8.3.17. :Exception: No response
cgistlaker
Post by cgistlaker »
Folding fails to start folding after installation. Internet is ok. Please add retry for the case with failed response.
08:40:04:I1: Version: 8.3.17
08:40:04:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:40:04:I1: Org: foldingathome.org
08:40:04:I1: Copyright: 2023-2024, foldingathome.org
08:40:04:I1: Homepage: https://foldingathome.org/
08:40:04:I1: License: GPL-3.0-or-later
08:40:04:I1: URL: https://v8-3.foldingathome.org/
08:40:04:I1: Date: Jun 24 2024
08:40:04:I1: Time: 13:37:05
08:40:04:I1: Revision: 5c16e77f0d64416eb66fd5be0b9bd1de33e7d1af
08:40:04:I1: Branch: master
08:40:04:I1: Compiler: Visual C++
08:40:04:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
08:40:04:I1: /Zc:throwingNew /MT
08:40:04:I1: Platform: win32 10
08:40:04:I1: Bits: 64
08:40:04:I1: Mode: Release
08:40:04:I1: Args: --open-web-control
08:40:04:I1:****************************** CBang ******************************
08:40:04:I1: Version: 1.7.2
08:40:04:I1: Org: Cauldron Development
08:40:04:I1: Copyright: Cauldron Development, 2003-2024
08:40:04:I1: Homepage: https://cauldrondevelopment.com/
08:40:04:I1: License: LGPL-2.1-or-later
08:40:04:I1: Time: 13:29:54
08:40:04:I1: Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
08:40:04:I1:***************************** System ******************************
08:40:04:I1: CPU: Intel(R) Core(TM) i5-14500
08:40:04:I1: CPU ID: GenuineIntel Family 6 Model 191 Stepping 2
08:40:04:I1: CPUs: 20
08:40:04:I1: Memory: 15.75GiB
08:40:04:I1:Free Memory: 9.62GiB
08:40:04:I1: OS Version: 6.2
08:40:04:I1:Has Battery: false
08:40:04:I1: On Battery: false
08:40:04:I1: Hostname: ATY-2024
08:40:04:I1: UTC Offset: 2
08:40:04:I1: PID: 16340
08:40:04:I1: CWD: C:\ProgramData\FAHClient
08:40:04:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
08:40:04:I1:*******************************************************************
08:40:04:I2:<config/>
08:40:04:I1:Opening Database
08:40:04:I1:Generating RSA key...........................................................................................................++++-...........................................................................++++-
08:40:04:I1:F@H ID = nFebx29JLO9z4tdTyvO0iLv1M44Z3vj3H78zGW_KqQg
08:40:04:I3:Loading default group
08:40:04:I3:Loading default resource group
08:40:04:I1:Listening for HTTP on 127.0.0.1:7396
08:40:04:I3:Loaded 0 wus.
08:40:04:I1:Started Windows systray control
08:40:04:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
08:40:05:I1:OUT1:< HTTP/1.1 200 HTTP_OK
08:40:06:I3:gpus = {
08:40:06:I3: "gpu:01:00:00": {
08:40:06:I3: "vendor": 4318,
08:40:06:I3: "type": "nvidia",
08:40:06:I3: "description": "NVIDIA GeForce RTX 4060",
08:40:06:I3: "uuid": "2fc16a05-a47b-66fd-3dfb-91881a86e851",
08:40:06:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "555.85"},
08:40:06:I3: "cuda": {"platform": 0, "device": 0, "compute": "8.9", "driver": "12.5"},
08:40:06:I3: "device": 10370,
08:40:06:I3: "supported": true
08:40:06:I3: }
08:40:06:I3:}
08:40:07:I1:OUT3:> PUT https://api.foldingathome.org/machine/nFebx29JLO9z4tdTyvO0iLv1M44Z3vj3H78zGW_KqQg HTTP/1.1
08:40:08:I1:OUT3:< HTTP/1.1 200 HTTP_OK
08:40:08:I1:Account linked
08:40:08:I1:OUT4:> GET https://api.foldingathome.org/machine/nFebx29JLO9z4tdTyvO0iLv1M44Z3vj3H78zGW_KqQg HTTP/1.1
08:40:08:I1:OUT4:< HTTP/1.1 200 HTTP_OK
08:40:08:W :Ignoring config key 'passkey' with wrong type NULL
08:40:09:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
08:40:09:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:40:09:I1:Logging into node account
08:40:22:I1:Default:Added new work unit: cpus:19 gpus:gpu:01:00:00
08:40:22:I1:WU1:Requesting WU assignment for user Tymchenko_Andrii team 0
08:40:37:W :CON6:DNS lookup failed for assign1.foldingathome.org
08:40:37:E :OUT6:Failed response: CONNECT
08:40:37:I1:WU1:Retry #1 in 2 secs
08:40:39:I1:WU1:Requesting WU assignment for user Tymchenko_Andrii team 0
08:40:39:I1:OUT7:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
08:40:40:I1:OUT7:< HTTP/1.1 200 HTTP_OK
08:40:40:I1:WU1:Received WU assignment sc7Z3WLYnqx34KReRnXyIyDx-8CpOU9Zs-w5IX7US_k
08:40:40:I1:WU1:Downloading WU
08:40:40:I1:OUT8:> POST https://vav23.fah.temple.edu/api/assign HTTP/1.1
08:40:44:I1:OUT8:< HTTP/1.1 200 HTTP_OK
08:40:45:I1:WU1:Received WU P12459 R19 C4 G429
08:40:45:I1:Downloading https://cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.crt
08:41:00:W :CON9:DNS lookup failed for cores.foldingathome.org
[b]08:41:00:E :Exception: No response[/b]
Re: 8.3.17. :Exception: No response
There is a problem at the datacenter where the server with folding core downloads is located, see this post - viewtopic.php?p=364629#p364629.
