WU 1737 - unstable?
marknu1
WU 1737 - unstable?
Post by marknu1 »
Hi all,
My machine is an Intel Quad 9450 with an ATI HD3870, running Vista Ultimate 32-bit. I've been folding away for the last month and half with almost no problems. I found I get a higher PPD using the GPU2 client on the 3870, and the 6.10beta3 console on 3 cores(leaving one available for the GPU client). All was going well -- my console clients were chugging away on mostly 458* and 459* WU's without issue. Yesterday my consoles received two 1737's and a 1736...and the crashing started. I pulled the GPU out of the mix, and got the same behavior. I pulled the 1736 out, and still crashed. Perhaps 1737 is not quite ready for prime time? I can't seem to find any information about it, or 1736, for that matter. Is there a way for me to 'ban' (for lack of a better word) certain WU's from my clients? As you can see, I'm brand new to this forum. SO, if there's anything I missed please let me know what I need to provide. Thanks for any help.
Re: WU 1737 - unstable?
Please post your logs ...
Is your Q9450 overclocked :?:
marknu1
Post by marknu1 »
Here's one of the 1737 logs (from the point where it begins to work on the 1737) - the other one looks basically the same. You'll see an intentional shutdown or two, but the abrupt stops are the crashes. Also, yes, the 9450 is OC'd. BUT, I can tell you that it will run the Prime95 blend stress test 'forever' without crashing - I mean, well over 24 hours, and I shut it down manually. So I don't think there is a stability issue. Also, like I mentioned, it was running the 458*'s and 459*'s with the GPU for days on end, with no issues.
--- Opening Log file [July 11 02:22:12]
# Windows Console Edition #####################################################
                       Folding@Home Client Version 6.10beta3
                          http://folding.stanford.edu
Launch directory: D:\F@H6\m3
Executable: fah6-win32-x86.exe
[02:22:12] - Ask before connecting: No
[02:22:12] - User name: marknu1 (Team 13285)
[02:22:12] - User ID: 256450BF79A37049
[02:22:12] - Machine ID: 3
[02:22:12]
[02:22:12] Loaded queue successfully.
[02:22:12] - Preparing to get new work unit...
[02:22:12] + Attempting to get work packet
[02:22:12] - Connecting to assignment server
[02:22:24] + Could not connect to Assignment Server
[02:22:36] + Could not connect to Assignment Server 2
[02:22:36] + Couldn't get work instructions.
[02:22:36] - Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[02:22:45] + Attempting to get work packet
[02:22:45] - Connecting to assignment server
[02:22:46] + No appropriate work server was available; will try again in a bit.
[02:22:46] + Couldn't get work instructions.
[02:22:46] - Attempt #2  to get work failed, and no other work to do.
[02:23:04] + Attempting to get work packet
[02:23:04] - Connecting to assignment server
[02:23:04] - Successful: assigned to (134.139.127.31).
[02:23:04] + News From Folding@Home: Welcome to Folding@Home
[02:23:05] Loaded queue successfully.
[02:23:06] + Closed connections
[02:23:06]
[02:23:06] + Processing work unit
[02:23:06] Core required: FahCore_78.exe
[02:23:06] Core not found.
[02:23:06] - Core is not present or corrupted.
[02:23:06] - Attempting to download new core...
[02:23:06] + Downloading new core: FahCore_78.exe
[02:23:06] + 10240 bytes downloaded
[02:23:06] + 20480 bytes downloaded
[02:23:06] + 30720 bytes downloaded
[02:23:06] + 40960 bytes downloaded
[02:23:06] + 51200 bytes downloaded
[02:23:06] + 61440 bytes downloaded
[02:23:06] + 71680 bytes downloaded
[02:23:06] + 81920 bytes downloaded
[02:23:06] + 92160 bytes downloaded
[02:23:06] + 102400 bytes downloaded
[02:23:06] + 112640 bytes downloaded
[02:23:06] + 122880 bytes downloaded
[02:23:06] + 133120 bytes downloaded
[02:23:06] + 143360 bytes downloaded
[02:23:06] + 153600 bytes downloaded
[02:23:06] + 163840 bytes downloaded
[02:23:06] + 174080 bytes downloaded
[02:23:06] + 184320 bytes downloaded
[02:23:06] + 194560 bytes downloaded
[02:23:06] + 204800 bytes downloaded
[02:23:06] + 215040 bytes downloaded
[02:23:06] + 225280 bytes downloaded
[02:23:06] + 235520 bytes downloaded
[02:23:06] + 245760 bytes downloaded
[02:23:06] + 256000 bytes downloaded
[02:23:06] + 266240 bytes downloaded
[02:23:06] + 276480 bytes downloaded
[02:23:06] + 286720 bytes downloaded
[02:23:06] + 296960 bytes downloaded
[02:23:06] + 307200 bytes downloaded
[02:23:07] + 317440 bytes downloaded
[02:23:07] + 327680 bytes downloaded
[02:23:07] + 337920 bytes downloaded
[02:23:07] + 348160 bytes downloaded
[02:23:07] + 358400 bytes downloaded
[02:23:07] + 368640 bytes downloaded
[02:23:07] + 378880 bytes downloaded
[02:23:07] + 389120 bytes downloaded
[02:23:07] + 399360 bytes downloaded
[02:23:07] + 409600 bytes downloaded
[02:23:07] + 419840 bytes downloaded
[02:23:07] + 430080 bytes downloaded
[02:23:07] + 440320 bytes downloaded
[02:23:07] + 450560 bytes downloaded
[02:23:07] + 460800 bytes downloaded
[02:23:07] + 471040 bytes downloaded
[02:23:07] + 481280 bytes downloaded
[02:23:07] + 491520 bytes downloaded
[02:23:07] + 501760 bytes downloaded
[02:23:07] + 512000 bytes downloaded
[02:23:07] + 522240 bytes downloaded
[02:23:07] + 532480 bytes downloaded
[02:23:07] + 542720 bytes downloaded
[02:23:07] + 552960 bytes downloaded
[02:23:07] + 563200 bytes downloaded
[02:23:07] + 573440 bytes downloaded
[02:23:07] + 583680 bytes downloaded
[02:23:07] + 593920 bytes downloaded
[02:23:07] + 604160 bytes downloaded
[02:23:07] + 614400 bytes downloaded
[02:23:07] + 624640 bytes downloaded
[02:23:07] + 634880 bytes downloaded
[02:23:07] + 645120 bytes downloaded
[02:23:07] + 655360 bytes downloaded
[02:23:07] + 665600 bytes downloaded
[02:23:07] + 675840 bytes downloaded
[02:23:07] + 686080 bytes downloaded
[02:23:07] + 696320 bytes downloaded
[02:23:07] + 706560 bytes downloaded
[02:23:07] + 716800 bytes downloaded
[02:23:07] + 727040 bytes downloaded
[02:23:07] + 737280 bytes downloaded
[02:23:07] + 747520 bytes downloaded
[02:23:07] + 757760 bytes downloaded
[02:23:07] + 768000 bytes downloaded
[02:23:07] + 778240 bytes downloaded
[02:23:07] + 788480 bytes downloaded
[02:23:07] + 798720 bytes downloaded
[02:23:07] + 808960 bytes downloaded
[02:23:07] + 819200 bytes downloaded
[02:23:07] + 825633 bytes downloaded
[02:23:07] Verifying core Core_78.fah...
[02:23:07] Signature is VALID
[02:23:07]
[02:23:07] Trying to unzip core FahCore_78.exe
[02:23:07] Decompressed FahCore_78.exe (2338816 bytes) successfully
[02:23:07] + Core successfully engaged
[02:23:12]
[02:23:12] + Processing work unit
[02:23:12] Core required: FahCore_78.exe
[02:23:12] Core found.
[02:23:12] Working on Unit 09 [July 11 02:23:12]
[02:23:12] + Working ...
[02:23:12]
[02:23:12] *------------------------------*
[02:23:12] Folding@Home Gromacs Core
[02:23:12] Version 1.90 (March 8, 2006)
[02:23:12]
[02:23:12] Preparing to commence simulation
[02:23:12] - Looking at optimizations...
[02:23:12] - Created dyn
[02:23:12] - Files status OK
[02:23:12] - Expanded 167787 -> 954189 (decompressed 568.6 percent)
[02:23:12] - Starting from initial work packet
[02:23:12]
[02:23:12] Project: 1737 (Run 0, Clone 17, Gen 0)
[02:23:12]
[02:23:12] Assembly optimizations on if available.
[02:23:12] Entering M.D.
[02:23:19] Protein: p1737_unf_305_SB
[02:23:19]
[02:23:19] Writing local files
[02:23:19] Extra SSE boost OK.
[02:23:19] Completed 0 out of 2500000 steps  (0%)
[02:26:56] Writing local files
[02:26:56] Completed 25000 out of 2500000 steps  (1%)
[02:30:38] Writing local files
[02:30:38] Completed 50000 out of 2500000 steps  (2%)
[02:34:29] Writing local files
[02:34:29] Completed 75000 out of 2500000 steps  (3%)
[02:38:13] Writing local files
[02:38:13] Completed 100000 out of 2500000 steps  (4%)
[02:42:07] Writing local files
[02:42:07] Completed 125000 out of 2500000 steps  (5%)
[02:46:02] Writing local files
[02:46:02] Completed 150000 out of 2500000 steps  (6%)
[02:49:29] Writing local files
[02:49:29] Completed 175000 out of 2500000 steps  (7%)
[02:53:26] Writing local files
[02:53:26] Completed 200000 out of 2500000 steps  (8%)
[02:57:26] Writing local files
[02:57:26] Completed 225000 out of 2500000 steps  (9%)
[03:01:45] Writing local files
[03:01:45] Completed 250000 out of 2500000 steps  (10%)
[03:05:38] Writing local files
[03:05:38] Completed 275000 out of 2500000 steps  (11%)
[03:09:08] Writing local files
[03:09:08] Completed 300000 out of 2500000 steps  (12%)
[03:12:55] Writing local files
[03:12:55] Completed 325000 out of 2500000 steps  (13%)
[03:16:39] Writing local files
[03:16:39] Completed 350000 out of 2500000 steps  (14%)
[03:20:23] Writing local files
[03:20:23] Completed 375000 out of 2500000 steps  (15%)
[03:24:12] Writing local files
[03:24:12] Completed 400000 out of 2500000 steps  (16%)
[03:28:01] Writing local files
[03:28:01] Completed 425000 out of 2500000 steps  (17%)
--- Opening Log file [July 11 03:58:01]
[03:58:01] - Ask before connecting: No
[03:58:01] - User name: marknu1 (Team 13285)
[03:58:01] - User ID: 256450BF79A37049
[03:58:01] - Machine ID: 3
[03:58:01]
[03:58:01] Loaded queue successfully.
[03:58:01]
[03:58:01] + Processing work unit
[03:58:01] Core required: FahCore_78.exe
[03:58:01] Core found.
[03:58:01] Working on Unit 09 [July 11 03:58:01]
[03:58:01] + Working ...
[03:58:01]
[03:58:01] *------------------------------*
[03:58:01] Folding@Home Gromacs Core
[03:58:01] Version 1.90 (March 8, 2006)
[03:58:01]
[03:58:01] Preparing to commence simulation
[03:58:01] - Ensuring status. Please wait.
[03:58:18] - Looking at optimizations...
[03:58:18] - Working with standard loops on this execution.
[03:58:18] - Previous termination of core was improper.
[03:58:18] - Files status OK
[03:58:18] - Expanded 167787 -> 954189 (decompressed 568.6 percent)
[03:58:19]
[03:58:19] Project: 1737 (Run 0, Clone 17, Gen 0)
[03:58:19]
[03:58:19] Entering M.D.
[03:58:39] (Starting from checkpoint)
[03:58:39] Protein: p1737_unf_305_SB
[03:58:39]
[03:58:39] Writing local files
[03:58:39] Completed 425000 out of 2500000 steps  (17%)
Folding@Home Client Shutdown.
--- Opening Log file [July 11 04:08:22]
[04:08:22] - Ask before connecting: No
[04:08:22] - User name: marknu1 (Team 13285)
[04:08:22] - User ID: 256450BF79A37049
[04:08:22] - Machine ID: 3
[04:08:22]
[04:08:22] Loaded queue successfully.
[04:08:22]
[04:08:22] + Processing work unit
[04:08:22] Core required: FahCore_78.exe
[04:08:22] Core found.
[04:08:22] Working on Unit 09 [July 11 04:08:22]
[04:08:22] + Working ...
[04:08:22]
[04:08:22] *------------------------------*
[04:08:22] Folding@Home Gromacs Core
[04:08:22] Version 1.90 (March 8, 2006)
[04:08:22]
[04:08:22] Preparing to commence simulation
[04:08:22] - Looking at optimizations...
[04:08:22] - Files status OK
[04:08:22] - Expanded 167787 -> 954189 (decompressed 568.6 percent)
[04:08:23]
[04:08:23] Project: 1737 (Run 0, Clone 17, Gen 0)
[04:08:23]
[04:08:23] Assembly optimizations on if available.
[04:08:23] Entering M.D.
[04:08:43] (Starting from checkpoint)
[04:08:43] Protein: p1737_unf_305_SB
[04:08:43]
[04:08:43] Writing local files
[04:08:43] Completed 425000 out of 2500000 steps  (17%)
[04:08:43] Extra SSE boost OK.
[04:12:43] Writing local files
[04:12:43] Completed 450000 out of 2500000 steps  (18%)
[04:16:43] Writing local files
[04:16:43] Completed 475000 out of 2500000 steps  (19%)
[04:20:43] Writing local files
[04:20:43] Completed 500000 out of 2500000 steps  (20%)
[04:24:48] Writing local files
[04:24:48] Completed 525000 out of 2500000 steps  (21%)
[04:28:52] Writing local files
[04:28:52] Completed 550000 out of 2500000 steps  (22%)
[04:32:55] Writing local files
[04:32:55] Completed 575000 out of 2500000 steps  (23%)
[04:36:54] Writing local files
[04:36:54] Completed 600000 out of 2500000 steps  (24%)
[04:40:56] Writing local files
[04:40:56] Completed 625000 out of 2500000 steps  (25%)
[04:44:59] Writing local files
[04:44:59] Completed 650000 out of 2500000 steps  (26%)
[04:49:01] Writing local files
[04:49:01] Completed 675000 out of 2500000 steps  (27%)
[04:53:04] Writing local files
[04:53:04] Completed 700000 out of 2500000 steps  (28%)
[04:57:10] Writing local files
[04:57:10] Completed 725000 out of 2500000 steps  (29%)
[05:01:15] Writing local files
[05:01:15] Completed 750000 out of 2500000 steps  (30%)
[05:05:20] Writing local files
[05:05:20] Completed 775000 out of 2500000 steps  (31%)
[05:09:27] Writing local files
[05:09:27] Completed 800000 out of 2500000 steps  (32%)
--- Opening Log file [July 11 05:29:48]
[05:29:48] - Ask before connecting: No
[05:29:48] - User name: marknu1 (Team 13285)
[05:29:48] - User ID: 256450BF79A37049
[05:29:48] - Machine ID: 3
[05:29:48]
[05:29:48] Loaded queue successfully.
[05:29:48]
[05:29:48] + Processing work unit
[05:29:48] Core required: FahCore_78.exe
[05:29:48] Core found.
[05:29:48] Working on Unit 09 [July 11 05:29:48]
[05:29:48] + Working ...
[05:29:49]
[05:29:49] *------------------------------*
[05:29:49] Folding@Home Gromacs Core
[05:29:49] Version 1.90 (March 8, 2006)
[05:29:49]
[05:29:49] Preparing to commence simulation
[05:29:49] - Ensuring status. Please wait.
[05:30:06] - Looking at optimizations...
[05:30:06] - Working with standard loops on this execution.
[05:30:06] - Previous termination of core was improper.
[05:30:06] - Files status OK
[05:30:06] - Expanded 167787 -> 954189 (decompressed 568.6 percent)
[05:30:06]
[05:30:06] Project: 1737 (Run 0, Clone 17, Gen 0)
[05:30:06]
[05:30:06] Entering M.D.
[05:30:26] (Starting from checkpoint)
[05:30:26] Protein: p1737_unf_305_SB
[05:30:26]
[05:30:26] Writing local files
[05:30:26] Completed 800000 out of 2500000 steps  (32%)
[05:40:34] Writing local files
[05:40:34] Completed 825000 out of 2500000 steps  (33%)
[05:50:43] Writing local files
[05:50:43] Completed 850000 out of 2500000 steps  (34%)
[06:00:51] Writing local files
[06:00:51] Completed 875000 out of 2500000 steps  (35%)
[06:10:59] Writing local files
[06:10:59] Completed 900000 out of 2500000 steps  (36%)
[06:20:56] Writing local files
[06:20:56] Completed 925000 out of 2500000 steps  (37%)
[06:31:05] Writing local files
[06:31:05] Completed 950000 out of 2500000 steps  (38%)
[06:41:13] Writing local files
[06:41:13] Completed 975000 out of 2500000 steps  (39%)
[06:51:22] Writing local files
[06:51:22] Completed 1000000 out of 2500000 steps  (40%)
[07:01:30] Writing local files
[07:01:30] Completed 1025000 out of 2500000 steps  (41%)
[07:11:39] Writing local files
[07:11:39] Completed 1050000 out of 2500000 steps  (42%)
[07:21:46] Writing local files
[07:21:46] Completed 1075000 out of 2500000 steps  (43%)
[07:31:54] Writing local files
[07:31:54] Completed 1100000 out of 2500000 steps  (44%)
[07:42:02] Writing local files
[07:42:02] Completed 1125000 out of 2500000 steps  (45%)
[07:52:11] Writing local files
[07:52:11] Completed 1150000 out of 2500000 steps  (46%)
[08:02:20] Writing local files
[08:02:20] Completed 1175000 out of 2500000 steps  (47%)
[08:12:28] Writing local files
[08:12:28] Completed 1200000 out of 2500000 steps  (48%)
[08:22:36] Writing local files
[08:22:36] Completed 1225000 out of 2500000 steps  (49%)
[08:32:45] Writing local files
[08:32:45] Completed 1250000 out of 2500000 steps  (50%)
[08:42:53] Writing local files
[08:42:53] Completed 1275000 out of 2500000 steps  (51%)
[08:52:51] Writing local files
[08:52:51] Completed 1300000 out of 2500000 steps  (52%)
[09:03:01] Writing local files
[09:03:01] Completed 1325000 out of 2500000 steps  (53%)
[09:13:10] Writing local files
[09:13:10] Completed 1350000 out of 2500000 steps  (54%)
[09:23:19] Writing local files
[09:23:19] Completed 1375000 out of 2500000 steps  (55%)
[09:33:28] Writing local files
[09:33:28] Completed 1400000 out of 2500000 steps  (56%)
[09:43:42] Writing local files
[09:43:42] Completed 1425000 out of 2500000 steps  (57%)
[09:53:52] Writing local files
[09:53:52] Completed 1450000 out of 2500000 steps  (58%)
[10:04:00] Writing local files
[10:04:00] Completed 1475000 out of 2500000 steps  (59%)
[10:14:08] Writing local files
[10:14:08] Completed 1500000 out of 2500000 steps  (60%)
[10:24:16] Writing local files
[10:24:16] Completed 1525000 out of 2500000 steps  (61%)
[10:34:24] Writing local files
[10:34:24] Completed 1550000 out of 2500000 steps  (62%)
[10:44:32] Writing local files
[10:44:32] Completed 1575000 out of 2500000 steps  (63%)
[10:54:42] Writing local files
[10:54:42] Completed 1600000 out of 2500000 steps  (64%)
--- Opening Log file [July 11 12:44:25]
[12:44:25] - Ask before connecting: No
[12:44:25] - User name: marknu1 (Team 13285)
[12:44:25] - User ID: 256450BF79A37049
[12:44:25] - Machine ID: 3
[12:44:25]
[12:44:26] Loaded queue successfully.
[12:44:26]
[12:44:26] + Processing work unit
[12:44:26] Core required: FahCore_78.exe
[12:44:26] Core found.
[12:44:26] Working on Unit 09 [July 11 12:44:26]
[12:44:26] + Working ...
[12:44:26]
[12:44:26] *------------------------------*
[12:44:26] Folding@Home Gromacs Core
[12:44:26] Version 1.90 (March 8, 2006)
[12:44:26]
[12:44:26] Preparing to commence simulation
[12:44:26] - Ensuring status. Please wait.
[12:44:43] - Looking at optimizations...
[12:44:43] - Working with standard loops on this execution.
[12:44:43] - Previous termination of core was improper.
[12:44:43] - Going to use standard loops.
[12:44:43] - Files status OK
[12:44:43] - Expanded 167787 -> 954189 (decompressed 568.6 percent)
[12:44:43]
[12:44:43] Project: 1737 (Run 0, Clone 17, Gen 0)
[12:44:43]
[12:44:43] Entering M.D.
[12:45:03] (Starting from checkpoint)
[12:45:03] Protein: p1737_unf_305_SB
[12:45:03]
[12:45:03] Writing local files
[12:45:03] Completed 1600000 out of 2500000 steps  (64%)
--- Opening Log file [July 11 12:53:09]
Arguments: -oneunit
[12:53:09] - Ask before connecting: No
[12:53:09] - User name: marknu1 (Team 13285)
[12:53:09] - User ID: 256450BF79A37049
[12:53:09] - Machine ID: 3
[12:53:09]
[12:53:10] Loaded queue successfully.
[12:53:10]
[12:53:10] + Processing work unit
[12:53:10] Core required: FahCore_78.exe
[12:53:10] Core found.
[12:53:10] Working on Unit 09 [July 11 12:53:10]
[12:53:10] + Working ...
[12:53:10]
[12:53:10] *------------------------------*
[12:53:10] Folding@Home Gromacs Core
[12:53:10] Version 1.90 (March 8, 2006)
[12:53:10]
[12:53:10] Preparing to commence simulation
[12:53:10] - Looking at optimizations...
[12:53:10] - Files status OK
[12:53:10] - Expanded 167787 -> 954189 (decompressed 568.6 percent)
[12:53:10]
[12:53:10] Project: 1737 (Run 0, Clone 17, Gen 0)
[12:53:10]
[12:53:10] Assembly optimizations on if available.
[12:53:10] Entering M.D.
[12:53:30] (Starting from checkpoint)
[12:53:30] Protein: p1737_unf_305_SB
[12:53:30]
[12:53:30] Writing local files
[12:53:30] Completed 1600000 out of 2500000 steps  (64%)
[12:53:30] Extra SSE boost OK.
[12:56:44] Writing local files
[12:56:44] Completed 1625000 out of 2500000 steps  (65%)
[12:59:58] Writing local files
[12:59:58] Completed 1650000 out of 2500000 steps  (66%)
[13:03:12] Writing local files
[13:03:12] Completed 1675000 out of 2500000 steps  (67%)
[13:06:26] Writing local files
[13:06:26] Completed 1700000 out of 2500000 steps  (68%)
[13:09:40] Writing local files
[13:09:40] Completed 1725000 out of 2500000 steps  (69%)
--- Opening Log file [July 11 13:54:29]
marknu1
Post by marknu1 »
I just realized that I posted this in the wrong category. Hopefully a Moderator will move this to the correct one.
I don't see crashes in the logs ... but improper shutdowns, and then a client restart.
Prime95 (pure FPU calculation) is absolutely not FAH stable (mainly SSE calculations) ... Prime is old, and doesn't stresses the same parts that FAH use.
Try this test instead (it's based on Gromacs and use SSE instruction to stress your CPU ... it also detects multicore automatically) : viewtopic.php?f=14&t=430
marknu1
Post by marknu1 »
Well, the improper shutdowns are the crashes.
I ran the Gromacs stress test for 14 hours today, and not even a hint of a problem. So again, it does not look like my system is the slightest bit unstable.
Any other ideas?
Passing the StressCPU v2.0 test does not guarantee a stable system for the SMP client. It does for the CPU client, but the SMP client is slightly more involved using much more memory, and 4 cores. You will need to back off your clocks 10% or more to get stability on all work units.
marknu1
Post by marknu1 »
Well, back to my original post, I'm not using the SMP client. Only single 6.10beta3 clients on 3 cores (with separate machine ID's), and the GPU2 client (also with a unique machine ID), which leaves one core to feed the GPU.
anandhanju
Post by anandhanju »
When you say crashes, what kind are you referring to? BSOD? The Windows "Shall I send an error report?" kind? A system auto-restart?
As 7im indicated, OCing can cause problems for some types of clients (SMP) as well as certain projects (WUs) that are more demanding that the rest. Backing off the OC would be a good place to begin figuring this out so that everybody can agree that it isn't the OC. The only real test for FAH stability on an OCd system is unfortunately FAH itself.
marknu1
Post by marknu1 »
I only witnessed one crash (although there were a number of them). When I saw it go, the computer became unresponsive, then black screen, followed by a very quick BSOD and the system restarted.
codysluder
Post by codysluder »
marknu1 wrote:I only witnessed one crash (although there were a number of them). When I saw it go, the computer became unresponsive, then black screen, followed by a very quick BSOD and the system restarted.
Reconfigure your OS so that it does not restart after a BSOD. Then you can read the messages and restart the machine manually. (Also, you'll have a realistic impression of how often you're having BSODs.)
marknu1
Post by marknu1 »
Do you know the steps required to set my machine to not restart after a BSOD? I'd like to be able to catch those messages when they appear. And to be honest, I really don't need a "realistic impression" of how often my machine has BSOD's. It almost never does...until just recently (with this WU). And if it does, I know because I find my machine with a clear desktop -- no folding consoles or other windows.
codysluder
marknu1 wrote:Do you know the steps required to set my machine to not restart after a BSOD?
Right-click MyComputer+Properties+Advanced+Startup_And_Recovery+ uncheck Automatic_Restart
