Ryzen 5700G GPU
des1957
Ryzen 5700G GPU
Post by des1957 »
Ryzen 5700G. CPU folds very well. The GPU is not recognized.
Name: AMD Radeon(TM) Graphics
Device ID: 1002 1638-1458 D000
Please add to GPUs.txt file
*********************** Log Started 2021-06-07T13:17:56Z ***********************
13:17:56:******************************* libFAH ********************************
13:17:56:           Date: Oct 20 2020
13:17:56:           Time: 13:36:55
13:17:56:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:17:56:         Branch: master
13:17:56:       Compiler: Visual C++ 2015
13:17:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:17:56:       Platform: win32 10
13:17:56:           Bits: 32
13:17:56:           Mode: Release
13:17:56:****************************** FAHClient ******************************
13:17:56:        Version: 7.6.21
13:17:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:17:56:      Copyright: 2020 foldingathome.org
13:17:56:       Homepage: https://foldingathome.org/
13:17:56:           Time: 13:41:04
13:17:56:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:17:56:           Bits: 32
13:17:56:         Config: C:\ProgramData\FAHClient\config.xml
13:17:56:******************************** CBang ********************************
13:17:56:           Time: 11:36:18
13:17:56:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:17:56:           Bits: 32
13:17:56:******************************* System ********************************
13:17:56:            CPU: AMD Ryzen 7 5700G with Radeon Graphics
13:17:56:         CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
13:17:56:           CPUs: 16
13:17:56:         Memory: 15.39GiB
13:17:56:    Free Memory: 13.35GiB
13:17:56:        Threads: WINDOWS_THREADS
13:17:56:     OS Version: 6.2
13:17:56:    Has Battery: false
13:17:56:     On Battery: false
13:17:56:     UTC Offset: -4
13:17:56:            PID: 10496
13:17:56:            CWD: C:\ProgramData\FAHClient
13:17:56:  Win32 Service: false
13:17:56:             OS: Windows 10 Enterprise
13:17:56:        OS Arch: AMD64
13:17:56:           GPUs: 1
13:17:56:          GPU 0: Bus:6 Slot:0 Func:0 AMD:1
13:17:56:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:17:56:                 specified module could not be found.
13:17:56:
13:17:56:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3240.6
13:17:56:***********************************************************************
13:17:56:<config>
13:17:56:  <!-- Network -->
13:17:56:  <proxy v=':8080'/>
13:17:56:
13:17:56:  <!-- Slot Control -->
13:17:56:  <power v='FULL'/>
13:17:56:
13:17:56:  <!-- User Information -->
13:17:56:  <passkey v='*****'/>
13:17:56:  <team v='224497'/>
13:17:56:  <user v='Donald_E_Smith'/>
13:17:56:
13:17:56:  <!-- Folding Slots -->
13:17:56:  <slot id='0' type='CPU'/>
13:17:56:  <slot id='1' type='GPU'>
13:17:56:    <pci-bus v='6'/>
13:17:56:    <pci-slot v='0'/>
13:17:56:  </slot>
13:17:56:</config>
13:17:56:Trying to access database...
13:17:56:Successfully acquired database lock
13:17:56:FS00:Initialized folding slot 00: cpu:15
13:17:56:WARNING:FS01:Disabling beta GPU slot 01: gpu:6:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
13:17:56:WU00:FS00:Starting
13:17:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10496 -checkpoint 15 -np 15
13:17:56:WU00:FS00:Started FahCore on PID 10888
13:17:56:WU00:FS00:Core PID:10912
13:17:56:WU00:FS00:FahCore 0xa8 started
13:17:57:WU00:FS00:0xa8:*********************** Log Started 2021-06-07T13:17:56Z ***********************
13:17:57:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
13:17:57:WU00:FS00:0xa8:       Core: Gromacs
13:17:57:WU00:FS00:0xa8:       Type: 0xa8
13:17:57:WU00:FS00:0xa8:    Version: 0.0.12
13:17:57:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:17:57:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
13:17:57:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
13:17:57:WU00:FS00:0xa8:       Date: Jan 16 2021
13:17:57:WU00:FS00:0xa8:       Time: 12:29:40
13:17:57:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
13:17:57:WU00:FS00:0xa8:     Branch: master
13:17:57:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
13:17:57:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:17:57:WU00:FS00:0xa8:   Platform: win32 10
13:17:57:WU00:FS00:0xa8:       Bits: 64
13:17:57:WU00:FS00:0xa8:       Mode: Release
13:17:57:WU00:FS00:0xa8:       SIMD: avx2_256
13:17:57:WU00:FS00:0xa8:     OpenMP: ON
13:17:57:WU00:FS00:0xa8:       CUDA: OFF
13:17:57:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10888 -checkpoint 15 -np
13:17:57:WU00:FS00:0xa8:             15
13:17:57:WU00:FS00:0xa8:************************************ libFAH ************************************
13:17:57:WU00:FS00:0xa8:       Time: 11:24:13
13:17:57:WU00:FS00:0xa8:************************************ CBang *************************************
13:17:57:WU00:FS00:0xa8:       Time: 11:23:53
13:17:57:WU00:FS00:0xa8:************************************ System ************************************
13:17:57:WU00:FS00:0xa8:        CPU: AMD Ryzen 7 5700G with Radeon Graphics
13:17:57:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
13:17:57:WU00:FS00:0xa8:       CPUs: 16
13:17:57:WU00:FS00:0xa8:     Memory: 15.39GiB
13:17:57:WU00:FS00:0xa8:Free Memory: 13.31GiB
13:17:57:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
13:17:57:WU00:FS00:0xa8: OS Version: 6.2
13:17:57:WU00:FS00:0xa8:Has Battery: false
13:17:57:WU00:FS00:0xa8: On Battery: false
13:17:57:WU00:FS00:0xa8: UTC Offset: -4
13:17:57:WU00:FS00:0xa8:        PID: 10912
13:17:57:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
13:17:57:WU00:FS00:0xa8:********************************************************************************
13:17:57:WU00:FS00:0xa8:Project: 16969 (Run 9, Clone 434, Gen 22)
13:17:57:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
13:17:57:WU00:FS00:0xa8:Digital signatures verified
13:17:57:WU00:FS00:0xa8:Calling: mdrun -c frame22.gro -s frame22.tpr -x frame22.xtc -cpi state.cpt -cpt 15 -nt 15 -ntmpi 1
13:17:57:WU00:FS00:0xa8:Steps: first=55000000 total=57500000
13:17:57:WU00:FS00:0xa8:Completed 1093801 out of 2500000 steps (43%)
13:18:31:WU00:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
13:25:05:WARNING:WU00:FS00:Detected clock skew (6 mins 23 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
13:27:05:WU00:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
13:29:10:WU00:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
13:31:20:WU00:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
13:33:31:WU00:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
13:35:37:WU00:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
13:37:41:WU00:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
13:39:46:WU00:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
13:41:51:WU00:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
13:43:55:WU00:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
13:46:00:WU00:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
13:48:05:WU00:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
13:50:09:WU00:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
13:52:14:WU00:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
13:54:19:WU00:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
13:56:24:WU00:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
13:58:29:WU00:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
14:00:34:WU00:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
14:02:39:WU00:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
14:04:43:WU00:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
14:06:47:WU00:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
14:08:51:WU00:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
14:10:55:WU00:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
14:12:59:WU00:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
14:15:03:WU00:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
14:17:07:WU00:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
14:19:11:WU00:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
14:21:15:WU00:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
14:23:19:WU00:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
14:25:22:WU00:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
14:27:26:WU00:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
14:29:30:WU00:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
14:31:34:WU00:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
14:33:37:WU00:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
14:35:41:WU00:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
14:37:45:WU00:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
14:39:49:WU00:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
14:41:53:WU00:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
14:43:57:WU00:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
14:46:00:WU00:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
14:48:04:WU00:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
14:50:08:WU00:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
14:52:13:WU00:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
14:52:15:FS00:Finishing
14:52:15:FS01:Finishing
14:54:18:WU00:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
14:56:22:WU00:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
14:58:27:WU00:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
15:00:32:WU00:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
15:02:37:WU00:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
15:04:42:WU00:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
15:06:46:WU00:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
15:08:51:WU00:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
15:10:56:WU00:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
15:13:00:WU00:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
15:15:05:WU00:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
15:17:09:WU00:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
15:19:14:WU00:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
15:19:15:WU01:FS00:Connecting to assign1.foldingathome.org:80
15:19:15:WU01:FS00:Assigned to work server 129.32.209.203
15:19:15:WU01:FS00:Requesting new work unit for slot 00: cpu:15 from 129.32.209.203
15:19:15:WU01:FS00:Connecting to 129.32.209.203:8080
15:19:16:WU01:FS00:Downloading 758.50KiB
15:19:17:WU01:FS00:Download complete
15:19:17:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16954 run:19 clone:9 gen:115 core:0xa8 unit:0x00000009000000730000423a00000013
15:21:18:WU00:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
15:21:19:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
15:21:19:WU00:FS00:0xa8:Saving result file frame22.gro
15:21:19:WU00:FS00:0xa8:Saving result file frame22.xtc
15:21:19:WU00:FS00:0xa8:Saving result file md.log
15:21:19:WU00:FS00:0xa8:Saving result file science.log
15:21:19:WU00:FS00:0xa8:Saving result file state.cpt
15:21:19:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
15:21:19:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:21:19:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16969 run:9 clone:434 gen:22 core:0xa8 unit:0x000001b2000000160000424900000009
15:21:19:WU00:FS00:Uploading 5.13MiB to 129.32.209.205
15:21:19:WU00:FS00:Connecting to 129.32.209.205:8080
15:21:19:WU01:FS00:Starting
15:21:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 10496 -checkpoint 15 -np 15
15:21:19:WU01:FS00:Started FahCore on PID 12200
15:21:19:WU01:FS00:Core PID:10504
15:21:19:WU01:FS00:FahCore 0xa8 started
15:21:20:WU01:FS00:0xa8:*********************** Log Started 2021-06-07T15:21:19Z ***********************
15:21:20:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:21:20:WU01:FS00:0xa8:       Core: Gromacs
15:21:20:WU01:FS00:0xa8:       Type: 0xa8
15:21:20:WU01:FS00:0xa8:    Version: 0.0.12
15:21:20:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:21:20:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
15:21:20:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
15:21:20:WU01:FS00:0xa8:       Date: Jan 16 2021
15:21:20:WU01:FS00:0xa8:       Time: 12:29:40
15:21:20:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:21:20:WU01:FS00:0xa8:     Branch: master
15:21:20:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
15:21:20:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:21:20:WU01:FS00:0xa8:   Platform: win32 10
15:21:20:WU01:FS00:0xa8:       Bits: 64
15:21:20:WU01:FS00:0xa8:       Mode: Release
15:21:20:WU01:FS00:0xa8:       SIMD: avx2_256
15:21:20:WU01:FS00:0xa8:     OpenMP: ON
15:21:20:WU01:FS00:0xa8:       CUDA: OFF
15:21:20:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12200 -checkpoint 15 -np
15:21:20:WU01:FS00:0xa8:             15
15:21:20:WU01:FS00:0xa8:************************************ libFAH ************************************
15:21:20:WU01:FS00:0xa8:       Time: 11:24:13
15:21:20:WU01:FS00:0xa8:************************************ CBang *************************************
15:21:20:WU01:FS00:0xa8:       Time: 11:23:53
15:21:20:WU01:FS00:0xa8:************************************ System ************************************
15:21:20:WU01:FS00:0xa8:        CPU: AMD Ryzen 7 5700G with Radeon Graphics
15:21:20:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
15:21:20:WU01:FS00:0xa8:       CPUs: 16
15:21:20:WU01:FS00:0xa8:     Memory: 15.39GiB
15:21:20:WU01:FS00:0xa8:Free Memory: 12.67GiB
15:21:20:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
15:21:20:WU01:FS00:0xa8: OS Version: 6.2
15:21:20:WU01:FS00:0xa8:Has Battery: false
15:21:20:WU01:FS00:0xa8: On Battery: false
15:21:20:WU01:FS00:0xa8: UTC Offset: -4
15:21:20:WU01:FS00:0xa8:        PID: 10504
15:21:20:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
15:21:20:WU01:FS00:0xa8:********************************************************************************
15:21:20:WU01:FS00:0xa8:Project: 16954 (Run 19, Clone 9, Gen 115)
15:21:20:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:21:20:WU01:FS00:0xa8:Reading tar file core.xml
15:21:20:WU01:FS00:0xa8:Reading tar file frame115.tpr
15:21:20:WU01:FS00:0xa8:Digital signatures verified
15:21:20:WU01:FS00:0xa8:Calling: mdrun -c frame115.gro -s frame115.tpr -x frame115.xtc -cpt 15 -nt 15 -ntmpi 1
15:21:20:WU01:FS00:0xa8:Steps: first=575000000 total=580000000
15:21:21:WU01:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
15:21:25:WU00:FS00:Upload 32.91%
15:21:31:WU00:FS00:Upload 67.04%
15:21:37:WU00:FS00:Upload complete
15:21:37:WU00:FS00:Server responded WORK_ACK (400)
15:21:37:WU00:FS00:Final credit estimate, 41708.00 points
15:21:37:WU00:FS00:Cleaning up
15:24:54:WU01:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
15:28:27:WU01:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
15:31:59:WU01:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
15:35:31:WU01:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
15:39:02:WU01:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
15:42:32:WU01:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
15:46:02:WU01:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
15:49:31:WU01:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
15:53:00:WU01:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
15:56:31:WU01:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
16:00:03:WU01:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
16:03:32:WU01:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
16:07:08:WU01:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
16:10:53:WU01:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
16:14:40:WU01:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
16:18:40:WU01:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
16:22:26:WU01:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
16:26:07:WU01:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
16:29:40:WU01:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
16:33:13:WU01:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
16:36:45:WU01:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
16:40:16:WU01:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
16:43:48:WU01:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
16:47:19:WU01:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
16:50:48:WU01:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
16:54:20:WU01:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
16:57:52:WU01:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
17:01:24:WU01:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
17:04:56:WU01:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
17:08:27:WU01:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
17:11:57:WU01:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
17:15:26:WU01:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
17:18:55:WU01:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
17:22:24:WU01:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
17:25:53:WU01:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
17:29:23:WU01:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
17:32:52:WU01:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
17:36:21:WU01:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
17:39:49:WU01:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
17:43:18:WU01:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
17:46:47:WU01:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
17:50:16:WU01:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
17:53:46:WU01:FS00:0xa8:Completed 2150000 out of 5000000 steps (43%)
17:57:14:WU01:FS00:0xa8:Completed 2200000 out of 5000000 steps (44%)
18:00:44:WU01:FS00:0xa8:Completed 2250000 out of 5000000 steps (45%)
18:04:12:WU01:FS00:0xa8:Completed 2300000 out of 5000000 steps (46%)
18:07:41:WU01:FS00:0xa8:Completed 2350000 out of 5000000 steps (47%)
18:11:11:WU01:FS00:0xa8:Completed 2400000 out of 5000000 steps (48%)
18:14:41:WU01:FS00:0xa8:Completed 2450000 out of 5000000 steps (49%)
18:18:10:WU01:FS00:0xa8:Completed 2500000 out of 5000000 steps (50%)
18:21:39:WU01:FS00:0xa8:Completed 2550000 out of 5000000 steps (51%)
18:25:08:WU01:FS00:0xa8:Completed 2600000 out of 5000000 steps (52%)
18:28:38:WU01:FS00:0xa8:Completed 2650000 out of 5000000 steps (53%)
18:32:08:WU01:FS00:0xa8:Completed 2700000 out of 5000000 steps (54%)
18:35:37:WU01:FS00:0xa8:Completed 2750000 out of 5000000 steps (55%)
18:39:06:WU01:FS00:0xa8:Completed 2800000 out of 5000000 steps (56%)
18:42:35:WU01:FS00:0xa8:Completed 2850000 out of 5000000 steps (57%)
18:46:04:WU01:FS00:0xa8:Completed 2900000 out of 5000000 steps (58%)
18:49:34:WU01:FS00:0xa8:Completed 2950000 out of 5000000 steps (59%)
18:53:04:WU01:FS00:0xa8:Completed 3000000 out of 5000000 steps (60%)
18:56:49:WU01:FS00:0xa8:Completed 3050000 out of 5000000 steps (61%)
19:00:24:WU01:FS00:0xa8:Completed 3100000 out of 5000000 steps (62%)
19:04:00:WU01:FS00:0xa8:Completed 3150000 out of 5000000 steps (63%)
19:07:36:WU01:FS00:0xa8:Completed 3200000 out of 5000000 steps (64%)
19:11:11:WU01:FS00:0xa8:Completed 3250000 out of 5000000 steps (65%)
Re: Ryzen 5700G GPU
As a CPU, it supports the latest AVX2 math standard.
https://www.techpowerup.com/cpu-specs/r ... 700g.c2472
Once it is entered in the database it should fold as a GPU, a little slower than a GT 1030
https://www.techpowerup.com/gpu-specs/r ... ga-8.c3042
des1957
Re: Ryzen 5700G GPU
Post by des1957 »
Well, it has been a week and only 1 reply. Did I do something wrong or do you need more info?
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Ryzen 5700G GPU
Post by BobWilliams757 »
viewtopic.php?f=83&t=26208#p262894
Use GPU-Z as directed in the above Link in step 3 to find your specific device ID. Then post it in the thread, and somebody should get to it.
There are only a handful of people that take care of this stuff, and they need the device ID to add it to the white list.
Fold them if you get them!
gunnarre
Re: Ryzen 5700G GPU
Post by gunnarre »
Isn't this it?
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
Re: Ryzen 5700G GPU
gunnarre wrote:Isn't this it?
I guess so, based on the other thread by the OP of this one. I hadn't seen that, and now I do.
It is strange that as of now it identifies as something in beta....
"13:17:56:WARNING:FS01:Disabling beta GPU slot 01: gpu:6:0. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration."
I'm assuming this is somehow related to the Intel testing, as I've heard of nothing else being tested as far as on board graphics.
I'd imagine the Vega 8 will fold decent with that kind of clock speed.
des1957
Re: Ryzen 5700G GPU
Post by des1957 »
T added the beta option to see if it would get any work. That is why there is that message in my log.
Re: Ryzen 5700G GPU
According to Techpowerup.com, the integrated GPU lacks any special drivers. https://www.techpowerup.com/280879/amd- ... and-tested. That suggests that FAH will not recognize it as a gpu. That's the same thing reported in the first post in this topic. That's in conflict with the statement "GPU-Z reports a Vega 8 processor" but it won't be recognized unless we get the correct device ID.
I suggest that you'll need to configure it as a CPU so that FAH will assign CPU WorkUnits to it. (It might appear as both.)
Run both GPU-Z and CPU-Z and show us what they both say.
Adding the beta flag will not give you access to GPU assignments when as far as FAH is concerned, it doesn't exist yet.
des1957
Re: Ryzen 5700G GPU
Post by des1957 »
Why is this so complicated? According to my log, FAH already see's this as an unknown AMD gpu. In my original post I provided all the requested info -device name, device id and FAH log. According to GPU-Z this a Cezanne chip GFX9 (gfx90c). As far as the cpu, it has been folding since I installed FAH with no problems.
des1957
Re: Ryzen 5700G GPU
Post by des1957 »
Update - Someone added gpu to GPUs.txt fileand it is filding just fine. Thank You
Re: Ryzen 5700G GPU
Thank you for keeping us updated!
I can give (bad) advice and do, but only about 3 regulars can update GPUs.txt on the server from user requests here. I notified them when I saw your request was not being processed.
No one here is paid to be here, we are all volunteers just like you.
As to why they are cautious, both the CPU and GPU in that chip have device IDs, they want the right one. Sending a CPU to do GPU work would be bad.
Re: Ryzen 5700G GPU
Confirmation #1: I added ut late last night ... provisionally.
#2 at least I got the right Device ID.
Request #1: Please: More reports about the GPU performance
Request #2: What does GPU-Z call it? (The "unknown" is temporary.)
Request #3: What AMD drivers have you installed?
Request #4: Is it producing a lot of heat?
des1957
Re: Ryzen 5700G GPU
Post by des1957 »
1 - Performance is About 80,000 points per day. Overall ppd about the same either way.
2 - Per GPU-Z: AMD Radeon(TM) Graphics (Cezanne chip GFX9 (gfx90c)) from Techpowerup
3 - 21.5.2
4 - Liquid cooled CPU 55 degrees GPU - 48 degrees CPU temp only went up 1 -2 degrees when GPU started folding. Running at full speed
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
Re: Ryzen 5700G GPU
des1957 wrote:1 - Performance is About 80,000 points per day. Overall ppd about the same either way.
3 - 21.5.2
And the power consumption will be next to nothing doing it. :mrgreen:
With those clocks on the Vega 8, I wonder if there is room to overclock it more? Just curiosity as many of the earlier ones would overclock fairly well.
Wait until you get some of the really small atom count work units that many people with the "big" cards seem to hate. These things will eat them up. My Vega 11 (2400G) at stock clocks averages probably a bit lower than the 80K you are seeing, but here and there with the right work units it will crank out 250+ K.
iero
Re: Ryzen 5700G GPU
Post by iero »
80K on a Vega 8? Wow, i must have been doing something very wrong on my 2200g, cause that number sounds extremely high compared to my cpu. Jesus, ill have to retest the Ryzen 3 2200g one of these days.
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
