24: 57.77%
13:04:59:WU02:FS01:FahCore 24: 57.83%
13:05:09:WU02:FS01:FahCore 24: 57.89%
13:05:15:WU02:FS01:FahCore 24: 57.92%
13:05:23:WU02:FS01:FahCore 24: 57.98%
13:05:46:WU02:FS01:FahCore 24: 58.04%
13:06:48:WU02:FS01:FahCore 24: 58.08%
13:07:10:WU02:FS01:FahCore 24: 58.11%
13:07:17:WU02:FS01:FahCore 24: 58.14%
13:07:26:WU02:FS01:FahCore 24: 58.17%
13:07:36:WU02:FS01:FahCore 24: 58.23%
13:07:57:WU02:FS01:FahCore 24: 58.26%
13:08:01:ERROR:WU02:FS01:Exception: Transfer failed
13:08:01:WU02:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
13:08:01:WU02:FS01:Connecting to cores.foldingathome.org:80
13:08:03:WU02:FS01:FahCore 24: Downloading 202.97MiB
13:08:11:WU02:FS01:FahCore 24: 0.06%
13:08:17:WU02:FS01:FahCore 24: 0.22%
13:08:23:WU02:FS01:FahCore 24: 0.40%
13:08:31:WU02:FS01:FahCore 24: 0.52%
13:08:37:WU02:FS01:FahCore 24: 0.77%
13:08:43:WU02:FS01:FahCore 24: 1.05%
13:08:50:WU02:FS01:FahCore 24: 1.26%
13:08:56:WU02:FS01:FahCore 24: 1.48%
13:09:02:WU02:FS01:FahCore 24: 1.69%
13:09:09:WU02:FS01:FahCore 24: 2.03%
13:09:15:WU02:FS01:FahCore 24: 2.25%
13:09:21:WU02:FS01:FahCore 24: 2.49%
13:09:27:WU02:FS01:FahCore 24: 2.65%
13:09:33:WU02:FS01:FahCore 24: 2.86%
13:09:39:WU02:FS01:FahCore 24: 3.11%
13:09:45:WU02:FS01:FahCore 24: 3.33%
13:09:51:WU02:FS01:FahCore 24: 3.51%
13:09:57:WU02:FS01:FahCore 24: 3.73%
13:10:09:WU02:FS01:FahCore 24: 3.91%
13:10:15:WU02:FS01:FahCore 24: 4.00%
13:10:22:WU02:FS01:FahCore 24: 4.16%
13:10:28:WU02:FS01:FahCore 24: 4.31%
13:10:35:WU02:FS01:FahCore 24: 4.50%
13:10:44:WU02:FS01:FahCore 24: 4.59%
13:10:50:WU02:FS01:FahCore 24: 4.87%
13:10:57:WU02:FS01:FahCore 24: 4.96%
13:11:03:WU02:FS01:FahCore 24: 5.11%
13:11:10:WU02:FS01:FahCore 24: 5.42%
13:11:16:WU02:FS01:FahCore 24: 5.54%
13:11:27:WU02:FS01:FahCore 24: 5.70%
13:11:38:WU02:FS01:FahCore 24: 5.73%
13:11:47:WU02:FS01:FahCore 24: 5.76%
13:11:53:WU02:FS01:FahCore 24: 5.91%
13:11:59:WU02:FS01:FahCore 24: 6.07%
13:12:05:WU02:FS01:FahCore 24: 6.34%
13:12:11:WU02:FS01:FahCore 24: 6.65%
13:12:17:WU02:FS01:FahCore 24: 6.87%
13:12:23:WU02:FS01:FahCore 24: 7.27%
13:12:30:WU02:FS01:FahCore 24: 7.58%
13:12:37:WU02:FS01:FahCore 24: 7.70%
13:12:44:WU02:FS01:FahCore 24: 7.85%
13:12:50:WU02:FS01:FahCore 24: 7.91%
13:12:56:WU02:FS01:FahCore 24: 8.16%
13:13:23:WU02:FS01:FahCore 24: 8.22%
13:13:29:WU02:FS01:FahCore 24: 8.34%
13:13:44:WU02:FS01:FahCore 24: 8.41%
13:13:56:WU02:FS01:FahCore 24: 8.47%
13:14:05:WU02:FS01:FahCore 24: 8.50%
13:14:29:WU02:FS01:FahCore 24: 8.56%
13:14:56:WU02:FS01:FahCore 24: 8.59%
13:15:46:WU02:FS01:FahCore 24: 8.68%
13:16:06:WU02:FS01:FahCore 24: 8.71%
13:16:18:WU02:FS01:FahCore 24: 8.81%
13:16:34:WU02:FS01:FahCore 24: 8.87%
13:16:38:ERROR:WU02:FS01:Exception: Transfer failed
13:16:38:WU02:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
13:16:38:WU02:FS01:Connecting to cores.foldingathome.org:80
13:16:39:WU02:FS01:FahCore 24: Downloading 202.97MiB
13:16:45:WU02:FS01:FahCore 24: 0.06%
13:16:54:WU02:FS01:FahCore 24: 0.09%
13:17:00:WU02:FS01:FahCore 24: 0.12%
13:17:10:WU02:FS01:FahCore 24: 0.18%
13:17:22:WU02:FS01:FahCore 24: 0.25%
13:17:29:WU02:FS01:FahCore 24: 0.28%
13:17:35:WU02:FS01:FahCore 24: 0.31%
13:17:41:WU02:FS01:FahCore 24: 0.40%
13:17:47:WU02:FS01:FahCore 24: 0.52%
13:17:53:WU02:FS01:FahCore 24: 0.71%
13:17:59:WU02:FS01:FahCore 24: 0.89%
13:18:05:WU02:FS01:FahCore 24: 1.17%
13:18:12:WU02:FS01:FahCore 24: 1.29%
13:18:20:WU02:FS01:FahCore 24: 1.54%
13:18:26:WU02:FS01:FahCore 24: 1.72%
13:18:32:WU02:FS01:FahCore 24: 1.97%
13:18:40:WU02:FS01:FahCore 24: 2.19%
13:18:46:WU02:FS01:FahCore 24: 2.40%
13:18:52:WU02:FS01:FahCore 24: 2.68%
13:18:59:WU02:FS01:FahCore 24: 2.77%
13:19:05:WU02:FS01:FahCore 24: 2.99%
13:19:11:WU02:FS01:FahCore 24: 3.29%
13:19:17:WU02:FS01:FahCore 24: 3.39%
13:19:24:WU02:FS01:FahCore 24: 3.70%
13:19:30:WU02:FS01:FahCore 24: 3.88%
13:19:36:WU02:FS01:FahCore 24: 4.06%
13:19:43:WU02:FS01:FahCore 24: 4.19%
13:19:49:WU02:FS01:FahCore 24: 4.22%
13:19:57:WU02:FS01:FahCore 24: 4.25%
13:20:06:WU02:FS01:FahCore 24: 4.28%
13:20:18:WU02:FS01:FahCore 24: 4.34%
13:20:24:WU02:FS01:FahCore 24: 4.46%
13:20:30:WU02:FS01:FahCore 24: 4.71%
13:20:38:WU02:FS01:FahCore 24: 4.77%
13:20:45:WU02:FS01:FahCore 24: 4.90%
13:20:51:WU02:FS01:FahCore 24: 5.02%
13:20:59:WU02:FS01:FahCore 24: 5.14%
13:21:06:WU02:FS01:FahCore 24: 5.23%
13:21:13:WU02:FS01:FahCore 24: 5.36%
13:21:19:WU02:FS01:FahCore 24: 5.67%
13:21:25:WU02:FS01:FahCore 24: 5.79%
13:21:31:WU02:FS01:FahCore 24: 5.88%
13:22:13:WU02:FS01:FahCore 24: 5.97%
13:22:20:WU02:FS01:FahCore 24: 6.10%
13:22:26:WU02:FS01:FahCore 24: 6.19%
13:22:32:WU02:FS01:FahCore 24: 6.31%
13:22:39:WU02:FS01:FahCore 24: 6.44%
13:22:45:WU02:FS01:FahCore 24: 6.62%
13:22:52:WU02:FS01:FahCore 24: 6.74%
13:22:58:WU02:FS01:FahCore 24: 6.84%
13:23:04:WU02:FS01:FahCore 24: 6.96%
13:23:10:WU02:FS01:FahCore 24: 7.17%
13:23:16:WU02:FS01:FahCore 24: 7.39%
13:23:22:WU02:FS01:FahCore 24: 7.45%
13:23:30:WU02:FS01:FahCore 24: 7.51%
13:23:37:WU02:FS01:FahCore 24: 7.54%
13:23:43:WU02:FS01:FahCore 24: 7.61%
13:23:49:WU02:FS01:FahCore 24: 7.73%
13:23:55:WU02:FS01:FahCore 24: 7.91%
13:24:01:WU02:FS01:FahCore 24: 8.16%
13:24:09:WU02:FS01:FahCore 24: 8.44%
13:24:15:WU02:FS01:FahCore 24: 8.50%
13:24:21:WU02:FS01:FahCore 24: 8.71%
13:24:27:WU02:FS01:FahCore 24: 8.90%
13:24:33:WU02:FS01:FahCore 24: 9.08%
13:24:39:WU02:FS01:FahCore 24: 9.33%
13:24:45:WU02:FS01:FahCore 24: 9.55%
13:24:51:WU02:FS01:FahCore 24: 9.88%
13:24:57:WU02:FS01:FahCore 24: 10.10%
13:25:03:WU02:FS01:FahCore 24: 10.41%
13:25:11:WU02:FS01:FahCore 24: 10.59%
13:25:17:WU02:FS01:FahCore 24: 10.84%
13:25:23:WU02:FS01:FahCore 24: 11.24%
13:25:29:WU02:FS01:FahCore 24: 11.46%
13:25:35:WU02:FS01:FahCore 24: 11.64%
13:25:41:WU02:FS01:FahCore 24: 11.82%
13:25:47:WU02:FS01:FahCore 24: 12.13%
13:25:53:WU02:FS01:FahCore 24: 12.29%
13:25:59:WU02:FS01:FahCore 24: 12.38%
13:26:05:WU02:FS01:FahCore 24: 12.47%
13:26:13:WU02:FS01:FahCore 24: 12.59%
13:26:21:WU02:FS01:FahCore 24: 12.69%
13:26:27:WU02:FS01:FahCore 24: 12.78%
13:26:33:WU02:FS01:FahCore 24: 12.93%
13:26:39:WU02:FS01:FahCore 24: 13.06%
13:26:46:WU02:FS01:FahCore 24: 13.18%
13:26:54:WU02:FS01:FahCore 24: 13.30%
13:27:01:WU02:FS01:FahCore 24: 13.39%
13:27:07:WU02:FS01:FahCore 24: 13.52%
13:27:13:WU02:FS01:FahCore 24: 13.70%
13:27:20:WU02:FS01:FahCore 24: 13.98%
13:27:26:WU02:FS01:FahCore 24: 14.23%
13:27:35:WU02:FS01:FahCore 24: 14.35%
13:27:41:WU02:FS01:FahCore 24: 14.50%
13:27:47:WU02:FS01:FahCore 24: 14.57%
13:27:55:WU02:FS01:FahCore 24: 14.69%
13:28:05:WU02:FS01:FahCore 24: 14.84%
13:28:11:WU02:FS01:FahCore 24: 14.97%
13:28:19:WU02:FS01:FahCore 24: 15.12%
13:28:26:WU02:FS01:FahCore 24: 15.27%
13:28:32:WU02:FS01:FahCore 24: 15.37%
13:28:38:WU02:FS01:FahCore 24: 15.55%
13:28:47:WU02:FS01:FahCore 24: 15.64%
13:28:54:WU02:FS01:FahCore 24: 15.74%
13:29:00:WU02:FS01:FahCore 24: 15.83%
13:29:06:WU02:FS01:FahCore 24: 15.89%
13:29:12:WU02:FS01:FahCore 24: 16.07%
13:29:21:WU02:FS01:FahCore 24: 16.20%
13:29:28:WU02:FS01:FahCore 24: 16.32%
13:29:35:WU02:FS01:FahCore 24: 16.44%
13:29:41:WU02:FS01:FahCore 24: 16.54%
13:29:47:WU02:FS01:FahCore 24: 16.63%
13:29:53:WU02:FS01:FahCore 24: 16.72%
13:30:00:WU02:FS01:FahCore 24: 16.81%
13:30:06:WU02:FS01:FahCore 24: 16.94%
13:30:12:WU02:FS01:FahCore 24: 17.09%
13:30:19:WU02:FS01:FahCore 24: 17.12%
13:30:26:WU02:FS01:FahCore 24: 17.21%
13:30:35:WU02:FS01:FahCore 24: 17.43%
13:30:41:WU02:FS01:FahCore 24: 17.49%
13:30:47:WU02:FS01:FahCore 24: 17.71%
13:30:53:WU02:FS01:FahCore 24: 17.98%
13:30:59:WU02:FS01:FahCore 24: 18.17%
13:31:05:WU02:FS01:FahCore 24: 18.45%
13:31:11:WU02:FS01:FahCore 24: 18.60%
13:31:17:WU02:FS01:FahCore 24: 18.85%
13:31:23:WU02:FS01:FahCore 24: 19.12%
13:31:29:WU02:FS01:FahCore 24: 19.25%
13:31:35:WU02:FS01:FahCore 24: 19.37%
13:31:41:WU02:FS01:FahCore 24: 19.62%
13:31:47:WU02:FS01:FahCore 24: 19.71%
13:31:53:WU02:FS01:FahCore 24: 19.86%
13:31:59:WU02:FS01:FahCore 24: 20.20%
13:32:05:WU02:FS01:FahCore 24: 20.35%
13:32:12:WU02:FS01:FahCore 24: 20.57%
13:32:18:WU02:FS01:FahCore 24: 20.82%
13:32:24:WU02:FS01:FahCore 24: 21.06%
13:32:31:WU02:FS01:FahCore 24: 21.31%
13:32:37:WU02:FS01:FahCore 24: 21.68%
13:32:43:WU02:FS01:FahCore 24: 21.89%
13:32:49:WU02:FS01:FahCore 24: 22.02%
13:32:57:WU02:FS01:FahCore 24: 22.08%
13:33:12:WU02:FS01:FahCore 24: 22.11%
13:33:21:WU02:FS01:FahCore 24: 22.14%
13:33:34:WU02:FS01:FahCore 24: 22.20%
13:33:41:WU02:FS01:FahCore 24: 22.23%
13:33:51:WU02:FS01:FahCore 24: 22.32%
13:34:00:WU02:FS01:FahCore 24: 22.36%
13:34:06:WU02:FS01:FahCore 24: 22.39%
13:34:17:WU02:FS01:FahCore 24: 22.45%
13:34:24:WU02:FS01:FahCore 24: 22.54%
13:34:30:WU02:FS01:FahCore 24: 22.82%
13:34:36:WU02:FS01:FahCore 24: 22.91%
13:34:42:WU02:FS01:FahCore 24: 23.16%
13:34:48:WU02:FS01:FahCore 24: 23.40%
13:34:54:WU02:FS01:FahCore 24: 23.50%
13:35:00:WU02:FS01:FahCore 24: 23.71%
13:35:08:WU02:FS01:FahCore 24: 23.86%
13:35:14:WU02:FS01:FahCore 24: 24.05%
13:35:20:WU02:FS01:FahCore 24: 24.33%
13:35:26:WU02:FS01:FahCore 24: 24.48%
13:35:32:WU02:FS01:FahCore 24: 24.70%
13:35:38:WU02:FS01:FahCore 24: 24.82%
13:35:44:WU02:FS01:FahCore 24: 25.00%
13:35:51:WU02:FS01:FahCore 24: 25.22%
13:35:57:WU02:FS01:FahCore 24: 25.34%
13:36:06:WU02:FS01:FahCore 24: 25.59%
13:36:12:WU02:FS01:FahCore 24: 25.77%
13:36:18:WU02:FS01:FahCore 24: 25.90%
13:36:24:WU02:FS01:FahCore 24: 26.02%
13:36:33:WU02:FS01:FahCore 24: 26.24%
13:36:43:WU02:FS01:FahCore 24: 26.30%
13:36:49:WU02:FS01:FahCore 24: 26.33%
13:36:56:WU02:FS01:FahCore 24: 26.36%
13:37:05:WU02:FS01:FahCore 24: 26.42%
13:37:12:WU02:FS01:FahCore 24: 26.45%
13:37:20:WU02:FS01:FahCore 24: 26.51%
13:37:26:WU02:FS01:FahCore 24: 26.57%
13:37:33:WU02:FS01:FahCore 24: 26.64%
13:37:42:WU02:FS01:FahCore 24: 26.73%
13:37:48:WU02:FS01:FahCore 24: 26.79%
13:37:54:WU02:FS01:FahCore 24: 26.85%
13:38:10:WU02:FS01:FahCore 24: 26.91%
13:38:18:WU02:FS01:FahCore 24: 26.94%
13:38:26:WU02:FS01:FahCore 24: 27.01%
13:38:42:WU02:FS01:FahCore 24: 27.13%
13:39:10:WU02:FS01:FahCore 24: 27.19%
13:39:16:WU02:FS01:FahCore 24: 27.22%
13:39:26:WU02:FS01:FahCore 24: 27.34%
13:39:33:WU02:FS01:FahCore 24: 27.41%
13:39:49:WU02:FS01:FahCore 24: 27.50%
13:40:28:WU02:FS01:FahCore 24: 27.59%
13:40:35:WU02:FS01:FahCore 24: 27.65%
13:40:43:WU02:FS01:FahCore 24: 27.68%
13:40:49:WU02:FS01:FahCore 24: 27.81%
13:40:55:WU02:FS01:FahCore 24: 27.96%
13:41:09:WU02:FS01:FahCore 24: 27.99%
13:41:16:WU02:FS01:FahCore 24: 28.11%
13:41:28:WU02:FS01:FahCore 24: 28.24%
13:41:34:WU02:FS01:FahCore 24: 28.36%
13:41:40:WU02:FS01:FahCore 24: 28.42%
13:41:47:WU02:FS01:FahCore 24: 28.61%
13:41:54:WU02:FS01:FahCore 24: 28.85%
13:42:30:WU02:FS01:FahCore 24: 28.91%
13:42:46:WU02:FS01:FahCore 24: 28.95%
13:42:52:WU02:FS01:FahCore 24: 29.16%
13:42:58:WU02:FS01:FahCore 24: 29.22%
13:43:04:WU02:FS01:FahCore 24: 29.38%
13:43:10:WU02:FS01:FahCore 24: 29.47%
13:43:16:WU02:FS01:FahCore 24: 29.59%
13:43:23:WU02:FS01:FahCore 24: 29.84%
13:43:29:WU02:FS01:FahCore 24: 29.99%
13:43:35:WU02:FS01:FahCore 24: 30.21%
13:43:42:WU02:FS01:FahCore 24: 30.30%
13:43:48:WU02:FS01:FahCore 24: 30.42%
13:43:54:WU02:FS01:FahCore 24: 30.55%
13:44:01:WU02:FS01:FahCore 24: 30.64%
13:44:07:WU02:FS01:FahCore 24: 30.82%
13:44:13:WU02:FS01:FahCore 24: 30.98%
13:44:24:WU02:FS01:FahCore 24: 31.22%
13:44:33:WU02:FS01:FahCore 24: 31.38%
13:44:39:WU02:FS01:FahCore 24: 31.41%
13:44:45:WU02:FS01:FahCore 24: 31.62%
13:44:51:WU02:FS01:FahCore 24: 31.78%
13:44:57:WU02:FS01:FahCore 24: 32.09%
13:45:03:WU02:FS01:FahCore 24: 32.36%
13:45:13:WU02:FS01:FahCore 24: 32.46%
13:45:19:WU02:FS01:FahCore 24: 32.55%
13:45:25:WU02:FS01:FahCore 24: 32.70%
13:45:33:WU02:FS01:FahCore 24: 32.92%
13:45:40:WU02:FS01:FahCore 24: 33.01%
13:45:46:WU02:FS01:FahCore 24: 33.23%
13:45:54:WU02:FS01:FahCore 24: 33.32%
13:46:01:WU02:FS01:FahCore 24: 33.38%
13:46:19:WU02:FS01:FahCore 24: 33.56%
13:46:25:WU02:FS01:FahCore 24: 33.63%
13:46:32:WU02:FS01:FahCore 24: 33.81%
13:46:39:WU02:FS01:FahCore 24: 33.96%
13:46:45:WU02:FS01:FahCore 24: 34.06%
13:46:51:WU02:FS01:FahCore 24: 34.18%
13:46:57:WU02:FS01:FahCore 24: 34.40%
13:47:03:WU02:FS01:FahCore 24: 34.52%
13:47:09:WU02:FS01:FahCore 24: 34.67%
13:47:18:WU02:FS01:FahCore 24: 34.80%
13:47:33:WU02:FS01:FahCore 24: 34.83%
13:47:40:WU02:FS01:FahCore 24: 34.92%
13:47:47:WU02:FS01:FahCore 24: 35.04%
13:47:53:WU02:FS01:FahCore 24: 35.17%
13:47:59:WU02:FS01:FahCore 24: 35.29%
13:48:05:WU02:FS01:FahCore 24: 35.50%
13:48:11:WU02:FS01:FahCore 24: 35.69%
13:48:22:WU02:FS01:FahCore 24: 35.72%
13:48:28:WU02:FS01:FahCore 24: 35.81%
13:48:36:WU02:FS01:FahCore 24: 35.97%
13:48:44:WU02:FS01:FahCore 24: 36.06%
13:48:50:WU02:FS01:FahCore 24: 36.09%
13:49:25:WU02:FS01:FahCore 24: 36.18%
13:50:06:WU02:FS01:FahCore 24: 36.21%
13:50:37:WU02:FS01:FahCore 24: 36.24%
13:50:44:WU02:FS01:FahCore 24: 36.34%
13:50:46:ERROR:WU02:FS01:Exception: Transfer failed
13:50:46:WU02:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
13:50:46:WU02:FS01:Connecting to cores.foldingathome.org:80
13:50:47:WU02:FS01:FahCore 24: Downloading 202.97MiB
13:50:53:WU02:FS01:FahCore 24: 0.25%
13:50:59:WU02:FS01:FahCore 24: 0.52%
13:51:06:WU02:FS01:FahCore 24: 0.80%
13:51:13:WU02:FS01:FahCore 24: 0.89%
13:51:39:WU02:FS01:FahCore 24: 1.02%
13:51:45:WU02:FS01:FahCore 24: 1.14%
13:51:54:WU02:FS01:FahCore 24: 1.26%
13:52:34:WU02:FS01:FahCore 24: 1.32%
13:54:25:WU02:FS01:FahCore 24: 1.35%
13:54:31:WU02:FS01:FahCore 24: 1.42%
13:54:32:ERROR:WU02:FS01:Exception: Transfer failed
14:08:42:WU02:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_24.fah
14:08:42:WU02:FS01:Connecting to cores.foldingathome.org:80
14:08:43:WU02:FS01:FahCore 24: Downloading 202.97MiB
14:08:49:WU02:FS01:FahCore 24: 0.43%
14:08:55:WU02:FS01:FahCore 24: 2.16%
14:09:05:WU02:FS01:FahCore 24: 3.39%
14:15:57:WU02:FS01:FahCore 24: 97.52%
14:16:04:WU02:FS01:FahCore 24: 97.95%
14:16:08:WU02:FS01:FahCore 24: Download complete
14:16:08:WU02:FS01:Valid core signature
14:16:08:WARNING:WU02:FS01:FahCore has not changed since last download, aborting core update
14:16:08:WU02:FS01:Starting
14:16:08:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:16:08:WU02:FS01:Started FahCore on PID 16675
14:16:08:WU02:FS01:Core PID:16679
14:16:08:WU02:FS01:FahCore 0x24 started
14:16:09:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:16:09:WU02:FS01:Starting
14:16:09:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:16:09:WU02:FS01:Started FahCore on PID 16680
14:16:09:WU02:FS01:Core PID:16684
14:16:09:WU02:FS01:FahCore 0x24 started
14:16:10:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:17:09:WU02:FS01:Starting
14:17:09:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:17:09:WU02:FS01:Started FahCore on PID 16704
14:17:09:WU02:FS01:Core PID:16708
14:17:09:WU02:FS01:FahCore 0x24 started
14:17:10:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:18:09:WU02:FS01:Starting
14:18:09:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:18:09:WU02:FS01:Started FahCore on PID 16731
14:18:09:WU02:FS01:Core PID:16735
14:18:09:WU02:FS01:FahCore 0x24 started
14:18:10:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:19:09:WU02:FS01:Starting
14:19:09:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:19:09:WU02:FS01:Started FahCore on PID 16768
14:19:09:WU02:FS01:Core PID:16772
14:19:09:WU02:FS01:FahCore 0x24 started
14:19:10:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:19:10:WARNING:WU02:FS01:Too many errors, failing
14:19:10:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:18237 run:1154 clone:3 gen:73 core:0x24 unit:0x00000003000000490000473d00000482
14:19:10:WU02:FS01:Connecting to 158.130.118.23:8080
14:19:11:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:19:11:WU02:FS01:Server responded WORK_ACK (400)
14:19:11:WU02:FS01:Cleaning up
14:19:12:WU00:FS01:Assigned to work server 158.130.118.23
14:19:12:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
14:19:12:WU00:FS01:Connecting to 158.130.118.23:8080
14:19:13:WU00:FS01:Downloading 10.83MiB
14:19:22:WU00:FS01:Download 17.31%
14:19:33:WU00:FS01:Download 38.09%
14:19:39:WU00:FS01:Download 46.17%
14:19:45:WU00:FS01:Download 73.88%
14:19:47:WU00:FS01:Download complete
14:19:47:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18237 run:793 clone:3 gen:86 core:0x24 unit:0x00000003000000560000473d00000319
14:19:47:WU00:FS01:Starting
14:19:47:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:19:47:WU00:FS01:Started FahCore on PID 16787
14:19:47:WU00:FS01:Core PID:16791
14:19:47:WU00:FS01:FahCore 0x24 started
14:19:48:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:19:48:WU00:FS01:Starting
14:19:48:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:19:48:WU00:FS01:Started FahCore on PID 16792
14:19:48:WU00:FS01:Core PID:16796
14:19:48:WU00:FS01:FahCore 0x24 started
14:19:49:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:20:48:WU00:FS01:Starting
14:20:48:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:20:48:WU00:FS01:Started FahCore on PID 16829
14:20:48:WU00:FS01:Core PID:16833
14:20:48:WU00:FS01:FahCore 0x24 started
14:20:49:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:21:48:WU00:FS01:Starting
14:21:48:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:21:48:WU00:FS01:Started FahCore on PID 16854
14:21:48:WU00:FS01:Core PID:16858
14:21:48:WU00:FS01:FahCore 0x24 started
14:21:49:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:22:48:WU00:FS01:Starting
14:22:48:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:22:48:WU00:FS01:Started FahCore on PID 16883
14:22:48:WU00:FS01:Core PID:16887
14:22:48:WU00:FS01:FahCore 0x24 started
14:22:49:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:22:49:WARNING:WU00:FS01:Too many errors, failing
14:22:49:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18237 run:793 clone:3 gen:86 core:0x24 unit:0x00000003000000560000473d00000319
14:22:49:WU00:FS01:Connecting to 158.130.118.23:8080
14:22:50:WU02:FS01:Connecting to assign1.foldingathome.org:80
14:22:50:WU00:FS01:Server responded WORK_ACK (400)
14:22:50:WU00:FS01:Cleaning up
14:22:50:WU02:FS01:Assigned to work server 158.130.118.23
14:22:50:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.23
14:22:50:WU02:FS01:Connecting to 158.130.118.23:8080
14:22:51:WU02:FS01:Downloading 9.45MiB
14:22:57:WU02:FS01:Download 11.91%
14:23:04:WU02:FS01:Download 18.52%
14:23:12:WU02:FS01:Download 31.09%
14:23:18:WU02:FS01:Download 59.54%
14:23:24:WU02:FS01:Download 95.26%
14:23:24:WU02:FS01:Download complete
14:23:24:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18237 run:126 clone:3 gen:87 core:0x24 unit:0x00000003000000570000473d0000007e
14:23:24:WU02:FS01:Starting
14:23:24:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:23:24:WU02:FS01:Started FahCore on PID 16907
14:23:24:WU02:FS01:Core PID:16911
14:23:24:WU02:FS01:FahCore 0x24 started
14:23:25:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:23:25:WU02:FS01:Starting
14:23:25:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:23:25:WU02:FS01:Started FahCore on PID 16915
14:23:25:WU02:FS01:Core PID:16919
14:23:25:WU02:FS01:FahCore 0x24 started
14:24:25:WU02:FS01:Starting
14:24:25:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:24:25:WU02:FS01:Started FahCore on PID 16963
14:24:25:WU02:FS01:Core PID:16967
14:24:25:WU02:FS01:FahCore 0x24 started
14:24:25:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:25:25:WU02:FS01:Starting
14:25:25:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:25:25:WU02:FS01:Started FahCore on PID 16999
14:25:25:WU02:FS01:Core PID:17003
14:25:25:WU02:FS01:FahCore 0x24 started
14:25:25:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:26:25:WU02:FS01:Starting
14:26:25:WU02:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 02 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:26:25:WU02:FS01:Started FahCore on PID 17025
14:26:25:WU02:FS01:Core PID:17029
14:26:25:WU02:FS01:FahCore 0x24 started
14:26:25:WARNING:WU02:FS01:FahCore returned: FAILED_2 (1 = 0x1)
14:26:25:WARNING:WU02:FS01:Too many errors, failing
14:26:25:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:18237 run:126 clone:3 gen:87 core:0x24 unit:0x00000003000000570000473d0000007e
14:26:26:WU02:FS01:Connecting to 158.130.118.23:8080
14:26:26:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:26:26:WU02:FS01:Server responded WORK_ACK (400)
14:26:26:WU02:FS01:Cleaning up
14:26:27:WU00:FS01:Assigned to work server 158.130.118.26
14:26:27:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070 Ti] from 158.130.118.26
14:26:27:WU00:FS01:Connecting to 158.130.118.26:8080
14:26:28:WU00:FS01:Downloading 29.63MiB
14:26:37:WU00:FS01:Download 2.53%
14:26:43:WU00:FS01:Download 13.50%
14:26:49:WU00:FS01:Download 18.98%
14:27:51:WU00:FS01:Download 98.71%
14:27:52:WU00:FS01:Download complete
14:27:52:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18228 run:62 clone:9 gen:73 core:0x23 unit:0x0000000900000049000047340000003e
14:27:52:WU00:FS01:Downloading core from http://cores.foldingathome.org/openmm-c ... ore_23.fah
14:27:52:WU00:FS01:Connecting to cores.foldingathome.org:80
14:27:52:WU00:FS01:FahCore 23: Downloading 167.88MiB
14:27:58:WU00:FS01:FahCore 23: 1.45%
14:28:04:WU00:FS01:FahCore 23: 3.57%
14:28:10:WU00:FS01:FahCore 23: 5.44%
14:28:16:WU00:FS01:FahCore 23: 9.42%
14:28:22:WU00:FS01:FahCore 23: 10.42%
14:28:28:WU00:FS01:FahCore 23: 11.17%
14:28:34:WU00:FS01:FahCore 23: 11.91%
14:28:40:WU00:FS01:FahCore 23: 13.74%
14:28:48:WU00:FS01:FahCore 23: 14.97%
14:28:54:WU00:FS01:FahCore 23: 17.20%
14:29:05:WU00:FS01:FahCore 23: 19.69%
14:29:11:WU00:FS01:FahCore 23: 21.56%
14:29:17:WU00:FS01:FahCore 23: 24.09%
14:29:23:WU00:FS01:FahCore 23: 27.81%
14:29:30:WU00:FS01:FahCore 23: 33.21%
14:29:36:WU00:FS01:FahCore 23: 34.77%
14:29:42:WU00:FS01:FahCore 23: 34.81%
14:29:48:WU00:FS01:FahCore 23: 37.49%
14:29:56:WU00:FS01:FahCore 23: 40.73%
14:30:02:WU00:FS01:FahCore 23: 41.10%
14:30:08:WU00:FS01:FahCore 23: 43.07%
14:32:48:WU00:FS01:FahCore 23: 93.74%
14:32:54:WU00:FS01:FahCore 23: 98.62%
14:32:55:WU00:FS01:FahCore 23: Download complete
14:32:55:WU00:FS01:Valid core signature
14:32:55:WU00:FS01:Unpacked 2.80MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23
14:32:55:WU00:FS01:Unpacked 928.20KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMAmoebaOpenCL.so
14:32:55:WU00:FS01:Unpacked 3.14MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libcrypto.so.1.1
14:32:55:WU00:FS01:Unpacked 38.98KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMCudaCompiler.so
14:32:55:WU00:FS01:Unpacked 65.23KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMDrudeReference.so
14:32:55:WU00:FS01:Unpacked 720.11KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMCPU.so
14:32:55:WU00:FS01:Unpacked 129.85KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMDrude.so
14:32:55:WU00:FS01:Unpacked 299.52KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libbz2.so.1.0
14:32:55:WU00:FS01:Unpacked 125.42KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMRPMDOpenCL.so
14:32:55:WU00:FS01:Unpacked 2.25MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libfftw3f.so.3
14:32:55:WU00:FS01:Unpacked 1.01MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMAmoebaCUDA.so
14:32:55:WU00:FS01:Unpacked 448.75KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMAmoeba.so
14:32:55:WU00:FS01:Unpacked 41.04KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libfftw3f_threads.so.3
14:32:55:WU00:FS01:Unpacked 13.16MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libstdc++.so.6
14:32:55:WU00:FS01:Unpacked 2.43MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMCUDA.so
14:32:55:WU00:FS01:Unpacked 120.02KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMRPMDCUDA.so
14:32:55:WU00:FS01:Unpacked 660.64KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libssl.so.1.1
14:32:55:WU00:FS01:Unpacked 4.82MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMM.so.8.0
14:32:55:WU00:FS01:Unpacked 2.46MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMOpenCL.so
14:32:55:WU00:FS01:Unpacked 5.84MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libnvrtc-builtins.so.11.2
14:32:55:WU00:FS01:Unpacked 755.48KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMAmoebaReference.so
14:32:55:WU00:FS01:Unpacked 105.17KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMDrudeCUDA.so
14:32:55:WU00:FS01:Unpacked 95.70KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMRPMD.so
14:32:55:WU00:FS01:Unpacked 348.16KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMPME.so
14:32:55:WU00:FS01:Unpacked 125.46KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenCL.so.1
14:32:55:WU00:FS01:Unpacked 106.58KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMDrudeOpenCL.so
14:32:55:WU00:FS01:Unpacked 197.30KiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMMRPMDReference.so
14:32:55:WU00:FS01:Unpacked 181.31MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libcufft.so.10
14:32:55:WU00:FS01:Unpacked 41.92MiB to cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libnvrtc.so.11.2
14:32:57:WU00:FS01:Starting
14:32:57:WU00:FS01:Running FahCore: /snap/folding-at-home-fcole90/613/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23 -dir 00 -suffix 01 -version 706 -lifeline 4718 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:32:57:WU00:FS01:Started FahCore on PID 17330
14:32:57:WU00:FS01:Core PID:17334
14:32:57:WU00:FS01:FahCore 0x23 started
14:32:57:WU00:FS01:0x23:*********************** Log Started 2025-01-03T14:32:57Z ***********************
14:32:57:WU00:FS01:0x23:*************************** Core23 Folding@home Core ***************************
14:32:57:WU00:FS01:0x23: Core: Core23
14:32:57:WU00:FS01:0x23: Type: 0x23
14:32:57:WU00:FS01:0x23: Version: 8.0.3
14:32:57:WU00:FS01:0x23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:32:57:WU00:FS01:0x23: Copyright: 2022 foldingathome.org
14:32:57:WU00:FS01:0x23: Homepage: https://foldingathome.org/
14:32:57:WU00:FS01:0x23: Date: Aug 3 2023
14:32:57:WU00:FS01:0x23: Time: 08:28:22
14:32:57:WU00:FS01:0x23: Revision: 199cb870317d05441d0a301287d9ef61254fa32b
14:32:57:WU00:FS01:0x23: Branch: HEAD
14:32:57:WU00:FS01:0x23: Compiler: GNU 7.5.0
14:32:57:WU00:FS01:0x23: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
14:32:57:WU00:FS01:0x23: -fdata-sections -O3 -funroll-loops -fno-pie
14:32:57:WU00:FS01:0x23: -DOPENMM_VERSION="\"8.0.0\""
14:32:57:WU00:FS01:0x23: Platform: linux 5.15.0-1041-azure
14:32:57:WU00:FS01:0x23: Bits: 64
14:32:57:WU00:FS01:0x23: Mode: Release
14:32:57:WU00:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:32:57:WU00:FS01:0x23: <peastman@stanford.edu>
14:32:57:WU00:FS01:0x23: Args: -dir 00 -suffix 01 -version 706 -lifeline 17330 -checkpoint 15
14:32:57:WU00:FS01:0x23: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
14:32:57:WU00:FS01:0x23: nvidia -gpu 0 -gpu-usage 100
14:32:57:WU00:FS01:0x23:************************************ libFAH ************************************
14:32:57:WU00:FS01:0x23: Time: 08:27:48
14:32:57:WU00:FS01:0x23: Revision: 112c2234abe20611a05652defc3c7f854cbf927f
14:32:57:WU00:FS01:0x23:************************************ CBang *************************************
14:32:57:WU00:FS01:0x23: Version: 1.7.2
14:32:57:WU00:FS01:0x23: Org: Cauldron Development LLC
14:32:57:WU00:FS01:0x23: Copyright: Cauldron Development LLC, 2003-2023
14:32:57:WU00:FS01:0x23: Homepage: https://cauldrondevelopment.com/
14:32:57:WU00:FS01:0x23: License: GPL 2+
14:32:57:WU00:FS01:0x23: Time: 08:27:30
14:32:57:WU00:FS01:0x23: Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
14:32:57:WU00:FS01:0x23: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
14:32:57:WU00:FS01:0x23:************************************ System ************************************
14:32:57:WU00:FS01:0x23: CPU: 12th Gen Intel(R) Core(TM) i5-12400F
14:32:57:WU00:FS01:0x23: CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
14:32:57:WU00:FS01:0x23: CPUs: 12
14:32:57:WU00:FS01:0x23: Memory: 31.16GiB
14:32:57:WU00:FS01:0x23:Free Memory: 15.73GiB
14:32:57:WU00:FS01:0x23: Threads: POSIX_THREADS
14:32:57:WU00:FS01:0x23: OS Version: 6.12
14:32:57:WU00:FS01:0x23:Has Battery: false
14:32:57:WU00:FS01:0x23: On Battery: false
14:32:57:WU00:FS01:0x23: UTC Offset: 1
14:32:57:WU00:FS01:0x23: PID: 17334
14:32:57:WU00:FS01:0x23: CWD: /var/snap/folding-at-home-fcole90/common/work
14:32:57:WU00:FS01:0x23: Exec: /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23
14:32:57:WU00:FS01:0x23:************************************ OpenMM ************************************
14:32:57:WU00:FS01:0x23: Version: 8.0.0
14:32:57:WU00:FS01:0x23:********************************************************************************
14:32:57:WU00:FS01:0x23:Project: 18228 (Run 62, Clone 9, Gen 73)
14:32:57:WU00:FS01:0x23:Reading tar file core.xml
14:32:57:WU00:FS01:0x23:Reading tar file integrator.xml
14:32:57:WU00:FS01:0x23:Reading tar file state.xml.bz2
14:32:57:WU00:FS01:0x23:Reading tar file system.xml.bz2
14:32:57:WU00:FS01:0x23:Digital signatures verified
14:32:57:WU00:FS01:0x23:Folding@home GPU Core23 Folding@home Core
14:32:57:WU00:FS01:0x23:Version 8.0.3
14:32:57:WU00:FS01:0x23: Checkpoint write interval: 25000 steps (2%) [50 total]
14:32:57:WU00:FS01:0x23: JSON viewer frame write interval: 12500 steps (1%) [100 total]
14:32:57:WU00:FS01:0x23: XTC frame write interval: 10000 steps (0.8%) [125 total]
14:32:57:WU00:FS01:0x23: Global context and integrator variables write interval: disabled
14:32:57:WU00:FS01:0x23:There are 4 platforms available.
14:32:57:WU00:FS01:0x23:Platform 0: Reference
14:32:57:WU00:FS01:0x23:Platform 1: CPU
14:32:57:WU00:FS01:0x23:Platform 2: OpenCL
14:32:57:WU00:FS01:0x23: opencl-device 0 specified
14:32:57:WU00:FS01:0x23:Platform 3: CUDA
14:32:57:WU00:FS01:0x23: cuda-device 0 specified
14:33:04:WU00:FS01:0x23:Attempting to create CUDA context:
14:33:04:WU00:FS01:0x23: Configuring platform CUDA
14:33:08:WU00:FS01:0x23: Using CUDA on CUDA Platform and gpu 0
14:33:08:WU00:FS01:0x23: GPU info: Platform: CUDA
14:33:08:WU00:FS01:0x23: GPU info: PlatformIndex: 0
14:33:08:WU00:FS01:0x23: GPU info: Device: NVIDIA GeForce RTX 4070 Ti
14:33:08:WU00:FS01:0x23: GPU info: DeviceIndex: 0
14:33:08:WU00:FS01:0x23: GPU info: Vendor: 0x10de
14:33:08:WU00:FS01:0x23: GPU info: PCI: 01:00:00
14:33:08:WU00:FS01:0x23: GPU info: Compute: 8.9
14:33:08:WU00:FS01:0x23: GPU info: Driver: 12.7
14:33:08:WU00:FS01:0x23: GPU info: GPU: true
14:33:08:WU00:FS01:0x23:Completed 0 out of 1250000 steps (0%)
14:33:08:WU00:FS01:0x23:Checkpoint completed at step 0
14:33:51:WU00:FS01:0x23:Completed 12500 out of 1250000 steps (1%)
AlterFalter101
Re: GPU Disabled on Arch Linux (after Reboot)
pcwolf wrote: Fri Jan 03, 2025 4:37 pm I have been folding on Manjaro for a number of years now, starting with AUR version you are running (fahcontrol 7.6.21) and updating to latest web-based control AUR version (foldingathome 8.4.9) early in 2024. I might suggest trying that update.
May i ask if you can recommend a Tutorial how to install the version you suggested ? I m pretty new to the Linux world.
Maybe can i get that from a github page ?
Actually FaH was the the first Program i used via Snap because i found that Tutorial.
https://snapcraft.io/install/folding-at ... ole90/arch
pcwolf
Hardware configuration: Manjaro Linux - AsRock B550 Taichi - Ryzen 5950X - NVidia RTX 4070ti
FAH v8-4.3
Post by pcwolf »
I had some trouble with FCole's Snap package for version 7 and believe I ended up building it myself from AUR.
Without knowing your familiarity with Arch specifically, and at the risk of overwhelming you with information, if you have not already I would urge you to check out the following Arch references.
Overview of the Arch User Repository (AUR) and how to "build it yourself":
https://wiki.archlinux.org/title/Arch_User_Repository
Greatly simplified way to build and install from AUR using a helper (yay):
https://linuxiac.com/how-to-install-aur ... rch-linux/
The quick (and hazardous! LOL) answer to your question is:
yay -S foldingathome
good luck!
AlterFalter101 wrote: Sat Jan 04, 2025 12:05 pm I m pretty new to the Linux world.
If you're new to Linux, stick to a supported distribution where you could find an installation package.
AlterFalter101
pcwolf wrote: Sun Jan 05, 2025 6:17 pm I had some trouble with FCole's Snap package for version 7 and believe I ended up building it myself from AUR.
Thank you very much :)
I thought in the first place, the Snap was to easy of an Install way for an Arch system and FaH is not widely used xD
Many of my bubble switchin from win to Lin. Mint was generally to old from feature perspective.
Ill give it a try to build an AUR, if i fail ill try to get it running on Fedora on a second usb drive.
I think with steam investing in Arch and there close relations to Amd , nvidia gpu will not the best option on Arch ^^
Post by calxalot »
There is an up to date pkg on AUR
https://aur.archlinux.org/packages/foldingathome
I believe you’ll need to manually enable and start the service after installing it.
pcwolf
FAH v8-4.3
Post by pcwolf »
Thanks again calxalot
To AlterFalter101 ... the mainstream Linux packages tend to shy away from cutting edge, of course, since that is not their promise or appeal. Fedora and others will never try and keep up with latest features, and certainly not with Folding At Home. The AUR is for maintainers that WANT to keep up. It gets a bad rap a lot because of users who don't want to spend the time to keep their Arch systems up to date. But the fact as I see it is that you can't go wrong when the PKGBUILD files are clear and open so you can check under the hood and understand *exactly* what is going on in your system.
Arch is pretty demanding, but it is pretty rewarding, too!
