Curious different PPD Linux v. Windows 11
pcwolf
Hardware configuration: Manjaro Linux - AsRock B550 Taichi - Ryzen 5950X - NVidia RTX 4070ti
FAH v8-4.3
Post by pcwolf »
I built a dual-boot machine to run F@H. There is an extreme difference in points per day between Linux and Windows 11.
Same hardware.
AMD Ryzen 5950X on ECO mode through UEFI
32 GB DDR4 memory @ 4000 mHz
NVidia RTX-4070
Manjaro Linux = 12,000,000 PPD
Windows 11 fresh registered installation with all updates = 3,500,000 PPD
I have no background tasks started and running other than standard system tasks.
Is there any explanation for this difference I am not seeing? Is this common in anyone else experience?
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Curious different PPD Linux v. Windows 11
Post by BobWilliams757 »
I have no help to offer, but if the differences were that excessive I would think that nobody would want to run Win 11 at all for folding. Most feedback I've seen seems to indicate that it works just as well as Win 10.
Fold them if you get them!
Post by calxalot »
Do you have a passkey set on both machines?
HaloJones
Post by HaloJones »
Your 4070 alone should be getting more than the 3.5m you get with win11.
4070 super
pcwolf
FAH v8-4.3
Post by pcwolf »
I will boot to Win11 then and let it run a few days straight to see if I haven't let the machine "warm up" and reach full PPD.
Same F@H Team and passkeys, same account.
bikeaddict
Post by bikeaddict »
The PPD for individual WUs can be calculated at
https://apps.foldingathome.org/cpu
Search for your username, click a link in the "Last returned" column, then divide the Credit column by the Days column to calculate actual PPD for that task.
Do you leave one CPU core (2 threads) free to feed the GPU on Windows ?
Note : FAH has always been faster on Linux than on Windows due to system and driver architecture differences.
