18027 Bad Work Unit
18027 Bad Work Unit
Project 18027.
5 Bad Work Units in a row.
Re: 18027 Bad Work Unit
Can you elaborate ? Logs ? Work unit references ? GPU and environement ?
I'm in the same boat. I've had two system crashes in one hour since I've turned my computer on. Here are the logs from my F@H log folder.
Log 1:
Log 1:
*********************** Log Started 2021-12-22T18:50:14Z ***********************
18:50:14:******************************* libFAH ********************************
18:50:14: Date: Oct 20 2020
18:50:14: Time: 13:36:55
18:50:14: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
18:50:14: Branch: master
18:50:14: Compiler: Visual C++ 2015
18:50:14: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:50:14: Platform: win32 10
18:50:14: Bits: 32
18:50:14: Mode: Release
18:50:14:****************************** FAHClient ******************************
18:50:14: Version: 7.6.21
18:50:14: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:14: Copyright: 2020 foldingathome.org
18:50:14: Homepage: https://foldingathome.org/
18:50:14: Time: 13:41:04
18:50:14: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
18:50:14: Bits: 32
18:50:14: Config: C:\Users\Keith\AppData\Roaming\FAHClient\config.xml
18:50:14:******************************** CBang ********************************
18:50:14: Time: 11:36:18
18:50:14: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
18:50:14: Bits: 32
18:50:14:******************************* System ********************************
18:50:14: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
18:50:14: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:50:14: CPUs: 8
18:50:14: Memory: 15.94GiB
18:50:14: Free Memory: 11.77GiB
18:50:14: Threads: WINDOWS_THREADS
18:50:14: OS Version: 6.2
18:50:14: Has Battery: false
18:50:14: On Battery: false
18:50:14: UTC Offset: -6
18:50:14: PID: 4408
18:50:14: CWD: C:\Users\Keith\AppData\Roaming\FAHClient
18:50:14: Win32 Service: false
18:50:14: OS: Windows 10 Enterprise
18:50:14: OS Arch: AMD64
18:50:14: GPUs: 1
18:50:14: GPU 0: Bus:3 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
18:50:14: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:50:14: specified module could not be found.
18:50:14:
18:50:14:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3354.13
18:50:14:***********************************************************************
18:50:15:<config>
18:50:15: <!-- Folding Core -->
18:50:15: <checkpoint v='9'/>
18:50:15: <core-priority v='low'/>
18:50:15:
18:50:15: <!-- Network -->
18:50:15: <proxy v=':8080'/>
18:50:15:
18:50:15: <!-- Slot Control -->
18:50:15: <pause-on-battery v='false'/>
18:50:15:
18:50:15: <!-- User Information -->
18:50:15: <passkey v='*****'/>
18:50:15: <team v='224497'/>
18:50:15: <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
18:50:15:
18:50:15: <!-- Folding Slots -->
18:50:15: <slot id='0' type='GPU'>
18:50:15: <pci-bus v='3'/>
18:50:15: <pci-slot v='0'/>
18:50:15: </slot>
18:50:15:</config>
18:50:15:Trying to access database...
18:50:15:Successfully acquired database lock
18:50:15:FS00:Initialized folding slot 00: gpu:3:0 Vega 10 XL/XT [Radeon RX Vega 56/64]
18:50:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:50:16:WU00:FS00:Assigned to work server 34.72.228.44
18:50:16:WU00:FS00:Requesting new work unit for slot 00: gpu:3:0 Vega 10 XL/XT [Radeon RX Vega 56/64] from 34.72.228.44
18:50:16:WU00:FS00:Connecting to 34.72.228.44:8080
18:50:17:WU00:FS00:Downloading 3.04MiB
18:50:21:WU00:FS00:Download complete
18:50:22:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18027 run:4 clone:127 gen:7 core:0x22 unit:0x0000007f000000070000466b00000004
18:50:22:WU00:FS00:Starting
18:50:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 4408 -checkpoint 9 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
18:50:22:WU00:FS00:Started FahCore on PID 7580
18:50:22:WU00:FS00:Core PID:13388
18:50:22:WU00:FS00:FahCore 0x22 started
18:50:23:WU00:FS00:0x22:*********************** Log Started 2021-12-22T18:50:22Z ***********************
18:50:23:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
18:50:23:WU00:FS00:0x22: Core: Core22
18:50:23:WU00:FS00:0x22: Type: 0x22
18:50:23:WU00:FS00:0x22: Version: 0.0.18
18:50:23:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:23:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
18:50:23:WU00:FS00:0x22: Homepage: https://foldingathome.org/
18:50:23:WU00:FS00:0x22: Date: Sep 28 2021
18:50:23:WU00:FS00:0x22: Time: 05:55:05
18:50:23:WU00:FS00:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:50:23:WU00:FS00:0x22: Branch: HEAD
18:50:23:WU00:FS00:0x22: Compiler: Visual C++
18:50:23:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:50:23:WU00:FS00:0x22: -DOPENMM_VERSION="\"7.6.0\""
18:50:23:WU00:FS00:0x22: Platform: win32 10
18:50:23:WU00:FS00:0x22: Bits: 64
18:50:23:WU00:FS00:0x22: Mode: Release
18:50:23:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:50:23:WU00:FS00:0x22: <peastman@stanford.edu>
18:50:23:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7580 -checkpoint 9
18:50:23:WU00:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
18:50:23:WU00:FS00:0x22: -gpu-usage 100
18:50:23:WU00:FS00:0x22:************************************ libFAH ************************************
18:50:23:WU00:FS00:0x22: Time: 05:53:43
18:50:23:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:50:23:WU00:FS00:0x22:************************************ CBang *************************************
18:50:23:WU00:FS00:0x22: Time: 05:52:38
18:50:23:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:50:23:WU00:FS00:0x22:************************************ System ************************************
18:50:23:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
18:50:23:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:50:23:WU00:FS00:0x22: CPUs: 8
18:50:23:WU00:FS00:0x22: Memory: 15.94GiB
18:50:23:WU00:FS00:0x22:Free Memory: 11.09GiB
18:50:23:WU00:FS00:0x22: Threads: WINDOWS_THREADS
18:50:23:WU00:FS00:0x22: OS Version: 6.2
18:50:23:WU00:FS00:0x22:Has Battery: false
18:50:23:WU00:FS00:0x22: On Battery: false
18:50:23:WU00:FS00:0x22: UTC Offset: -6
18:50:23:WU00:FS00:0x22: PID: 13388
18:50:23:WU00:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
18:50:23:WU00:FS00:0x22:************************************ OpenMM ************************************
18:50:23:WU00:FS00:0x22: Version: 7.6.0
18:50:23:WU00:FS00:0x22:********************************************************************************
18:50:23:WU00:FS00:0x22:Project: 18027 (Run 4, Clone 127, Gen 7)
18:50:23:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
18:50:23:WU00:FS00:0x22:Reading tar file core.xml
18:50:23:WU00:FS00:0x22:Reading tar file integrator.xml.bz2
18:50:23:WU00:FS00:0x22:Reading tar file state.xml.bz2
18:50:23:WU00:FS00:0x22:Reading tar file system.xml.bz2
18:50:23:WU00:FS00:0x22:Digital signatures verified
18:50:23:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
18:50:23:WU00:FS00:0x22:Version 0.0.18
18:50:23:WU00:FS00:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
18:50:23:WU00:FS00:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
18:50:23:WU00:FS00:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
18:50:23:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
18:50:23:WU00:FS00:0x22:There are 3 platforms available.
18:50:23:WU00:FS00:0x22:Platform 0: Reference
18:50:23:WU00:FS00:0x22:Platform 1: CPU
18:50:23:WU00:FS00:0x22:Platform 2: OpenCL
18:50:23:WU00:FS00:0x22: opencl-device 0 specified
18:50:29:WU00:FS00:0x22:Attempting to create OpenCL context:
18:50:29:WU00:FS00:0x22: Configuring platform OpenCL
18:50:40:WU00:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
18:50:40:WU00:FS00:0x22:Completed 0 out of 250000 steps (0%)
18:50:40:WU00:FS00:0x22:Checkpoint completed at step 0
18:50:48:WU00:FS00:0x22:Completed 2500 out of 250000 steps (1%)
18:50:55:WU00:FS00:0x22:Completed 5000 out of 250000 steps (2%)
18:51:03:WU00:FS00:0x22:Completed 7500 out of 250000 steps (3%)
18:51:10:WU00:FS00:0x22:Completed 10000 out of 250000 steps (4%)
18:51:19:WU00:FS00:0x22:Completed 12500 out of 250000 steps (5%)
18:51:19:WU00:FS00:0x22:Checkpoint completed at step 12500
18:51:28:WU00:FS00:0x22:Completed 15000 out of 250000 steps (6%)
18:51:35:WU00:FS00:0x22:Completed 17500 out of 250000 steps (7%)
18:51:42:WU00:FS00:0x22:Completed 20000 out of 250000 steps (8%)
18:51:49:WU00:FS00:0x22:Completed 22500 out of 250000 steps (9%)
18:51:56:WU00:FS00:0x22:Completed 25000 out of 250000 steps (10%)
18:51:56:WU00:FS00:0x22:Checkpoint completed at step 25000
18:52:03:WU00:FS00:0x22:Completed 27500 out of 250000 steps (11%)
18:52:11:WU00:FS00:0x22:Completed 30000 out of 250000 steps (12%)
18:52:18:WU00:FS00:0x22:Completed 32500 out of 250000 steps (13%)
18:52:25:WU00:FS00:0x22:Completed 35000 out of 250000 steps (14%)
18:52:33:WU00:FS00:0x22:Completed 37500 out of 250000 steps (15%)
18:52:33:WU00:FS00:0x22:Checkpoint completed at step 37500
18:52:41:WU00:FS00:0x22:Completed 40000 out of 250000 steps (16%)
18:52:48:WU00:FS00:0x22:Completed 42500 out of 250000 steps (17%)
18:52:56:WU00:FS00:0x22:Completed 45000 out of 250000 steps (18%)
18:53:03:WU00:FS00:0x22:Completed 47500 out of 250000 steps (19%)
18:53:10:WU00:FS00:0x22:Completed 50000 out of 250000 steps (20%)
18:53:10:WU00:FS00:0x22:Checkpoint completed at step 50000
18:53:17:WU00:FS00:0x22:Completed 52500 out of 250000 steps (21%)
18:53:24:WU00:FS00:0x22:Completed 55000 out of 250000 steps (22%)
18:53:31:WU00:FS00:0x22:Completed 57500 out of 250000 steps (23%)
18:53:38:WU00:FS00:0x22:Completed 60000 out of 250000 steps (24%)
18:53:45:WU00:FS00:0x22:Completed 62500 out of 250000 steps (25%)
18:53:45:WU00:FS00:0x22:Checkpoint completed at step 62500
18:53:52:WU00:FS00:0x22:Completed 65000 out of 250000 steps (26%)
18:53:58:WU00:FS00:0x22:Completed 67500 out of 250000 steps (27%)
18:54:05:WU00:FS00:0x22:Completed 70000 out of 250000 steps (28%)
18:54:12:WU00:FS00:0x22:Completed 72500 out of 250000 steps (29%)
18:54:19:WU00:FS00:0x22:Completed 75000 out of 250000 steps (30%)
18:54:20:WU00:FS00:0x22:Checkpoint completed at step 75000
18:54:27:WU00:FS00:0x22:Completed 77500 out of 250000 steps (31%)
18:54:33:WU00:FS00:0x22:Completed 80000 out of 250000 steps (32%)
18:54:40:WU00:FS00:0x22:Completed 82500 out of 250000 steps (33%)
18:54:47:WU00:FS00:0x22:Completed 85000 out of 250000 steps (34%)
18:54:54:WU00:FS00:0x22:Completed 87500 out of 250000 steps (35%)
18:54:54:WU00:FS00:0x22:Checkpoint completed at step 87500
18:55:01:WU00:FS00:0x22:Completed 90000 out of 250000 steps (36%)
18:55:08:WU00:FS00:0x22:Completed 92500 out of 250000 steps (37%)
18:55:15:WU00:FS00:0x22:Completed 95000 out of 250000 steps (38%)
18:55:22:WU00:FS00:0x22:Completed 97500 out of 250000 steps (39%)
18:55:29:WU00:FS00:0x22:Completed 100000 out of 250000 steps (40%)
18:55:29:WU00:FS00:0x22:Checkpoint completed at step 100000
18:55:36:WU00:FS00:0x22:Completed 102500 out of 250000 steps (41%)
18:55:43:WU00:FS00:0x22:Completed 105000 out of 250000 steps (42%)
18:55:49:WU00:FS00:0x22:Completed 107500 out of 250000 steps (43%)
18:55:57:WU00:FS00:0x22:Completed 110000 out of 250000 steps (44%)
19:05:59:WU00:FS00:0x22:Watchdog triggered, requesting soft shutdown down
Log 2:
*********************** Log Started 2021-12-22T19:14:44Z ***********************
19:14:44:******************************* libFAH ********************************
19:14:44: Date: Oct 20 2020
19:14:44: Time: 13:36:55
19:14:44: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:14:44: Branch: master
19:14:44: Compiler: Visual C++ 2015
19:14:44: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:14:44: Platform: win32 10
19:14:44: Bits: 32
19:14:44: Mode: Release
19:14:44:****************************** FAHClient ******************************
19:14:44: Version: 7.6.21
19:14:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:14:44: Copyright: 2020 foldingathome.org
19:14:44: Homepage: https://foldingathome.org/
19:14:44: Time: 13:41:04
19:14:44: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:14:44: Bits: 32
19:14:44: Config: C:\Users\Keith\AppData\Roaming\FAHClient\config.xml
19:14:44:******************************** CBang ********************************
19:14:44: Time: 11:36:18
19:14:44: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:14:44: Bits: 32
19:14:44:******************************* System ********************************
19:14:44: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
19:14:44: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:14:44: CPUs: 8
19:14:44: Memory: 15.94GiB
19:14:44: Free Memory: 12.11GiB
19:14:44: Threads: WINDOWS_THREADS
19:14:44: OS Version: 6.2
19:14:44: Has Battery: false
19:14:44: On Battery: false
19:14:44: UTC Offset: -6
19:14:44: PID: 15224
19:14:44: CWD: C:\Users\Keith\AppData\Roaming\FAHClient
19:14:44: Win32 Service: false
19:14:44: OS: Windows 10 Enterprise
19:14:44: OS Arch: AMD64
19:14:44: GPUs: 1
19:14:44: GPU 0: Bus:3 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
19:14:44: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:14:44: specified module could not be found.
19:14:44:
19:14:44:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3354.13
19:14:44:***********************************************************************
19:14:44:<config>
19:14:44: <!-- Folding Core -->
19:14:44: <checkpoint v='9'/>
19:14:44: <core-priority v='low'/>
19:14:44:
19:14:44: <!-- Network -->
19:14:44: <proxy v=':8080'/>
19:14:44:
19:14:44: <!-- Slot Control -->
19:14:44: <pause-on-battery v='false'/>
19:14:44:
19:14:44: <!-- User Information -->
19:14:44: <passkey v='*****'/>
19:14:44: <team v='224497'/>
19:14:44: <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
19:14:44:
19:14:44: <!-- Folding Slots -->
19:14:44: <slot id='0' type='GPU'>
19:14:44: <pci-bus v='3'/>
19:14:44: <pci-slot v='0'/>
19:14:44: </slot>
19:14:44:</config>
19:14:44:Trying to access database...
19:14:44:Successfully acquired database lock
19:14:44:FS00:Initialized folding slot 00: gpu:3:0 Vega 10 XL/XT [Radeon RX Vega 56/64]
19:14:44:WU00:FS00:Starting
19:14:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15224 -checkpoint 9 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
19:14:47:WU00:FS00:Started FahCore on PID 15928
19:14:47:WU00:FS00:Core PID:16200
19:14:47:WU00:FS00:FahCore 0x22 started
19:14:48:WU00:FS00:0x22:*********************** Log Started 2021-12-22T19:14:48Z ***********************
19:14:48:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:14:48:WU00:FS00:0x22: Core: Core22
19:14:48:WU00:FS00:0x22: Type: 0x22
19:14:48:WU00:FS00:0x22: Version: 0.0.18
19:14:48:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:14:48:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
19:14:48:WU00:FS00:0x22: Homepage: https://foldingathome.org/
19:14:48:WU00:FS00:0x22: Date: Sep 28 2021
19:14:48:WU00:FS00:0x22: Time: 05:55:05
19:14:48:WU00:FS00:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
19:14:48:WU00:FS00:0x22: Branch: HEAD
19:14:48:WU00:FS00:0x22: Compiler: Visual C++
19:14:48:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:14:48:WU00:FS00:0x22: -DOPENMM_VERSION="\"7.6.0\""
19:14:48:WU00:FS00:0x22: Platform: win32 10
19:14:48:WU00:FS00:0x22: Bits: 64
19:14:48:WU00:FS00:0x22: Mode: Release
19:14:48:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:14:48:WU00:FS00:0x22: <peastman@stanford.edu>
19:14:48:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 15928 -checkpoint 9
19:14:48:WU00:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
19:14:48:WU00:FS00:0x22: -gpu-usage 100
19:14:48:WU00:FS00:0x22:************************************ libFAH ************************************
19:14:48:WU00:FS00:0x22: Time: 05:53:43
19:14:48:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:14:48:WU00:FS00:0x22:************************************ CBang *************************************
19:14:48:WU00:FS00:0x22: Time: 05:52:38
19:14:48:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:14:48:WU00:FS00:0x22:************************************ System ************************************
19:14:48:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
19:14:48:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:14:48:WU00:FS00:0x22: CPUs: 8
19:14:48:WU00:FS00:0x22: Memory: 15.94GiB
19:14:48:WU00:FS00:0x22:Free Memory: 11.78GiB
19:14:48:WU00:FS00:0x22: Threads: WINDOWS_THREADS
19:14:48:WU00:FS00:0x22: OS Version: 6.2
19:14:48:WU00:FS00:0x22:Has Battery: false
19:14:48:WU00:FS00:0x22: On Battery: false
19:14:48:WU00:FS00:0x22: UTC Offset: -6
19:14:48:WU00:FS00:0x22: PID: 16200
19:14:48:WU00:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
19:14:48:WU00:FS00:0x22:************************************ OpenMM ************************************
19:14:48:WU00:FS00:0x22: Version: 7.6.0
19:14:48:WU00:FS00:0x22:********************************************************************************
19:14:48:WU00:FS00:0x22:Project: 18027 (Run 4, Clone 127, Gen 7)
19:14:48:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
19:14:48:WU00:FS00:0x22:Digital signatures verified
19:14:48:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:14:48:WU00:FS00:0x22:Version 0.0.18
19:14:48:WU00:FS00:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
19:14:48:WU00:FS00:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
19:14:48:WU00:FS00:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
19:14:48:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
19:14:48:WU00:FS00:0x22:There are 3 platforms available.
19:14:48:WU00:FS00:0x22:Platform 0: Reference
19:14:48:WU00:FS00:0x22:Platform 1: CPU
19:14:48:WU00:FS00:0x22:Platform 2: OpenCL
19:14:48:WU00:FS00:0x22: opencl-device 0 specified
19:14:55:WU00:FS00:0x22:Attempting to create OpenCL context:
19:14:55:WU00:FS00:0x22: Configuring platform OpenCL
19:15:01:WU00:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
19:15:01:WU00:FS00:0x22:Completed 100000 out of 250000 steps (40%)
19:15:11:WU00:FS00:0x22:Completed 102500 out of 250000 steps (41%)
19:15:31:WU00:FS00:0x22:Completed 105000 out of 250000 steps (42%)
19:15:31:FS00:Paused
19:15:31:FS00:Shutting core down
19:15:32:WU00:FS00:0x22:WARNING:Console control signal 1 on PID 16200
19:15:32:WU00:FS00:0x22:Exiting, please wait. . .
19:15:32:WU00:FS00:0x22:Folding@home Core Shutdown: INTERRUPTED
19:15:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:15:45:Removing old file 'configs/config-20211220-031903.xml'
19:15:45:Saving configuration to config.xml
19:15:45:<config>
19:15:45: <!-- Folding Core -->
19:15:45: <checkpoint v='9'/>
19:15:45: <core-priority v='low'/>
19:15:45:
19:15:45: <!-- Network -->
19:15:45: <proxy v=':8080'/>
19:15:45:
19:15:45: <!-- Slot Control -->
19:15:45: <pause-on-battery v='false'/>
19:15:45:
19:15:45: <!-- User Information -->
19:15:45: <passkey v='*****'/>
19:15:45: <team v='224497'/>
19:15:45: <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
19:15:45:
19:15:45: <!-- Folding Slots -->
19:15:45: <slot id='0' type='GPU'>
19:15:45: <paused v='true'/>
19:15:45: <pci-bus v='3'/>
19:15:45: <pci-slot v='0'/>
19:15:45: </slot>
19:15:45:</config>
19:16:17:FS00:Unpaused
19:16:17:WU00:FS00:Starting
19:16:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15224 -checkpoint 9 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
19:16:17:WU00:FS00:Started FahCore on PID 12864
19:16:17:WU00:FS00:Core PID:19132
19:16:17:WU00:FS00:FahCore 0x22 started
19:16:17:WU00:FS00:0x22:*********************** Log Started 2021-12-22T19:16:17Z ***********************
19:16:17:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:16:17:WU00:FS00:0x22: Core: Core22
19:16:17:WU00:FS00:0x22: Type: 0x22
19:16:17:WU00:FS00:0x22: Version: 0.0.18
19:16:17:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:16:17:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
19:16:17:WU00:FS00:0x22: Homepage: https://foldingathome.org/
19:16:17:WU00:FS00:0x22: Date: Sep 28 2021
19:16:17:WU00:FS00:0x22: Time: 05:55:05
19:16:17:WU00:FS00:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
19:16:17:WU00:FS00:0x22: Branch: HEAD
19:16:17:WU00:FS00:0x22: Compiler: Visual C++
19:16:17:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:16:17:WU00:FS00:0x22: -DOPENMM_VERSION="\"7.6.0\""
19:16:17:WU00:FS00:0x22: Platform: win32 10
19:16:17:WU00:FS00:0x22: Bits: 64
19:16:17:WU00:FS00:0x22: Mode: Release
19:16:17:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:16:17:WU00:FS00:0x22: <peastman@stanford.edu>
19:16:17:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 12864 -checkpoint 9
19:16:17:WU00:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
19:16:17:WU00:FS00:0x22: -gpu-usage 100
19:16:17:WU00:FS00:0x22:************************************ libFAH ************************************
19:16:17:WU00:FS00:0x22: Time: 05:53:43
19:16:17:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:16:18:WU00:FS00:0x22: Platform: win32 10
19:16:18:WU00:FS00:0x22: Bits: 64
19:16:18:WU00:FS00:0x22: Mode: Release
19:16:18:WU00:FS00:0x22:************************************ CBang *************************************
19:16:18:WU00:FS00:0x22: Date: Sep 28 2021
19:16:18:WU00:FS00:0x22: Time: 05:52:38
19:16:18:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:16:18:WU00:FS00:0x22: Branch: HEAD
19:16:18:WU00:FS00:0x22: Compiler: Visual C++
19:16:18:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:16:18:WU00:FS00:0x22:************************************ System ************************************
19:16:18:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
19:16:18:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:16:18:WU00:FS00:0x22: CPUs: 8
19:16:18:WU00:FS00:0x22: Memory: 15.94GiB
19:16:18:WU00:FS00:0x22:Free Memory: 9.11GiB
19:16:18:WU00:FS00:0x22: Threads: WINDOWS_THREADS
19:16:18:WU00:FS00:0x22: OS Version: 6.2
19:16:18:WU00:FS00:0x22:Has Battery: false
19:16:18:WU00:FS00:0x22: On Battery: false
19:16:18:WU00:FS00:0x22: UTC Offset: -6
19:16:18:WU00:FS00:0x22: PID: 19132
19:16:18:WU00:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
19:16:18:WU00:FS00:0x22:************************************ OpenMM ************************************
19:16:18:WU00:FS00:0x22: Version: 7.6.0
19:16:18:WU00:FS00:0x22:********************************************************************************
19:16:18:WU00:FS00:0x22:Project: 18027 (Run 4, Clone 127, Gen 7)
19:16:18:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
19:16:18:WU00:FS00:0x22:Digital signatures verified
19:16:18:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:16:18:WU00:FS00:0x22:Version 0.0.18
19:16:18:WU00:FS00:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
19:16:18:WU00:FS00:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
19:16:18:WU00:FS00:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
19:16:18:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
19:16:18:WU00:FS00:0x22:There are 3 platforms available.
19:16:18:WU00:FS00:0x22:Platform 0: Reference
19:16:18:WU00:FS00:0x22:Platform 1: CPU
19:16:18:WU00:FS00:0x22:Platform 2: OpenCL
19:16:18:WU00:FS00:0x22: opencl-device 0 specified
19:16:21:WU00:FS00:0x22:Attempting to create OpenCL context:
19:16:21:WU00:FS00:0x22: Configuring platform OpenCL
19:16:26:WU00:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
19:16:27:WU00:FS00:0x22:Completed 100000 out of 250000 steps (40%)
19:16:36:WU00:FS00:0x22:Completed 102500 out of 250000 steps (41%)
19:16:44:WU00:FS00:0x22:Completed 105000 out of 250000 steps (42%)
19:16:46:Removing old file 'configs/config-20211220-035640.xml'
19:16:46:Saving configuration to config.xml
19:16:46:<config>
19:16:46: <!-- Folding Core -->
19:16:46: <checkpoint v='9'/>
19:16:46: <core-priority v='low'/>
19:16:46:
19:16:46: <!-- Network -->
19:16:46: <proxy v=':8080'/>
19:16:46:
19:16:46: <!-- Slot Control -->
19:16:46: <pause-on-battery v='false'/>
19:16:46:
19:16:46: <!-- User Information -->
19:16:46: <passkey v='*****'/>
19:16:46: <team v='224497'/>
19:16:46: <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
19:16:46:
19:16:46: <!-- Folding Slots -->
19:16:46: <slot id='0' type='GPU'>
19:16:46: <pci-bus v='3'/>
19:16:46: <pci-slot v='0'/>
19:16:46: </slot>
19:16:46:</config>
19:16:51:WU00:FS00:0x22:Completed 107500 out of 250000 steps (43%)
19:16:58:WU00:FS00:0x22:Completed 110000 out of 250000 steps (44%)
19:17:05:WU00:FS00:0x22:Completed 112500 out of 250000 steps (45%)
19:17:05:WU00:FS00:0x22:Checkpoint completed at step 112500
19:17:12:WU00:FS00:0x22:Completed 115000 out of 250000 steps (46%)
19:17:20:WU00:FS00:0x22:Completed 117500 out of 250000 steps (47%)
19:17:28:WU00:FS00:0x22:Completed 120000 out of 250000 steps (48%)
19:17:35:WU00:FS00:0x22:Completed 122500 out of 250000 steps (49%)
19:17:42:WU00:FS00:0x22:Completed 125000 out of 250000 steps (50%)
19:17:43:WU00:FS00:0x22:Checkpoint completed at step 125000
19:17:50:WU00:FS00:0x22:Completed 127500 out of 250000 steps (51%)
19:17:57:WU00:FS00:0x22:Completed 130000 out of 250000 steps (52%)
19:18:04:WU00:FS00:0x22:Completed 132500 out of 250000 steps (53%)
19:18:10:WU00:FS00:0x22:Completed 135000 out of 250000 steps (54%)
19:18:17:WU00:FS00:0x22:Completed 137500 out of 250000 steps (55%)
19:18:18:WU00:FS00:0x22:Checkpoint completed at step 137500
19:18:25:WU00:FS00:0x22:Completed 140000 out of 250000 steps (56%)
19:18:32:WU00:FS00:0x22:Completed 142500 out of 250000 steps (57%)
19:18:38:WU00:FS00:0x22:Completed 145000 out of 250000 steps (58%)
19:18:45:WU00:FS00:0x22:Completed 147500 out of 250000 steps (59%)
19:18:52:WU00:FS00:0x22:Completed 150000 out of 250000 steps (60%)
19:18:53:WU00:FS00:0x22:Checkpoint completed at step 150000
19:18:59:WU00:FS00:0x22:Completed 152500 out of 250000 steps (61%)
19:19:06:WU00:FS00:0x22:Completed 155000 out of 250000 steps (62%)
19:19:13:WU00:FS00:0x22:Completed 157500 out of 250000 steps (63%)
19:19:20:WU00:FS00:0x22:Completed 160000 out of 250000 steps (64%)
19:19:27:WU00:FS00:0x22:Completed 162500 out of 250000 steps (65%)
19:19:27:WU00:FS00:0x22:Checkpoint completed at step 162500
19:19:34:WU00:FS00:0x22:Completed 165000 out of 250000 steps (66%)
19:19:42:WU00:FS00:0x22:Completed 167500 out of 250000 steps (67%)
19:19:48:WU00:FS00:0x22:Completed 170000 out of 250000 steps (68%)
19:19:55:WU00:FS00:0x22:Completed 172500 out of 250000 steps (69%)
19:20:02:WU00:FS00:0x22:Completed 175000 out of 250000 steps (70%)
19:20:03:WU00:FS00:0x22:Checkpoint completed at step 175000
19:20:10:WU00:FS00:0x22:Completed 177500 out of 250000 steps (71%)
19:20:17:WU00:FS00:0x22:Completed 180000 out of 250000 steps (72%)
19:20:24:WU00:FS00:0x22:Completed 182500 out of 250000 steps (73%)
19:20:33:WU00:FS00:0x22:An exception occurred at step 184986: Particle coordinate is nan
19:20:33:WU00:FS00:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
19:20:33:WU00:FS00:0x22:Folding@home Core Shutdown: CORE_RESTART
19:20:33:WARNING:WU00:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
19:20:34:WU00:FS00:Starting
19:20:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15224 -checkpoint 9 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
19:20:34:WU00:FS00:Started FahCore on PID 16360
19:20:34:WU00:FS00:Core PID:14440
19:20:34:WU00:FS00:FahCore 0x22 started
19:20:34:WU00:FS00:0x22:*********************** Log Started 2021-12-22T19:20:34Z ***********************
19:20:34:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:20:34:WU00:FS00:0x22: Core: Core22
19:20:34:WU00:FS00:0x22: Type: 0x22
19:20:34:WU00:FS00:0x22: Version: 0.0.18
19:20:34:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:20:34:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
19:20:34:WU00:FS00:0x22: Homepage: https://foldingathome.org/
19:20:34:WU00:FS00:0x22: Date: Sep 28 2021
19:20:34:WU00:FS00:0x22: Time: 05:55:05
19:20:34:WU00:FS00:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
19:20:34:WU00:FS00:0x22: Branch: HEAD
19:20:34:WU00:FS00:0x22: Compiler: Visual C++
19:20:34:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:20:34:WU00:FS00:0x22: -DOPENMM_VERSION="\"7.6.0\""
19:20:34:WU00:FS00:0x22: Platform: win32 10
19:20:34:WU00:FS00:0x22: Bits: 64
19:20:34:WU00:FS00:0x22: Mode: Release
19:20:34:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:20:34:WU00:FS00:0x22: <peastman@stanford.edu>
19:20:34:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 16360 -checkpoint 9
19:20:34:WU00:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
19:20:34:WU00:FS00:0x22: -gpu-usage 100
19:20:34:WU00:FS00:0x22:************************************ libFAH ************************************
19:20:34:WU00:FS00:0x22: Time: 05:53:43
19:20:34:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:20:34:WU00:FS00:0x22:************************************ CBang *************************************
19:20:34:WU00:FS00:0x22: Time: 05:52:38
19:20:34:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:20:34:WU00:FS00:0x22:************************************ System ************************************
19:20:34:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
19:20:34:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:20:34:WU00:FS00:0x22: CPUs: 8
19:20:34:WU00:FS00:0x22: Memory: 15.94GiB
19:20:34:WU00:FS00:0x22:Free Memory: 8.66GiB
19:20:34:WU00:FS00:0x22: Threads: WINDOWS_THREADS
19:20:34:WU00:FS00:0x22: OS Version: 6.2
19:20:34:WU00:FS00:0x22:Has Battery: false
19:20:34:WU00:FS00:0x22: On Battery: false
19:20:34:WU00:FS00:0x22: UTC Offset: -6
19:20:34:WU00:FS00:0x22: PID: 14440
19:20:34:WU00:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
19:20:34:WU00:FS00:0x22:************************************ OpenMM ************************************
19:20:34:WU00:FS00:0x22: Version: 7.6.0
19:20:34:WU00:FS00:0x22:********************************************************************************
19:20:34:WU00:FS00:0x22:Project: 18027 (Run 4, Clone 127, Gen 7)
19:20:34:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
19:20:34:WU00:FS00:0x22:Digital signatures verified
19:20:34:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:20:34:WU00:FS00:0x22:Version 0.0.18
19:20:34:WU00:FS00:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
19:20:34:WU00:FS00:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
19:20:34:WU00:FS00:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
19:20:34:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
19:20:34:WU00:FS00:0x22:There are 3 platforms available.
19:20:34:WU00:FS00:0x22:Platform 0: Reference
19:20:34:WU00:FS00:0x22:Platform 1: CPU
19:20:34:WU00:FS00:0x22:Platform 2: OpenCL
19:20:34:WU00:FS00:0x22: opencl-device 0 specified
19:20:38:WU00:FS00:0x22:Attempting to create OpenCL context:
19:20:38:WU00:FS00:0x22: Configuring platform OpenCL
19:20:43:WU00:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
19:20:43:WU00:FS00:0x22:Completed 175000 out of 250000 steps (70%)
19:20:51:WU00:FS00:0x22:Completed 177500 out of 250000 steps (71%)
19:20:58:WU00:FS00:0x22:Completed 180000 out of 250000 steps (72%)
19:21:05:WU00:FS00:0x22:Completed 182500 out of 250000 steps (73%)
19:21:12:WU00:FS00:0x22:Completed 185000 out of 250000 steps (74%)
19:21:19:WU00:FS00:0x22:Completed 187500 out of 250000 steps (75%)
19:21:20:WU00:FS00:0x22:Checkpoint completed at step 187500
19:21:27:WU00:FS00:0x22:Completed 190000 out of 250000 steps (76%)
19:21:34:WU00:FS00:0x22:Completed 192500 out of 250000 steps (77%)
19:21:41:WU00:FS00:0x22:Completed 195000 out of 250000 steps (78%)
19:21:48:WU00:FS00:0x22:Completed 197500 out of 250000 steps (79%)
19:21:55:WU00:FS00:0x22:Completed 200000 out of 250000 steps (80%)
19:21:55:WU00:FS00:0x22:Checkpoint completed at step 200000
19:22:02:WU00:FS00:0x22:Completed 202500 out of 250000 steps (81%)
19:22:09:WU00:FS00:0x22:Completed 205000 out of 250000 steps (82%)
19:22:16:WU00:FS00:0x22:Completed 207500 out of 250000 steps (83%)
19:22:23:WU00:FS00:0x22:Completed 210000 out of 250000 steps (84%)
19:22:30:WU00:FS00:0x22:Completed 212500 out of 250000 steps (85%)
19:22:31:WU00:FS00:0x22:Checkpoint completed at step 212500
19:22:38:WU00:FS00:0x22:Completed 215000 out of 250000 steps (86%)
19:22:45:WU00:FS00:0x22:Completed 217500 out of 250000 steps (87%)
19:22:52:WU00:FS00:0x22:Completed 220000 out of 250000 steps (88%)
19:22:59:WU00:FS00:0x22:Completed 222500 out of 250000 steps (89%)
19:23:06:WU00:FS00:0x22:Completed 225000 out of 250000 steps (90%)
19:23:06:WU00:FS00:0x22:Checkpoint completed at step 225000
19:23:13:WU00:FS00:0x22:Completed 227500 out of 250000 steps (91%)
19:23:20:WU00:FS00:0x22:Completed 230000 out of 250000 steps (92%)
19:23:27:WU00:FS00:0x22:Completed 232500 out of 250000 steps (93%)
19:23:34:WU00:FS00:0x22:Completed 235000 out of 250000 steps (94%)
19:23:41:WU00:FS00:0x22:Completed 237500 out of 250000 steps (95%)
19:23:41:WU00:FS00:0x22:Checkpoint completed at step 237500
19:23:48:WU00:FS00:0x22:Completed 240000 out of 250000 steps (96%)
19:23:55:WU00:FS00:0x22:Completed 242500 out of 250000 steps (97%)
19:24:02:WU00:FS00:0x22:Completed 245000 out of 250000 steps (98%)
19:24:09:WU00:FS00:0x22:Completed 247500 out of 250000 steps (99%)
19:24:10:WU01:FS00:Connecting to assign1.foldingathome.org:80
19:24:10:WU01:FS00:Assigned to work server 34.72.228.44
19:24:10:WU01:FS00:Requesting new work unit for slot 00: gpu:3:0 Vega 10 XL/XT [Radeon RX Vega 56/64] from 34.72.228.44
19:24:10:WU01:FS00:Connecting to 34.72.228.44:8080
19:24:11:WU01:FS00:Downloading 2.76MiB
19:24:12:WU01:FS00:Download complete
19:24:12:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18027 run:9 clone:139 gen:1 core:0x22 unit:0x0000008b000000010000466b00000009
19:24:16:WU00:FS00:0x22:Completed 250000 out of 250000 steps (100%)
19:24:16:WU00:FS00:0x22:Average performance: 246.857 ns/day
19:24:17:WU00:FS00:0x22:Checkpoint completed at step 250000
19:24:20:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
19:24:20:WU00:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
19:24:20:WU00:FS00:0x22:Saving result file checkpointState.xml.bz2
19:24:20:WU00:FS00:0x22:Saving result file positions.xtc
19:24:20:WU00:FS00:0x22:Saving result file science.log
19:24:20:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:24:20:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:24:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18027 run:4 clone:127 gen:7 core:0x22 unit:0x0000007f000000070000466b00000004
19:24:21:WU00:FS00:Uploading 3.28MiB to 34.72.228.44
19:24:21:WU00:FS00:Connecting to 34.72.228.44:8080
19:24:21:WU01:FS00:Starting
19:24:21:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 15224 -checkpoint 9 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
19:24:21:WU01:FS00:Started FahCore on PID 8904
19:24:21:WU01:FS00:Core PID:19700
19:24:21:WU01:FS00:FahCore 0x22 started
19:24:21:WU01:FS00:0x22:*********************** Log Started 2021-12-22T19:24:21Z ***********************
19:24:21:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:24:21:WU01:FS00:0x22: Core: Core22
19:24:21:WU01:FS00:0x22: Type: 0x22
19:24:21:WU01:FS00:0x22: Version: 0.0.18
19:24:21:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:24:21:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
19:24:21:WU01:FS00:0x22: Homepage: https://foldingathome.org/
19:24:21:WU01:FS00:0x22: Date: Sep 28 2021
19:24:21:WU01:FS00:0x22: Time: 05:55:05
19:24:21:WU01:FS00:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
19:24:21:WU01:FS00:0x22: Branch: HEAD
19:24:21:WU01:FS00:0x22: Compiler: Visual C++
19:24:21:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:24:21:WU01:FS00:0x22: -DOPENMM_VERSION="\"7.6.0\""
19:24:21:WU01:FS00:0x22: Platform: win32 10
19:24:21:WU01:FS00:0x22: Bits: 64
19:24:21:WU01:FS00:0x22: Mode: Release
19:24:21:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:24:21:WU01:FS00:0x22: <peastman@stanford.edu>
19:24:21:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8904 -checkpoint 9
19:24:21:WU01:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
19:24:21:WU01:FS00:0x22: -gpu-usage 100
19:24:21:WU01:FS00:0x22:************************************ libFAH ************************************
19:24:21:WU01:FS00:0x22: Time: 05:53:43
19:24:21:WU01:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:24:21:WU01:FS00:0x22:************************************ CBang *************************************
19:24:21:WU01:FS00:0x22: Time: 05:52:38
19:24:21:WU01:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:24:21:WU01:FS00:0x22:************************************ System ************************************
19:24:21:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
19:24:21:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:24:21:WU01:FS00:0x22: CPUs: 8
19:24:21:WU01:FS00:0x22: Memory: 15.94GiB
19:24:21:WU01:FS00:0x22:Free Memory: 8.80GiB
19:24:21:WU01:FS00:0x22: Threads: WINDOWS_THREADS
19:24:21:WU01:FS00:0x22: OS Version: 6.2
19:24:21:WU01:FS00:0x22:Has Battery: false
19:24:21:WU01:FS00:0x22: On Battery: false
19:24:21:WU01:FS00:0x22: UTC Offset: -6
19:24:21:WU01:FS00:0x22: PID: 19700
19:24:21:WU01:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
19:24:21:WU01:FS00:0x22:************************************ OpenMM ************************************
19:24:21:WU01:FS00:0x22: Version: 7.6.0
19:24:21:WU01:FS00:0x22:********************************************************************************
19:24:21:WU01:FS00:0x22:Project: 18027 (Run 9, Clone 139, Gen 1)
19:24:21:WU01:FS00:0x22:Unit: 0x00000000000000000000000000000000
19:24:21:WU01:FS00:0x22:Reading tar file core.xml
19:24:21:WU01:FS00:0x22:Reading tar file integrator.xml.bz2
19:24:21:WU01:FS00:0x22:Reading tar file state.xml.bz2
19:24:21:WU01:FS00:0x22:Reading tar file system.xml.bz2
19:24:21:WU01:FS00:0x22:Digital signatures verified
19:24:21:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:24:21:WU01:FS00:0x22:Version 0.0.18
19:24:21:WU01:FS00:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
19:24:21:WU01:FS00:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
19:24:21:WU01:FS00:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
19:24:21:WU01:FS00:0x22: Global context and integrator variables write interval: disabled
19:24:21:WU01:FS00:0x22:There are 3 platforms available.
19:24:21:WU01:FS00:0x22:Platform 0: Reference
19:24:21:WU01:FS00:0x22:Platform 1: CPU
19:24:21:WU01:FS00:0x22:Platform 2: OpenCL
19:24:21:WU01:FS00:0x22: opencl-device 0 specified
19:24:24:WU01:FS00:0x22:Attempting to create OpenCL context:
19:24:24:WU01:FS00:0x22: Configuring platform OpenCL
19:24:27:WU00:FS00:Upload 20.94%
19:24:30:WU01:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
19:24:30:WU01:FS00:0x22:Completed 0 out of 250000 steps (0%)
19:24:30:WU01:FS00:0x22:Checkpoint completed at step 0
19:24:33:WU00:FS00:Upload 39.98%
19:24:38:WU01:FS00:0x22:Completed 2500 out of 250000 steps (1%)
19:24:39:WU00:FS00:Upload 57.11%
19:24:45:WU00:FS00:Upload 72.34%
19:24:45:WU01:FS00:0x22:Completed 5000 out of 250000 steps (2%)
19:24:51:WU00:FS00:Upload 89.47%
19:24:53:WU01:FS00:0x22:Completed 7500 out of 250000 steps (3%)
19:24:57:WU00:FS00:Upload complete
19:24:57:WU00:FS00:Server responded WORK_ACK (400)
19:24:57:WU00:FS00:Final credit estimate, 7891.00 points
19:24:57:WU00:FS00:Cleaning up
19:25:00:WU01:FS00:0x22:Completed 10000 out of 250000 steps (4%)
19:25:07:WU01:FS00:0x22:Completed 12500 out of 250000 steps (5%)
19:25:08:WU01:FS00:0x22:Checkpoint completed at step 12500
19:25:16:WU01:FS00:0x22:Completed 15000 out of 250000 steps (6%)
19:25:25:WU01:FS00:0x22:Completed 17500 out of 250000 steps (7%)
19:25:33:WU01:FS00:0x22:Completed 20000 out of 250000 steps (8%)
19:25:40:WU01:FS00:0x22:Completed 22500 out of 250000 steps (9%)
19:25:47:WU01:FS00:0x22:Completed 25000 out of 250000 steps (10%)
19:25:48:WU01:FS00:0x22:Checkpoint completed at step 25000
19:25:56:WU01:FS00:0x22:Completed 27500 out of 250000 steps (11%)
19:26:03:WU01:FS00:0x22:Completed 30000 out of 250000 steps (12%)
19:26:11:WU01:FS00:0x22:Completed 32500 out of 250000 steps (13%)
19:26:19:WU01:FS00:0x22:Completed 35000 out of 250000 steps (14%)
19:26:26:WU01:FS00:0x22:Completed 37500 out of 250000 steps (15%)
19:26:27:WU01:FS00:0x22:Checkpoint completed at step 37500
19:26:34:WU01:FS00:0x22:Completed 40000 out of 250000 steps (16%)
19:26:42:WU01:FS00:0x22:Completed 42500 out of 250000 steps (17%)
19:26:49:WU01:FS00:0x22:Completed 45000 out of 250000 steps (18%)
19:26:57:WU01:FS00:0x22:Completed 47500 out of 250000 steps (19%)
19:27:05:WU01:FS00:0x22:Completed 50000 out of 250000 steps (20%)
19:27:06:WU01:FS00:0x22:Checkpoint completed at step 50000
19:27:14:WU01:FS00:0x22:Completed 52500 out of 250000 steps (21%)
19:27:21:WU01:FS00:0x22:Completed 55000 out of 250000 steps (22%)
19:27:29:WU01:FS00:0x22:Completed 57500 out of 250000 steps (23%)
19:27:37:WU01:FS00:0x22:Completed 60000 out of 250000 steps (24%)
19:27:44:WU01:FS00:0x22:Completed 62500 out of 250000 steps (25%)
19:27:45:WU01:FS00:0x22:Checkpoint completed at step 62500
19:27:52:WU01:FS00:0x22:Completed 65000 out of 250000 steps (26%)
19:28:00:WU01:FS00:0x22:Completed 67500 out of 250000 steps (27%)
19:28:08:WU01:FS00:0x22:Completed 70000 out of 250000 steps (28%)
19:28:16:WU01:FS00:0x22:Completed 72500 out of 250000 steps (29%)
19:28:23:WU01:FS00:0x22:Completed 75000 out of 250000 steps (30%)
19:28:23:WU01:FS00:0x22:Checkpoint completed at step 75000
19:28:30:WU01:FS00:0x22:Completed 77500 out of 250000 steps (31%)
19:28:38:WU01:FS00:0x22:Completed 80000 out of 250000 steps (32%)
19:28:45:WU01:FS00:0x22:Completed 82500 out of 250000 steps (33%)
19:28:52:WU01:FS00:0x22:Completed 85000 out of 250000 steps (34%)
19:29:00:WU01:FS00:0x22:Completed 87500 out of 250000 steps (35%)
19:29:00:WU01:FS00:0x22:Checkpoint completed at step 87500
19:29:07:WU01:FS00:0x22:Completed 90000 out of 250000 steps (36%)
19:29:15:WU01:FS00:0x22:Completed 92500 out of 250000 steps (37%)
19:29:21:WU01:FS00:0x22:Completed 95000 out of 250000 steps (38%)
19:29:29:WU01:FS00:0x22:Completed 97500 out of 250000 steps (39%)
19:29:36:WU01:FS00:0x22:Completed 100000 out of 250000 steps (40%)
19:29:36:WU01:FS00:0x22:Checkpoint completed at step 100000
19:29:43:WU01:FS00:0x22:Completed 102500 out of 250000 steps (41%)
19:29:50:WU01:FS00:0x22:Completed 105000 out of 250000 steps (42%)
19:29:57:WU01:FS00:0x22:Completed 107500 out of 250000 steps (43%)
19:30:04:WU01:FS00:0x22:Completed 110000 out of 250000 steps (44%)
19:30:11:WU01:FS00:0x22:Completed 112500 out of 250000 steps (45%)
19:30:11:WU01:FS00:0x22:Checkpoint completed at step 112500
19:30:20:WU01:FS00:0x22:Completed 115000 out of 250000 steps (46%)
19:30:29:WU01:FS00:0x22:Completed 117500 out of 250000 steps (47%)
19:30:40:WU01:FS00:0x22:Completed 120000 out of 250000 steps (48%)
19:30:51:WU01:FS00:0x22:Completed 122500 out of 250000 steps (49%)
19:31:00:WU01:FS00:0x22:Completed 125000 out of 250000 steps (50%)
19:31:01:WU01:FS00:0x22:Checkpoint completed at step 125000
19:31:08:WU01:FS00:0x22:Completed 127500 out of 250000 steps (51%)
19:31:16:WU01:FS00:0x22:Completed 130000 out of 250000 steps (52%)
19:31:23:WU01:FS00:0x22:Completed 132500 out of 250000 steps (53%)
19:31:31:WU01:FS00:0x22:Completed 135000 out of 250000 steps (54%)
19:31:38:WU01:FS00:0x22:Completed 137500 out of 250000 steps (55%)
19:31:38:WU01:FS00:0x22:Checkpoint completed at step 137500
19:31:46:WU01:FS00:0x22:Completed 140000 out of 250000 steps (56%)
19:31:56:WU01:FS00:0x22:Completed 142500 out of 250000 steps (57%)
19:32:03:WU01:FS00:0x22:Completed 145000 out of 250000 steps (58%)
19:32:11:WU01:FS00:0x22:Completed 147500 out of 250000 steps (59%)
19:32:19:WU01:FS00:0x22:Completed 150000 out of 250000 steps (60%)
19:32:19:WU01:FS00:0x22:Checkpoint completed at step 150000
19:32:27:WU01:FS00:0x22:Completed 152500 out of 250000 steps (61%)
19:32:36:WU01:FS00:0x22:Completed 155000 out of 250000 steps (62%)
19:32:48:WU01:FS00:0x22:Completed 157500 out of 250000 steps (63%)
19:33:25:WU01:FS00:0x22:Completed 160000 out of 250000 steps (64%)
19:33:42:WU01:FS00:0x22:Completed 162500 out of 250000 steps (65%)
19:33:43:9:127.0.0.1:New Web session
19:33:43:WU01:FS00:0x22:Checkpoint completed at step 162500
19:33:46:11:127.0.0.1:New Web session
19:33:53:WU01:FS00:0x22:Completed 165000 out of 250000 steps (66%)
19:34:00:WU01:FS00:0x22:Completed 167500 out of 250000 steps (67%)
19:34:07:WU01:FS00:0x22:Completed 170000 out of 250000 steps (68%)
19:34:15:WU01:FS00:0x22:Completed 172500 out of 250000 steps (69%)
19:34:23:WU01:FS00:0x22:Completed 175000 out of 250000 steps (70%)
19:34:23:WU01:FS00:0x22:Checkpoint completed at step 175000
19:34:33:WU01:FS00:0x22:Completed 177500 out of 250000 steps (71%)
19:34:45:WU01:FS00:0x22:Completed 180000 out of 250000 steps (72%)
19:34:50:WU01:FS00:0x22:An exception occurred at step 180970: Particle coordinate is nan
19:34:50:WU01:FS00:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
19:34:50:WU01:FS00:0x22:Folding@home Core Shutdown: CORE_RESTART
19:34:50:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
19:34:51:WU01:FS00:Starting
19:34:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 15224 -checkpoint 9 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
19:34:51:WU01:FS00:Started FahCore on PID 7960
19:34:51:WU01:FS00:Core PID:2840
19:34:51:WU01:FS00:FahCore 0x22 started
19:34:51:WU01:FS00:0x22:*********************** Log Started 2021-12-22T19:34:51Z ***********************
19:34:51:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:34:51:WU01:FS00:0x22: Core: Core22
19:34:51:WU01:FS00:0x22: Type: 0x22
19:34:51:WU01:FS00:0x22: Version: 0.0.18
19:34:51:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:34:51:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
19:34:51:WU01:FS00:0x22: Homepage: https://foldingathome.org/
19:34:51:WU01:FS00:0x22: Date: Sep 28 2021
19:34:51:WU01:FS00:0x22: Time: 05:55:05
19:34:51:WU01:FS00:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
19:34:51:WU01:FS00:0x22: Branch: HEAD
19:34:51:WU01:FS00:0x22: Compiler: Visual C++
19:34:51:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:34:51:WU01:FS00:0x22: -DOPENMM_VERSION="\"7.6.0\""
19:34:51:WU01:FS00:0x22: Platform: win32 10
19:34:51:WU01:FS00:0x22: Bits: 64
19:34:51:WU01:FS00:0x22: Mode: Release
19:34:51:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:34:51:WU01:FS00:0x22: <peastman@stanford.edu>
19:34:51:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 7960 -checkpoint 9
19:34:51:WU01:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
19:34:51:WU01:FS00:0x22: -gpu-usage 100
19:34:51:WU01:FS00:0x22:************************************ libFAH ************************************
19:34:51:WU01:FS00:0x22: Time: 05:53:43
19:34:51:WU01:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:34:51:WU01:FS00:0x22:************************************ CBang *************************************
19:34:51:WU01:FS00:0x22: Time: 05:52:38
19:34:51:WU01:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:34:51:WU01:FS00:0x22:************************************ System ************************************
19:34:51:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
19:34:51:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:34:51:WU01:FS00:0x22: CPUs: 8
19:34:51:WU01:FS00:0x22: Memory: 15.94GiB
19:34:51:WU01:FS00:0x22:Free Memory: 5.94GiB
19:34:51:WU01:FS00:0x22: Threads: WINDOWS_THREADS
19:34:51:WU01:FS00:0x22: OS Version: 6.2
19:34:51:WU01:FS00:0x22:Has Battery: false
19:34:51:WU01:FS00:0x22: On Battery: false
19:34:51:WU01:FS00:0x22: UTC Offset: -6
19:34:51:WU01:FS00:0x22: PID: 2840
19:34:51:WU01:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
19:34:51:WU01:FS00:0x22:************************************ OpenMM ************************************
19:34:51:WU01:FS00:0x22: Version: 7.6.0
19:34:51:WU01:FS00:0x22:********************************************************************************
19:34:51:WU01:FS00:0x22:Project: 18027 (Run 9, Clone 139, Gen 1)
19:34:51:WU01:FS00:0x22:Unit: 0x00000000000000000000000000000000
19:34:51:WU01:FS00:0x22:Digital signatures verified
19:34:51:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:34:51:WU01:FS00:0x22:Version 0.0.18
19:34:51:WU01:FS00:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
19:34:51:WU01:FS00:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
19:34:51:WU01:FS00:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
19:34:51:WU01:FS00:0x22: Global context and integrator variables write interval: disabled
19:34:51:WU01:FS00:0x22:There are 3 platforms available.
19:34:51:WU01:FS00:0x22:Platform 0: Reference
19:34:51:WU01:FS00:0x22:Platform 1: CPU
19:34:51:WU01:FS00:0x22:Platform 2: OpenCL
19:34:51:WU01:FS00:0x22: opencl-device 0 specified
19:34:56:WU01:FS00:0x22:Attempting to create OpenCL context:
19:34:56:WU01:FS00:0x22: Configuring platform OpenCL
19:35:03:WU01:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
19:35:03:WU01:FS00:0x22:Completed 175000 out of 250000 steps (70%)
19:35:12:WU01:FS00:0x22:Completed 177500 out of 250000 steps (71%)
19:35:30:WU01:FS00:0x22:Completed 180000 out of 250000 steps (72%)
19:35:45:WU01:FS00:0x22:Completed 182500 out of 250000 steps (73%)
19:36:03:WU01:FS00:0x22:Completed 185000 out of 250000 steps (74%)
19:36:13:WU01:FS00:0x22:Completed 187500 out of 250000 steps (75%)
19:36:14:WU01:FS00:0x22:Checkpoint completed at step 187500
19:36:23:WU01:FS00:0x22:Completed 190000 out of 250000 steps (76%)
19:36:32:WU01:FS00:0x22:Completed 192500 out of 250000 steps (77%)
19:36:39:WU01:FS00:0x22:Completed 195000 out of 250000 steps (78%)
19:36:47:WU01:FS00:0x22:Completed 197500 out of 250000 steps (79%)
19:36:56:WU01:FS00:0x22:Completed 200000 out of 250000 steps (80%)
19:36:56:WU01:FS00:0x22:Checkpoint completed at step 200000
19:37:03:WU01:FS00:0x22:Completed 202500 out of 250000 steps (81%)
19:37:11:WU01:FS00:0x22:Completed 205000 out of 250000 steps (82%)
19:37:18:WU01:FS00:0x22:Completed 207500 out of 250000 steps (83%)
19:37:25:WU01:FS00:0x22:Completed 210000 out of 250000 steps (84%)
19:37:33:WU01:FS00:0x22:Completed 212500 out of 250000 steps (85%)
19:37:34:WU01:FS00:0x22:Checkpoint completed at step 212500
19:37:41:WU01:FS00:0x22:Completed 215000 out of 250000 steps (86%)
19:37:48:WU01:FS00:0x22:Completed 217500 out of 250000 steps (87%)
19:37:56:WU01:FS00:0x22:Completed 220000 out of 250000 steps (88%)
Much more bad work units. 13 and counting.
It's the first and only project to give me bad work units in years.
One of the log files:
20:29:10:WU00:FS01:Starting
20:29:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 3404 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
20:29:10:WU00:FS01:Started FahCore on PID 2656
20:29:10:WU00:FS01:Core PID:11244
20:29:10:WU00:FS01:FahCore 0x22 started
20:29:10:WU00:FS01:0x22:*********************** Log Started 2021-12-22T20:29:10Z ***********************
20:29:10:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:29:10:WU00:FS01:0x22: Core: Core22
20:29:10:WU00:FS01:0x22: Type: 0x22
20:29:10:WU00:FS01:0x22: Version: 0.0.18
20:29:10:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:29:10:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
20:29:10:WU00:FS01:0x22: Homepage: https://foldingathome.org/
20:29:10:WU00:FS01:0x22: Date: Sep 28 2021
20:29:10:WU00:FS01:0x22: Time: 05:55:05
20:29:10:WU00:FS01:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
20:29:10:WU00:FS01:0x22: Branch: HEAD
20:29:10:WU00:FS01:0x22: Compiler: Visual C++
20:29:10:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:29:10:WU00:FS01:0x22: -DOPENMM_VERSION="\"7.6.0\""
20:29:10:WU00:FS01:0x22: Platform: win32 10
20:29:10:WU00:FS01:0x22: Bits: 64
20:29:10:WU00:FS01:0x22: Mode: Release
20:29:10:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:29:10:WU00:FS01:0x22: <peastman@stanford.edu>
20:29:10:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 2656 -checkpoint 15
20:29:10:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
20:29:10:WU00:FS01:0x22: -gpu-usage 100
20:29:10:WU00:FS01:0x22:************************************ libFAH ************************************
20:29:10:WU00:FS01:0x22: Time: 05:53:43
20:29:10:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:29:10:WU00:FS01:0x22:************************************ CBang *************************************
20:29:10:WU00:FS01:0x22: Time: 05:52:38
20:29:10:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:29:10:WU00:FS01:0x22:************************************ System ************************************
20:29:10:WU00:FS01:0x22: CPU: AMD Ryzen 7 2700 Eight-Core Processor
20:29:10:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
20:29:10:WU00:FS01:0x22: CPUs: 16
20:29:10:WU00:FS01:0x22: Memory: 15.95GiB
20:29:10:WU00:FS01:0x22:Free Memory: 8.07GiB
20:29:10:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:29:10:WU00:FS01:0x22: OS Version: 6.2
20:29:10:WU00:FS01:0x22:Has Battery: false
20:29:11:WU00:FS01:0x22: On Battery: false
20:29:11:WU00:FS01:0x22: UTC Offset: 1
20:29:11:WU00:FS01:0x22: PID: 11244
20:29:11:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
20:29:11:WU00:FS01:0x22:************************************ OpenMM ************************************
20:29:11:WU00:FS01:0x22: Version: 7.6.0
20:29:11:WU00:FS01:0x22:********************************************************************************
20:29:11:WU00:FS01:0x22:Project: 18027 (Run 8, Clone 134, Gen 4)
20:29:11:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
20:29:11:WU00:FS01:0x22:Digital signatures verified
20:29:11:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:29:11:WU00:FS01:0x22:Version 0.0.18
20:29:11:WU00:FS01:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
20:29:11:WU00:FS01:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
20:29:11:WU00:FS01:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
20:29:11:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
20:29:11:WU00:FS01:0x22:There are 3 platforms available.
20:29:11:WU00:FS01:0x22:Platform 0: Reference
20:29:11:WU00:FS01:0x22:Platform 1: CPU
20:29:11:WU00:FS01:0x22:Platform 2: OpenCL
20:29:11:WU00:FS01:0x22: opencl-device 0 specified
20:29:15:WU00:FS01:0x22:Attempting to create OpenCL context:
20:29:15:WU00:FS01:0x22: Configuring platform OpenCL
20:29:22:WU00:FS01:0x22: Using OpenCL on platformId 0 and gpu 0
20:29:22:WU00:FS01:0x22:Completed 0 out of 250000 steps (0%)
20:29:37:WU00:FS01:0x22:Completed 2500 out of 250000 steps (1%)
20:29:50:WU00:FS01:0x22:Completed 5000 out of 250000 steps (2%)
20:30:03:WU00:FS01:0x22:Completed 7500 out of 250000 steps (3%)
20:30:03:WU00:FS01:0x22:An exception occurred at step 7529: Particle coordinate is nan
20:30:03:WU00:FS01:0x22:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
20:30:03:WU00:FS01:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
20:30:03:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:30:03:WU00:FS01:0x22:Saving result file science.log
20:30:03:WU00:FS01:0x22:Saving result file state.xml.bz2
20:30:03:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:30:04:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:30:04:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18027 run:8 clone:134 gen:4 core:0x22 unit:0x00000086000000040000466b00000008
20:30:04:WU00:FS01:Uploading 2.55MiB to 34.72.228.44
20:30:04:WU00:FS01:Connecting to 34.72.228.44:8080
20:30:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:30:06:WU01:FS01:Assigned to work server 34.72.228.44
20:30:06:WU01:FS01:Requesting new work unit for slot 01: gpu:38:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 34.72.228.44
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
I had posted a question about this project in another thread. Since it was quick and high PPD, I didn't look at the log. But it did have a nan error at 35% complete. The core restarted and it finished fine after the restart. FAH and the system had been running about 4 days when it picked this up.
Log included just in case the researcher is interested.
16:43:42:WU00:FS01:0x22:*********************** Log Started 2021-12-21T16:43:42Z ***********************
16:43:42:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:43:42:WU00:FS01:0x22: Core: Core22
16:43:42:WU00:FS01:0x22: Type: 0x22
16:43:42:WU00:FS01:0x22: Version: 0.0.18
16:43:42:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:43:42:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
16:43:42:WU00:FS01:0x22: Homepage: https://foldingathome.org/
16:43:42:WU00:FS01:0x22: Date: Sep 28 2021
16:43:42:WU00:FS01:0x22: Time: 05:55:05
16:43:42:WU00:FS01:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
16:43:42:WU00:FS01:0x22: Branch: HEAD
16:43:42:WU00:FS01:0x22: Compiler: Visual C++
16:43:42:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:43:42:WU00:FS01:0x22: -DOPENMM_VERSION="\"7.6.0\""
16:43:42:WU00:FS01:0x22: Platform: win32 10
16:43:42:WU00:FS01:0x22: Bits: 64
16:43:42:WU00:FS01:0x22: Mode: Release
16:43:42:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:43:42:WU00:FS01:0x22: <peastman@stanford.edu>
16:43:42:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 22420 -checkpoint 15
16:43:42:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:43:42:WU00:FS01:0x22:************************************ libFAH ************************************
16:43:42:WU00:FS01:0x22: Time: 05:53:43
16:43:42:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
16:43:42:WU00:FS01:0x22:************************************ CBang *************************************
16:43:42:WU00:FS01:0x22: Time: 05:52:38
16:43:42:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
16:43:42:WU00:FS01:0x22:************************************ System ************************************
16:43:42:WU00:FS01:0x22: CPU: AMD Ryzen 5 2400G with Radeon Vega Graphics
16:43:42:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
16:43:42:WU00:FS01:0x22: CPUs: 8
16:43:42:WU00:FS01:0x22: Memory: 14.93GiB
16:43:42:WU00:FS01:0x22:Free Memory: 11.61GiB
16:43:42:WU00:FS01:0x22: Threads: WINDOWS_THREADS
16:43:42:WU00:FS01:0x22: OS Version: 6.2
16:43:42:WU00:FS01:0x22:Has Battery: false
16:43:42:WU00:FS01:0x22: On Battery: false
16:43:42:WU00:FS01:0x22: UTC Offset: -5
16:43:42:WU00:FS01:0x22: PID: 17924
16:43:42:WU00:FS01:0x22: CWD: C:\Users\rober\AppData\Roaming\FAHClient\work
16:43:42:WU00:FS01:0x22:************************************ OpenMM ************************************
16:43:42:WU00:FS01:0x22: Version: 7.6.0
16:43:42:WU00:FS01:0x22:********************************************************************************
16:43:42:WU00:FS01:0x22:Project: 18027 (Run 1, Clone 95, Gen 2)
16:43:42:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
16:43:42:WU00:FS01:0x22:Reading tar file core.xml
16:43:42:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
16:43:42:WU00:FS01:0x22:Reading tar file state.xml.bz2
16:43:42:WU00:FS01:0x22:Reading tar file system.xml.bz2
16:43:42:WU00:FS01:0x22:Digital signatures verified
16:43:42:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:43:42:WU00:FS01:0x22:Version 0.0.18
16:43:42:WU00:FS01:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
16:43:42:WU00:FS01:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
16:43:42:WU00:FS01:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
16:43:42:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
16:43:42:WU00:FS01:0x22:There are 3 platforms available.
16:43:42:WU00:FS01:0x22:Platform 0: Reference
16:43:42:WU00:FS01:0x22:Platform 1: CPU
16:43:42:WU00:FS01:0x22:Platform 2: OpenCL
16:43:42:WU00:FS01:0x22: opencl-device 0 specified
16:43:46:WU00:FS01:0x22:Attempting to create OpenCL context:
16:43:46:WU00:FS01:0x22: Configuring platform OpenCL
16:43:52:WU00:FS01:0x22: Using OpenCL on platformId 0 and gpu 0
16:43:52:WU00:FS01:0x22:Completed 0 out of 250000 steps (0%)
16:43:52:WU00:FS01:0x22:Checkpoint completed at step 0
16:44:19:WU00:FS01:0x22:Completed 2500 out of 250000 steps (1%)
16:44:46:WU00:FS01:0x22:Completed 5000 out of 250000 steps (2%)
16:45:12:WU00:FS01:0x22:Completed 7500 out of 250000 steps (3%)
16:45:39:WU00:FS01:0x22:Completed 10000 out of 250000 steps (4%)
16:46:05:WU00:FS01:0x22:Completed 12500 out of 250000 steps (5%)
16:46:05:WU00:FS01:0x22:Checkpoint completed at step 12500
16:46:31:WU00:FS01:0x22:Completed 15000 out of 250000 steps (6%)
16:46:57:WU00:FS01:0x22:Completed 17500 out of 250000 steps (7%)
16:47:23:WU00:FS01:0x22:Completed 20000 out of 250000 steps (8%)
16:47:49:WU00:FS01:0x22:Completed 22500 out of 250000 steps (9%)
16:48:15:WU00:FS01:0x22:Completed 25000 out of 250000 steps (10%)
16:48:16:WU00:FS01:0x22:Checkpoint completed at step 25000
16:48:41:WU00:FS01:0x22:Completed 27500 out of 250000 steps (11%)
16:49:07:WU00:FS01:0x22:Completed 30000 out of 250000 steps (12%)
16:49:33:WU00:FS01:0x22:Completed 32500 out of 250000 steps (13%)
16:50:01:WU00:FS01:0x22:Completed 35000 out of 250000 steps (14%)
16:50:28:WU00:FS01:0x22:Completed 37500 out of 250000 steps (15%)
16:50:29:WU00:FS01:0x22:Checkpoint completed at step 37500
16:50:55:WU00:FS01:0x22:Completed 40000 out of 250000 steps (16%)
16:51:20:WU00:FS01:0x22:Completed 42500 out of 250000 steps (17%)
16:51:46:WU00:FS01:0x22:Completed 45000 out of 250000 steps (18%)
16:52:12:WU00:FS01:0x22:Completed 47500 out of 250000 steps (19%)
16:52:38:WU00:FS01:0x22:Completed 50000 out of 250000 steps (20%)
16:52:38:WU00:FS01:0x22:Checkpoint completed at step 50000
16:53:04:WU00:FS01:0x22:Completed 52500 out of 250000 steps (21%)
16:53:30:WU00:FS01:0x22:Completed 55000 out of 250000 steps (22%)
16:53:55:WU00:FS01:0x22:Completed 57500 out of 250000 steps (23%)
16:54:21:WU00:FS01:0x22:Completed 60000 out of 250000 steps (24%)
16:54:47:WU00:FS01:0x22:Completed 62500 out of 250000 steps (25%)
16:54:47:WU00:FS01:0x22:Checkpoint completed at step 62500
16:55:13:WU00:FS01:0x22:Completed 65000 out of 250000 steps (26%)
16:55:39:WU00:FS01:0x22:Completed 67500 out of 250000 steps (27%)
16:56:05:WU00:FS01:0x22:Completed 70000 out of 250000 steps (28%)
16:56:31:WU00:FS01:0x22:Completed 72500 out of 250000 steps (29%)
16:56:56:WU00:FS01:0x22:Completed 75000 out of 250000 steps (30%)
16:56:57:WU00:FS01:0x22:Checkpoint completed at step 75000
16:57:23:WU00:FS01:0x22:Completed 77500 out of 250000 steps (31%)
16:57:48:WU00:FS01:0x22:Completed 80000 out of 250000 steps (32%)
16:58:14:WU00:FS01:0x22:Completed 82500 out of 250000 steps (33%)
16:58:40:WU00:FS01:0x22:Completed 85000 out of 250000 steps (34%)
16:59:05:WU00:FS01:0x22:Completed 87500 out of 250000 steps (35%)
16:59:06:WU00:FS01:0x22:Checkpoint completed at step 87500
16:59:40:WU00:FS01:0x22:An exception occurred at step 89857: Particle coordinate is nan
16:59:40:WU00:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
16:59:40:WU00:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
16:59:40:WARNING:WU00:FS01:FahCore returned: CORE_RESTART (98 = 0x62)
16:59:40:WU00:FS01:Starting
16:59:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\rober\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 3848 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:59:40:WU00:FS01:Started FahCore on PID 24328
16:59:40:WU00:FS01:Core PID:22880
16:59:40:WU00:FS01:FahCore 0x22 started
16:59:41:WU00:FS01:0x22:*********************** Log Started 2021-12-21T16:59:40Z ***********************
16:59:41:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:59:41:WU00:FS01:0x22: Core: Core22
16:59:41:WU00:FS01:0x22: Type: 0x22
16:59:41:WU00:FS01:0x22: Version: 0.0.18
16:59:41:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:59:41:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
16:59:41:WU00:FS01:0x22: Homepage: https://foldingathome.org/
16:59:41:WU00:FS01:0x22: Date: Sep 28 2021
16:59:41:WU00:FS01:0x22: Time: 05:55:05
16:59:41:WU00:FS01:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
16:59:41:WU00:FS01:0x22: Branch: HEAD
16:59:41:WU00:FS01:0x22: Compiler: Visual C++
16:59:41:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:59:41:WU00:FS01:0x22: -DOPENMM_VERSION="\"7.6.0\""
16:59:41:WU00:FS01:0x22: Platform: win32 10
16:59:41:WU00:FS01:0x22: Bits: 64
16:59:41:WU00:FS01:0x22: Mode: Release
16:59:41:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:59:41:WU00:FS01:0x22: <peastman@stanford.edu>
16:59:41:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 24328 -checkpoint 15
16:59:41:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:59:41:WU00:FS01:0x22:************************************ libFAH ************************************
16:59:41:WU00:FS01:0x22: Time: 05:53:43
16:59:41:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
16:59:41:WU00:FS01:0x22:************************************ CBang *************************************
16:59:41:WU00:FS01:0x22: Time: 05:52:38
16:59:41:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
16:59:41:WU00:FS01:0x22:************************************ System ************************************
16:59:41:WU00:FS01:0x22: CPU: AMD Ryzen 5 2400G with Radeon Vega Graphics
16:59:41:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
16:59:41:WU00:FS01:0x22: CPUs: 8
16:59:41:WU00:FS01:0x22: Memory: 14.93GiB
16:59:41:WU00:FS01:0x22:Free Memory: 9.88GiB
16:59:41:WU00:FS01:0x22: Threads: WINDOWS_THREADS
16:59:41:WU00:FS01:0x22: OS Version: 6.2
16:59:41:WU00:FS01:0x22:Has Battery: false
16:59:41:WU00:FS01:0x22: On Battery: false
16:59:41:WU00:FS01:0x22: UTC Offset: -5
16:59:41:WU00:FS01:0x22: PID: 22880
16:59:41:WU00:FS01:0x22: CWD: C:\Users\rober\AppData\Roaming\FAHClient\work
16:59:41:WU00:FS01:0x22:************************************ OpenMM ************************************
16:59:41:WU00:FS01:0x22: Version: 7.6.0
16:59:41:WU00:FS01:0x22:********************************************************************************
16:59:41:WU00:FS01:0x22:Project: 18027 (Run 1, Clone 95, Gen 2)
16:59:41:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
16:59:41:WU00:FS01:0x22:Digital signatures verified
16:59:41:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:59:41:WU00:FS01:0x22:Version 0.0.18
16:59:41:WU00:FS01:0x22: Checkpoint write interval: 12500 steps (5%) [20 total]
16:59:41:WU00:FS01:0x22: JSON viewer frame write interval: 2500 steps (1%) [100 total]
16:59:41:WU00:FS01:0x22: XTC frame write interval: 25000 steps (10%) [10 total]
16:59:41:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
16:59:41:WU00:FS01:0x22:There are 3 platforms available.
16:59:41:WU00:FS01:0x22:Platform 0: Reference
16:59:41:WU00:FS01:0x22:Platform 1: CPU
16:59:41:WU00:FS01:0x22:Platform 2: OpenCL
16:59:41:WU00:FS01:0x22: opencl-device 0 specified
16:59:45:WU00:FS01:0x22:Attempting to create OpenCL context:
16:59:45:WU00:FS01:0x22: Configuring platform OpenCL
16:59:50:WU00:FS01:0x22: Using OpenCL on platformId 0 and gpu 0
16:59:51:WU00:FS01:0x22:Completed 87500 out of 250000 steps (35%)
17:00:17:WU00:FS01:0x22:Completed 90000 out of 250000 steps (36%)
17:00:43:WU00:FS01:0x22:Completed 92500 out of 250000 steps (37%)
17:01:09:WU00:FS01:0x22:Completed 95000 out of 250000 steps (38%)
17:01:35:WU00:FS01:0x22:Completed 97500 out of 250000 steps (39%)
17:02:00:WU00:FS01:0x22:Completed 100000 out of 250000 steps (40%)
17:02:01:WU00:FS01:0x22:Checkpoint completed at step 100000
17:02:26:WU00:FS01:0x22:Completed 102500 out of 250000 steps (41%)
17:02:52:WU00:FS01:0x22:Completed 105000 out of 250000 steps (42%)
17:03:18:WU00:FS01:0x22:Completed 107500 out of 250000 steps (43%)
17:03:45:WU00:FS01:0x22:Completed 110000 out of 250000 steps (44%)
17:04:10:WU00:FS01:0x22:Completed 112500 out of 250000 steps (45%)
17:04:10:WU00:FS01:0x22:Checkpoint completed at step 112500
17:04:36:WU00:FS01:0x22:Completed 115000 out of 250000 steps (46%)
17:05:02:WU00:FS01:0x22:Completed 117500 out of 250000 steps (47%)
17:05:28:WU00:FS01:0x22:Completed 120000 out of 250000 steps (48%)
17:05:54:WU00:FS01:0x22:Completed 122500 out of 250000 steps (49%)
17:06:20:WU00:FS01:0x22:Completed 125000 out of 250000 steps (50%)
17:06:20:WU00:FS01:0x22:Checkpoint completed at step 125000
17:06:46:WU00:FS01:0x22:Completed 127500 out of 250000 steps (51%)
17:07:12:WU00:FS01:0x22:Completed 130000 out of 250000 steps (52%)
17:07:37:WU00:FS01:0x22:Completed 132500 out of 250000 steps (53%)
17:08:03:WU00:FS01:0x22:Completed 135000 out of 250000 steps (54%)
17:08:29:WU00:FS01:0x22:Completed 137500 out of 250000 steps (55%)
17:08:29:WU00:FS01:0x22:Checkpoint completed at step 137500
17:08:57:WU00:FS01:0x22:Completed 140000 out of 250000 steps (56%)
17:09:23:WU00:FS01:0x22:Completed 142500 out of 250000 steps (57%)
17:09:49:WU00:FS01:0x22:Completed 145000 out of 250000 steps (58%)
17:10:15:WU00:FS01:0x22:Completed 147500 out of 250000 steps (59%)
17:10:41:WU00:FS01:0x22:Completed 150000 out of 250000 steps (60%)
17:10:41:WU00:FS01:0x22:Checkpoint completed at step 150000
17:11:07:WU00:FS01:0x22:Completed 152500 out of 250000 steps (61%)
17:11:33:WU00:FS01:0x22:Completed 155000 out of 250000 steps (62%)
17:11:59:WU00:FS01:0x22:Completed 157500 out of 250000 steps (63%)
17:12:25:WU00:FS01:0x22:Completed 160000 out of 250000 steps (64%)
17:12:51:WU00:FS01:0x22:Completed 162500 out of 250000 steps (65%)
17:12:51:WU00:FS01:0x22:Checkpoint completed at step 162500
17:13:17:WU00:FS01:0x22:Completed 165000 out of 250000 steps (66%)
17:13:43:WU00:FS01:0x22:Completed 167500 out of 250000 steps (67%)
17:14:10:WU00:FS01:0x22:Completed 170000 out of 250000 steps (68%)
17:14:36:WU00:FS01:0x22:Completed 172500 out of 250000 steps (69%)
17:15:02:WU00:FS01:0x22:Completed 175000 out of 250000 steps (70%)
17:15:02:WU00:FS01:0x22:Checkpoint completed at step 175000
17:15:29:WU00:FS01:0x22:Completed 177500 out of 250000 steps (71%)
17:15:54:WU00:FS01:0x22:Completed 180000 out of 250000 steps (72%)
17:16:21:WU00:FS01:0x22:Completed 182500 out of 250000 steps (73%)
17:16:47:WU00:FS01:0x22:Completed 185000 out of 250000 steps (74%)
17:17:13:WU00:FS01:0x22:Completed 187500 out of 250000 steps (75%)
17:17:13:WU00:FS01:0x22:Checkpoint completed at step 187500
17:17:39:WU00:FS01:0x22:Completed 190000 out of 250000 steps (76%)
17:18:05:WU00:FS01:0x22:Completed 192500 out of 250000 steps (77%)
17:18:31:WU00:FS01:0x22:Completed 195000 out of 250000 steps (78%)
17:18:58:WU00:FS01:0x22:Completed 197500 out of 250000 steps (79%)
17:19:23:WU00:FS01:0x22:Completed 200000 out of 250000 steps (80%)
17:19:24:WU00:FS01:0x22:Checkpoint completed at step 200000
17:19:50:WU00:FS01:0x22:Completed 202500 out of 250000 steps (81%)
17:20:16:WU00:FS01:0x22:Completed 205000 out of 250000 steps (82%)
17:20:42:WU00:FS01:0x22:Completed 207500 out of 250000 steps (83%)
17:21:08:WU00:FS01:0x22:Completed 210000 out of 250000 steps (84%)
17:21:34:WU00:FS01:0x22:Completed 212500 out of 250000 steps (85%)
17:21:34:WU00:FS01:0x22:Checkpoint completed at step 212500
17:22:01:WU00:FS01:0x22:Completed 215000 out of 250000 steps (86%)
17:22:27:WU00:FS01:0x22:Completed 217500 out of 250000 steps (87%)
17:22:52:WU00:FS01:0x22:Completed 220000 out of 250000 steps (88%)
17:23:19:WU00:FS01:0x22:Completed 222500 out of 250000 steps (89%)
17:23:45:WU00:FS01:0x22:Completed 225000 out of 250000 steps (90%)
17:23:45:WU00:FS01:0x22:Checkpoint completed at step 225000
17:24:12:WU00:FS01:0x22:Completed 227500 out of 250000 steps (91%)
17:24:39:WU00:FS01:0x22:Completed 230000 out of 250000 steps (92%)
17:25:05:WU00:FS01:0x22:Completed 232500 out of 250000 steps (93%)
17:25:31:WU00:FS01:0x22:Completed 235000 out of 250000 steps (94%)
17:25:57:WU00:FS01:0x22:Completed 237500 out of 250000 steps (95%)
17:25:57:WU00:FS01:0x22:Checkpoint completed at step 237500
17:26:23:WU00:FS01:0x22:Completed 240000 out of 250000 steps (96%)
17:26:49:WU00:FS01:0x22:Completed 242500 out of 250000 steps (97%)
17:27:15:WU00:FS01:0x22:Completed 245000 out of 250000 steps (98%)
17:27:41:WU00:FS01:0x22:Completed 247500 out of 250000 steps (99%)
17:27:42:WU01:FS01:Connecting to 65.254.110.245:80
17:27:42:WU01:FS01:Assigned to work server 128.252.203.11
17:27:42:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Raven [Ryzen vega 8 mobile] from 128.252.203.11
17:27:42:WU01:FS01:Connecting to 128.252.203.11:8080
17:27:52:WU01:FS01:Downloading 26.58MiB
17:27:57:WU01:FS01:Download complete
17:27:57:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18201 run:44018 clone:0 gen:31 core:0x22 unit:0x000000000000001f000047190000abf2
17:28:07:WU00:FS01:0x22:Completed 250000 out of 250000 steps (100%)
17:28:07:WU00:FS01:0x22:Average performance: 66.4615 ns/day
17:28:07:WU00:FS01:0x22:Checkpoint completed at step 250000
17:28:11:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
17:28:11:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
17:28:11:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
17:28:11:WU00:FS01:0x22:Saving result file positions.xtc
17:28:11:WU00:FS01:0x22:Saving result file science.log
17:28:11:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:28:11:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:28:11:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18027 run:1 clone:95 gen:2 core:0x22 unit:0x0000005f000000020000466b00000001
17:28:11:WU00:FS01:Uploading 3.27MiB to 34.72.228.44
Fold them if you get them!
Re: 18027 Bad Work Unit
I see that the common factor for everyone here is AMD GPUs ... Interesting.
No, common factor is AMD Species 5 GPUs, which were reported to project author to be disabled, but I guess project author deemed the failure rate to be not too disruptive
AMD Species 6 is much more stable on these, though still have some failures, in line with what nVidia GPUs are getting
Is there anyway to opt out of 18027?
I keep getting these and most of them fail.
Had a few other projects in between and those are successfull.
Now 22 wu's failed, which is a waste.
You may find setting a cause preference may help avoid these
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
Most of us have no idea what it is. It doesn't show up in Beta or moving to FAH. I had started another thread out of curiosity on what it was.....Neil-B wrote:You may find setting a cause preference may help avoid these
But some people must know if they know AMD GPUs of certain species have more errors.
I've only had the one, so I can't say if the hiccup would be a trend. Generally this little iGPU is very stable if nothing else. I often see WU's that give certain AMD GPU's fits and this one stays solid. I guess there are advantages to being slow sometimes.
Is there an advanced slot command line flag that I can set client side to avoid a specific WU?
No
I just watched one of these all the way through on my RTX 2080ti 18207 (5/805/3) it completed successfully but had the time per frame rate of 2-3 seconds.
Very small units and ppd estimates all over the place due to the super fast frame rate.
Best chance for avoiding is to set a cause preference that has a live project ... such as alz ... then you should get those rather than these ... this should be a fairly short lived project as I understand it.
