How to make both CPU and GPU work on the same work unit?
vahid.rakhshan
Post by vahid.rakhshan »
Is it possible to set the client to use both my CPU and GPU to process the same work unit? If different cores of a CPU can be altogether assigned the same work unit, I think it will be possible to also add the GPU to the whole complex and use them all for processing one work unit at a time. But I could not find a way to do that. Perhaps this might be done by configuring client folding slots in the Advanced Control? :?:
I am asking this because my GPU work units keep expiring unfinished (at percentages below 10%). So all its processing power is going to waste. It would be much better if my GPU could help the CPU, instead of working on a separate work unit that keeps expiring.
Re: How to make both CPU and GPU work on the same work unit?
Using the current folding cores this is not possible. A future folding core might support this, but balancing the resources which are different between CPU and GPU will not be easy.
Until this possibility eventually appears, it would be better to disable your GPU slot.
vahid.rakhshan
Disabled it, thanks. Hope this feature gets implemented in the future.
vahid.rakhshan
I keep removing the GPU slot; but every time I close the core and re-open it (for example, after each computer restart), the GPU slot is back there and active! Is there a way to remove it permanently?
Post by calxalot »
In FAHControl > Configure > Expert > Extra client options, add
gpu false
vahid.rakhshan
calxalot wrote: Mon Feb 13, 2023 9:23 am In FAHControl > Configure > Expert > Extra client options, add gpu false
Thanks. Can you give me a link to a page with a list of all the Expert options?
Post by calxalot »
I don't have a link. Someone else might.
Interesting options include
next-unit-percentage 100
pause-on-start true
You can see tons of options with
FAHClient --help
But most options are actually internal things you should NOT change.
vahid.rakhshan
calxalot wrote: Mon Feb 13, 2023 10:39 am I don't have a link. Someone else might.
pause-on-start true
FAHClient --help
Many thanks for the nice info. For future reference, I am copying them below:
OPTIONS:
  --chdir <string>
      Change directory before starting server. All files opened after this
      point, such as the configuration file, must have paths relative to the new
      directory.
  --configure
      Create a basic configuration file, then exit.
  --dump <string>
      Dump either 'all' or a specific work unit, identified by its queue ID,
      then exit.
  --finish
      Finish all current work units, send the results, then exit.
  --install-service
      Install the application as a Win32 service then exit.
  --lspci
      List the PCI bus devices, which can be helpful for finding GPU vendor and
      device IDs.
  --queue-info
      Print work unit queue then exit.
  --send
      Send all finished work units, then exit.
  --send-command <string>
      Send a command to an already running client.
  --send-finish [string]
      Finish a slot or all slots on an already running client.
  --send-pause [string]
      Pause a slot or all slots on an already running client.
  --send-unpause [string]
      Unpause a slot or all slots on an already running client.
  --start-service
      Start Win32 service then exit.
  --stop-service
      Stop Win32 service then exit.
  --uninstall-service
      Uninstall the application as a Win32 service then exit.
Configuration:
  --config <string=config.xml>
      Set configuration file.
  --print
      Print configuration and exit.
Informational:
  --help [string]
      Print help screen or help on a particular option and exit.
  --html-help
      Print help in HTML format and exit.
  --info
      Print application and system information and exit.
  --license
      License information and exit.
  -q|--quiet
      Set verbosity to zero.
  -v|--verbose
      Increase verbosity level.
  --version
      Print application version and exit.
Configuration options:
The following options can be specified in a configuration file or on the command
line using the following syntax:
    --<option> <value>
  or:
    --<option>=<value>
  or when marking boolean values true:
    --<option>
Client Control:
  client-threads <integer=6>
    The number of client processing threads.
  cycle-rate <double=4>
    The maximum cycle frequency in Hz of client threads.
  cycles <integer=-1>
    Run at most this many cycles. A value less than zero means run indefinitely.
  disable-sleep-when-active <boolean=true>
    Attempt to keep the system from sleeping when folding, unless on battery.
  exit-when-done <boolean=false>
    Exit when all slots are paused.
  fold-anon <boolean=false>
    Start folding even if not configured.
  open-web-control <boolean=false>
    Make an operating system specific call to open the Web Control in a browser
    once client is fully loaded
Configuration:
  config-rotate <boolean=true>
    Rotate the configuration file to a backup when saving would overwrite the
    previous configuration.
  config-rotate-dir <string=configs>
    Put rotated configs in this directory.
  config-rotate-max <integer=16>
    The maximum number of rotated configuration files to keep. A value of zero
    will keep all configuration file backups.
Error Handling:
  max-slot-errors <integer=10>
    The maximum number of errors before a slot is paused.
  max-unit-errors <integer=5>
    The maximum number of errors before a work unit is dumped.
Folding Core:
  checkpoint <integer=15>
    Tell cores to checkpoint at least every # minutes.
  core-priority <string=idle>
    Set the core priority. Valid values are: idle or low
  cpu-usage <integer=100>
    The maximum percentage of the CPU a core should use. Not implemented by all
    cores.
  gpu-usage <integer=100>
    GPU usage as a percent from 10-100
  no-assembly <boolean=false>
    Tell cores to disable optimized assembly code.
Folding Slot Configuration:
  cause <string=ANY>
    The cause you prefer to support.
  client-subtype <string=STDCLI>
    The client subtype
  client-type <string=normal>
    The client type. Can be 'normal', 'advanced' or 'beta'.
  cpu-species <string=X86_PENTIUM_II>
    CPU species.
  cpu-type <string=AMD64>
    CPU type.
  cpus <integer=-1>
    How many CPUs a slot should use. <= 0 will use all the CPUs detected in the
    system.
  cuda-index <integer>
    CUDA device index
  disable-viz <boolean=false>
    Disable reading visualization data.
  extra-core-args <string>
    Pass extra arguments to the core.
  gpu <boolean=true>
    Enable or disable auto-confiugration of GPU slots, requires appropriate
    hardware.
  gpu-beta <boolean=false>
    Enable beta GPUs
  gpu-index <string>
    The index of the GPU in the order detected by the operating system.
  max-packet-size <string=normal>
    Max size in bytes of a work unit packet. Can be small=5MiB, normal=25MiB,
    big=500MiB or a number.
  memory <string>
    Override memory, in bytes, reported to Folding@home.
  opencl-index <integer>
    OpenCL device index
  os-species <string=WIN_8>
    Operating system species.
  os-type <string=WIN32>
    Operating system type.
  pci-bus <string>
    The GPUs PCI bus ID.
  pci-slot <string>
    The GPUs PCI slot ID.
  project-key <integer=0>
    Key for access to restricted testing projects.
  smp <boolean=true>
    Enable or disable auto-configuration of SMP slots, requires appropriate
    hardware.
GUI:
  gui-enabled <boolean=true>
    Set to false to disable the GUI. A GUI is not currently supported on all
    operating systems.
HTTP Server:
  allow <string=127.0.0.1>
    Client addresses which are allowed to connect to this server. This option
    overrides IPs which are denied in the deny option. The pattern 0/0 matches
    all addresses.
  connection-timeout <integer=60>
    The maximum amount of time, in seconds, a connection can be idle before
    being dropped.
  deny <string=0/0>
    Client address which are not allowed to connect to this server.
  http-addresses <string=0:7396>
    A space separated list of server address and port pairs to listen on in the
    form <ip | hostname>[:<port>]
  https-addresses <string=>
    A space separated list of secure server address and port pairs to listen on
    in the form <ip | hostname>[:<port>]
  max-connect-time <integer=900>
    The maximum amount of time, in seconds, a client can be connected to the
    server.
  max-connections <integer=800>
    Sets the maximum number of simultaneous connections.
  max-request-length <integer=52428800>
    Sets the maximum length of a client request packet.
  min-connect-time <integer=300>
    The minimum amount of time, in seconds, a client must be connected to the
    server before it can be dropped in favor or a new connection.
HTTP Server SSL:
  certificate-file <string>
    The servers certificate file in PEM format.
  crl-file <string>
    Supply a Certificate Revocation List. Overrides any internal CRL
  private-key-file <string>
    The servers private key file in PEM format.
Logging:
  log <string=log.txt>
    Set log file.
  log-color <boolean=false>
    Print log messages with ANSI color coding.
  log-crlf <boolean=true>
    Print carriage return and line feed at end of log lines.
  log-date <boolean=false>
    Print date information with log entries.
  log-date-periodically <integer=21600>
    Print date to log before new log entries if so many seconds have passed
    since the last date was printed.
  log-domain <boolean=false>
    Print domain information with log entries.
  log-domain-levels <string ...>
    Set log levels by domain. Format is:
      <domain>[:i|d|t]:<level> ...
    Entries are separated by white-space and or commas.
      i - info
    For example: server:i:3 module:6
    Set 'server' domain info messages to level 3 and 'module' info messages to
    level 6. All other domains will follow the system wide log verbosity level.
    If <level> is negative it is relative to the system wide verbosity.
  log-header <boolean=true>
    Enable log message headers.
  log-level <boolean=true>
    Print level information with log entries.
  log-no-info-header <boolean=true>
    Don't print 'INFO(#):' in header.
  log-redirect <boolean=false>
    Redirect all output to log file. Implies !log-to-screen.
  log-rotate <boolean=true>
    Rotate log files on each run.
  log-rotate-dir <string=logs>
    Put rotated logs in this directory.
  log-rotate-max <integer=16>
    Maximum number of rotated logs to keep.
  log-short-level <boolean=false>
    Print shortened level information with log entries.
  log-simple-domains <boolean=true>
    Remove any leading directories and trailing file extensions from domains so
    that source code file names can be easily used as log domains.
  log-thread-id <boolean=false>
    Print id with log entries.
  log-thread-prefix <boolean=true>
    Print thread prefixes, if set, with log entries.
  log-time <boolean=true>
    Print time information with log entries.
  log-to-screen <boolean=true>
    Log to screen.
  log-truncate <boolean=false>
    Truncate log file.
  verbosity <integer=3>
    Set logging level for INFO messages.
Network:
  proxy <string=>
    Set proxy for outgoing HTTP connections
  proxy-enable <boolean=false>
    Enable proxy configuration
  proxy-pass <string=>
    Set password for proxy connections
  proxy-user <string=>
    Set user name for proxy connections
Process Control:
  child <boolean=false>
    Disable 'daemon', 'fork', 'pid' and 'respawn' options. Also defaults
    'log-to-screen' to false. Used internally.
  daemon <boolean=false>
    Short for --pid --service --respawn --log=''
  pid <boolean=false>
    Create PID file.
  pid-file <string=FAHClient.pid>
    Name of PID file.
  priority <string>
    Set the process priority. Valid values are: idle, low, normal, high or
    realtime.
  respawn <boolean=false>
    Run the application as a child process and respawn if it is killed or exits.
  service <boolean=false>
    Ignore user logout or hangup and interrupt signals
Remote Command Server:
  command-address <string=0.0.0.0>
    The address to which the command server should be bound.
  command-allow-no-pass <string=127.0.0.1>
    IP address ranges that are allowed access to the command server with out a
    password if the 'password' option is set. These addresses will also have to
    be allowed IP based access.
  command-deny-no-pass <string=0/0>
    IP address ranges that are not allowed access to the command server with out
    a password if the 'password' option is set. Overridden by
  command-enable <boolean=true>
    Set to false to disable the command server.
  command-port <integer=36330>
    The port to which the command server should be bound.
  password <string>
    Set a command server password. Warning, setting a password disables the
    default IP address blocking.
Slot Control:
  auto-conf <boolean=true>
    Enable/disable auto configuration of folding slots.
  idle <boolean=false>
    Only run slot when idle.
  max-shutdown-wait <integer=60>
    The maximum amount of time to wait in seconds for a unit to exit on
    shutdown.
  pause-on-battery <boolean=true>
    Pause the client or slot when the OS indicates the machine is running on
    battery power.
  pause-on-start <boolean=false>
    If true the slot will be started in a paused state.
  paused <boolean=false>
    True if slot is paused.
  power <string=light>
    Set the client's power level. Valid values are 'light', 'medium' or 'full'.
    This setting affects the defaults of several other options such as 'cpus',
    'pause-on-battery', etc.
User Information:
  machine-id <integer=0>
    The machine ID.
  passkey <string=>
    Your passkey.
  team <integer=0>
    Your team number.
  user <string=Anonymous>
    Your user name.
Web Server:
  web-allow <string=127.0.0.1>
    Client addresses which are allowed to connect to this Web server. This
    option overrides IPs which are denied in the web-deny option. This option
    differs from the 'allow'/'deny' options in that clients that are not allowed
    are served an access denied page rather than simply dropping the connection.
    The value '0/0' matches all IPs.
  web-deny <string=0/0>
    Client address which are not allowed to connect to this Web server.
  web-enable <boolean=true>
    Set to false to disable the web server.
Web Server Sessions:
  session-cookie <string=sid>
    The name of the session cookie.
  session-lifetime <integer=86400>
    The maximum session lifetime in seconds. Zero for unlimited session
    lifetime.
  session-timeout <integer=3600>
    The max maximum amount of time in seconds since the last time a session was
    used before it timesout. Zero for no session timeout.
Windows Service:
  service-description <string=FAHClient>
    The description for the Windows service control manager.
  service-restart <boolean=true>
    Configure Windows service to automatically restart on failure.
  service-restart-delay <integer=5000>
    The amount of time in milliseconds to delay between restarts of the Windows
    service.
Work Unit Control:
  dump-after-deadline <boolean=true>
    Dump units if their deadline has passed.
  max-queue <integer=16>
    Maximum units per slot in the work queue.
  max-units <integer=0>
    Process at most this number of units, then pause.
  next-unit-percentage <integer=99>
    Pre-download the next work unit when the current one is this far along.
    Values less than 90 are not allowed.
  stall-detection-enabled <boolean=false>
    Attempt to detect stalled work units and restart them.
  stall-percent <integer=5>
    Minimum estimated percent work unit completion since last frame before a WU
    can be considered stalled, if zero the percentage is ignored.
  stall-timeout <integer=1800>
    Minimum time, in seconds, since last frame before a WU can be considered
    stalled.
Reason: added code tags to scroll list of options
