Radeon HD 5830 AMDSpecies1
victor
Post by victor »
Hello!
Currently running Windows 10 x64 and Beta Client 8.1.18 with the HD 5830 (FP64 and OpenCL 1.2 capable), Catalyst 15.7.1 (the latest supported).
The card seems to be properly recognized and enabled, but no WUs.
I'm wondering if it's the MDSpecies1: TeraScale classification. GPU.txt entry x1002:0x689e:1:1:Cypress LE [Radeon HD 5830].
Any possibility to make it run, maybe change species if possible? I've seen a 5870 get running here: viewtopic.php?t=35029
Thank you.
Log with ::Added new work unit: cpus:0 gpus:gpu:01:00:00
09:24:54:I1::WU30:************************************ System ************************************
09:24:54:I1::WU30: CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
09:24:54:I1::WU30: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
09:24:54:I1::WU30: CPUs: 8
09:24:54:I1::WU30: Memory: 3.96GiB
09:24:54:I1::WU30:Free Memory: 1.46GiB
09:24:54:I1::WU30: Threads: WINDOWS_THREADS
09:24:54:I1::WU30: OS Version: 6.2
09:24:54:I1::WU30:Has Battery: false
09:24:54:I1::WU30: On Battery: false
09:24:54:I1::WU30: UTC Offset: -3
09:24:54:I1::WU30: PID: 1740
09:24:54:I1::WU30: CWD: C:\ProgramData\FAHClient\work
09:24:54:I1::WU30:********************************************************************************
09:24:54:I1::WU30:Project: 19412 (Run 84, Clone 36, Gen 39)
09:24:54:I1::WU30:Unit: 0x00000000000000000000000000000000
09:24:54:I1::WU30:Reading tar file core.xml
09:24:54:I1::WU30:Reading tar file frame39.tpr
09:24:54:I1::WU30:Digital signatures verified
09:24:54:I1::WU30:Calling: mdrun -c frame39.gro -s frame39.tpr -x frame39.xtc -cpt 5 -nt 5 -ntmpi 1
09:24:54:I1::WU30:Steps: first=48750000 total=50000000
09:24:57:I1::WU30:Completed 1 out of 1250000 steps (0%)
09:25:45:I1:OUT45:< vav20.fah.temple.edu:443 HTTP/1.1 200 HTTP_OK
09:25:45:I1::WU29:Credited
09:25:46:I1::Added new work unit: cpus:0 gpus:gpu:01:00:00
09:25:46:I1::WU33:Requesting WU assignment for user Anonymous team 0
09:25:46:I1:OUT46:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
09:25:46:I3:Connecting to assign2.foldingathome.org:443
09:25:47:I1:OUT46:< assign2.foldingathome.org:443 HTTP/1.1 200 HTTP_OK
09:25:47:I1::WU33:Received WU assignment wiJVsAH-fEmXtFZQEd7JbVOL0_heiAuM700QnafQZ3s
09:25:47:I1::WU33:Downloading WU
09:25:48:I1:OUT47:> POST https://fah1.innovatr.ca/api/assign HTTP/1.1
09:25:48:I3:Connecting to fah1.innovatr.ca:443
09:25:49:I1::WU30:WARNING:Console control signal 1 on PID 1740
09:25:49:I1::WU30:Exiting, please wait. . .
09:25:50:I1::WU30:Folding@home Core Shutdown: INTERRUPTED
09:25:51:I1::WU30:Core returned INTERRUPTED (102)
09:26:05:I1:OUT47:< fah1.innovatr.ca:443 HTTP/1.1 200 HTTP_OK
09:26:05:I1::WU33:Received WU
09:26:05:I3::WU30:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx_256-0.0.12/FahCore_a8.exe -dir 02NoOXIHv_WJ2Bs3UWkn2fKshx0ePoi3_ximmF9kJjQ -suffix 01 -version 8.1.18 -lifeline 3820 -np 5
09:26:05:I3::WU30:Started FahCore on PID 7624
Re: Radeon HD 5830 AMDSpecies1
They have dropped all support for the Terascale GPUs being used for folding. They are over a dozen years old, AMD has dropped support, and the current GPU folding core does not work well on the Terascale microarchitecture. That includes not supporting the HD 5870 that you found in a 3 year old topic.
victor
Post by victor »
Joe_H wrote: Fri Jun 02, 2023 4:39 pm Welcome to the folding support forum.
Thank you for the welcome and clarification, @Joe_H. Those cards are very old indeed, I understand. Will keep the folding on the CPU.
Take care and thanks again.
