Clean Mint21.1 PPD, Very Low After Reinstall.
suprleg
Post by suprleg »
Clean Mint21.1 install after installing fah I was getting the error message: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':libOpenCL.so: cannot open shared object file: No such file or directory,however, the cpu and gpu slots were folding away and my PPD appeared to be normal for this setup at +-4mil/day.
In the past when I would get this error installing 'ocl-icd-opencl-dev' would remedy the problem and things were fine.
After installing, 'ocl-icd-opencl-dev', the 'no OpenCL' error did indeed go away and so did my PPD. At this point I'm doing about 700k PPD. My fah key is in place, I've been actively folding forever with no extended inactive periods, and my gpu TPF is normal at 1min,30sec., but currently poor PPD.
While in the process of diagnosing the problem, removing the gpu slot and reinstalling with only the 'client-type=advanced' option added to whatever the defaults are I got the 'gpu slot disabled error' as well Unfortunately I uninstalled the client at that point and reinstalled without capturing the logging of that error.
Perhaps I've never noticed this, but in the 'System Info' portion of the fah log I see the GPU isn't notated, only the CPU which doesn't seem right.
That's pretty much the info I can offer at this point. After reinstalling fah both slots, cpu and gpu, are fold away as normal, for this setup, with very low PPD being generated by the gpu.
Any thoughts are appreciated.
15:07:51:WU00:FS00:0xa8:*********************** Log Started 2023-03-16T15:07:51Z ***********************
15:07:51:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:07:51:WU00:FS00:0xa8:       Core: Gromacs
15:07:51:WU00:FS00:0xa8:       Type: 0xa8
15:07:51:WU00:FS00:0xa8:    Version: 0.0.12
15:07:51:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:07:51:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
15:07:51:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
15:07:51:WU00:FS00:0xa8:       Date: Jan 16 2021
15:07:51:WU00:FS00:0xa8:       Time: 19:23:19
15:07:51:WU00:FS00:0xa8:   Compiler: GNU 8.3.0
15:07:51:WU00:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
15:07:51:WU00:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
15:07:51:WU00:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
15:07:51:WU00:FS00:0xa8:       Bits: 64
15:07:51:WU00:FS00:0xa8:       Mode: Release
15:07:51:WU00:FS00:0xa8:       SIMD: avx_256
15:07:51:WU00:FS00:0xa8:     OpenMP: ON
15:07:51:WU00:FS00:0xa8:       CUDA: OFF
15:07:51:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4196 -checkpoint 15 -np 2
15:07:51:WU00:FS00:0xa8:************************************ libFAH ************************************
15:07:51:WU00:FS00:0xa8:       Time: 19:21:38
15:07:51:WU00:FS00:0xa8:************************************ CBang *************************************
15:07:51:WU00:FS00:0xa8:       Time: 19:21:24
15:07:51:WU00:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
15:07:51:WU00:FS00:0xa8:************************************ System ************************************
15:07:51:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
15:07:51:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:07:51:WU00:FS00:0xa8:       CPUs: 4
15:07:51:WU00:FS00:0xa8:     Memory: 15.57GiB
15:07:51:WU00:FS00:0xa8:Free Memory: 13.10GiB
15:07:51:WU00:FS00:0xa8:    Threads: POSIX_THREADS
15:07:51:WU00:FS00:0xa8: OS Version: 5.15
15:07:51:WU00:FS00:0xa8:Has Battery: false
15:07:51:WU00:FS00:0xa8: On Battery: false
15:07:51:WU00:FS00:0xa8: UTC Offset: -7
15:07:51:WU00:FS00:0xa8:        PID: 4200
15:07:51:WU00:FS00:0xa8:        CWD: /var/lib/fahclient/work
15:07:51:WU00:FS00:0xa8:********************************************************************************
15:07:51:WU00:FS00:0xa8:Project: 16977 (Run 19, Clone 1930, Gen 463)
15:07:51:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:07:51:WU00:FS00:0xa8:Digital signatures verified
15:07:51:WU00:FS00:0xa8:Calling: mdrun -c frame463.gro -s frame463.tpr -x frame463.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
15:07:51:WU00:FS00:0xa8:Steps: first=1157500000 total=1160000000
15:07:51:WU01:FS01:0x22:*********************** Log Started 2023-03-16T15:07:51Z ***********************
15:07:51:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:07:51:WU01:FS01:0x22:       Core: Core22
15:07:51:WU01:FS01:0x22:       Type: 0x22
15:07:51:WU01:FS01:0x22:    Version: 0.0.20
15:07:51:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:07:51:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
15:07:51:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
15:07:51:WU01:FS01:0x22:       Date: Jan 20 2022
15:07:51:WU01:FS01:0x22:       Time: 00:57:52
15:07:51:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:07:51:WU01:FS01:0x22:     Branch: HEAD
15:07:51:WU01:FS01:0x22:   Compiler: GNU 9.4.0
15:07:51:WU01:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
15:07:51:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
15:07:51:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
15:07:51:WU01:FS01:0x22:   Platform: linux 5.11.0-1025-azure
15:07:51:WU01:FS01:0x22:       Bits: 64
15:07:51:WU01:FS01:0x22:       Mode: Release
15:07:51:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:07:51:WU01:FS01:0x22:             <peastman@stanford.edu>
15:07:51:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4204 -checkpoint 15
15:07:51:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:07:51:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
15:07:51:WU01:FS01:0x22:************************************ libFAH ************************************
15:07:51:WU01:FS01:0x22:       Time: 00:57:22
15:07:51:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:07:51:WU01:FS01:0x22:************************************ CBang *************************************
15:07:51:WU01:FS01:0x22:       Time: 00:57:00
15:07:51:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:07:51:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
15:07:51:WU01:FS01:0x22:************************************ System ************************************
15:07:51:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
15:07:51:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:07:51:WU01:FS01:0x22:       CPUs: 4
15:07:51:WU01:FS01:0x22:     Memory: 15.57GiB
15:07:51:WU01:FS01:0x22:Free Memory: 13.10GiB
15:07:51:WU01:FS01:0x22:    Threads: POSIX_THREADS
15:07:51:WU01:FS01:0x22: OS Version: 5.15
15:07:51:WU01:FS01:0x22:Has Battery: false
15:07:51:WU01:FS01:0x22: On Battery: false
15:07:51:WU01:FS01:0x22: UTC Offset: -7
15:07:51:WU01:FS01:0x22:        PID: 4208
15:07:51:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
15:07:51:WU01:FS01:0x22:************************************ OpenMM ************************************
15:07:51:WU01:FS01:0x22:    Version: 7.7.0
15:07:51:WU01:FS01:0x22:********************************************************************************
15:07:51:WU01:FS01:0x22:Project: 18213 (Run 30785, Clone 1, Gen 30)
15:07:51:WU01:FS01:0x22:Digital signatures verified
15:07:51:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:07:51:WU01:FS01:0x22:Version 0.0.20
15:07:51:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
15:07:51:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
15:07:51:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
15:07:51:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
15:07:51:WU01:FS01:0x22:There are 4 platforms available.
15:07:51:WU01:FS01:0x22:Platform 0: Reference
15:07:51:WU01:FS01:0x22:Platform 1: CPU
15:07:51:WU01:FS01:0x22:Platform 2: OpenCL
15:07:51:WU01:FS01:0x22:  opencl-device 0 specified
15:07:51:WU01:FS01:0x22:Platform 3: CUDA
15:07:51:WU01:FS01:0x22:  cuda-device 0 specified
15:07:52:WU00:FS00:0xa8:Completed 288702 out of 2500000 steps (11%)
15:08:00:WU01:FS01:0x22:Attempting to create CUDA context:
15:08:00:WU01:FS01:0x22:  Configuring platform CUDA
15:08:06:WU01:FS01:0x22:  Using CUDA and gpu 0
15:08:06:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
15:08:35:Removing old file 'configs/config-20230316-144607.xml'
15:08:35:Saving configuration to /etc/fahclient/config.xml
15:08:35:<config>
15:08:35:  <!-- Client Control -->
15:08:35:  <fold-anon v='true'/>
15:08:35:
15:08:35:  <!-- Folding Slot Configuration -->
15:08:35:  <client-type v='advanced'/>
15:08:35:  <gpu v='false'/>
15:08:35:
15:08:35:  <!-- Network -->
15:08:35:  <proxy v=':8080'/>
15:08:35:
15:08:35:  <!-- User Information -->
15:08:35:  <passkey v='*****'/>
15:08:35:  <team v='4'/>
15:08:35:  <user v='suprleg'/>
15:08:35:
15:08:35:  <!-- Folding Slots -->
15:08:35:  <slot id='0' type='CPU'/>
15:08:35:  <slot id='1' type='GPU'>
15:08:35:    <pci-bus v='1'/>
15:08:35:    <pci-slot v='0'/>
15:08:35:  </slot>
15:08:35:</config>
15:09:37:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
15:11:06:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
15:11:08:WU01:FS01:0x22:Checkpoint completed at step 175000
15:11:23:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
15:12:38:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
15:14:08:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
15:14:09:WU01:FS01:0x22:Checkpoint completed at step 200000
15:15:40:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
15:17:10:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
15:17:11:WU01:FS01:0x22:Checkpoint completed at step 225000
:~$ inxi -Fxxxrz
System:
  Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
    Desktop: Cinnamon 5.6.8 tk: GTK 3.24.33 wm: muffin vt: 7 dm: LightDM 1.30.0
    Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Machine:
  Type: Desktop Mobo: MSI model: Z77A-G45 (MS-7752) v: 1.0
    serial: <superuser required> BIOS: American Megatrends v: 2.12
    date: 09/29/2013
CPU:
  Info: quad core model: Intel Core i5-3450 bits: 64 type: MCP
    smt: <unsupported> arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB
    L3: 6 MiB
  Speed (MHz): avg: 1952 high: 2272 min/max: 1600/3500 cores: 1: 1641
    2: 2272 3: 2059 4: 1836 bogomips: 24801
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 525.85.05 pcie: speed: 2.5 GT/s lanes: 16 ports:
    active: none off: HDMI-A-2 empty: DP-1, DP-2, DP-3, HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
    s-diag: 610mm (24")
  Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
  OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 525.85.05 direct render: Yes
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 1.6 TiB used: 17.42 GiB (1.1%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: MBR
  ID-2: /dev/sdb vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
  ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-00BN5A0
    size: 931.51 GiB speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: MBR
Partition:
  ID-1: / size: 457.38 GiB used: 17.42 GiB (3.8%) fs: ext4 dev: /dev/sdb1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
Sensors:
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Repos:
  Packages: apt: 2269
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb http://packages.linuxmint.com vera main upstream import backport
    2: deb http://archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
    3: deb http://archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
    4: deb http://archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
    5: deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Info:
  Processes: 239 Uptime: 9h 52m wakeups: 0 Memory: 15.57 GiB
  used: 2.34 GiB (15.0%) Init: systemd v: 249 runlevel: 5 Compilers:
  gcc: 11.3.0 alt: 11/12 Shell: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.13
Re: Clean Mint21.1 PPD, Very Low After Reinstall.
Using the F@h Bonus points calculator - http://www.linuxforge.net/bonuscalc2.php - from the two data points from your log on the progress of your GPU WU gives a PPD of about 1.4M. If your client is showing a lower number that is from the fresh install. The client maintains a database of information on projects it has worked on to improve initial estimates of ETAs and PPD. Otherwise it takes completing several percent of a WU before the estimates will be accurate. Before then the estimates are based on the timeout values connected to the WU and its project.
suprleg
Post by suprleg »
You are spot on, Sir. Things have already begun to improve. Looks like I got little too nervous. Thanks :oops:
