not enough time for computing a 0x22 WU
promeneur
- Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
OpenSUSE 15.3
computing mode: "full", when i am working
GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:3 GK208B [GeForce GT 730] 692.7
CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:11.4
3 WU (0x22) :
- 3 days for computing for each one
- estimate time for each one 3,5 Days
=> each WU computing with "Past final deadline <date>, dumping"
3 WU (0x22) :
Re: not enough time for computing a 0x22 WU
Support for the Kepler based NVidia cards by FAH is ending, as NVidia's latest drivers (which are required for full support of OpenMM_22 core 18) are starting the process for end-of-useful-life support for them. Therefore, upgrading to a card that supports the Pascal, Turing, or Ampere architectures should be considered (along with an appropriately sized Corsair or EVGA PSU for the card you select).
Please read the following thread: viewtopic.php?f=80&t=37387&p=354017#p352846
Paul
Paul
promeneur
It's a pity because that was a way to recycle an old nvidia adapter.
I am satisfied with IGPU then I don't buy anymore DGPU.
The GT 730 has always been close to the bare minimum GPU needed to process any WU. The Kepler versions of the card have been a bit better than the Fermi ones. It may be time to reclassify the cards species entries, that will change what is assigned to them. However without any information on what WUs from which projects are failing to complete on time, that is hard to tell as it may just be assignment settings that need to be adjusted on the servers.
I really would check your logs to be sure you are using CUDA, not OpenCL to process WUs. As weak as that card is, the additional 30% in speed may be the difference in go and no go.
If you need help post the first 200 lines here.
viewtopic.php?f=24&t=26036
promeneur
This is CUDA, not opencl.
*********************** Log Started 2021-12-03T07:14:38Z ***********************
07:14:38:******************************* libFAH ********************************
07:14:38: Date: Oct 20 2020
07:14:38: Time: 20:36:41
07:14:38: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
07:14:38: Branch: master
07:14:38: Compiler: GNU 4.9.4
07:14:38: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
07:14:38: -O3 -funroll-loops
07:14:38: Platform: linux2 5.8.0-1-amd64
07:14:38: Bits: 64
07:14:38: Mode: Release
07:14:38:****************************** FAHClient ******************************
07:14:38: Version: 7.6.21
07:14:38: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:14:38: Copyright: 2020 foldingathome.org
07:14:38: Homepage: https://foldingathome.org/
07:14:38: Time: 20:38:59
07:14:38: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
07:14:38: Bits: 64
07:14:38: Args: /etc/fahclient/config.xml
07:14:38: --pid-file=/run/fahclient/fahclient.pid
07:14:38: Config: /etc/fahclient/config.xml
07:14:38:******************************** CBang ********************************
07:14:38: Time: 18:38:01
07:14:38: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
07:14:38: -O3 -funroll-loops -fPIC
07:14:38: Bits: 64
07:14:38:******************************* System ********************************
07:14:38: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:14:38: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:14:38: CPUs: 4
07:14:38: Memory: 15.50GiB
07:14:38: Free Memory: 14.56GiB
07:14:38: Threads: POSIX_THREADS
07:14:38: OS Version: 5.3
07:14:38: Has Battery: false
07:14:38: On Battery: false
07:14:38: UTC Offset: 1
07:14:38: PID: 2309
07:14:38: CWD: /var/lib/fahclient
07:14:38: OS: Linux 5.3.18-59.34-default x86_64
07:14:38: OS Arch: AMD64
07:14:38: GPUs: 2
07:14:38: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
07:14:38: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:3 GK208B [GeForce GT 730] 692.7
07:14:38: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:11.4
07:14:38:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:470.86
07:14:38:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:1.3
07:14:38:***********************************************************************
07:14:38:<config>
07:14:38: <!-- Network -->
07:14:38: <proxy v=':8080'/>
07:14:38:
07:14:38: <!-- Slot Control -->
07:14:38: <power v='FULL'/>
07:14:38:
07:14:38: <!-- User Information -->
07:14:38: <passkey v='*****'/>
07:14:38: <team v='51'/>
07:14:38: <user v='philippe_roubach'/>
07:14:38:
07:14:38: <!-- Folding Slots -->
07:14:38: <slot id='0' type='CPU'>
07:14:38: <cpus v='3'/>
07:14:38: </slot>
07:14:38: <slot id='1' type='GPU'>
07:14:38: <gpu-beta v='False'/>
07:14:38: <opencl-index v='0'/>
07:14:38: <paused v='True'/>
07:14:38: <pci-bus v='0'/>
07:14:38: <pci-slot v='2'/>
07:14:38: </slot>
07:14:38: <slot id='2' type='GPU'>
07:14:38: <pci-bus v='1'/>
07:14:38: <pci-slot v='0'/>
07:14:38: </slot>
07:14:38:</config>
07:14:38:Trying to access database...
07:14:38:Successfully acquired database lock
07:14:38:FS00:Initialized folding slot 00: cpu:3
07:14:38:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 KBL GT2 [HD Graphics 630]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
07:14:38:FS02:Initialized folding slot 02: gpu:1:0 GK208B [GeForce GT 730] 692.7
07:14:38:WU00:FS02:Starting
07:14:38:WU00:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.18/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 2309 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:14:38:WU00:FS02:Started FahCore on PID 2409
07:14:38:WU00:FS02:Core PID:2413
07:14:38:WU00:FS02:FahCore 0x22 started
07:14:38:WU02:FS00:Starting
07:14:38:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 2309 -checkpoint 15 -np 3
07:14:38:WU02:FS00:Started FahCore on PID 2422
07:14:38:WU02:FS00:Core PID:2427
07:14:38:WU02:FS00:FahCore 0xa8 started
07:14:38:WU00:FS02:0x22:*********************** Log Started 2021-12-03T07:14:38Z ***********************
07:14:38:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:14:38:WU00:FS02:0x22: Core: Core22
07:14:38:WU00:FS02:0x22: Type: 0x22
07:14:38:WU00:FS02:0x22: Version: 0.0.18
07:14:38:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:14:38:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
07:14:38:WU00:FS02:0x22: Homepage: https://foldingathome.org/
07:14:38:WU00:FS02:0x22: Date: Sep 28 2021
07:14:38:WU00:FS02:0x22: Time: 05:43:02
07:14:38:WU00:FS02:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
07:14:38:WU00:FS02:0x22: Branch: HEAD
07:14:38:WU00:FS02:0x22: Compiler: GNU 9.4.0
07:14:38:WU00:FS02:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
07:14:38:WU00:FS02:0x22: -funroll-loops -fno-pie -DOPENMM_VERSION="\"7.6.0\""
07:14:38:WU00:FS02:0x22: Platform: linux 5.8.0-1041-azure
07:14:38:WU00:FS02:0x22: Bits: 64
07:14:38:WU00:FS02:0x22: Mode: Release
07:14:38:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:14:38:WU00:FS02:0x22: <peastman@stanford.edu>
07:14:38:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 2409 -checkpoint 15
07:14:38:WU00:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:14:38:WU00:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
07:14:38:WU00:FS02:0x22:************************************ libFAH ************************************
07:14:38:WU00:FS02:0x22: Time: 05:42:27
07:14:38:WU00:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
07:14:38:WU00:FS02:0x22:************************************ CBang *************************************
07:14:38:WU00:FS02:0x22: Time: 05:42:00
07:14:38:WU00:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
07:14:38:WU00:FS02:0x22: -funroll-loops -fno-pie -fPIC
07:14:38:WU00:FS02:0x22:************************************ System ************************************
07:14:38:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:14:38:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:14:38:WU00:FS02:0x22: CPUs: 4
07:14:38:WU00:FS02:0x22: Memory: 15.50GiB
07:14:38:WU00:FS02:0x22:Free Memory: 14.33GiB
07:14:38:WU00:FS02:0x22: Threads: POSIX_THREADS
07:14:38:WU00:FS02:0x22: OS Version: 5.3
07:14:38:WU00:FS02:0x22:Has Battery: false
07:14:38:WU00:FS02:0x22: On Battery: false
07:14:38:WU00:FS02:0x22: UTC Offset: 1
07:14:38:WU00:FS02:0x22: PID: 2413
07:14:38:WU00:FS02:0x22: CWD: /var/lib/fahclient/work
07:14:38:WU00:FS02:0x22:************************************ OpenMM ************************************
07:14:38:WU00:FS02:0x22: Version: 7.6.0
07:14:38:WU00:FS02:0x22:********************************************************************************
07:14:38:WU00:FS02:0x22:Project: 18431 (Run 47, Clone 15, Gen 21)
07:14:38:WU00:FS02:0x22:Unit: 0x00000000000000000000000000000000
07:14:38:WU00:FS02:0x22:Digital signatures verified
07:14:38:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:14:38:WU00:FS02:0x22:Version 0.0.18
07:14:38:WU00:FS02:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
07:14:38:WU00:FS02:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:14:38:WU00:FS02:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
07:14:38:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
07:14:38:WU00:FS02:0x22:There are 4 platforms available.
07:14:38:WU00:FS02:0x22:Platform 0: Reference
07:14:38:WU00:FS02:0x22:Platform 1: CPU
07:14:38:WU00:FS02:0x22:Platform 2: OpenCL
07:14:38:WU00:FS02:0x22: opencl-device 0 specified
07:14:38:WU00:FS02:0x22:Platform 3: CUDA
07:14:38:WU00:FS02:0x22: cuda-device 0 specified
07:14:38:WU02:FS00:0xa8:*********************** Log Started 2021-12-03T07:14:38Z ***********************
07:14:38:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
07:14:38:WU02:FS00:0xa8: Core: Gromacs
07:14:38:WU02:FS00:0xa8: Type: 0xa8
07:14:38:WU02:FS00:0xa8: Version: 0.0.12
07:14:38:WU02:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:14:38:WU02:FS00:0xa8: Copyright: 2020 foldingathome.org
07:14:38:WU02:FS00:0xa8: Homepage: https://foldingathome.org/
07:14:38:WU02:FS00:0xa8: Date: Jan 16 2021
07:14:38:WU02:FS00:0xa8: Time: 19:24:44
07:14:38:WU02:FS00:0xa8: Compiler: GNU 8.3.0
07:14:38:WU02:FS00:0xa8: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
07:14:38:WU02:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie
07:14:38:WU02:FS00:0xa8: Platform: linux2 4.15.0-128-generic
07:14:38:WU02:FS00:0xa8: Bits: 64
07:14:38:WU02:FS00:0xa8: Mode: Release
07:14:38:WU02:FS00:0xa8: SIMD: avx2_256
07:14:38:WU02:FS00:0xa8: OpenMP: ON
07:14:38:WU02:FS00:0xa8: CUDA: OFF
07:14:38:WU02:FS00:0xa8: Args: -dir 02 -suffix 01 -version 706 -lifeline 2422 -checkpoint 15 -np 3
07:14:38:WU02:FS00:0xa8:************************************ libFAH ************************************
07:14:38:WU02:FS00:0xa8: Time: 19:21:38
07:14:38:WU02:FS00:0xa8:************************************ CBang *************************************
07:14:38:WU02:FS00:0xa8: Time: 19:21:24
07:14:38:WU02:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:14:38:WU02:FS00:0xa8:************************************ System ************************************
07:14:38:WU02:FS00:0xa8: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:14:38:WU02:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:14:38:WU02:FS00:0xa8: CPUs: 4
07:14:38:WU02:FS00:0xa8: Memory: 15.50GiB
07:14:38:WU02:FS00:0xa8:Free Memory: 14.29GiB
07:14:38:WU02:FS00:0xa8: Threads: POSIX_THREADS
07:14:38:WU02:FS00:0xa8: OS Version: 5.3
07:14:38:WU02:FS00:0xa8:Has Battery: false
07:14:38:WU02:FS00:0xa8: On Battery: false
07:14:38:WU02:FS00:0xa8: UTC Offset: 1
07:14:38:WU02:FS00:0xa8: PID: 2427
07:14:38:WU02:FS00:0xa8: CWD: /var/lib/fahclient/work
07:14:38:WU02:FS00:0xa8:********************************************************************************
07:14:38:WU02:FS00:0xa8:Project: 18210 (Run 24036, Clone 0, Gen 38)
07:14:38:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
07:14:38:WU02:FS00:0xa8:Digital signatures verified
07:14:38:WU02:FS00:0xa8:Calling: mdrun -c frame38.gro -s frame38.tpr -x frame38.xtc -cpi state.cpt -cpt 15 -nt 3 -ntmpi 1
07:14:38:WU02:FS00:0xa8:Steps: first=4750000 total=4875000
07:14:41:WU00:FS02:0x22:Attempting to create CUDA context:
07:14:41:WU00:FS02:0x22: Configuring platform CUDA
07:14:44:WU02:FS00:0xa8:Completed 9182 out of 125000 steps (7%)
07:14:49:WU00:FS02:0x22: Using CUDA and gpu 0
07:14:49:WU00:FS02:0x22:Completed 700000 out of 5000000 steps (14%)
07:27:09:WU02:FS00:0xa8:Completed 10000 out of 125000 steps (8%)
07:43:48:WU02:FS00:0xa8:Completed 11250 out of 125000 steps (9%)
08:00:34:WU02:FS00:0xa8:Completed 12500 out of 125000 steps (10%)
08:01:27:WU00:FS02:0x22:Completed 750000 out of 5000000 steps (15%)
08:16:40:WU02:FS00:0xa8:Completed 13750 out of 125000 steps (11%)
08:33:25:WU02:FS00:0xa8:Completed 15000 out of 125000 steps (12%)
08:49:05:WU02:FS00:0xa8:Completed 16250 out of 125000 steps (13%)
08:49:06:WU00:FS02:0x22:Completed 800000 out of 5000000 steps (16%)
08:49:08:WU00:FS02:0x22:Checkpoint completed at step 800000
09:05:52:WU02:FS00:0xa8:Completed 17500 out of 125000 steps (14%)
09:22:56:WU02:FS00:0xa8:Completed 18750 out of 125000 steps (15%)
09:36:57:WU00:FS02:0x22:Completed 850000 out of 5000000 steps (17%)
09:39:45:WU02:FS00:0xa8:Completed 20000 out of 125000 steps (16%)
09:55:48:WU02:FS00:0xa8:Completed 21250 out of 125000 steps (17%)
10:12:33:WU02:FS00:0xa8:Completed 22500 out of 125000 steps (18%)
10:23:56:WU00:FS02:0x22:Completed 900000 out of 5000000 steps (18%)
10:23:57:WU00:FS02:0x22:Checkpoint completed at step 900000
10:28:22:WU02:FS00:0xa8:Completed 23750 out of 125000 steps (19%)
10:43:56:WU02:FS00:0xa8:Completed 25000 out of 125000 steps (20%)
11:00:29:WU02:FS00:0xa8:Completed 26250 out of 125000 steps (21%)
11:11:50:WU00:FS02:0x22:Completed 950000 out of 5000000 steps (19%)
11:16:12:WU02:FS00:0xa8:Completed 27500 out of 125000 steps (22%)
11:32:34:WU02:FS00:0xa8:Completed 28750 out of 125000 steps (23%)
11:48:33:WU02:FS00:0xa8:Completed 30000 out of 125000 steps (24%)
11:58:55:WU00:FS02:0x22:Completed 1000000 out of 5000000 steps (20%)
11:58:56:WU00:FS02:0x22:Checkpoint completed at step 1000000
12:04:42:WU02:FS00:0xa8:Completed 31250 out of 125000 steps (25%)
12:25:02:WU02:FS00:0xa8:Completed 32500 out of 125000 steps (26%)
12:44:25:WU00:FS02:0x22:Completed 1050000 out of 5000000 steps (21%)
12:45:18:WU02:FS00:0xa8:Completed 33750 out of 125000 steps (27%)
13:05:31:WU02:FS00:0xa8:Completed 35000 out of 125000 steps (28%)
promeneur
The current project is https://stats.foldingathome.org/project/18431
ETA 2.57 days
Assign 2021-12-02T09:06:52Z
timeout 2021-12-03T21:06:52Z
Expiration 2021-12-04T09:06:52Z
today 2021-12-3 13:12Z
ETA 2.57 days
promeneur
a new WU
progress = 30 % when expiration occurs.
PRCG 18431 (78, 29, 23)
ETA 3.42 days
Assign 2021-12-04T13:31:38Z
timeout 2021-12-06T01:31:38Z
Expiration 2021-12-06T13:31:38Z
today 2021-12-4 14:07Z
a new WU
The current project is https://apps.foldingathome.org/project.py?p=17804
PRCG 17804 (17, 68, 720)
ETA 2.47 days
Assign 2021-12-06T13:31:39Z
timeout 2021-12-07T13:31:39Z
Expiration 2021-12-08T13:31:39Z
today 2021-12-7 10:33Z
a new WU
progress = 50 % when expiration occurs.
The current project is https://apps.foldingathome.org/project.py?p=17806
PRCG 17806 (5, 44, 116)
ETA 2.15 days
Assign 2021-12-08T13:31:40Z
timeout 2021-12-09T13:31:40Z
Expiration 2021-12-10T13:31:40Z
today 2021-12-8T14:29Z
a new WU
progress =58 %. There is surely a good chance to finish computing before the expiration date
The current project is https://apps.foldingathome.org/project.py?p=18206
PRCG 18206 (8005, 0, 68)
ETA 1.64 days
Assign 2021-12-12T18:36:02Z
timeout 2021-12-14T18:36:02Z
Expiration 2021-12-17T18:36:02Z
today 2021-12-14T10:43Z
ETA 3.42 days
a new WU
ETA 2.47 days
a new WU
ETA 2.15 days
a new WU
ETA 1.64 days
GeForce GT 730
https://www.techpowerup.com/gpu-specs/g ... -730.c1988
This GPU should still fold, it meets the two prerequisites 64 bit floating point math and OpenCL 1.2 or higher.
Nvidia has dropped driver support recntly, so long term, be thinking of moving on. If you need a half height card, the GTX 1650 is as new as is made. If it needs to be both half height and single slot, GT 1030 is about twice as fast)
Your driver is the latest supported driver.
Iirc there are at least two if not three versions of gt730 one of which will struggle ... yup https://www.google.com/amp/s/www.tomsha ... 27087.htmlJimboPalmer wrote:GeForce GT 730
This one will struggle https://www.techpowerup.com/gpu-specs/g ... -730.c2590
The wikipedia listing of nVidia GPUs shows 3 variants, and that may not be complete. Two used two different Kepler chips, one used a Fermi chip. The Kepler based cards have 384 shaders, the Fermi 96. Two of them were rebranded GT 630 cards, hardware that was the same as cards sold 1 and 2 years prior to the introduction as GT 730s.
promeneur
my card is ASUS Geforce GT 730 SL 2GBD3 BRK
the specs (in french)
Informations générales
Désignation: ASUS GT730-SL-2GD3-BRK - GeForce GT 730 2 Go
Marque: ASUS
Modèle: 90YV06P0-M0NA00
Chipset graphique NVIDIA GeForce GT 730
Marque du GPU: NVIDIA
Fréquence du chipset: 902 MHz
Overclockée: Non
Nombre de GPU: 1
Bus: PCI Express 2.0 8x
Mémoire
Taille mémoire vidéo: 2 Go
Interface mémoire: 64 bit(s)
Fréquence mémoire vidéo: 900 MHz
Type de mémoire: GDDR3
Architecture
Processeurs de flux: 384
Support Direct X (version): 11
Spécifications techniques
Multi-GPU: Aucun
Affichage:
HD Ready: Oui
Résolution(s) 4K UHD: Non
VR Ready (réalité virtuelle): Non
Connectique
Sorties vidéo
1 X HDMI Femelle
1 X DVI Femelle
1 X VGA (D-sub 15 Femelle)
Norme de Sortie DVI
1 X DVI-D Dual Link (24+1)
DVI Dual-Link: Oui
Connecteur(s) alimentation: Aucun
Design
Type de refroidissement: Passif (fanless)
Consommation: 25 W
Low profile: Oui
Format: Single Slot
Nombre de slots PCI: 1
LED: Non
LED RGB: Non
Longueur: 137 mm
Largeur: 69 mm
Epaisseur: 30 mm
Utilisation: Multimédia NVIDIA GT
It's the Kepler variant ... but it doesn't make it a fast GPU ...
