Hi,
Looks like there is some ongoing issue right now. I can't get any results when searching stats for teams or donors.
Example:
URL: https://stats.foldingathome.org/team
Enter any team name, for instance "intel". Press Lookup. No results
Note that if the edit box is empty, pressing the Lookup returns results.
Same issue if you use Intel's team number - https://stats.foldingathome.org/team/711. No results.
Same issue is with Donors lookups - empty edit box - there are results; enter existing donor name - for instance Arbutus then - no results. Using Arbutus URL - https://stats.foldingathome.org/donor/166229 - no results.
Please help investigate and resume the service.
Thanks,
Same issue is with
stats for Donors and Teams - no results
Re: stats for Donors and Teams - no results
The developer has been notified. Some changes made over last weekend caused problems that were fixed, appears other problems have surfaced.
It should be fixed now.
Yes! Thanks for fixing it!
