Crashes on FahCore_22 on windows
novaitsme
Post by novaitsme »
I'm very new to folding and since ive started trying this about 24 hours ago, ive had about 5 identical complete graphics driver failures while folding. I believe about 4/5 of the crashes happened when there was a sudden increase in a load, usually when opening a new app or video or something similar. upon doing this, both of my monitors black out and my primary monitor flashes to life about 6 times then turns back on fully while the second stays off, meanwhile the fans on the gpu kick to 100% and Windows no longer recognizes either of my graphics cards in task manager. I have done some digging around on forums but I havent found a definitive solution (i think) yet. I have tried manually underclocking my 2060 since I assume that is the thing causing the problem. I considered turning off the cuda core folding, but I would rather have the speed gained by those cores, so that is a last resort. Last night I had thought it was a CPU issue which lead me to turning off the folding for it and leaving only my gpus to fold. Also, once overnight, while idle folding, the crash had happened again.
Windows log:
Faulting application name: FahCore_22.exe, version: 0.0.0.0, time stamp: 0x61e8b7bf
Faulting module name: ucrtbase.dll, version: 10.0.19041.3636, time stamp: 0x81cf5d89
Exception code: 0xc0000409
Fault offset: 0x000000000007286e
Faulting process id: 0x1ddc
Faulting application start time: 0x01da09f417997d6e
Faulting application path: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\win\64bit\22-0.0.20\Core_22.fah\FahCore_22.exe
Faulting module path: C:\Windows\System32\ucrtbase.dll
Report Id: 3be8a9b0-cae3-4a19-a53b-9727db985613
Faulting package full name:
Faulting package-relative application ID:
Specs:
Ryzen 5 2600x
RTX 2060 6gb
GTX 1060 3gb
16gb ram
I assume that more information would be needed to diagnose this, so please tell me what info would help and I will find it and send it over.
novaitsme
Re: Crashes on FahCore_22 on windows
Post by novaitsme »
just had a crash, logs in Fah were as following before attempting and failing to restart 9 times before i cut the cord and paused it:
[normal running]
06:15:23:WU02:FS02:0x22:An exception occurred at step 2151714: Error invoking kernel: CUDA_ERROR_LAUNCH_TIMEOUT (702)
06:15:23:WU02:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
06:15:24:WU02:FS02:0x22:Folding@home Core Shutdown: CORE_RESTART
06:15:28:WARNING:WU02:FS02:FahCore returned an unknown error code which probably indicates that it crashed
06:15:28:WARNING:WU02:FS02:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
[attempted restarts]
novaitsme
Post by novaitsme »
I have increased the TdrDelay to 60 and testing to see if that resolves the timeout error
edit: this seemed to make it so the drivers just became completely unresponsive on crash as opposed to restarting, reverting change
One of your GPUs doesn't seem stable ... did you run some stability tests ?
Did you try to start FAH on only one GPU at once ?
Is PSU powerful enough to feed both GPUs ?
