Did a search... currently running F@H v7.6.21 on a couple boxes... they are happily crunching along....
Just noticed there is a new version 8.3.18 on the Start Folding page.....
Should I update? Will it change anything?
Or am I fine just plugging along with my current version?
Thanky
Should I upgrade/update my software?
Re: Should I upgrade/update my software?
You are fine as you are.
Upgrade if you are on Apple silicon.
You might glance at the guide.
https://foldingathome.org/v8-3-client-guide/
If you are happy with the version you're running, there's no need to update.
exeter_acres
Cool beans...thanky
