On a Notebook with Windows 10 Home I updated the F@H client to the latest available version without uninstalling the previous version.
Once the installation was finished, I restarted the PC and F@H started automatically, but in the SysTray the 'F@H Control' icon no longer appears, not even among the hidden ones, with which I can quickly call up the work monitoring window.
Can anyone suggest me how to make it reappear ?
Problem after updating the latest version
Re: Problem after updating the latest version
It sometimes happens for unknown reason ... it will come back magically, one day ...
If the client is still running fine (FAHClient.exe is showing in task manager), you can still run FAHControl or Webcontrol from Start menu shortcuts.
I was hoping for a safer solution but thanks anyway.
