I am on version v8.3.18 and my main folding rig with an RTX 4080 (Driver 560.94) is stuck! Trying to figure out if the issue is on my end, or the server end and it looks like it is the server end if I am reading this correctly:
13:07:45:I1:Downloading https://cores2.foldingathome.org/openmm ... ar.bz2.crt
13:07:45:I1:OUT1:> GET https://api.foldingathome.org/machine/w ... C0yltFB2Lw HTTP/1.1
13:07:45:I1:OUT1:< HTTP/1.1 200 HTTP_OK
13:07:50:I1:OUT4:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
13:07:50:I1:OUT4:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
13:07:50:I1:Logging into node account
13:08:00:W :CON3:DNS lookup failed for cores2.foldingathome.org
13:08:00:E :Exception: No response
Stuck at Downloading Core
Re: Stuck at Downloading Core
Yes, it's a known bug of v8 client ... and since I didn't see any explanation or solution to this, I can only advice to stick to v7 client on affected systems ...
ecretcarve
Hey red454,red454 wrote: ↑Sun Sep 08, 2024 1:57 pm I am on version v8.3.18 and my main folding rig with an RTX 4080 (Driver 560.94) is stuck! Trying to figure out if the issue is on my end, or the server end and it looks like it is the server end if I am reading this correctly:
13:07:45:I1:Downloading https://cores2.foldingathome.org/openmm-core-22/ geometry dash lite/fahcore-22-windows-64bit-release-0.0.20.tar.bz2.crt
Did you try clearing out your work directory (usually in the Folding@Home installation folder) and then restarting the client to see if it attempts a fresh download?
I had never installed Folding@Home on this machine, installed v8 client, it was seeing similar issues as others reported. I installed v7 client and it works fine. I downloaded from here: https://foldingathome.org/v7-client/
