Nvidia 3050 Mobile Not Being Used
gckw
Post by gckw »
I'm having trouble with my nvidia 3050 mobile folding on my laptop.
*********************** Log Started 2023-06-14T23:20:11Z ***********************
23:20:11:******************************* libFAH ********************************
23:20:11:           Date: Oct 20 2020
23:20:11:           Time: 13:36:55
23:20:11:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
23:20:11:         Branch: master
23:20:11:       Compiler: Visual C++ 2015
23:20:11:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:20:11:       Platform: win32 10
23:20:11:           Bits: 32
23:20:11:           Mode: Release
23:20:11:****************************** FAHClient ******************************
23:20:11:        Version: 7.6.21
23:20:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:20:11:      Copyright: 2020 foldingathome.org
23:20:11:       Homepage: https://foldingathome.org/
23:20:11:           Time: 13:41:04
23:20:11:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
23:20:11:           Bits: 32
23:20:11:         Config: C:\ProgramData\FAHClient\config.xml
23:20:11:******************************** CBang ********************************
23:20:11:           Time: 11:36:18
23:20:11:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
23:20:11:           Bits: 32
23:20:11:******************************* System ********************************
23:20:11:            CPU: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
23:20:11:         CPU ID: GenuineIntel Family 6 Model 141 Stepping 1
23:20:11:           CPUs: 16
23:20:11:         Memory: 31.74GiB
23:20:11:    Free Memory: 24.81GiB
23:20:11:        Threads: WINDOWS_THREADS
23:20:11:     OS Version: 6.2
23:20:11:    Has Battery: true
23:20:11:     On Battery: false
23:20:11:     UTC Offset: 8
23:20:11:            PID: 16464
23:20:11:            CWD: C:\ProgramData\FAHClient
23:20:11:  Win32 Service: false
23:20:11:             OS: Windows 10 Enterprise
23:20:11:        OS Arch: AMD64
23:20:11:           GPUs: 1
23:20:11:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GA107M [GeForce RTX 3050 Mobile]
23:20:11:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.2
23:20:11:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:535.98
23:20:11:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:31.0
23:20:11:***********************************************************************
23:20:11:<config>
23:20:11:  <!-- Folding Core -->
23:20:11:  <core-priority v='low'/>
23:20:11:
23:20:11:  <!-- Network -->
23:20:11:  <proxy v=':8080'/>
23:20:11:
23:20:11:  <!-- Slot Control -->
23:20:11:  <pause-on-battery v='false'/>
23:20:11:  <power v='full'/>
23:20:11:
23:20:11:  <!-- User Information -->
23:20:11:  <user v='gckw'/>
23:20:11:
23:20:11:  <!-- Folding Slots -->
23:20:11:  <slot id='0' type='CPU'>
23:20:11:    <cpus v='15'/>
23:20:11:  </slot>
23:20:11:</config>
23:20:11:Trying to access database...
23:20:11:Successfully acquired database lock
23:20:11:FS00:Initialized folding slot 00: cpu:15
23:20:11:FS01:Initialized folding slot 01: gpu:1:0 GA107M [GeForce RTX 3050 Mobile]
23:20:11:WU01:FS00:Starting
23:20:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 16464 -checkpoint 15 -np 15
23:20:12:WU01:FS00:Started FahCore on PID 18512
23:20:12:WU01:FS00:Core PID:18564
23:20:12:WU01:FS00:FahCore 0xa8 started
23:20:12:WU01:FS00:0xa8:*********************** Log Started 2023-06-14T23:20:12Z ***********************
23:20:12:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
23:20:12:WU01:FS00:0xa8:       Core: Gromacs
23:20:12:WU01:FS00:0xa8:       Type: 0xa8
23:20:12:WU01:FS00:0xa8:    Version: 0.0.12
23:20:12:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:20:12:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
23:20:12:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
23:20:12:WU01:FS00:0xa8:       Date: Jan 16 2021
23:20:12:WU01:FS00:0xa8:       Time: 12:29:40
23:20:12:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
23:20:12:WU01:FS00:0xa8:     Branch: master
23:20:12:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
23:20:12:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:20:12:WU01:FS00:0xa8:   Platform: win32 10
23:20:12:WU01:FS00:0xa8:       Bits: 64
23:20:12:WU01:FS00:0xa8:       Mode: Release
23:20:12:WU01:FS00:0xa8:       SIMD: avx2_256
23:20:12:WU01:FS00:0xa8:     OpenMP: ON
23:20:12:WU01:FS00:0xa8:       CUDA: OFF
23:20:12:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 18512 -checkpoint 15 -np
23:20:12:WU01:FS00:0xa8:             15
23:20:12:WU01:FS00:0xa8:************************************ libFAH ************************************
23:20:12:WU01:FS00:0xa8:       Time: 11:24:13
23:20:12:WU01:FS00:0xa8:************************************ CBang *************************************
23:20:12:WU01:FS00:0xa8:       Time: 11:23:53
23:20:12:WU01:FS00:0xa8:************************************ System ************************************
23:20:12:WU01:FS00:0xa8:        CPU: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
23:20:12:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 141 Stepping 1
23:20:12:WU01:FS00:0xa8:       CPUs: 16
23:20:12:WU01:FS00:0xa8:     Memory: 31.74GiB
23:20:12:WU01:FS00:0xa8:Free Memory: 24.34GiB
23:20:12:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
23:20:12:WU01:FS00:0xa8: OS Version: 6.2
23:20:12:WU01:FS00:0xa8:Has Battery: true
23:20:12:WU01:FS00:0xa8: On Battery: false
23:20:12:WU01:FS00:0xa8: UTC Offset: 8
23:20:12:WU01:FS00:0xa8:        PID: 18564
23:20:12:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
23:20:12:WU01:FS00:0xa8:********************************************************************************
23:20:12:WU01:FS00:0xa8:Project: 12412 (Run 72, Clone 8, Gen 0)
23:20:12:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
23:20:12:WU01:FS00:0xa8:Digital signatures verified
23:20:12:WU01:FS00:0xa8:Calling: mdrun -c frame0.gro -s frame0.tpr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 15 -ntmpi 1
23:20:12:WU01:FS00:0xa8:Steps: first=0 total=5000000
23:20:14:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:20:17:WU00:FS01:Assigned to work server 128.174.73.74
23:20:17:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA107M [GeForce RTX 3050 Mobile] from 128.174.73.74
23:20:17:WU00:FS01:Connecting to 128.174.73.74:8080
23:20:18:WU01:FS00:0xa8:Completed 1485901 out of 5000000 steps (29%)
23:20:39:WU00:FS01:Downloading 37.75MiB
23:20:45:WU00:FS01:Download 1.49%
23:20:52:WU00:FS01:Download 2.15%
23:20:58:WU00:FS01:Download 3.15%
23:21:04:WU00:FS01:Download 3.97%
23:21:10:WU00:FS01:Download 4.80%
23:21:12:Removing old file 'configs/config-20230614-091603.xml'
23:21:12:Saving configuration to config.xml
23:21:12:<config>
23:21:12:  <!-- Folding Core -->
23:21:12:  <core-priority v='low'/>
23:21:12:
23:21:12:  <!-- Network -->
23:21:12:  <proxy v=':8080'/>
23:21:12:
23:21:12:  <!-- Slot Control -->
23:21:12:  <pause-on-battery v='false'/>
23:21:12:  <power v='full'/>
23:21:12:
23:21:12:  <!-- User Information -->
23:21:12:  <user v='gckw'/>
23:21:12:
23:21:12:  <!-- Folding Slots -->
23:21:12:  <slot id='0' type='CPU'>
23:21:12:    <cpus v='15'/>
23:21:12:  </slot>
23:21:12:  <slot id='1' type='GPU'>
23:21:12:    <pci-bus v='1'/>
23:21:12:    <pci-slot v='0'/>
23:21:12:  </slot>
23:21:12:</config>
23:21:16:WU00:FS01:Download 5.46%
23:21:22:WU00:FS01:Download 7.12%
23:21:28:WU00:FS01:Download 9.11%
23:21:34:WU00:FS01:Download 10.43%
23:21:40:WU00:FS01:Download 11.42%
23:21:46:WU00:FS01:Download 13.08%
23:21:52:WU00:FS01:Download 14.57%
23:21:59:WU00:FS01:Download 15.40%
23:22:06:WU00:FS01:Download 15.73%
23:22:13:WU00:FS01:Download 16.39%
23:22:19:WU00:FS01:Download 17.22%
23:22:25:WU00:FS01:Download 19.70%
23:22:31:WU00:FS01:Download 22.02%
23:22:37:WU00:FS01:Download 23.01%
23:22:43:WU00:FS01:Download 24.01%
23:22:49:WU00:FS01:Download 25.00%
23:22:58:WU00:FS01:Download 25.50%
23:23:04:WU00:FS01:Download 26.33%
23:23:10:WU00:FS01:Download 30.13%
23:23:16:WU00:FS01:Download 47.02%
23:23:22:WU00:FS01:Download 64.90%
23:23:28:WU00:FS01:Download 77.82%
23:23:34:WU00:FS01:Download 81.79%
23:23:40:WU00:FS01:Download 86.26%
23:23:46:WU00:FS01:Download 98.02%
23:23:46:WU00:FS01:Download complete
23:23:46:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14955 run:0 clone:260 gen:2 core:0x22 unit:0x000001040000000200003a6b00000000
23:23:46:WU00:FS01:Starting
23:23:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 16464 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
23:23:46:WU00:FS01:Started FahCore on PID 15688
23:23:47:WU00:FS01:Core PID:18724
23:23:47:WU00:FS01:FahCore 0x22 started
23:23:47:WU00:FS01:0x22:*********************** Log Started 2023-06-14T23:23:47Z ***********************
23:23:47:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:23:47:WU00:FS01:0x22:       Core: Core22
23:23:47:WU00:FS01:0x22:       Type: 0x22
23:23:47:WU00:FS01:0x22:    Version: 0.0.20
23:23:47:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:23:47:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
23:23:47:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
23:23:47:WU00:FS01:0x22:       Date: Jan 20 2022
23:23:47:WU00:FS01:0x22:       Time: 01:15:36
23:23:47:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:23:47:WU00:FS01:0x22:     Branch: HEAD
23:23:47:WU00:FS01:0x22:   Compiler: Visual C++
23:23:47:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:23:47:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:23:47:WU00:FS01:0x22:   Platform: win32 10
23:23:47:WU00:FS01:0x22:       Bits: 64
23:23:47:WU00:FS01:0x22:       Mode: Release
23:23:47:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:23:47:WU00:FS01:0x22:             <peastman@stanford.edu>
23:23:47:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15688 -checkpoint 15
23:23:47:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
23:23:47:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
23:23:47:WU00:FS01:0x22:************************************ libFAH ************************************
23:23:47:WU00:FS01:0x22:       Time: 01:14:17
23:23:47:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:23:47:WU00:FS01:0x22:************************************ CBang *************************************
23:23:47:WU00:FS01:0x22:       Time: 01:13:20
23:23:47:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:23:47:WU00:FS01:0x22:************************************ System ************************************
23:23:47:WU00:FS01:0x22:        CPU: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
23:23:47:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 141 Stepping 1
23:23:47:WU00:FS01:0x22:       CPUs: 16
23:23:47:WU00:FS01:0x22:     Memory: 31.74GiB
23:23:47:WU00:FS01:0x22:Free Memory: 21.46GiB
23:23:47:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
23:23:47:WU00:FS01:0x22: OS Version: 6.2
23:23:47:WU00:FS01:0x22:Has Battery: true
23:23:47:WU00:FS01:0x22: On Battery: false
23:23:47:WU00:FS01:0x22: UTC Offset: 8
23:23:47:WU00:FS01:0x22:        PID: 18724
23:23:47:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
23:23:47:WU00:FS01:0x22:************************************ OpenMM ************************************
23:23:47:WU00:FS01:0x22:    Version: 7.7.0
23:23:47:WU00:FS01:0x22:********************************************************************************
23:23:47:WU00:FS01:0x22:Project: 14955 (Run 0, Clone 260, Gen 2)
23:23:47:WU00:FS01:0x22:Reading tar file core.xml
23:23:47:WU00:FS01:0x22:Reading tar file integrator.xml
23:23:47:WU00:FS01:0x22:Reading tar file state.xml
23:23:48:WU00:FS01:0x22:Reading tar file system.xml
23:23:52:WU00:FS01:0x22:Digital signatures verified
23:23:52:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:23:52:WU00:FS01:0x22:Version 0.0.20
23:23:52:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
23:23:52:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
23:23:52:WU00:FS01:0x22:  XTC frame write interval: 25000 steps (2.5%) [40 total]
23:23:52:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
23:23:53:WU00:FS01:0x22:There are 4 platforms available.
23:23:53:WU00:FS01:0x22:Platform 0: Reference
23:23:53:WU00:FS01:0x22:Platform 1: CPU
23:23:53:WU00:FS01:0x22:Platform 2: OpenCL
23:23:53:WU00:FS01:0x22:  opencl-device 0 specified
23:23:53:WU00:FS01:0x22:Platform 3: CUDA
23:23:53:WU00:FS01:0x22:  cuda-device 0 specified
23:25:23:WU00:FS01:0x22:Attempting to create CUDA context:
23:25:23:WU00:FS01:0x22:  Configuring platform CUDA
23:25:57:WU00:FS01:0x22:  Using CUDA and gpu 0
23:25:58:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
23:26:04:WU00:FS01:0x22:Checkpoint completed at step 0
23:28:13:WU01:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
23:53:12:WU01:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
00:07:04:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
00:18:10:WU01:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
00:43:49:WU01:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
00:47:55:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
01:05:59:WU01:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
01:27:50:WU01:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
01:28:44:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
I don't know what is wrong. GPU usage in task manager is zero but the WU isn't failing. Any suggestions what to look at? Thanks.
Re: Nvidia 3050 Mobile Not Being Used
Windows Task Manager shows the video processing utilization of your GPU by default. Click on the dropdown menu and change to one of the Compute displays, or if your version of Windows has CUDA listed use that. Or you can use an utility such as GPU-Z.
gckw
Post by gckw »
Thank you for the help!
GPU-Z shows it's at 100% GPU but it's limited by power and thermal. I'll have to do some digging to see why it's power limited when it's only using 12W. And the GPU is showing it's at 50C...210 MHz GPU and 101 MHz memory. I wish I can post the screenshot from GPU-Z to see if I got any settings wrong.
