8.3.5, code exited, status=217/user
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
openSUSE Tumbleweed
Fah 8.3.5
I try to start faclient service. This fails.
I get the error : code exited, status=217/user
icreated the cofig.xlm in /etc/fah-client folder
contents of config.xml
<config>
<allowed-origins v='https://app.foldingathome.org http://localhost:7396'/>
<web-root v='fah-web-control/dist'/>
</config>
Re: 8.3.5, code exited, status=217/user
Post by calxalot »
Doesn’t 217/user mean the user specified in the service file does not exist?
Post by calxalot »
The Debian installer creates user and group “fah-client”
I believe it also adds groups video,render to the user.
promeneur
Re: 8.3.5, code exited, status=217/user, [solved]
Post by promeneur »
I fixed it.
With "alien" I created a rpm from the deb.
The resulting rpm is partially adapted to openSUSE.
It does not create the required folders dedicated to fa-client.
It does not create the system user "fah-client" and the system group "fah-client".
The systemd service file is not good. We must complete it.
fah currently computes with 4 CPU assigned :
- an a8 project with 3 CPU
- a project 22 with 1 CPU and 1 NVIDIA dGPU
It seems there is a bug in web control. It indicates that 0 CPU is used for 22 project.
Post by calxalot »
0 CPUs for GPU WUs is correct.
Post by calxalot »
Or rather, you can create a group with zero CPUs for your GPU.
Post by calxalot »
It’s on you to not use too many cpus now. Supposed to be.
promeneur
Post by promeneur »
@calxalot
calxalot wrote: Sun Feb 18, 2024 8:16 pm 0 CPUs for GPU WUs is correct.
If I say that, it is because :
you see here https://beta.foldingathome.org/machines
for the 22 core, 1 CPU 1 GPU
you see at "work unit details"
for the 22 core, CPU 0 GPU 01:00:00
Post by calxalot »
I would need a screenshot to see what you do.
A GPU WU does not need any cpu assigned.
But you should leave some cpu threads free for system and GPU core overhead.
promeneur
Post by promeneur »
