The owner has not added the description for the project.
DRQ
Post by DRQ »
Hi,
I, and others, have had several instances of work units assigned where "The owner has not added the description for the project.". This does not inspire me to fold, or provide my resources to F@H.
My GPU is currently working on project 12442, which at the time of writing (2023-11-28T09:17Z) gives the "The owner has not added the description for the project." message, which does not reflect well on the owner.
https://stats.foldingathome.org/project/12442
A few examples of other posts on this point.
viewtopic.php?p=361740
viewtopic.php?p=360646
viewtopic.php?p=360616
viewtopic.php?t=39257
Can it not be made a requirement that the project owner provides a description for every project that is submitted?
I'm considering dumping work units where there's no description. If that is considered bad form (worse than not providing a description?) then I may just stop folding. I appreciate that that wouldn't be a great loss to the F@H.
PaulTV
Re: The owner has not added the description for the project.
Post by PaulTV »
Hi,
You are right, projects appearing without description seems to happen more and more compared to a couple years ago, and that's not a way to keep people involved. Entering a project (even in the beta stage) should require a description full stop. If the new project is a continuation from a previous one, a redirect would work as well.
Ryzen 5600X / RTX 3070 Ti / Ubuntu 22.04
Ryzen 5600 / RTX 3060 Ti / Windows 11
DRQ
Post by DRQ »
Another one.
https://stats.foldingathome.org/project/12437
Well, the owner can find someone else to do their work for them, then.
How do we make the people who determine which projects are accepted, or the criteria for accepting projects, aware of this?
DRQ
Post by DRQ »
Someone else experiencing the same:
viewtopic.php?t=40853
DJNovack
Pande Group Member
Post by DJNovack »
Hi,
These are my projects. Sorry for the delay in getting a project descriptions up. I've made the moves to do so. In the meantime, projects 12437-42 are the same as https://stats.foldingathome.org/project/12425. Thank you for donating your computing resources to do some really cool science. :)
Lazvon
Hardware configuration: 4080 / 12700F, 3090Ti/12900KS, 3090/12900K, 3090/10940X, 3080Ti/12700K, 3080Ti/9900X, 3080Ti/9900X
Post by Lazvon »
DJNovack wrote: Mon Dec 04, 2023 9:02 pmThank you for donating your computing resources to do some really cool science. :)
And thank you for doing the really cool science that we get to donate to!
Folding since Feb 2021. 1) 4090/12900KS, 2) 4080/12700F, 3) 4070Ti/9900X, 4) 3090/12900K, 5) 3090/10940X, 6) 3080Ti/12700K, 7) 3080Ti/9900X
