128.252.203.10 Does not accept ANY uploads
rok65612
Post by rok65612 »
I have 3 completed Work Units from 3 different projects that have been stuck in the queue and not accepted by 128.252.203.10 for over 48 hours now.
What is wrong with this server? Same response every time: ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
debs3759
Re: 128.252.203.10 Does not accept ANY uploads
Post by debs3759 »
I usually find with that error that the wu has uploaded, but the server has not replied. It will keep trying, but I get the points after the first attempt.
rok65612
Post by rok65612 »
Thanks for replying.
I'm not sure about whether I'll get the points, but I thought it might still be a good idea to let FAH know that there seems to be a serious error with either the client application, the server, or something in between.
If it was a one-off error I might have just let it slide like before, but now I've got a queue growing ever longer because the server or client is not clearing the completed WUs.
jjmiller
Scientist
Post by jjmiller »
Hi rok65612- thanks for the report and apologies for the delayed response. Have these WUs been uploaded now? If not, would you be willing to post the project/run/clone/gen information for the WUs that are causing trouble? With that information I'll chase down the error codes that the server may be throwing.
wjha
Post by wjha »
I got the same problem
But - to be true, that problem occures to several servers:
******************************* Date: 2021-07-15 *******************************
15:28:18:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18206 run:927 clone:2 gen:5 core:0xa8 unit:0x00000002000000050000471e0000039f
15:28:18:WU02:FS00:Uploading 27.83MiB to 128.252.203.11
15:28:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18206 run:10498 clone:1 gen:6 core:0xa8 unit:0x00000001000000060000471e00002902
15:28:18:WU00:FS00:Uploading 27.83MiB to 128.252.203.11
15:28:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:18206 run:8320 clone:3 gen:6 core:0xa8 unit:0x00000003000000060000471e00002080
15:28:18:WU01:FS00:Uploading 27.83MiB to 128.252.203.11
15:28:18:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:18212 run:17384 clone:1 gen:37 core:0xa8 unit:0x000000010000002500004724000043e8
15:28:18:WU03:FS00:Uploading 27.83MiB to 128.252.203.12
15:28:48:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:28:48:WU02:FS00:Trying to send results to collection server
15:28:48:WU02:FS00:Uploading 27.83MiB to 128.252.203.1
15:28:48:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:28:48:WU00:FS00:Trying to send results to collection server
15:28:48:WU00:FS00:Uploading 27.83MiB to 128.252.203.10
15:28:48:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:28:48:WU01:FS00:Trying to send results to collection server
15:28:48:WU01:FS00:Uploading 27.83MiB to 128.252.203.1
15:28:49:WARNING:WU03:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:28:49:WU03:FS00:Trying to send results to collection server
15:28:49:WU03:FS00:Uploading 27.83MiB to 128.252.203.10
15:29:18:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
15:29:19:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
15:29:19:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
15:29:20:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
Some network problem?
Got that problem also >14 days ago, could not send any work units in more than a week.
Best regards
Juergen
jjmiller
Scientist
Post by jjmiller »
Hi Juergen,
Thanks for the report. We had a major version upgrade to almost every FAH server on Monday which resulted in some issues with WU return. We've been chasing down the last missing WUs and think we have them all sorted out now. Is your client still listing these WUs as not returned? WU status (https://apps.foldingathome.org/wu#proje ... e=1&gen=37) indicates that all of these WUs have been credited and I have the data on our end.
Thanks!
wjha
Post by wjha »
Sadly on my panel they are still pending:
08:18:59:WU00:FS00:Trying to send results to collection server
08:18:59:WU00:FS00:Uploading 27.83MiB to 128.252.203.10
08:18:59:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:18:59:WU01:FS00:Trying to send results to collection server
08:18:59:WU01:FS00:Uploading 27.83MiB to 128.252.203.1
08:18:59:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:18:59:WU02:FS00:Trying to send results to collection server
08:18:59:WU02:FS00:Uploading 27.83MiB to 128.252.203.1
08:19:00:WARNING:WU03:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:19:00:WU03:FS00:Trying to send results to collection server
08:19:00:WU03:FS00:Uploading 27.83MiB to 128.252.203.10
08:19:29:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:19:30:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:19:30:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:19:30:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:20:38:WU05:FS00:0xa7:Completed 2500 out of 62500 steps (4%)
08:27:20:WU05:FS00:0xa7:Completed 3125 out of 62500 steps (5%)
08:29:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18206 run:10498 clone:1 gen:6 core:0xa8 unit:0x00000001000000060000471e00002902
08:29:34:WU00:FS00:Uploading 27.83MiB to 128.252.203.11
08:29:34:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:18206 run:8320 clone:3 gen:6 core:0xa8 unit:0x00000003000000060000471e00002080
08:29:34:WU01:FS00:Uploading 27.83MiB to 128.252.203.11
08:29:35:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18206 run:927 clone:2 gen:5 core:0xa8 unit:0x00000002000000050000471e0000039f
08:29:35:WU02:FS00:Uploading 27.83MiB to 128.252.203.11
08:29:35:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:18212 run:17384 clone:1 gen:37 core:0xa8 unit:0x000000010000002500004724000043e8
08:29:35:WU03:FS00:Uploading 27.83MiB to 128.252.203.12
08:30:04:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:30:04:WU00:FS00:Trying to send results to collection server
08:30:04:WU00:FS00:Uploading 27.83MiB to 128.252.203.10
08:30:05:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:30:05:WU01:FS00:Trying to send results to collection server
08:30:05:WU01:FS00:Uploading 27.83MiB to 128.252.203.1
08:30:05:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:30:05:WU02:FS00:Trying to send results to collection server
08:30:05:WU02:FS00:Uploading 27.83MiB to 128.252.203.1
08:30:05:WARNING:WU03:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:30:05:WU03:FS00:Trying to send results to collection server
08:30:05:WU03:FS00:Uploading 27.83MiB to 128.252.203.10
08:30:35:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:30:35:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:30:36:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:30:36:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:33:28:WU05:FS00:0xa7:Completed 3750 out of 62500 steps (6%)
08:40:37:WU05:FS00:0xa7:Completed 4375 out of 62500 steps (7%)
08:47:16:WU05:FS00:0xa7:Completed 5000 out of 62500 steps (8%)
08:47:31:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18206 run:10498 clone:1 gen:6 core:0xa8 unit:0x00000001000000060000471e00002902
08:47:31:WU00:FS00:Uploading 27.83MiB to 128.252.203.11
08:47:31:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:18206 run:8320 clone:3 gen:6 core:0xa8 unit:0x00000003000000060000471e00002080
08:47:31:WU01:FS00:Uploading 27.83MiB to 128.252.203.11
08:47:31:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18206 run:927 clone:2 gen:5 core:0xa8 unit:0x00000002000000050000471e0000039f
08:47:31:WU02:FS00:Uploading 27.83MiB to 128.252.203.11
08:47:32:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:18212 run:17384 clone:1 gen:37 core:0xa8 unit:0x000000010000002500004724000043e8
08:47:32:WU03:FS00:Uploading 27.83MiB to 128.252.203.12
08:48:01:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:48:01:WU00:FS00:Trying to send results to collection server
08:48:01:WU00:FS00:Uploading 27.83MiB to 128.252.203.10
08:48:01:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:48:01:WU01:FS00:Trying to send results to collection server
08:48:01:WU01:FS00:Uploading 27.83MiB to 128.252.203.1
08:48:02:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:48:02:WU02:FS00:Trying to send results to collection server
08:48:02:WU02:FS00:Uploading 27.83MiB to 128.252.203.1
08:48:02:WARNING:WU03:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
08:48:02:WU03:FS00:Trying to send results to collection server
08:48:02:WU03:FS00:Uploading 27.83MiB to 128.252.203.10
08:48:32:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:48:32:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:48:32:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:48:33:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
08:53:52:WU05:FS00:0xa7:Completed 5625 out of 62500 steps (9%)
09:00:17:WU05:FS00:0xa7:Completed 6250 out of 62500 steps (10%)
09:07:06:WU05:FS00:0xa7:Completed 6875 out of 62500 steps (11%)
09:13:28:WU05:FS00:0xa7:Completed 7500 out of 62500 steps (12%)
09:16:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18206 run:10498 clone:1 gen:6 core:0xa8 unit:0x00000001000000060000471e00002902
09:16:33:WU00:FS00:Uploading 27.83MiB to 128.252.203.11
09:16:33:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:18206 run:8320 clone:3 gen:6 core:0xa8 unit:0x00000003000000060000471e00002080
09:16:33:WU01:FS00:Uploading 27.83MiB to 128.252.203.11
09:16:33:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18206 run:927 clone:2 gen:5 core:0xa8 unit:0x00000002000000050000471e0000039f
09:16:33:WU02:FS00:Uploading 27.83MiB to 128.252.203.11
09:16:34:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:18212 run:17384 clone:1 gen:37 core:0xa8 unit:0x000000010000002500004724000043e8
09:16:34:WU03:FS00:Uploading 27.83MiB to 128.252.203.12
09:17:03:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:17:03:WU00:FS00:Trying to send results to collection server
09:17:03:WU00:FS00:Uploading 27.83MiB to 128.252.203.10
09:17:04:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:17:04:WU01:FS00:Trying to send results to collection server
09:17:04:WU01:FS00:Uploading 27.83MiB to 128.252.203.1
09:17:04:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:17:04:WU02:FS00:Trying to send results to collection server
09:17:04:WU02:FS00:Uploading 27.83MiB to 128.252.203.1
09:17:04:WARNING:WU03:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:17:04:WU03:FS00:Trying to send results to collection server
09:17:04:WU03:FS00:Uploading 27.83MiB to 128.252.203.10
09:17:34:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:17:34:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:17:35:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:17:35:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:19:54:WU05:FS00:0xa7:Completed 8125 out of 62500 steps (13%)
Best regards
Juergen
fz4z
Post by fz4z »
wjha wrote:Sadly on my panel they are still pending:
Please try to completely uninstall Anti Virus software, and then upload WU again.
wjha
Post by wjha »
With the exception of Microsoft Security I don't run other software.
On top: as mentioned, that problem existed last week. In the begin this week suddenly all pending jobs rolled out successful. Now same problem as last week raised again - without any changes in my system
Best regards
Juergen
jjmiller
Scientist
Post by jjmiller »
Hi wjha,
I'd agree with fz4z that this seems like it may be an issue with Antivirus/firewall settings as discussed here: viewtopic.php?f=19&t=37214&hilit=delete. If you see that your WU has been returned by checking the specific PROJECT/RUN/GEN/CLONE here: https://apps.foldingathome.org/wu then it should safe to delete the WU on your end (you'll have already returned the data to us and will have been credited your points!). If you do nothing, I believe that the WU should be removed automatically from your computer once the WU passes the deadline (we will still have the data and you will still have the points).
I will ping a few folks and see if there's anything that we can do on our end about this in the long run to reduce confusion and unnecessary connections/uploads. In the short term, these WUs have at least made it back to us.
fz4z
Post by fz4z »
wjha wrote:With the exception of Microsoft Security I don't run other software.
There might also be issues with your ISP, so try tethering the computer via the cell phone network or using VPN, and then see if the problem persists.
azhad
Post by azhad »
Do you use Kaspersky Anti-Virus? If that is the case, try turning off Network Monitoring of Port 8080. Steps below:
1. Go to the Kasperky Main screen
2. Click the Settings icon
3. Network Settings
4. Find the "Monitored Ports" Section
5. Click "Select" in "Monitor selected network ports only"
6. Port 8080 - Make Inactive.
Done. It should upload on the next try.
Monterone
Post by Monterone »
I have a similar problem with 4 WUs stuck. They stop while uploading at around 70 to 80%, retry and fail again.
The messages are like
21:10:27:WU00:FS00:Upload 75.02%
21:10:30:ERROR:WU00:FS00:Exception: Transfer failed
21:10:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18212 run:928 clone:0 gen:42 core:0xa8 unit:0x000000000000002a00004724000003a0
21:10:30:WU00:FS00:Uploading 27.83MiB to 128.252.203.12
21:10:30:WU00:FS00:Connecting to 128.252.203.12:8080
It concerns the following PRCGs (Work Server - WS, Collection Server - CS)
- 18212 (928, 0, 42) - WS: 128.252.203.12, CS: 128.252.203.1
- 18212 (2474, 1, 26) - WS: 128.252.203.12, CS: 128.252.203.10
- 18206 (6367, 9, 9) - WS: 128.252.203.11, CS: 128.252.203.1
- 18212 (10709, 0, 39) - WS: 128.252.203.12, CS: 128.252.203.10
fz4z
Post by fz4z »
Monterone wrote:I have a similar problem with 4 WUs stuck. They stop while uploading at around 70 to 80%, retry and fail again.
There might be issues with your ISP, so try tethering the computer via the cell phone network or using VPN, and then see if the problem persists.
jjmiller
Scientist
Post by jjmiller »
Hi Monterone, Have these WUs been returned or are you seeing any different behavior on your end? I'm searching through the logs on our end and not finding any errors in reference to these WUs.Are these still only trying to upload to 128.252.203.1/10?
