web client showing no machines after installing 8.3.18
randoPrime
I am trying to get back into folding, last time I did was in v.7 with the control panel app. Using M1 Pro MacBook Pro.
After successfully installing the 8.3.18 pkg file, I navigated to https://v8-3.foldingathome.org/machines via Chrome, and it shows there are no machines available for folding. I feel like I am missing a step. Suggestions? Any additional information needed from me? Thanks in advance, I am looking forward to getting folding again.
Re: web client showing no machines after installing 8.3.18
Some servers have moved, which may be causing you some trouble.
Please look for errors in your browser JavaScript console.
I just tried the link you're using and got a "no machines" message.
I clicked on Login in and they all showed up.
Also, https://v8-4.foldingathome.org/machines works better & nicer.
Even without login the local client should show up.
randoPrime
Yes, that is why I am posting with this question. haha
Here is what I see after logging in: https://imgur.com/a/tTHfxyV
That is from Chrome after logging in.
What else can I provide which could help to solve my issue? I am happy to do what I can.
edit: the last time I folded was a couple of years ago. Could the fact that I used the same login before be causing an issue, I.e. could it think my computer is already being 'allocated'? Not familiar with the assignment process of machines and such, if that wasn't already apparent.
Check that fah-client is running in Activity Monitor. Set it to show all processes for all users.
randoPrime
randoPrime
Here is what I see, also here's the console errors.
https://imgur.com/a/Qd28pk3
randoPrime
Update: I DO have it running now, but it is on the OLLLLLD site with a login I am okay with abandoning. Got it working by re-downloading the 7.x FAH control app for the Mac, which is no longer supported I believe. Don't know how to tell this one to stop and have it work on the new 8.x page.
https://imgur.com/a/ND2PM7T
You just need to install v8. It will upgrade v7.
randoPrime
I did install v.8 via this link for Mac:
https://foldingathome.org/start-folding/
There was no new Mac controller app that got installed.
Please re-read the guide
https://foldingathome.org/v8-3-client-guide/
There is no controller app. Just the web app.
