I got this error...
FrancoV78
I got this error...
Post by FrancoV78 »
Greetings.
After this error no more calculations are performed on the gpu even if running is written in the FAHControl status.
*********************** Log Started 2023-08-26T17:49:55Z ***********************
17:49:55:******************************* libFAH ********************************
17:49:55:           Date: Oct 20 2020
17:49:55:           Time: 13:36:55
17:49:55:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
17:49:55:         Branch: master
17:49:55:       Compiler: Visual C++ 2015
17:49:55:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:49:55:       Platform: win32 10
17:49:55:           Bits: 32
17:49:55:           Mode: Release
17:49:55:****************************** FAHClient ******************************
17:49:55:        Version: 7.6.21
17:49:55:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:49:55:      Copyright: 2020 foldingathome.org
17:49:55:       Homepage: https://foldingathome.org/
17:49:55:           Time: 13:41:04
17:49:55:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
17:49:55:           Bits: 32
17:49:55:         Config: D:\Folding\FAHClient\config.xml
17:49:55:******************************** CBang ********************************
17:49:55:           Time: 11:36:18
17:49:55:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
17:49:55:           Bits: 32
17:49:55:******************************* System ********************************
17:49:55:            CPU: Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz
17:49:55:         CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
17:49:55:           CPUs: 10
17:49:55:         Memory: 15.91GiB
17:49:55:    Free Memory: 8.52GiB
17:49:55:        Threads: WINDOWS_THREADS
17:49:55:     OS Version: 6.2
17:49:55:    Has Battery: false
17:49:55:     On Battery: false
17:49:55:     UTC Offset: 2
17:49:55:            PID: 14752
17:49:55:            CWD: D:\Folding\FAHClient
17:49:55:  Win32 Service: false
17:49:55:             OS: Windows 10 Enterprise
17:49:55:        OS Arch: AMD64
17:49:55:           GPUs: 1
17:49:55:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
17:49:55:                 M 13448
17:49:55:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:12.2
17:49:55:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:537.13
17:49:55:***********************************************************************
17:49:55:<config>
17:49:55:  <!-- Folding Core -->
17:49:55:  <checkpoint v='3'/>
17:49:55:  <core-priority v='low'/>
17:49:55:
17:49:55:  <!-- Folding Slot Configuration -->
17:49:55:  <cause v='CANCER'/>
17:49:55:
17:49:55:  <!-- Network -->
17:49:55:  <proxy v='127.0.0.1:8118'/>
17:49:55:
17:49:55:  <!-- Slot Control -->
17:49:55:  <pause-on-battery v='false'/>
17:49:55:  <power v='full'/>
17:49:55:
17:49:55:  <!-- User Information -->
17:49:55:  <passkey v='*****'/>
17:49:55:  <user v='Killer666'/>
17:49:55:
17:49:55:  <!-- Folding Slots -->
17:49:55:  <slot id='1' type='GPU'>
17:49:55:    <pci-bus v='1'/>
17:49:55:    <pci-slot v='0'/>
17:49:55:  </slot>
17:49:55:</config>
17:49:55:Trying to access database...
17:49:55:Successfully acquired database lock
17:49:55:FS01:Initialized folding slot 01: gpu:1:0 TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
17:49:55:WU00:FS01:Starting
17:49:55:ERROR:WU00:FS01:Failed to start core: Failed to rename 'work/00/logfile_01.txt' to 'work/00/logfile_01-20230826-174955.txt': Impossibile accedere al file. Il file è utilizzato da un altro processo.
17:49:56:WU00:FS01:Starting
17:49:56:ERROR:WU00:FS01:Failed to start core: Failed to rename 'work/00/logfile_01.txt' to 'work/00/logfile_01-20230826-174956.txt': Impossibile accedere al file. Il file è utilizzato da un altro processo.
17:50:56:WU00:FS01:Starting
17:50:56:WU00:FS01:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:\Folding\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 14752 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
17:50:56:WU00:FS01:Started FahCore on PID 10044
17:50:56:WU00:FS01:Core PID:10844
17:50:56:WU00:FS01:FahCore 0x22 started
17:50:57:WU00:FS01:0x22:*********************** Log Started 2023-08-26T17:50:56Z ***********************
17:50:57:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:50:57:WU00:FS01:0x22:       Core: Core22
17:50:57:WU00:FS01:0x22:       Type: 0x22
17:50:57:WU00:FS01:0x22:    Version: 0.0.20
17:50:57:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:50:57:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
17:50:57:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
17:50:57:WU00:FS01:0x22:       Date: Jan 20 2022
17:50:57:WU00:FS01:0x22:       Time: 01:15:36
17:50:57:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
17:50:57:WU00:FS01:0x22:     Branch: HEAD
17:50:57:WU00:FS01:0x22:   Compiler: Visual C++
17:50:57:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:50:57:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
17:50:57:WU00:FS01:0x22:   Platform: win32 10
17:50:57:WU00:FS01:0x22:       Bits: 64
17:50:57:WU00:FS01:0x22:       Mode: Release
17:50:57:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:50:57:WU00:FS01:0x22:             <peastman@stanford.edu>
17:50:57:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10044 -checkpoint 3
17:50:57:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:50:57:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
17:50:57:WU00:FS01:0x22:************************************ libFAH ************************************
17:50:57:WU00:FS01:0x22:       Time: 01:14:17
17:50:57:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
17:50:57:WU00:FS01:0x22:************************************ CBang *************************************
17:50:57:WU00:FS01:0x22:       Time: 01:13:20
17:50:57:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
17:50:57:WU00:FS01:0x22:************************************ System ************************************
17:50:57:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz
17:50:57:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
17:50:57:WU00:FS01:0x22:       CPUs: 10
17:50:57:WU00:FS01:0x22:     Memory: 15.91GiB
17:50:57:WU00:FS01:0x22:Free Memory: 10.95GiB
17:50:57:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
17:50:57:WU00:FS01:0x22: OS Version: 6.2
17:50:57:WU00:FS01:0x22:Has Battery: false
17:50:57:WU00:FS01:0x22: On Battery: false
17:50:57:WU00:FS01:0x22: UTC Offset: 2
17:50:57:WU00:FS01:0x22:        PID: 10844
17:50:57:WU00:FS01:0x22:        CWD: D:\Folding\FAHClient\work
17:50:57:WU00:FS01:0x22:************************************ OpenMM ************************************
17:50:57:WU00:FS01:0x22:    Version: 7.7.0
17:50:57:WU00:FS01:0x22:********************************************************************************
17:50:57:WU00:FS01:0x22:Project: 17639 (Run 0, Clone 45, Gen 283)
17:50:57:WU00:FS01:0x22:Digital signatures verified
17:50:57:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:50:57:WU00:FS01:0x22:Version 0.0.20
17:50:57:WU00:FS01:0x22:  Checkpoint write interval: 12500 steps (5%) [20 total]
17:50:57:WU00:FS01:0x22:  JSON viewer frame write interval: 2500 steps (1%) [100 total]
17:50:57:WU00:FS01:0x22:  XTC frame write interval: 25000 steps (10%) [10 total]
17:50:57:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
17:50:57:WU00:FS01:0x22:There are 4 platforms available.
17:50:57:WU00:FS01:0x22:Platform 0: Reference
17:50:57:WU00:FS01:0x22:Platform 1: CPU
17:50:57:WU00:FS01:0x22:Platform 2: OpenCL
17:50:57:WU00:FS01:0x22:  opencl-device 0 specified
17:50:57:WU00:FS01:0x22:Platform 3: CUDA
17:50:57:WU00:FS01:0x22:  cuda-device 0 specified
17:52:32:WU00:FS01:0x22:Attempting to create CUDA context:
17:52:32:WU00:FS01:0x22:  Configuring platform CUDA
FrancoV78
Re: I got this error...
Post by FrancoV78 »
Could be a problem with my seagate hard drive. My harddisk is having problems.
It could be. Previous times this type of error has shown up were traced to such things as two or more programs having access to the F@h files and locking them. Only the F@h client should be accessing the files, anything that locks access when it needs to name or remove temp work files can cause problems.
