Whitelist request - NVIDIA TU117M GeForce MX450
ScoPi
Post by ScoPi »
01:00.0 3D controller: NVIDIA Corporation TU117M [GeForce MX450] (rev a1)
*********************** Log Started 2021-10-19T13:03:39Z ***********************
13:03:39:******************************* libFAH ********************************
13:03:39:           Date: Oct 20 2020
13:03:39:           Time: 20:36:39
13:03:39:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:03:39:         Branch: master
13:03:39:       Compiler: GNU 8.3.0
13:03:39:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
13:03:39:                 -fdata-sections -O3 -funroll-loops -fno-pie
13:03:39:       Platform: linux2 5.8.0-1-amd64
13:03:39:           Bits: 64
13:03:39:           Mode: Release
13:03:39:****************************** FAHClient ******************************
13:03:39:        Version: 7.6.21
13:03:39:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:03:39:      Copyright: 2020 foldingathome.org
13:03:39:       Homepage: https://foldingathome.org/
13:03:39:           Time: 20:39:00
13:03:39:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:03:39:           Bits: 64
13:03:39:           Args: --child /etc/fahclient/config.xml --run-as fahclient
13:03:39:                 --pid-file=/var/run/fahclient.pid --daemon
13:03:39:         Config: /etc/fahclient/config.xml
13:03:39:******************************** CBang ********************************
13:03:39:           Time: 18:37:59
13:03:39:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:03:39:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
13:03:39:           Bits: 64
13:03:39:******************************* System ********************************
13:03:39:            CPU: 11th Gen Intel(R) Core(TM) i7-11370H @ 3.30GHz
13:03:39:         CPU ID: GenuineIntel Family 6 Model 140 Stepping 1
13:03:39:           CPUs: 8
13:03:39:         Memory: 15.38GiB
13:03:39:    Free Memory: 11.78GiB
13:03:39:        Threads: POSIX_THREADS
13:03:39:     OS Version: 5.11
13:03:39:    Has Battery: true
13:03:39:     On Battery: false
13:03:39:     UTC Offset: 11
13:03:39:            PID: 6426
13:03:39:            CWD: /var/lib/fahclient
13:03:39:             OS: Linux 5.11.0-38-generic x86_64
13:03:39:        OS Arch: AMD64
13:03:39:           GPUs: 2
13:03:39:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 TGL GT2 [Iris(R) Iris Xe Graphics]
13:03:39:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:1
13:03:39:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.4
13:03:39:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:470.63
13:03:39:***********************************************************************
13:03:39:<config>
13:03:39:  <!-- Slot Control -->
13:03:39:  <power v='full'/>
13:03:39:
13:03:39:  <!-- User Information -->
13:03:39:  <passkey v='*****'/>
13:03:39:  <team v='24'/>
13:03:39:  <user v='X6X6X6X'/>
13:03:39:
13:03:39:  <!-- Folding Slots -->
13:03:39:  <slot id='0' type='CPU'/>
13:03:39:  <slot id='1' type='GPU'>
13:03:39:    <pci-bus v='1'/>
13:03:39:    <pci-slot v='0'/>
13:03:39:  </slot>
13:03:39:  <slot id='2' type='GPU'>
13:03:39:    <pci-bus v='0'/>
13:03:39:    <pci-slot v='2'/>
13:03:39:  </slot>
13:03:39:</config>
13:03:39:Trying to access database...
13:03:39:Successfully acquired database lock
13:03:39:FS00:Initialized folding slot 00: cpu:6
13:03:39:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
13:03:39:WARNING:FS02:Disabling beta GPU slot 02: gpu:0:2 TGL GT2 [Iris(R) Iris Xe Graphics].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
13:03:39:WU00:FS00:Starting
In the meantime I've turned on beta.
Cheers!
Re: Whitelist request - NVIDIA TU117M GeForce MX450
If you could provide output from the command fahclient --lspci that gives the PCI ID for the GPU, that would make it possible to add it
ScoPi
Post by ScoPi »
0x10de:0x1f97:1:0:0:NVIDIA Corporation
Not sure how I forgot to do that last night, my apologies
It was not the only one missing in this family ...
I added :
1f97 / TU117M [GeForce MX450]
1f98 / TU117M [GeForce MX450]
1f9c / TU117M [GeForce MX450]
1f9d / TU117M [GeForce GTX 1650 Mobile / Max-Q]
1fb0 / TU117GLM [Quadro T1000 Mobile]
1fb1 / TU117GL [T600]
1fb2 / TU117GLM [Quadro T400 Mobile]
1fba / TU117GLM [T600 Mobile]
1fbb / TU117GLM [Quadro T500 Mobile]
1fd9 / TU117BM [GeForce GTX 1650 Mobile Refresh]
1fdd / TU117BM [GeForce GTX 1650 Mobile Refresh]
1ff9 / TU117GLM [Quadro T1000 Mobile]
ScoPi
Post by ScoPi »
Excellent, it works. Thank you for that
23:17:51:Trying to access database...
23:17:51:Successfully acquired database lock
23:17:51:FS00:Initialized folding slot 00: cpu:6
23:17:51:FS01:Initialized folding slot 01: gpu:1:0
