18435 stuck on Ready 0%
Knish
Post by Knish »
uh-0h, looks like it's been stuck in this loop for over a day. 6-core CPU only in archlinux.
tried pause/unpause, and rebooting, Looks like its still stuck.
Advanced control showing TPF 55 sec but the Folding slots area is blue, stuck at "Ready" and the cpu isn't doing any calculations
*********************** Log Started 2023-01-13T23:05:18Z ***********************
23:05:18:******************************* libFAH ********************************
23:05:18:       Date: Oct 20 2020
23:05:18:       Time: 20:36:39
23:05:18:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
23:05:18:     Branch: master
23:05:18:   Compiler: GNU 8.3.0
23:05:18:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
23:05:18:             -fdata-sections -O3 -funroll-loops -fno-pie
23:05:18:   Platform: linux2 5.8.0-1-amd64
23:05:18:       Bits: 64
23:05:18:       Mode: Release
23:05:18:****************************** FAHClient ******************************
23:05:18:    Version: 7.6.21
23:05:18:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:05:18:  Copyright: 2020 foldingathome.org
23:05:18:   Homepage: https://foldingathome.org/
23:05:18:       Time: 20:39:00
23:05:18:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
23:05:18:       Bits: 64
23:05:18:       Args: --config /etc/foldingathome/config.xml --log
23:05:18:             /var/log/foldingathome/log.txt --log-rotate-dir
23:05:18:     Config: /etc/foldingathome/config.xml
23:05:18:******************************** CBang ********************************
23:05:18:       Time: 18:37:59
23:05:18:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
23:05:18:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
23:05:18:       Bits: 64
23:05:18:******************************* System ********************************
23:05:18:        CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
23:05:18:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
23:05:18:       CPUs: 6
23:05:18:     Memory: 3.70GiB
23:05:18:Free Memory: 3.44GiB
23:05:18:    Threads: POSIX_THREADS
23:05:18: OS Version: 5.19
23:05:18:Has Battery: false
23:05:18: On Battery: false
23:05:18: UTC Offset: -8
23:05:18:        PID: 367
23:05:18:        CWD: /var/lib/private/fah
23:05:18:         OS: Linux 5.19.13-arch1-1 x86_64
23:05:18:    OS Arch: AMD64
23:05:18:       GPUs: 0
23:05:18:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
23:05:18:             libcuda.so: cannot open shared object file: No such file or
23:05:18:             directory
23:05:18:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
23:05:18:             libOpenCL.so: cannot open shared object file: No such file or
23:05:18:             directory
23:05:18:***********************************************************************
23:05:18:<config>
23:05:18:  <!-- Folding Slot Configuration -->
23:05:18:  <cause v='PARKINSONS'/>
23:05:18:  <gpu v='false'/>
23:05:18:
23:05:18:  <!-- Work Unit Control -->
23:05:18:  <next-unit-percentage v='100'/>
23:05:18:
23:05:18:  <!-- Folding Slots -->
23:05:18:  <slot id='0' type='CPU'>
23:05:18:    <paused v='true'/>
23:05:18:  </slot>
23:05:18:</config>
23:05:18:Trying to access database...
23:05:18:Successfully acquired database lock
23:05:18:FS00:Initialized folding slot 00: cpu:6
23:05:56:FS00:Unpaused
23:05:56:WU01:FS00:Starting
23:05:56:WU01:FS00:Removing old file 'work/01/logfile_01-20230113-223134.txt'
23:05:56:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 01 -suffix 01 -version 706 -lifeline 367 -checkpoint 15 -np 6
23:05:56:WU01:FS00:Started FahCore on PID 424
23:05:56:WU01:FS00:Core PID:428
23:05:56:WU01:FS00:FahCore 0xa8 started
23:05:57:WU01:FS00:0xa8:*********************** Log Started 2023-01-13T23:05:57Z ***********************
23:05:57:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
23:05:57:WU01:FS00:0xa8:       Core: Gromacs
23:05:57:WU01:FS00:0xa8:       Type: 0xa8
23:05:57:WU01:FS00:0xa8:    Version: 0.0.12
23:05:57:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:05:57:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
23:05:57:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
23:05:57:WU01:FS00:0xa8:       Date: Jan 16 2021
23:05:57:WU01:FS00:0xa8:       Time: 19:24:44
23:05:57:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
23:05:57:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
23:05:57:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
23:05:57:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
23:05:57:WU01:FS00:0xa8:       Bits: 64
23:05:57:WU01:FS00:0xa8:       Mode: Release
23:05:57:WU01:FS00:0xa8:       SIMD: avx2_256
23:05:57:WU01:FS00:0xa8:     OpenMP: ON
23:05:57:WU01:FS00:0xa8:       CUDA: OFF
23:05:57:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 424 -checkpoint 15 -np 6
23:05:57:WU01:FS00:0xa8:************************************ libFAH ************************************
23:05:57:WU01:FS00:0xa8:       Time: 19:21:38
23:05:57:WU01:FS00:0xa8:************************************ CBang *************************************
23:05:57:WU01:FS00:0xa8:       Time: 19:21:24
23:05:57:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
23:05:57:WU01:FS00:0xa8:************************************ System ************************************
23:05:57:WU01:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
23:05:57:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
23:05:57:WU01:FS00:0xa8:       CPUs: 6
23:05:57:WU01:FS00:0xa8:     Memory: 3.70GiB
23:05:57:WU01:FS00:0xa8:Free Memory: 3.44GiB
23:05:57:WU01:FS00:0xa8:    Threads: POSIX_THREADS
23:05:57:WU01:FS00:0xa8: OS Version: 5.19
23:05:57:WU01:FS00:0xa8:Has Battery: false
23:05:57:WU01:FS00:0xa8: On Battery: false
23:05:57:WU01:FS00:0xa8: UTC Offset: -8
23:05:57:WU01:FS00:0xa8:        PID: 428
23:05:57:WU01:FS00:0xa8:        CWD: /var/lib/private/fah/work
23:05:57:WU01:FS00:0xa8:********************************************************************************
23:05:57:WU01:FS00:0xa8:Project: 18435 (Run 29, Clone 11, Gen 0)
23:05:57:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
23:05:57:WU01:FS00:0xa8:Digital signatures verified
23:05:57:WU01:FS00:0xa8:Calling: mdrun -c frame0.gro -s frame0.tpr -x frame0.xtc -cpt 15 -nt 6 -ntmpi 1
23:05:57:WU01:FS00:0xa8:Steps: first=0 total=5000000
23:05:59:WU01:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
23:06:02:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:06:02:WU01:FS00:Starting
23:06:02:WU01:FS00:Removing old file 'work/01/logfile_01-20230113-223234.txt'
23:06:02:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 01 -suffix 01 -version 706 -lifeline 367 -checkpoint 15 -np 6
23:06:02:WU01:FS00:Started FahCore on PID 447
23:06:02:WU01:FS00:Core PID:451
23:06:02:WU01:FS00:FahCore 0xa8 started
23:06:03:WU01:FS00:0xa8:*********************** Log Started 2023-01-13T23:06:02Z ***********************
23:06:03:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
23:06:03:WU01:FS00:0xa8:       Core: Gromacs
23:06:03:WU01:FS00:0xa8:       Type: 0xa8
23:06:03:WU01:FS00:0xa8:    Version: 0.0.12
23:06:03:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:06:03:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
23:06:03:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
23:06:03:WU01:FS00:0xa8:       Date: Jan 16 2021
23:06:03:WU01:FS00:0xa8:       Time: 19:24:44
23:06:03:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
23:06:03:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
23:06:03:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
23:06:03:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
23:06:03:WU01:FS00:0xa8:       Bits: 64
23:06:03:WU01:FS00:0xa8:       Mode: Release
23:06:03:WU01:FS00:0xa8:       SIMD: avx2_256
23:06:03:WU01:FS00:0xa8:     OpenMP: ON
23:06:03:WU01:FS00:0xa8:       CUDA: OFF
23:06:03:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 447 -checkpoint 15 -np 6
23:06:03:WU01:FS00:0xa8:************************************ libFAH ************************************
23:06:03:WU01:FS00:0xa8:       Time: 19:21:38
23:06:03:WU01:FS00:0xa8:************************************ CBang *************************************
23:06:03:WU01:FS00:0xa8:       Time: 19:21:24
23:06:03:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
23:06:03:WU01:FS00:0xa8:************************************ System ************************************
23:06:03:WU01:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
23:06:03:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
23:06:03:WU01:FS00:0xa8:       CPUs: 6
23:06:03:WU01:FS00:0xa8:     Memory: 3.70GiB
23:06:03:WU01:FS00:0xa8:Free Memory: 3.43GiB
23:06:03:WU01:FS00:0xa8:    Threads: POSIX_THREADS
23:06:03:WU01:FS00:0xa8: OS Version: 5.19
23:06:03:WU01:FS00:0xa8:Has Battery: false
23:06:03:WU01:FS00:0xa8: On Battery: false
23:06:03:WU01:FS00:0xa8: UTC Offset: -8
23:06:03:WU01:FS00:0xa8:        PID: 451
23:06:03:WU01:FS00:0xa8:        CWD: /var/lib/private/fah/work
23:06:03:WU01:FS00:0xa8:********************************************************************************
23:06:03:WU01:FS00:0xa8:Project: 18435 (Run 29, Clone 11, Gen 0)
23:06:03:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
23:06:03:WU01:FS00:0xa8:Digital signatures verified
23:06:03:WU01:FS00:0xa8:Calling: mdrun -c frame0.gro -s frame0.tpr -x frame0.xtc -cpt 15 -nt 6 -ntmpi 1
23:06:03:WU01:FS00:0xa8:Steps: first=0 total=5000000
23:06:03:WU01:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
23:06:09:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:06:19:Removing old file 'configs/config-20220814-040709.xml'
23:06:19:Saving configuration to /etc/foldingathome/config.xml
23:06:19:<config>
23:06:19:  <!-- Folding Slot Configuration -->
23:06:19:  <cause v='PARKINSONS'/>
23:06:19:  <gpu v='false'/>
23:06:19:
23:06:19:  <!-- Folding Slots -->
23:06:19:  <slot id='0' type='CPU'/>
23:06:19:</config>
bikeaddict
Re: 18435 stuck on Ready 0%
Post by bikeaddict »
This WU is failing for everyone, along with other adjacent Run/Clone numbers:
https://apps.foldingathome.org/wu#proje ... e=11&gen=0
To dump the bad WU, you can try stopping the FAHClient service, deleting the files in the work directory and restarting the service. Or you can delete and re-add the slot using FAHControl.
