FAH-Client 8 not working on Ubuntu Server
Locked
DoctorBob
Hardware configuration: -
OS: Ubuntu 24.04.2 LTS x86_64
Host: Sony VAIO
CPU: Intel Core i7-3517U CPU @ 1.90GHz
GPU: Intel 3rd Gen Core processor Graphics Controller
Memory: 576MiB / 3796MiB
Post by DoctorBob »
I installed fah-client 8.4.2 on my headless Ubuntu server but I am having difficulty getting it up and running.
I followed the installation procedures at: https://github.com/FoldingAtHome/fah-cl ... bian-linux
Fah-client installed without issue and the service is running:
~$ sudo service fah-client status
● fah-client.service - Folding@home Client
Loaded: loaded (/usr/lib/systemd/system/fah-client.service; enabled; preset: enabled)
Active: active (running) since Tue 2024-07-30 22:12:06 AEST; 1 day 10h ago
Main PID: 2417 (fah-client)
Tasks: 2 (limit: 2265)
Memory: 10.3M (peak: 10.8M)
CPU: 2min 29.949s
CGroup: /system.slice/fah-client.service
└─2417 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/
Jul 30 22:12:06 folding-laptop systemd[1]: Started fah-client.service - Folding@home Client.
I added the following lines to file /etc/fah-client/config.xml:
<config>
<account-token v="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<machine-name v="Folding Laptop"/>
</config>
Not sure if this is the correct way to go with the config.xml file.
Should I have just left it at its default?:
</config>
I created a account at: https://beta.foldingathome.org/account (from another PC on our network).
Once the account was created and I logged in I see under the Machines tab:
No folding machines found.
Login or install the Folding@home client software.
Here is the FAHClient Log file:
/v/l/f/log-20240731-000000.txt
12:12:06:I1: Org: foldingathome.org
12:12:06:I1: Copyright: 2023-2024, foldingathome.org
12:12:06:I1: Homepage: https://foldingathome.org/
12:12:06:I1: License: GPL-3.0-or-later
12:12:06:I1: URL: https://v8-4.foldingathome.org/
12:12:06:I1: Date: Jul 30 2024
12:12:06:I1: Time: 17:53:00
12:12:06:I1: Revision: 88692f3db014831bb4d226b4fc2efa8066b5118d
12:12:06:I1: Branch: master
12:12:06:I1: Compiler: GNU 13.2.0
12:12:06:I1: Options: -Wsuggest-override -faligned-new -std=c++14 -fsigned-char
12:12:06:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
12:12:06:I1: Platform: linux 6.8.0-39-generic
12:12:06:I1: Bits: 64
12:12:06:I1: Mode: Release
12:12:06:I1: Args: --config=/etc/fah-client/config.xml
12:12:06:I1: --log=/var/log/fah-client/log.txt
12:12:06:I1: --log-rotate-dir=/var/log/fah-client/
12:12:06:I1: Config: /etc/fah-client/config.xml
12:12:06:I1:****************************** CBang ******************************
12:12:06:I1: Version: 1.7.2
12:12:06:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:12:06:I1: Org: Cauldron Development
12:12:06:I1: Copyright: Cauldron Development, 2003-2024
12:12:06:I1: Homepage: https://cauldrondevelopment.com/
12:12:06:I1: License: LGPL-2.1-or-later
12:12:06:I1: Time: 17:51:32
12:12:06:I1: Revision: bb6841b234fcbbad74272d081b31eb3bb78bdde1
12:12:06:I1: -fPIC
12:12:06:I1:***************************** System ******************************
12:12:06:I1: CPU: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz
12:12:06:I1: CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
12:12:06:I1: CPUs: 2
12:12:06:I1: Memory: 1.91GiB
12:12:06:I1:Free Memory: 1.03GiB
12:12:06:I1: OS Version: 6.8
12:12:06:I1:Has Battery: false
12:12:06:I1: On Battery: false
12:12:06:I1: Hostname: folding-laptop
12:12:06:I1: UTC Offset: 10
12:12:06:I1: PID: 2417
12:12:06:I1: CWD: /var/lib/fah-client
12:12:06:I1: Exec: /usr/bin/fah-client
12:12:06:I1:*******************************************************************
12:12:06:I2:<config>
12:12:06:I2: <!-- Account -->
12:12:06:I2: <account-token v='xKiw2xKiRAntQRAnY3kDgY3lL4CdlL4IwxgRowxcQPY'/>
12:12:06:I2: <machine-name v='Folding Laptop'/>
12:12:06:I2:</config>
12:12:06:I1:Opening Database
12:12:06:I1:F@H ID = CIKK3xspUHL9YPCBagEmxXKzyyDVxDLs7uFXawZd1oo
12:12:06:I3:Loading default group
12:12:06:I3:Loading default resource group
12:12:06:I1:Listening for HTTP on 127.0.0.1:7396
12:12:06:I3:Loaded 0 wus.
12:12:07:I1:OUT1:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
^[[91m12:12:07:E :OUT1:Failed response: EOF^[[0m
12:12:22:I1:OUT2:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
^[[91m12:12:22:E :OUT2:Failed response: EOF^[[0m
12:12:44:I1:OUT3:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
^[[91m12:12:44:E :OUT3:Failed response: EOF^[[0m
12:13:18:I1:OUT4:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
^[[91m12:13:18:E :OUT4:Failed response: EOF^[[0m
12:14:08:I1:OUT5:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
^[[91m12:14:08:E :OUT5:Failed response: EOF^[[0m
12:15:24:I1:OUT6:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
^[[91m12:15:24:E :OUT6:Failed response: EOF^[[0m
12:17:18:I1:OUT7:> PUT https://api.foldingathome.org/machine/C ... uFXawZd1oo HTTP/1.1
The laptop is not folding, the CPU is idling.
I also tried to log into https://beta.foldingathome.org/machines using elinks and lynx on the Ubuntu server via SSH but it just produces a blank page.
Not sure if this was necessary, on our Internet router I port forwarded 7396 to the fah-client laptop.
How to I get fah-client folding and the web interface to show the machine?
Re: FAH-Client 8 not working on Ubuntu Server
No idea. v8.4.2 is an Alpha build, problems with it need to be reported on Github. It is not a public Beta.
https://github.com/FoldingAtHome/fah-client-bastet
https://github.com/FoldingAtHome/fah-web-client-bastet
Post by calxalot »
You should use the prebuilt debian package on alpha download page.
You should read https://github.com/FoldingAtHome/fah-cl ... ssions/214
You should create your config.xml before installing for best results.
Post by calxalot »
The web control url for 8.4 is
The client log shows the preferred web control url:
Post by calxalot »
I don't think fah-client on your server is able to reach the api server
The client can't register its existence without the PUT to api server.
Don't use alpha client.
Post in the appropriate section of the forums : viewforum.php?f=115
Locked
