Stats Not Uploading
ffsmith20
Stats Not Uploading
Post by ffsmith20 »
Not sure where to post this but I have completed some work units and my stats are not uploaded. Not sure where to start to see why any info would be appreciated. Running on Fedora 39 if that would help.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Stats Not Uploading
Post by BobWilliams757 »
If you have any information on a recent work completions that would be helpful.
There was recently a single server that had an issue but it is very rare that completed work units aren't credited.
Fold them if you get them!
PaulTV
Post by PaulTV »
What do you mean with not uploaded - do you see errors in the log that the client fails to send the results? At first it will try to upload the results to the work server, if that fails it'll try the collection server (most work servers have a collection serverj. If you see a failure to upload to the WS, but succesful upload to the CS, that sometimes happens and is okay.
Please post the part of the log with the error(s).
Ryzen 9800X3D / RTX 4090
Ryzen 5800X / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti
All running Fedora 43 with folding client v8.5.6
ffsmith20
Post by ffsmith20 »
*********************** Log Started 2024-04-16T01:28:07Z ***********************
01:28:07:******************************* libFAH ********************************
01:28:07:       Date: Oct 20 2020
01:28:07:       Time: 20:36:41
01:28:07:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
01:28:07:     Branch: master
01:28:07:   Compiler: GNU 4.9.4
01:28:07:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
01:28:07:             -funroll-loops
01:28:07:   Platform: linux2 5.8.0-1-amd64
01:28:07:       Bits: 64
01:28:07:       Mode: Release
01:28:07:****************************** FAHClient ******************************
01:28:07:    Version: 7.6.21
01:28:07:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:28:07:  Copyright: 2020 foldingathome.org
01:28:07:   Homepage: https://foldingathome.org/
01:28:07:       Time: 20:38:59
01:28:07:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
01:28:07:       Bits: 64
01:28:07:       Args: --child /etc/fahclient/config.xml --run-as fahclient
01:28:07:             --pid-file=/var/run/fahclient.pid --daemon
01:28:07:     Config: /etc/fahclient/config.xml
01:28:07:******************************** CBang ********************************
01:28:07:       Time: 18:38:01
01:28:07:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
01:28:07:             -funroll-loops -fPIC
01:28:07:       Bits: 64
01:28:07:******************************* System ********************************
01:28:07:        CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
01:28:07:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
01:28:07:       CPUs: 2
01:28:07:     Memory: 1.92GiB
01:28:07:Free Memory: 1.09GiB
01:28:07:    Threads: POSIX_THREADS
01:28:07: OS Version: 6.8
01:28:07:Has Battery: false
01:28:07: On Battery: false
01:28:07: UTC Offset: -4
01:28:07:        PID: 995
01:28:07:        CWD: /var/lib/fahclient
01:28:07:         OS: Linux 6.8.4-200.fc39.x86_64 x86_64
01:28:07:    OS Arch: AMD64
01:28:07:       GPUs: 0
01:28:07:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
01:28:07:             libcuda.so: cannot open shared object file: No such file or
01:28:07:             directory
01:28:07:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
01:28:07:             libOpenCL.so: cannot open shared object file: No such file or
01:28:07:             directory
01:28:07:***********************************************************************
01:28:07:<config>
01:28:07:  <!-- Folding Slot Configuration -->
01:28:07:  <cause v='CANCER'/>
01:28:07:  <gpu v='false'/>
01:28:07:
01:28:07:  <!-- HTTP Server -->
01:28:07:  <allow v='127.0.0.1 192.168.1.8'/>
01:28:07:
01:28:07:  <!-- Slot Control -->
01:28:07:  <power v='Full'/>
01:28:07:
01:28:07:  <!-- User Information -->
01:28:07:  <passkey v='*****'/>
01:28:07:  <team v='32'/>
01:28:07:  <user v='ffsmith20'/>
01:28:07:
01:28:07:  <!-- Web Server -->
01:28:07:  <web-allow v='127.0.0.1 192.168.1.8'/>
01:28:07:
01:28:07:  <!-- Folding Slots -->
01:28:07:  <slot id='0' type='CPU'/>
01:28:07:</config>
01:28:07:Trying to access database...
01:28:07:Successfully acquired database lock
01:28:07:FS00:Initialized folding slot 00: cpu:2
01:28:07:WU01:FS00:Starting
01:28:08:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 01 -suffix 01 -version 706 -lifeline 995 -checkpoint 15 -np 2
01:28:08:WU01:FS00:Started FahCore on PID 1004
01:28:08:WU01:FS00:Core PID:1215
01:28:08:WU01:FS00:FahCore 0xa8 started
01:28:17:WU01:FS00:0xa8:*********************** Log Started 2024-04-16T01:28:17Z ***********************
01:28:17:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
01:28:17:WU01:FS00:0xa8:       Core: Gromacs
01:28:17:WU01:FS00:0xa8:       Type: 0xa8
01:28:17:WU01:FS00:0xa8:    Version: 0.0.12
01:28:17:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:28:17:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
01:28:17:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
01:28:17:WU01:FS00:0xa8:       Date: Jan 16 2021
01:28:17:WU01:FS00:0xa8:       Time: 19:22:05
01:28:17:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
01:28:17:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
01:28:17:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
01:28:17:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
01:28:17:WU01:FS00:0xa8:       Bits: 64
01:28:17:WU01:FS00:0xa8:       Mode: Release
01:28:17:WU01:FS00:0xa8:       SIMD: sse2
01:28:17:WU01:FS00:0xa8:     OpenMP: ON
01:28:17:WU01:FS00:0xa8:       CUDA: OFF
01:28:17:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1004 -checkpoint 15 -np 2
01:28:17:WU01:FS00:0xa8:************************************ libFAH ************************************
01:28:17:WU01:FS00:0xa8:       Time: 19:21:38
01:28:17:WU01:FS00:0xa8:************************************ CBang *************************************
01:28:17:WU01:FS00:0xa8:       Time: 19:21:24
01:28:17:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
01:28:17:WU01:FS00:0xa8:************************************ System ************************************
01:28:17:WU01:FS00:0xa8:        CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
01:28:17:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
01:28:17:WU01:FS00:0xa8:       CPUs: 2
01:28:17:WU01:FS00:0xa8:     Memory: 1.92GiB
01:28:17:WU01:FS00:0xa8:Free Memory: 978.65MiB
01:28:17:WU01:FS00:0xa8:    Threads: POSIX_THREADS
01:28:17:WU01:FS00:0xa8: OS Version: 6.8
01:28:17:WU01:FS00:0xa8:Has Battery: false
01:28:17:WU01:FS00:0xa8: On Battery: false
01:28:17:WU01:FS00:0xa8: UTC Offset: -4
01:28:17:WU01:FS00:0xa8:        PID: 1215
01:28:17:WU01:FS00:0xa8:        CWD: /var/lib/fahclient/work
01:28:17:WU01:FS00:0xa8:********************************************************************************
01:28:17:WU01:FS00:0xa8:Project: 12444 (Run 17, Clone 17, Gen 56)
01:28:17:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
01:28:17:WU01:FS00:0xa8:Digital signatures verified
01:28:17:WU01:FS00:0xa8:Calling: mdrun -c frame56.gro -s frame56.tpr -x frame56.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
01:28:21:WU01:FS00:0xa8:Steps: first=140000000 total=142500000
01:28:26:WU01:FS00:0xa8:Completed 1965851 out of 2500000 steps (78%)
[93m01:36:49:WARNING:Denied 1:192.168.1.1 access to URI: /[0m
[93m01:36:50:WARNING:Denied 2:192.168.1.1 access to URI: /favicon.ico[0m
01:54:10:WU01:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
[93m01:58:07:WARNING:Denied 3:192.168.1.1 access to URI: /[0m
[93m01:58:08:WARNING:Denied 4:192.168.1.1 access to URI: /favicon.ico[0m
[93m02:00:24:WARNING:Denied 5:192.168.1.1 access to URI: /[0m
02:50:32:WU01:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
03:47:01:WU01:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
04:41:45:WU01:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
05:37:12:WU01:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
06:33:37:WU01:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
******************************* Date: 2024-04-16 *******************************
07:29:44:WU01:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
08:25:11:WU01:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
09:20:33:WU01:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
10:17:03:WU01:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
11:14:14:WU01:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
12:10:30:WU01:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
13:07:00:WU01:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
14:08:29:WU01:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
16:11:30:WU01:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
17:30:35:Caught signal SIGTERM(15) on PID 995
17:30:35:Exiting, please wait. . .
17:30:35:Caught signal SIGINT(2) on PID 995
[93m17:30:35:WARNING:Next signal will force exit[0m
17:30:35:WU01:FS00:0xa8:Caught signal SIGTERM(15) on PID 1215
17:30:35:WU01:FS00:0xa8:Exiting, please wait. . .
17:30:37:FS00:Shutting core down
17:30:41:Clean exit
Reason: Added code tags
Post by calxalot »
That shows the client being stopped before the WU was even finished.
Post by calxalot »
I would guess that your athlon x2 is also too slow to meet deadlines.
