Finally Got a 3080
skydivingcatfan
- Hardware configuration: AMD 5700x, Asus Prime X570-Pro, EVGA 3080 12gb, G.SKILL Aegis 16GB DDR4 3200, Windows 10
Finally Got a 3080
I had been on a wait-list for an EVGA 3080 and never got to my name before they ended the list. Looked a couple weeks ago and they had a sizable instant rebate on a 3080 12 GB so I purchased it. I also update the cpu to a 5700x. So far I have been disappointed with the performance of both. When I look at the lars interface I am always running below average.
Re: Finally Got a 3080
We don't know what OS you are using, but most likely Windows or Linux. Here is a post that shows how to post your log in several OS's.
viewtopic.php?t=26036
The first 200 lines should be the most helpful to show us your setup and configuration.
skydivingcatfan
Glad to read you finally got your 3000 series from EVGA. Worthwhile as you are on Windows to leave sufficient CPU resources for the GPU, maybe try GPU only note the work unit numbers and then add CPUs gradually to see the impact on similar work units.
skydivingcatfan
Log
*********************** Log Started 2023-01-22T10:29:57Z ***********************
10:29:57:******************************* libFAH ********************************
10:29:57: Date: Oct 20 2020
10:29:57: Time: 13:36:55
10:29:57: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
10:29:57: Branch: master
10:29:57: Compiler: Visual C++ 2015
10:29:57: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
10:29:57: Platform: win32 10
10:29:57: Bits: 32
10:29:57: Mode: Release
10:29:57:****************************** FAHClient ******************************
10:29:57: Version: 7.6.21
10:29:57: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:29:57: Copyright: 2020 foldingathome.org
10:29:57: Homepage: https://foldingathome.org/
10:29:57: Time: 13:41:04
10:29:57: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
10:29:57: Bits: 32
10:29:57: Config: C:\Users\David\AppData\Roaming\FAHClient\config.xml
10:29:57:******************************** CBang ********************************
10:29:57: Time: 11:36:18
10:29:57: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
10:29:57: Bits: 32
10:29:57:******************************* System ********************************
10:29:57: CPU: AMD Ryzen 7 5700X 8-Core Processor
10:29:57: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
10:29:57: CPUs: 16
10:29:57: Memory: 15.92GiB
10:29:57: Free Memory: 13.70GiB
10:29:57: Threads: WINDOWS_THREADS
10:29:57: OS Version: 6.2
10:29:57: Has Battery: false
10:29:57: On Battery: false
10:29:57: UTC Offset: -6
10:29:57: PID: 1976
10:29:57: CWD: C:\Users\David\AppData\Roaming\FAHClient
10:29:57: Win32 Service: false
10:29:57: OS: Windows 10 Enterprise
10:29:57: OS Arch: AMD64
10:29:57: GPUs: 1
10:29:57: GPU 0: Bus:7 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080 12GB]
10:29:57: CUDA Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:8.6 Driver:12.0
10:29:57:OpenCL Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:3.0 Driver:528.2
10:29:57:***********************************************************************
10:29:57:<config>
10:29:57: <!-- Network -->
10:29:57: <proxy v=':8080'/>
10:29:57:
10:29:57: <!-- Slot Control -->
10:29:57: <power v='FULL'/>
10:29:57:
10:29:57: <!-- User Information -->
10:29:57: <passkey v='*****'/>
10:29:57: <team v='234771'/>
10:29:57: <user v='skydivingcatfan'/>
10:29:57:
10:29:57: <!-- Folding Slots -->
10:29:57: <slot id='0' type='CPU'>
10:29:57: <next-unit-percentage v='95'/>
10:29:57: </slot>
10:29:57: <slot id='1' type='GPU'>
10:29:57: <pci-bus v='7'/>
10:29:57: <pci-slot v='0'/>
10:29:57: </slot>
10:29:57:</config>
10:29:57:Trying to access database...
10:29:57:Successfully acquired database lock
10:29:57:FS00:Initialized folding slot 00: cpu:15
10:29:57:FS01:Initialized folding slot 01: gpu:7:0 GA102 [GeForce RTX 3080 12GB]
10:29:57:WU01:FS00:Starting
10:29:57:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 1976 -checkpoint 15 -np 15
10:29:58:WU01:FS00:Started FahCore on PID 9404
10:30:01:WU01:FS00:Core PID:2296
10:30:01:WU01:FS00:FahCore 0xa8 started
10:30:06:WU00:FS01:Starting
10:30:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1976 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
10:30:06:WU00:FS01:Started FahCore on PID 2452
10:30:07:WU01:FS00:0xa8:*********************** Log Started 2023-01-22T10:30:07Z ***********************
10:30:07:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
10:30:07:WU01:FS00:0xa8: Core: Gromacs
10:30:07:WU01:FS00:0xa8: Type: 0xa8
10:30:07:WU01:FS00:0xa8: Version: 0.0.12
10:30:07:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:30:07:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
10:30:07:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
10:30:07:WU01:FS00:0xa8: Date: Jan 16 2021
10:30:07:WU01:FS00:0xa8: Time: 12:29:40
10:30:07:WU01:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
10:30:07:WU01:FS00:0xa8: Branch: master
10:30:07:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
10:30:07:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
10:30:07:WU01:FS00:0xa8: Platform: win32 10
10:30:07:WU01:FS00:0xa8: Bits: 64
10:30:07:WU01:FS00:0xa8: Mode: Release
10:30:07:WU01:FS00:0xa8: SIMD: avx2_256
10:30:07:WU01:FS00:0xa8: OpenMP: ON
10:30:07:WU01:FS00:0xa8: CUDA: OFF
10:30:07:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 9404 -checkpoint 15 -np
10:30:07:WU01:FS00:0xa8: 15
10:30:07:WU01:FS00:0xa8:************************************ libFAH ************************************
10:30:07:WU01:FS00:0xa8: Time: 11:24:13
10:30:07:WU01:FS00:0xa8:************************************ CBang *************************************
10:30:07:WU01:FS00:0xa8: Time: 11:23:53
10:30:07:WU01:FS00:0xa8:************************************ System ************************************
10:30:07:WU01:FS00:0xa8: CPU: AMD Ryzen 7 5700X 8-Core Processor
10:30:07:WU01:FS00:0xa8: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
10:30:07:WU01:FS00:0xa8: CPUs: 16
10:30:07:WU01:FS00:0xa8: Memory: 15.92GiB
10:30:07:WU01:FS00:0xa8:Free Memory: 13.67GiB
10:30:07:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
10:30:07:WU01:FS00:0xa8: OS Version: 6.2
10:30:07:WU01:FS00:0xa8:Has Battery: false
10:30:07:WU01:FS00:0xa8: On Battery: false
10:30:07:WU01:FS00:0xa8: UTC Offset: -6
10:30:07:WU01:FS00:0xa8: PID: 2296
10:30:07:WU01:FS00:0xa8: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
10:30:07:WU01:FS00:0xa8:********************************************************************************
10:30:07:WU01:FS00:0xa8:Project: 18415 (Run 105, Clone 7, Gen 75)
10:30:07:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
10:30:07:WU01:FS00:0xa8:Digital signatures verified
10:30:07:WU01:FS00:0xa8:Calling: mdrun -c frame75.gro -s frame75.tpr -x frame75.xtc -cpi state.cpt -cpt 15 -nt 15 -ntmpi 1
10:30:08:WU01:FS00:0xa8:Steps: first=750000000 total=760000000
10:30:09:WU00:FS01:Core PID:4496
10:30:09:WU00:FS01:FahCore 0x22 started
10:30:14:WU01:FS00:0xa8:Completed 4829501 out of 10000000 steps (48%)
10:30:15:WU00:FS01:0x22:*********************** Log Started 2023-01-22T10:30:15Z ***********************
10:30:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:30:15:WU00:FS01:0x22: Core: Core22
10:30:15:WU00:FS01:0x22: Type: 0x22
10:30:15:WU00:FS01:0x22: Version: 0.0.20
10:30:15:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:30:15:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
10:30:15:WU00:FS01:0x22: Homepage: https://foldingathome.org/
10:30:15:WU00:FS01:0x22: Date: Jan 20 2022
10:30:15:WU00:FS01:0x22: Time: 01:15:36
10:30:15:WU00:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
10:30:15:WU00:FS01:0x22: Branch: HEAD
10:30:15:WU00:FS01:0x22: Compiler: Visual C++
10:30:15:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
10:30:15:WU00:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
10:30:15:WU00:FS01:0x22: Platform: win32 10
10:30:15:WU00:FS01:0x22: Bits: 64
10:30:15:WU00:FS01:0x22: Mode: Release
10:30:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:30:15:WU00:FS01:0x22: <peastman@stanford.edu>
10:30:15:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 2452 -checkpoint 15
10:30:15:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
10:30:15:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
10:30:15:WU00:FS01:0x22:************************************ libFAH ************************************
10:30:15:WU00:FS01:0x22: Time: 01:14:17
10:30:15:WU00:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
10:30:15:WU00:FS01:0x22:************************************ CBang *************************************
10:30:15:WU00:FS01:0x22: Time: 01:13:20
10:30:15:WU00:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
10:30:15:WU00:FS01:0x22:************************************ System ************************************
10:30:15:WU00:FS01:0x22: CPU: AMD Ryzen 7 5700X 8-Core Processor
10:30:15:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
10:30:15:WU00:FS01:0x22: CPUs: 16
10:30:15:WU00:FS01:0x22: Memory: 15.92GiB
10:30:15:WU00:FS01:0x22:Free Memory: 13.68GiB
10:30:15:WU00:FS01:0x22: Threads: WINDOWS_THREADS
10:30:15:WU00:FS01:0x22: OS Version: 6.2
10:30:15:WU00:FS01:0x22:Has Battery: false
10:30:15:WU00:FS01:0x22: On Battery: false
10:30:15:WU00:FS01:0x22: UTC Offset: -6
10:30:15:WU00:FS01:0x22: PID: 4496
10:30:15:WU00:FS01:0x22: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
10:30:15:WU00:FS01:0x22:************************************ OpenMM ************************************
10:30:15:WU00:FS01:0x22: Version: 7.7.0
10:30:15:WU00:FS01:0x22:********************************************************************************
10:30:15:WU00:FS01:0x22:Project: 18601 (Run 813, Clone 4, Gen 28)
10:30:15:WU00:FS01:0x22:Digital signatures verified
10:30:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:30:15:WU00:FS01:0x22:Version 0.0.20
10:30:15:WU00:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
10:30:15:WU00:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
10:30:15:WU00:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
10:30:15:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
10:30:19:WU00:FS01:0x22:There are 4 platforms available.
10:30:19:WU00:FS01:0x22:Platform 0: Reference
10:30:19:WU00:FS01:0x22:Platform 1: CPU
10:30:19:WU00:FS01:0x22:Platform 2: OpenCL
10:30:19:WU00:FS01:0x22: opencl-device 0 specified
10:30:19:WU00:FS01:0x22:Platform 3: CUDA
10:30:19:WU00:FS01:0x22: cuda-device 0 specified
10:30:59:WU00:FS01:0x22:Attempting to create CUDA context:
10:30:59:WU00:FS01:0x22: Configuring platform CUDA
10:31:18:WU00:FS01:0x22: Using CUDA and gpu 0
10:31:19:WU00:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
10:32:10:6:127.0.0.1:New Web session
10:32:11:7:127.0.0.1:New Web session
10:32:23:WU00:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
10:33:31:WU00:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
10:33:35:WU00:FS01:0x22:Checkpoint completed at step 725000
10:34:39:WU00:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
10:35:46:WU00:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
10:35:49:WU00:FS01:0x22:Checkpoint completed at step 750000
10:36:53:WU00:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
10:37:43:WU01:FS00:0xa8:Completed 4900000 out of 10000000 steps (49%)
10:38:00:WU00:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
10:38:03:WU00:FS01:0x22:Checkpoint completed at step 775000
10:39:11:WU00:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
10:40:20:WU00:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
10:40:23:WU00:FS01:0x22:Checkpoint completed at step 800000
10:41:30:WU00:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
10:42:38:WU00:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
10:42:41:WU00:FS01:0x22:Checkpoint completed at step 825000
10:43:47:WU00:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
10:44:52:WU00:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
10:44:55:WU00:FS01:0x22:Checkpoint completed at step 850000
10:46:00:WU00:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
10:47:03:WU00:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
10:47:07:WU00:FS01:0x22:Checkpoint completed at step 875000
10:47:28:WU01:FS00:0xa8:Completed 5000000 out of 10000000 steps (50%)
10:48:10:WU00:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
10:49:13:WU00:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
10:49:17:WU00:FS01:0x22:Checkpoint completed at step 900000
10:50:20:WU00:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
10:51:24:WU00:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
10:51:27:WU00:FS01:0x22:Checkpoint completed at step 925000
10:52:30:WU00:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
10:53:32:WU00:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
10:53:35:WU00:FS01:0x22:Checkpoint completed at step 950000
10:54:38:WU00:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
10:55:40:WU00:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
10:55:43:WU00:FS01:0x22:Checkpoint completed at step 975000
10:56:29:WU01:FS00:0xa8:Completed 5100000 out of 10000000 steps (51%)
10:56:47:WU00:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
10:57:50:WU00:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
10:57:54:WU00:FS01:0x22:Checkpoint completed at step 1000000
10:58:57:WU00:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
10:59:58:WU00:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
11:00:02:WU00:FS01:0x22:Checkpoint completed at step 1025000
11:01:05:WU00:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
11:02:09:WU00:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
11:02:12:WU00:FS01:0x22:Checkpoint completed at step 1050000
11:03:17:WU00:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
11:04:22:WU00:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
11:04:26:WU00:FS01:0x22:Checkpoint completed at step 1075000
11:05:30:WU00:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
11:05:59:WU01:FS00:0xa8:Completed 5200000 out of 10000000 steps (52%)
11:06:33:WU00:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
11:06:37:WU00:FS01:0x22:Checkpoint completed at step 1100000
11:07:43:WU00:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
11:08:50:WU00:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
11:08:54:WU00:FS01:0x22:Checkpoint completed at step 1125000
11:10:00:WU00:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
11:11:06:WU00:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
11:11:09:WU00:FS01:0x22:Checkpoint completed at step 1150000
11:12:14:WU00:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
11:13:20:WU00:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
11:13:23:WU00:FS01:0x22:Checkpoint completed at step 1175000
11:14:28:WU00:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
11:14:28:WU02:FS01:Connecting to assign1.foldingathome.org:80
11:14:29:WU02:FS01:Assigned to work server 206.223.170.146
11:14:29:WU02:FS01:Requesting new work unit for slot 01: gpu:7:0 GA102 [GeForce RTX 3080 12GB] from 206.223.170.146
11:14:29:WU02:FS01:Connecting to 206.223.170.146:8080
11:14:29:WU02:FS01:Downloading 22.07MiB
11:14:30:WU02:FS01:Download complete
11:14:31:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18601 run:3456 clone:4 gen:28 core:0x22 unit:0x000000040000001c000048a900000d80
11:15:32:WU00:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
11:15:35:WU00:FS01:0x22:Checkpoint completed at step 1200000
11:16:19:WU01:FS00:0xa8:Completed 5300000 out of 10000000 steps (53%)
11:16:44:WU00:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
11:17:52:WU00:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
11:17:56:WU00:FS01:0x22:Checkpoint completed at step 1225000
11:19:04:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
11:20:12:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
11:20:12:WU00:FS01:0x22:Average performance: 31.7647 ns/day
11:20:16:WU00:FS01:0x22:Checkpoint completed at step 1250000
11:20:34:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:20:34:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
11:20:34:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
11:20:34:WU00:FS01:0x22:Saving result file positions.xtc
11:20:34:WU00:FS01:0x22:Saving result file science.log
11:20:34:WU00:FS01:0x22:Saving result file xtcAtoms.csv.bz2
11:20:34:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:20:35:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:20:35:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18601 run:813 clone:4 gen:28 core:0x22 unit:0x000000040000001c000048a90000032d
11:20:35:WU00:FS01:Uploading 22.94MiB to 206.223.170.146
11:20:35:WU00:FS01:Connecting to 206.223.170.146:8080
11:20:36:WU02:FS01:Starting
11:20:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 1976 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
11:20:36:WU02:FS01:Started FahCore on PID 11060
11:20:36:WU02:FS01:Core PID:8328
11:20:36:WU02:FS01:FahCore 0x22 started
11:20:36:WU02:FS01:0x22:*********************** Log Started 2023-01-22T11:20:36Z ***********************
11:20:36:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:20:36:WU02:FS01:0x22: Core: Core22
11:20:36:WU02:FS01:0x22: Type: 0x22
11:20:36:WU02:FS01:0x22: Version: 0.0.20
11:20:36:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:20:36:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
11:20:36:WU02:FS01:0x22: Homepage: https://foldingathome.org/
11:20:36:WU02:FS01:0x22: Date: Jan 20 2022
11:20:36:WU02:FS01:0x22: Time: 01:15:36
11:20:36:WU02:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
11:20:36:WU02:FS01:0x22: Branch: HEAD
11:20:36:WU02:FS01:0x22: Compiler: Visual C++
11:20:36:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
11:20:36:WU02:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
11:20:36:WU02:FS01:0x22: Platform: win32 10
11:20:36:WU02:FS01:0x22: Bits: 64
11:20:36:WU02:FS01:0x22: Mode: Release
11:20:36:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:20:36:WU02:FS01:0x22: <peastman@stanford.edu>
11:20:36:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 11060 -checkpoint 15
11:20:36:WU02:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
11:20:36:WU02:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
11:20:36:WU02:FS01:0x22:************************************ libFAH ************************************
11:20:36:WU02:FS01:0x22: Time: 01:14:17
11:20:36:WU02:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
11:20:36:WU02:FS01:0x22:************************************ CBang *************************************
11:20:36:WU02:FS01:0x22: Time: 01:13:20
11:20:36:WU02:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
11:20:36:WU02:FS01:0x22:************************************ System ************************************
11:20:36:WU02:FS01:0x22: CPU: AMD Ryzen 7 5700X 8-Core Processor
11:20:36:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
11:20:36:WU02:FS01:0x22: CPUs: 16
11:20:36:WU02:FS01:0x22: Memory: 15.92GiB
11:20:36:WU02:FS01:0x22:Free Memory: 13.05GiB
11:20:36:WU02:FS01:0x22: Threads: WINDOWS_THREADS
11:20:36:WU02:FS01:0x22: OS Version: 6.2
11:20:36:WU02:FS01:0x22:Has Battery: false
11:20:36:WU02:FS01:0x22: On Battery: false
11:20:36:WU02:FS01:0x22: UTC Offset: -6
11:20:36:WU02:FS01:0x22: PID: 8328
11:20:36:WU02:FS01:0x22: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
11:20:36:WU02:FS01:0x22:************************************ OpenMM ************************************
11:20:36:WU02:FS01:0x22: Version: 7.7.0
11:20:36:WU02:FS01:0x22:********************************************************************************
11:20:36:WU02:FS01:0x22:Project: 18601 (Run 3456, Clone 4, Gen 28)
11:20:36:WU02:FS01:0x22:Reading tar file core.xml
11:20:36:WU02:FS01:0x22:Reading tar file integrator.xml
11:20:36:WU02:FS01:0x22:Reading tar file state.xml.bz2
11:20:36:WU02:FS01:0x22:Reading tar file system.xml.bz2
11:20:36:WU02:FS01:0x22:Digital signatures verified
11:20:36:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:20:36:WU02:FS01:0x22:Version 0.0.20
11:20:36:WU02:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
11:20:36:WU02:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
11:20:36:WU02:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
11:20:36:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
11:20:37:WU00:FS01:Upload complete
11:20:37:WU02:FS01:0x22:There are 4 platforms available.
11:20:37:WU02:FS01:0x22:Platform 0: Reference
11:20:37:WU02:FS01:0x22:Platform 1: CPU
11:20:37:WU02:FS01:0x22:Platform 2: OpenCL
11:20:37:WU02:FS01:0x22: opencl-device 0 specified
11:20:37:WU02:FS01:0x22:Platform 3: CUDA
11:20:37:WU02:FS01:0x22: cuda-device 0 specified
11:20:37:WU00:FS01:Server responded WORK_ACK (400)
11:20:37:WU00:FS01:Final credit estimate, 539453.00 points
11:20:37:WU00:FS01:Cleaning up
11:21:18:WU02:FS01:0x22:Attempting to create CUDA context:
11:21:18:WU02:FS01:0x22: Configuring platform CUDA
11:21:38:WU02:FS01:0x22: Using CUDA and gpu 0
11:21:38:WU02:FS01:0x22:Completed 0 out of 1250000 steps (0%)
11:21:41:WU02:FS01:0x22:Checkpoint completed at step 0
11:22:43:WU02:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
11:23:46:WU02:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
11:23:49:WU02:FS01:0x22:Checkpoint completed at step 25000
11:24:52:WU02:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
11:25:21:WU01:FS00:0xa8:Completed 5400000 out of 10000000 steps (54%)
11:25:56:WU02:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
11:25:59:WU02:FS01:0x22:Checkpoint completed at step 50000
11:27:02:WU02:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
11:28:06:WU02:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
11:28:09:WU02:FS01:0x22:Checkpoint completed at step 75000
11:29:13:WU02:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
11:30:15:WU02:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
11:30:18:WU02:FS01:0x22:Checkpoint completed -
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Unless your numbers are really out of line with the LAR averages shown, I wouldn't give it much concern. The luck of the assignment servers alone could cost you points, and the rolling average is always changing based on what is available.
Combine that with not knowing the specifics of all the others using 3080's with 12 GB that use the LARS browser, and you can come up with a lot of variation in points. Then add in who overlclocks their gear, tweaks memory, runs their fans higher to aid cooling... the variations get even bigger.
If you could find people with the same brand and type card, running the same OS, and compare like work units and yours is a dog then you might have something to work with. Until then I'd accept that different people and all the factors will produce differing results.
Fold them if you get them!
skydivingcatfan
I turned of the CPU slot and now the GPU folding is running just a little over the average. I am going to add 4 threads of folding tomorrow and let that run for 3 days to see how it compares.
Think this a good idea, the number of optimal cpus will vary a bit by project but you will figure this out by trial and error on you system. Remember also that many PPD results by GPU may be distorted by reporting best results, like gamblers reporting only wins not losses.skydivingcatfan wrote: ↑Sat Jan 28, 2023 11:36 amI turned of the CPU slot and now the GPU folding is running just a little over the average. I am going to add 4 threads of folding tomorrow and let that run for 3 days to see how it compares.
skydivingcatfan
Looks like so far that 8 threads is the max for my system. When I went to 9 points per day went down and power draw went down. I will continue to increase and see if these trends continue.
8 threads sounds about right for your system. CPU folding is limited by floating point operations, your Ryzen has 8 FPUs shared between 16 threads. Versions of the CPU folding core since Core_A7 have been very efficient at using the FPUs, my personal experience on Intel processors with HT is that using more threads than FPUs results in little added throughput. On Intel the HT supported threads are enough to handle the CPU side of GPU folding. From what you are reporting it sounds about the same is happening with your AMD processor.
skydivingcatfan
ThanksJoe_H wrote: ↑Sat Feb 11, 2023 2:48 pm 8 threads sounds about right for your system. CPU folding is limited by floating point operations, your Ryzen has 8 FPUs shared between 16 threads. Versions of the CPU folding core since Core_A7 have been very efficient at using the FPUs, my personal experience on Intel processors with HT is that using more threads than FPUs results in little added throughput. On Intel the HT supported threads are enough to handle the CPU side of GPU folding. From what you are reporting it sounds about the same is happening with your AMD processor.
I am going to go back down to 7 and see where that puts me I had jumped from 4 to 8 threads.
