Adding NVIDIA Corporation TU117GL [T400 4GB] (rev a1)
fcharton
Post by fcharton »
Hi,
I request the addition of the NVIDIA Corporation TU117GL [T400 4GB] (rev a1)
Output of FAHClient --lspci :
0x10de:0x1ff2:101:0:0:NVIDIA Corporation:
Log file :
*********************** Log Started 2022-07-22T21:32:11Z ***********************
21:32:11:Trying to access database...
21:32:11:Successfully acquired database lock
21:32:11:Read GPUs.txt
21:32:11:Enabled folding slot 00: PAUSED cpu:14 (by user)
21:32:11:ERROR:Exception: No available GPUs
21:32:11:ERROR:No compute devices matched GPU #
21:32:11:ERROR:Exception: Option 'gpu-index' has no default and is not set.
21:32:11:****************************** FAHClient ******************************
21:32:11:        Version: 7.6.13
21:32:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:32:11:      Copyright: 2020 foldingathome.org
21:32:11:       Homepage: https://foldingathome.org/
21:32:11:           Date: Apr 28 2020
21:32:11:           Time: 04:20:16
21:32:11:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
21:32:11:         Branch: master
21:32:11:       Compiler: GNU 8.3.0
21:32:11:        Options: -std=c++11 -ffunction-sections -fdata-sections -O3
21:32:11:                 -funroll-loops -fno-pie
21:32:11:       Platform: linux2 4.19.0-5-amd64
21:32:11:           Bits: 64
21:32:11:           Mode: Release
21:32:11:           Args: --child /etc/fahclient/config.xml --run-as fahclient
21:32:11:                 --pid-file=/var/run/fahclient.pid --daemon
21:32:11:         Config: /etc/fahclient/config.xml
21:32:11:******************************** CBang ********************************
21:32:11:           Date: Apr 25 2020
21:32:11:           Time: 00:07:53
21:32:11:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
21:32:11:                 -funroll-loops -fno-pie -fPIC
21:32:11:           Bits: 64
21:32:11:******************************* System ********************************
21:32:11:            CPU: Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz
21:32:11:         CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
21:32:11:           CPUs: 16
21:32:11:         Memory: 62.50GiB
21:32:11:    Free Memory: 15.26GiB
21:32:11:        Threads: POSIX_THREADS
21:32:11:     OS Version: 5.18
21:32:11:    Has Battery: false
21:32:11:     On Battery: false
21:32:11:     UTC Offset: 2
21:32:11:            PID: 1886571
21:32:11:            CWD: /var/lib/fahclient
21:32:11:             OS: Linux 5.18.0-2-amd64 x86_64
21:32:11:        OS Arch: AMD64
21:32:11:           GPUs: 0
21:32:11:  CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:7.5 Driver:11.4
21:32:11:OpenCL Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:3.0 Driver:470.129
21:32:11:******************************* libFAH ********************************
21:32:11:           Date: Apr 15 2020
21:32:11:           Time: 21:43:24
21:32:11:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:32:11:           Bits: 64
21:32:11:***********************************************************************
Re: Adding NVIDIA Corporation TU117GL [T400 4GB] (rev a1)
https://www.techpowerup.com/gpu-specs/t400.c3808
Should be about half as fast as a GTX 1650, but 25% faster than a GT 1030. Similar speed to an RX 550.
Added :
0x1ff0 / TU117GL [T1000 8GB]
0x1ff2 / TU117GL [T400 4GB]
fcharton
Post by fcharton »
Thank you :)
