8.3.18 [SOLVED]
frazelle09
Hardware configuration: Operating System: PCLinuxOS 2025
KDE Plasma Version: 6.5.0
KDE Frameworks Version: 6.19.0
Qt Version: 6.10.0
Kernel Version: 6.12.43-pclos1 (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-4810MQ CPU @ 2.80GHz
Memory: 31.3 GiB of usable RAM
Graphics Processor: Intel® HD Graphics 4600
Manufacturer: Dell Inc.
Product Name: Precision M6800
System Version: 00
8.3.18 [SOLVED]
Post by frazelle09 »
Didn' t realize this was Beta. Ug. Well, got it converted from .deb to .rpm with alien but upon install it says i need a library which has to do with systemd and our OS doesn't use systemd. Sigh.
Should i just go back to the 7.x version?
KDE Plasma Version: 6.2.4
KDE Frameworks Version: 6.9.0
Qt Version: 6.7.3
Kernel Version: 6.6.63-pclos1 (64-bit)
Processors: 8 × AMD Ryzen 5 3400G with Radeon Vega Graphics
Memory: 13.6 GiB of RAM
Graphics Processor: AMD Radeon Vega 11 Graphics
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: B450 AORUS M
Want to take this time to thank all the devs for their time and effort. It's really appreciated. My wife was just cured of her cancer because of the results of the most recent medical advances. ¡Arriba Modern Medicine!
Have a beautiful day and be happy! :)
"The earth is one country and mankind its citizens."
Bahá'u'lláh
"La tierra es un sólo país y la humanidad sus ciudadanos."
Re: 8.3.18
v8.3.18 became the official release a couple months back, the current beta is v8.4.9. I just have not taken the time to redo the topic and split out posts from the beta test period for it and prior releases to current issues.
Directions on how to build a RPM can be found here - https://github.com/FoldingAtHome/fah-cl ... ING-RPM.md.
frazelle09
Qt Version: 6.10.0
System Version: 00
Re: 8.3.18
Thanks Joe!
the problem was not with creating the .rpm but with trying to install it because it evidently requires libraries that have to do with systemd. Not all of us Linux users have switched or want to switch to systemd.
Have a wonderful afternoon! And, thanks for answering / Wow / so fast!!! :)
Bahá'u'lláh
Re: 8.3.18
Post by calxalot »
If you build it yourself, it should work without systemd. But you also cannot use the installer, which only works with systemd.
frazelle09
Qt Version: 6.10.0
System Version: 00
Re: 8.3.18
Thanks calaxlot! Since i don't know how to build - that's not going to help very much. However i opened up and looked at the .rpm file and all it is is a bunch of directories and sub-directories, each with one or more files ... If i copied each file to its correct directory/sub-directory, would the program work then?
Just asking - lol
Have a radiant evening and be happy! :)
Bahá'u'lláh
Re: 8.3.18
Post by calxalot »
You may need to create init.d scripts if you want it to run as a service.
Easy to just run it manually. The client uses the current working directory when launched.
frazelle09
Qt Version: 6.10.0
System Version: 00
Re: 8.3.18
Thanks, calxalot! O.k. Here goes...
Have a super evening and thanks for replying! :)
Bahá'u'lláh
Re: 8.3.18
Post by calxalot »
If you don’t have systemd, you *must* build it yourself using the instructions at the link joe provided.
frazelle09
Qt Version: 6.10.0
System Version: 00
Re: 8.3.18
Thanks again, calxalot. You're correct, of course. i got the fah-client in /usr/bin and used a terminal to see if i could run it. Nope. It reports that i need the systemd library.
Well, i first need to figure out which method i must follow to build this by figuring out with which OS my OS is compatible / Redhat, OpenSuse or Fedora...
So, we'll continue in the morning. Happy dreams! :)
Bahá'u'lláh
frazelle09
Qt Version: 6.10.0
System Version: 00
Re: 8.3.18
As i understand the .rpm usage, it is just to install the fah-client in the proper sub-directory? Is this not correct? If it is, then i don't need to "build" anything. All i need is the fah-client file without any reference to systemd so that i can just copy it to the proper sub-directory.
Or, what am i missing. ChatGPT tells me to upload the file so that it can examine it to see if it is systemd-free, but i can't figure out which file to upload - lol
Have a great day! :)
Bahá'u'lláh
Re: 8.3.18
Post by calxalot »
ChatGPT is a friendly dementia patient. Don’t ask it.
You must build the client yourself to get one without a systemd dependency. You don’t need to build the package “scons package”.
frazelle09
Qt Version: 6.10.0
System Version: 00
Re: 8.3.18
Sigh, so, i'm stuck since i really don't know how to build ...
Maybe i can just copy back the 3 files i copied out of the sub-directory and it'll just start up again in ver 7.x.
Thanks again calxalot for being so patient. Have a beautiful Sunday afternoon! :)
Bahá'u'lláh
