GPU Disabled
coolbobjoe
GPU Disabled
Post by coolbobjoe »
Got a Tesla card for doing Cuda work and wanted to try it out with a bit of folding. Well I got the card running proper, but now I cannot use either my discrete GPU nor my main GPU a 660ti that is for sure on the white list. Any ideas?
Log:
*********************** Log Started 2023-12-23T03:11:46Z ***********************
03:11:46:******************************* libFAH ********************************
03:11:46: Date: Oct 20 2020
03:11:46: Time: 13:36:55
03:11:46: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
03:11:46: Branch: master
03:11:46: Compiler: Visual C++ 2015
03:11:46: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
03:11:46: Platform: win32 10
03:11:46: Bits: 32
03:11:46: Mode: Release
03:11:46:****************************** FAHClient ******************************
03:11:46: Version: 7.6.21
03:11:46: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:11:46: Copyright: 2020 foldingathome.org
03:11:46: Homepage: https://foldingathome.org/
03:11:46: Time: 13:41:04
03:11:46: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
03:11:46: Bits: 32
03:11:46: Args: --open-web-control
03:11:46: Config: C:\ProgramData\FAHClient\config.xml
03:11:46:******************************** CBang ********************************
03:11:46: Time: 11:36:18
03:11:46: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
03:11:46: Bits: 32
03:11:46:******************************* System ********************************
03:11:46: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:11:46: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:11:46: CPUs: 8
03:11:46: Memory: 15.84GiB
03:11:46: Free Memory: 10.58GiB
03:11:46: Threads: WINDOWS_THREADS
03:11:46: OS Version: 6.2
03:11:46: Has Battery: false
03:11:46: On Battery: false
03:11:46: UTC Offset: -6
03:11:46: PID: 9084
03:11:46: CWD: C:\ProgramData\FAHClient
03:11:46: Win32 Service: false
03:11:46: OS: Windows 10 Home
03:11:46: OS Arch: AMD64
03:11:46: GPUs: 3
03:11:46: GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:4 GK104 [GeForce GTX 660 Ti] 2634
03:11:46: GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 SKL GT2 [HD Graphics 530]
03:11:46: GPU 2: Bus:1 Slot:0 Func:0 NVIDIA:3 GK110 [Tesla K20Xm] 3935
03:11:46: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:11.4
03:11:46:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:474.64
03:11:46:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:31.0
03:11:46:***********************************************************************
03:11:46:<config>
03:11:46: <!-- Folding Slot Configuration -->
03:11:46: <cause v='HIGH_PRIORITY'/>
03:11:46:
03:11:46: <!-- Network -->
03:11:46: <proxy v=':8080'/>
03:11:46:
03:11:46: <!-- Slot Control -->
03:11:46: <power v='FULL'/>
03:11:46:
03:11:46: <!-- User Information -->
03:11:46: <team v='33'/>
03:11:46: <user v='Coolbobjoe'/>
03:11:46:
03:11:46: <!-- Folding Slots -->
03:11:46: <slot id='0' type='CPU'/>
03:11:46: <slot id='1' type='GPU'>
03:11:46: <pci-bus v='3'/>
03:11:46: <pci-slot v='0'/>
03:11:46: </slot>
03:11:46: <slot id='2' type='GPU'>
03:11:46: <pci-bus v='0'/>
03:11:46: <pci-slot v='2'/>
03:11:46: </slot>
03:11:46: <slot id='3' type='GPU'>
03:11:46: <pci-bus v='1'/>
03:11:46: </slot>
03:11:46:</config>
03:11:46:Trying to access database...
03:11:46:Successfully acquired database lock
03:11:46:FS00:Initialized folding slot 00: cpu:5
03:11:46:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:3:0 GK104 [GeForce GTX 660 Ti] 2634 . Disabling.
03:11:46:WARNING:FS02:Guessing ambiguous GPU to OpenCL device mapping for 02: gpu:0:2 SKL GT2 [HD Graphics 530]. Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
03:11:46:WARNING:FS02:Disabling beta GPU slot 02: gpu:0:2 SKL GT2 [HD Graphics 530]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
03:11:46:FS03:Initialized folding slot 03: gpu:1:0 GK110 [Tesla K20Xm] 3935
03:11:47:WU01:FS03:Starting
03:11:47:WU01:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 01 -suffix 01 -version 706 -lifeline 9084 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
03:11:47:WU01:FS03:Started FahCore on PID 13252
03:11:47:WU01:FS03:Core PID:2620
03:11:47:WU01:FS03:FahCore 0x23 started
03:11:47:WU00:FS00:Starting
03:11:47:WARNING:WU00:FS00:AS lowered CPUs from 5 to 4
03:11:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 9084 -checkpoint 15 -np 4
03:11:47:WU00:FS00:Started FahCore on PID 17060
03:11:47:WU00:FS00:Core PID:5392
03:11:47:WU00:FS00:FahCore 0xa8 started
03:11:47:WU01:FS03:0x23:*********************** Log Started 2023-12-23T03:11:47Z ***********************
03:11:47:WU01:FS03:0x23:*************************** Core23 Folding@home Core ***************************
03:11:47:WU01:FS03:0x23: Core: Core23
03:11:47:WU01:FS03:0x23: Type: 0x23
03:11:47:WU01:FS03:0x23: Version: 8.0.3
03:11:47:WU01:FS03:0x23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:11:47:WU01:FS03:0x23: Copyright: 2022 foldingathome.org
03:11:47:WU01:FS03:0x23: Homepage: https://foldingathome.org/
03:11:47:WU01:FS03:0x23: Date: Aug 3 2023
03:11:47:WU01:FS03:0x23: Time: 08:39:06
03:11:47:WU01:FS03:0x23: Compiler: Visual C++
03:11:47:WU01:FS03:0x23: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
03:11:47:WU01:FS03:0x23: -DOPENMM_VERSION="\"8.0.0\""
03:11:47:WU01:FS03:0x23: Platform: win32 10
03:11:47:WU01:FS03:0x23: Bits: 64
03:11:47:WU01:FS03:0x23: Mode: Release
03:11:47:WU01:FS03:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
03:11:47:WU01:FS03:0x23: <peastman@stanford.edu>
03:11:47:WU01:FS03:0x23: Args: -dir 01 -suffix 01 -version 706 -lifeline 13252 -checkpoint 15
03:11:47:WU01:FS03:0x23: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
03:11:47:WU01:FS03:0x23: nvidia -gpu 0 -gpu-usage 100
03:11:47:WU01:FS03:0x23:************************************ libFAH ************************************
03:11:47:WU01:FS03:0x23: Time: 08:37:55
03:11:47:WU01:FS03:0x23:************************************ CBang *************************************
03:11:47:WU01:FS03:0x23: Version: 1.7.2
03:11:47:WU01:FS03:0x23: Org: Cauldron Development LLC
03:11:47:WU01:FS03:0x23: Copyright: Cauldron Development LLC, 2003-2023
03:11:47:WU01:FS03:0x23: Homepage: https://cauldrondevelopment.com/
03:11:47:WU01:FS03:0x23: License: GPL 2+
03:11:47:WU01:FS03:0x23: Time: 08:37:14
03:11:47:WU00:FS00:0xa8:*********************** Log Started 2023-12-23T03:11:47Z ***********************
03:11:47:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
03:11:47:WU00:FS00:0xa8: Core: Gromacs
03:11:47:WU01:FS03:0x23:************************************ System ************************************
03:11:47:WU00:FS00:0xa8: Type: 0xa8
03:11:47:WU01:FS03:0x23: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:11:47:WU00:FS00:0xa8: Version: 0.0.12
03:11:47:WU01:FS03:0x23: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:11:47:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:11:47:WU01:FS03:0x23: CPUs: 8
03:11:47:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
03:11:47:WU01:FS03:0x23: Memory: 15.84GiB
03:11:47:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
03:11:47:WU01:FS03:0x23:Free Memory: 10.55GiB
03:11:47:WU00:FS00:0xa8: Date: Jan 16 2021
03:11:47:WU01:FS03:0x23: Threads: WINDOWS_THREADS
03:11:47:WU00:FS00:0xa8: Time: 12:29:40
03:11:47:WU01:FS03:0x23: OS Version: 6.2
03:11:47:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
03:11:47:WU01:FS03:0x23:Has Battery: false
03:11:47:WU00:FS00:0xa8: Branch: master
03:11:47:WU01:FS03:0x23: On Battery: false
03:11:47:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
03:11:47:WU01:FS03:0x23: UTC Offset: -6
03:11:47:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
03:11:47:WU01:FS03:0x23: PID: 2620
03:11:47:WU00:FS00:0xa8: Platform: win32 10
03:11:47:WU01:FS03:0x23: CWD: C:\ProgramData\FAHClient\work
03:11:47:WU00:FS00:0xa8: Bits: 64
03:11:47:WU01:FS03:0x23: Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
03:11:47:WU00:FS00:0xa8: Mode: Release
03:11:47:WU01:FS03:0x23:************************************ OpenMM ************************************
03:11:47:WU00:FS00:0xa8: SIMD: avx2_256
03:11:47:WU01:FS03:0x23: Version: 8.0.0
03:11:47:WU00:FS00:0xa8: OpenMP: ON
03:11:47:WU01:FS03:0x23:********************************************************************************
03:11:47:WU00:FS00:0xa8: CUDA: OFF
03:11:47:WU01:FS03:0x23:Project: 12257 (Run 0, Clone 155, Gen 30)
03:11:47:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 17060 -checkpoint 15 -np
03:11:47:WU01:FS03:0x23:Digital signatures verified
03:11:47:WU00:FS00:0xa8: 4
03:11:47:WU01:FS03:0x23:Folding@home GPU Core23 Folding@home Core
03:11:47:WU00:FS00:0xa8:************************************ libFAH ************************************
03:11:47:WU01:FS03:0x23:Version 8.0.3
03:11:47:WU01:FS03:0x23: Checkpoint write interval: 50000 steps (2%) [50 total]
03:11:47:WU00:FS00:0xa8: Time: 11:24:13
03:11:47:WU01:FS03:0x23: JSON viewer frame write interval: 25000 steps (1%) [100 total]
03:11:47:WU01:FS03:0x23: XTC frame write interval: 25000 steps (1%) [100 total]
03:11:47:WU01:FS03:0x23: Global context and integrator variables write interval: disabled
03:11:47:WU01:FS03:0x23:There are 4 platforms available.
03:11:47:WU01:FS03:0x23:Platform 0: Reference
03:11:47:WU01:FS03:0x23:Platform 1: CPU
03:11:47:WU01:FS03:0x23:Platform 2: OpenCL
03:11:47:WU01:FS03:0x23: opencl-device 0 specified
03:11:47:WU00:FS00:0xa8:************************************ CBang *************************************
03:11:47:WU01:FS03:0x23:Platform 3: CUDA
03:11:47:WU01:FS03:0x23: cuda-device 0 specified
03:11:47:WU00:FS00:0xa8: Time: 11:23:53
03:11:47:WU00:FS00:0xa8:************************************ System ************************************
03:11:47:WU00:FS00:0xa8: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:11:47:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:11:47:WU00:FS00:0xa8: CPUs: 8
03:11:47:WU00:FS00:0xa8: Memory: 15.84GiB
03:11:47:WU00:FS00:0xa8:Free Memory: 10.53GiB
03:11:47:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
03:11:47:WU00:FS00:0xa8: OS Version: 6.2
03:11:47:WU00:FS00:0xa8:Has Battery: false
03:11:47:WU00:FS00:0xa8: On Battery: false
03:11:47:WU00:FS00:0xa8: UTC Offset: -6
03:11:47:WU00:FS00:0xa8: PID: 5392
03:11:47:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
03:11:47:WU00:FS00:0xa8:********************************************************************************
03:11:47:WU00:FS00:0xa8:Project: 18493 (Run 30, Clone 61, Gen 52)
03:11:47:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
03:11:47:WU00:FS00:0xa8:Digital signatures verified
03:11:47:WU00:FS00:0xa8:Calling: mdrun -c frame52.gro -s frame52.tpr -x frame52.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
03:11:47:WU00:FS00:0xa8:Steps: first=260000000 total=265000000
03:11:48:WU00:FS00:0xa8:Completed 50641 out of 5000000 steps (1%)
03:11:48:4:127.0.0.1:New Web session
03:11:58:WU01:FS03:0x23:Attempting to create CUDA context:
03:11:58:WU01:FS03:0x23: Configuring platform CUDA
03:12:00:WU01:FS03:0x23: Using CUDA on CUDA Platform and gpu 0
03:12:00:WU01:FS03:0x23: GPU info: Platform: CUDA
03:12:00:WU01:FS03:0x23: GPU info: PlatformIndex: 0
03:12:00:WU01:FS03:0x23: GPU info: Device: Tesla K20Xm
03:12:00:WU01:FS03:0x23: GPU info: DeviceIndex: 0
03:12:00:WU01:FS03:0x23: GPU info: Vendor: 0x10de
03:12:00:WU01:FS03:0x23: GPU info: PCI: 01:00:00
03:12:00:WU01:FS03:0x23: GPU info: Compute: 3.5
03:12:00:WU01:FS03:0x23: GPU info: Driver: 11.4
03:12:00:WU01:FS03:0x23: GPU info: GPU: true
03:12:00:WU01:FS03:0x23:Completed 150000 out of 2500000 steps (6%)
Re: GPU Disabled
Something is wrong with your drivers, CUDA and OpenCL only see one nVidia GPU :
03:11:46: GPUs: 3
bikeaddict
Re: GPU Disabled
Post by bikeaddict »
The latest driver available for 660 Ti is 474.64 and latest for K20xm is 463.15. NVIDIA may have dropped support for the K20xm in 474.64.
Both of these are almost too slow and inefficient to still be worth using for folding. The 660 Ti shows 75K PPD on the LAR Systems database and K20xm shows 300K. These are low points for the 150W and 235W TDP of these GPUs. A modern GPU can do over 7M PPD for under 150W.
