Missing or Low points?
Foldingisfun
Post by Foldingisfun »
Hi all. I'm fairly new, only been folding a couple days now. I'm running FAH on my MacBook Pro and have noticed that the points in my log file aren't lining up with what I am being credited. I've already generated and verified my passkey is entered for my account.
I've completed 6 WUs thus far, with my log file showing Final credit estimates that sum up to 78459.00 points, however my account only reflect 4 WUs having been accomplished for a total of 14836.00 points.
I looked up each of the completed WUs separately on the FAH website.
All but one of the WUs (the second one in the abridged log file below) was verified received and credited. The second WU appears to be associated with an IP (129.32.209.205) that is very close to a string of other IPs for which there are various issues being reported in the specific server forum (129.32.209.xx servers).
Am I missing something? Where are these points that the log file reports credited, yet either don't show up or show up in a significantly reduced amount (know that can happen without a passkey, but wouldn't the log file show the reduced points then)?
The first Full log file shows up through completion of my first WU unit, due to character limit constraints. The second abridged log file shows a summary for each WU. Please let me know if you need some other portion of the log to help diagnose.
Thank you guys in advance for your help!
Full log file:
*********************** Log Started 2021-04-26T20:25:58Z ***********************
20:25:58:******************************* libFAH ********************************
20:25:58:       Date: Oct 20 2020
20:25:58:       Time: 13:36:42
20:25:58:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
20:25:58:     Branch: master
20:25:58:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
20:25:58:    Options: -std=c++11 -fsigned-char -O3 -funroll-loops
20:25:58:             -mmacosx-version-min=10.7 -Wno-unused-local-typedefs -stdlib=libc++
20:25:58:   Platform: darwin 19.2.0
20:25:58:       Bits: 64
20:25:58:       Mode: Release
20:25:58:****************************** FAHClient ******************************
20:25:58:    Version: 7.6.21
20:25:58:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:25:58:  Copyright: 2020 foldingathome.org
20:25:58:   Homepage: https://foldingathome.org/
20:25:58:       Time: 13:39:56
20:25:58:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
20:25:58:       Bits: 64
20:25:58:******************************** CBang ********************************
20:25:58:       Time: 11:39:07
20:25:58:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
20:25:58:             -fPIC
20:25:58:       Bits: 64
20:25:58:******************************* System ********************************
20:25:58:        CPU: VirtualApple @ 2.50GHz
20:25:58:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
20:25:58:       CPUs: 8
20:25:58:     Memory: 16.00GiB
20:25:58:Free Memory: 257.22MiB
20:25:58:    Threads: POSIX_THREADS
20:25:58: OS Version: 10.16
20:25:58:Has Battery: true
20:25:58: On Battery: false
20:25:58: UTC Offset: -4
20:25:58:        PID: 89868
20:25:58:        CWD: /Library/Application Support/FAHClient
20:25:58:         OS: Darwin 20.3.0 x86_64
20:25:58:    OS Arch: AMD64
20:25:58:       GPUs: 1
20:25:58:      GPU 0: Bus:0 Slot:0 Func:0 AMD:5 Hawaii [Radeon R9 200 Series]
20:25:58:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
20:25:58:             dlopen(libcuda.dylib, 1): no suitable image found. Did find:
20:25:58:               file system relative paths not allowed in hardened programs
20:25:58:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
20:25:58:             dlopen(libOpenCL.dylib, 1): no suitable image found. Did find:
20:25:58:***********************************************************************
20:25:58:<config>
20:25:58:  <!-- Folding Slots -->
20:25:58:</config>
20:25:58:Trying to access database...
20:25:58:Successfully acquired database lock
20:25:58:FS00:Initialized folding slot 00: cpu:4
20:26:11:17:127.0.0.1:New Web session
20:26:59:Saving configuration to config.xml
20:26:59:<config>
20:26:59:  <!-- Folding Slots -->
20:26:59:  <slot id='0' type='CPU'/>
20:26:59:</config>
20:26:59:Set client configured
20:26:59:WU00:FS00:Connecting to assign1.foldingathome.org:80
20:27:00:WU00:FS00:Connecting to assign1.foldingathome.org:80
20:27:00:WU00:FS00:Assigned to work server 206.223.170.146
20:27:00:WU00:FS00:Requesting new work unit for slot 00: cpu:4 from 206.223.170.146
20:27:00:WU00:FS00:Connecting to 206.223.170.146:8080
20:27:01:WU00:FS00:Downloading 31.15MiB
20:27:08:WU00:FS00:Download 62.81%
20:27:12:WU00:FS00:Download complete
20:27:13:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17231 run:5061 clone:0 gen:54 core:0xa7 unit:0x00000000000000360000434f000013c5
20:27:13:WU00:FS00:Downloading core from http://cores.foldingathome.org/osx/64bit-sse2/a7-0.0.19/Core_a7.fah
20:27:13:WU00:FS00:Connecting to cores.foldingathome.org:80
20:27:13:WU00:FS00:FahCore a7: Downloading 5.84MiB
20:27:15:WU00:FS00:FahCore a7: Download complete
20:27:16:WU00:FS00:Valid core signature
20:27:16:WU00:FS00:Unpacked 14.89MiB to cores/cores.foldingathome.org/osx/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7
20:27:16:WU00:FS00:Starting
20:27:16:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 89868 -checkpoint 15 -np 4
20:27:16:WU00:FS00:Started FahCore on PID 90082
20:27:16:WU00:FS00:Core PID:90083
20:27:16:WU00:FS00:FahCore 0xa7 started
20:27:18:WU00:FS00:0xa7:*********************** Log Started 2021-04-26T20:27:17Z ***********************
20:27:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:27:18:WU00:FS00:0xa7:       Type: 0xa7
20:27:18:WU00:FS00:0xa7:       Core: Gromacs
20:27:18:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 90082 -checkpoint 15 -np
20:27:18:WU00:FS00:0xa7:             4
20:27:18:WU00:FS00:0xa7:************************************ CBang *************************************
20:27:18:WU00:FS00:0xa7:       Date: Nov 27 2019
20:27:18:WU00:FS00:0xa7:       Time: 03:26:57
20:27:18:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
20:27:18:WU00:FS00:0xa7:     Branch: master
20:27:18:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
20:27:18:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
20:27:18:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
20:27:18:WU00:FS00:0xa7:   Platform: darwin 19.0.0
20:27:18:WU00:FS00:0xa7:       Bits: 64
20:27:18:WU00:FS00:0xa7:       Mode: Release
20:27:18:WU00:FS00:0xa7:************************************ System ************************************
20:27:18:WU00:FS00:0xa7:        CPU: VirtualApple @ 2.50GHz
20:27:18:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
20:27:18:WU00:FS00:0xa7:       CPUs: 8
20:27:18:WU00:FS00:0xa7:     Memory: 16.00GiB
20:27:18:WU00:FS00:0xa7:Free Memory: 416.84MiB
20:27:18:WU00:FS00:0xa7:    Threads: POSIX_THREADS
20:27:18:WU00:FS00:0xa7: OS Version: 10.16
20:27:18:WU00:FS00:0xa7:Has Battery: true
20:27:18:WU00:FS00:0xa7: On Battery: false
20:27:18:WU00:FS00:0xa7: UTC Offset: -4
20:27:18:WU00:FS00:0xa7:        PID: 90083
20:27:18:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
20:27:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:27:18:WU00:FS00:0xa7:    Version: 0.0.19
20:27:18:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:27:18:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:27:18:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:27:18:WU00:FS00:0xa7:       Date: Nov 25 2019
20:27:18:WU00:FS00:0xa7:       Time: 16:45:06
20:27:18:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
20:27:18:WU00:FS00:0xa7:************************************ Build *************************************
20:27:18:WU00:FS00:0xa7:       SIMD: sse2
20:27:18:WU00:FS00:0xa7:********************************************************************************
20:27:18:WU00:FS00:0xa7:Project: 17231 (Run 5061, Clone 0, Gen 54)
20:27:18:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
20:27:18:WU00:FS00:0xa7:Reading tar file core.xml
20:27:18:WU00:FS00:0xa7:Reading tar file frame54.tpr
20:27:18:WU00:FS00:0xa7:Digital signatures verified
20:27:18:WU00:FS00:0xa7:Calling: mdrun -s frame54.tpr -o frame54.trr -x frame54.xtc -cpt 15 -nt 4
20:27:18:WU00:FS00:0xa7:Steps: first=3375000 total=62500
20:27:20:WU00:FS00:0xa7:Completed 1 out of 62500 steps (0%)
20:29:01:Saving configuration to config.xml
20:29:01:<config>
20:29:01:  <!-- User Information -->
20:29:01:  <passkey v='*****'/>
20:29:01:  <team v='234980'/>
20:29:01:  <user v='9ouv465a73iz'/>
20:29:01:
20:29:01:  <!-- Folding Slots -->
20:29:01:  <slot id='0' type='CPU'/>
20:29:01:</config>
20:29:09:FS00:Shutting core down
20:29:09:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 90083
20:29:09:WU00:FS00:0xa7:Exiting, please wait. . .
20:29:19:FS00:Shutting core down
20:29:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:29:32:WU00:FS00:Starting
[93m20:29:32:WARNING:WU00:FS00:Changed SMP threads from 4 to 8 this can cause some work units to fail[0m
[93m20:29:32:WARNING:WU00:FS00:AS lowered CPUs from 8 to 4[0m
20:29:32:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 89868 -checkpoint 15 -np 4
20:29:32:WU00:FS00:Started FahCore on PID 90129
20:29:33:WU00:FS00:Core PID:90130
20:29:33:WU00:FS00:FahCore 0xa7 started
20:29:33:WU00:FS00:0xa7:*********************** Log Started 2021-04-26T20:29:33Z ***********************
20:29:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:29:33:WU00:FS00:0xa7:       Type: 0xa7
20:29:33:WU00:FS00:0xa7:       Core: Gromacs
20:29:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 90129 -checkpoint 15 -np
20:29:33:WU00:FS00:0xa7:             4
20:29:33:WU00:FS00:0xa7:************************************ CBang *************************************
20:29:33:WU00:FS00:0xa7:       Date: Nov 27 2019
20:29:33:WU00:FS00:0xa7:       Time: 03:26:57
20:29:33:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
20:29:33:WU00:FS00:0xa7:     Branch: master
20:29:33:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
20:29:33:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
20:29:33:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
20:29:33:WU00:FS00:0xa7:   Platform: darwin 19.0.0
20:29:33:WU00:FS00:0xa7:       Bits: 64
20:29:33:WU00:FS00:0xa7:       Mode: Release
20:29:33:WU00:FS00:0xa7:************************************ System ************************************
20:29:33:WU00:FS00:0xa7:        CPU: VirtualApple @ 2.50GHz
20:29:33:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
20:29:33:WU00:FS00:0xa7:       CPUs: 8
20:29:33:WU00:FS00:0xa7:     Memory: 16.00GiB
20:29:33:WU00:FS00:0xa7:Free Memory: 1.69GiB
20:29:33:WU00:FS00:0xa7:    Threads: POSIX_THREADS
20:29:33:WU00:FS00:0xa7: OS Version: 10.16
20:29:33:WU00:FS00:0xa7:Has Battery: true
20:29:33:WU00:FS00:0xa7: On Battery: false
20:29:33:WU00:FS00:0xa7: UTC Offset: -4
20:29:33:WU00:FS00:0xa7:        PID: 90130
20:29:33:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
20:29:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:29:33:WU00:FS00:0xa7:    Version: 0.0.19
20:29:33:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:29:33:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:29:33:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:29:33:WU00:FS00:0xa7:       Date: Nov 25 2019
20:29:33:WU00:FS00:0xa7:       Time: 16:45:06
20:29:33:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
20:29:33:WU00:FS00:0xa7:************************************ Build *************************************
20:29:33:WU00:FS00:0xa7:       SIMD: sse2
20:29:33:WU00:FS00:0xa7:********************************************************************************
20:29:33:WU00:FS00:0xa7:Project: 17231 (Run 5061, Clone 0, Gen 54)
20:29:33:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
20:29:33:WU00:FS00:0xa7:Digital signatures verified
20:29:33:WU00:FS00:0xa7:Calling: mdrun -s frame54.tpr -o frame54.trr -x frame54.xtc -cpi state.cpt -cpt 15 -nt 4
20:29:34:WU00:FS00:0xa7:Steps: first=3375000 total=62500
20:29:36:WU00:FS00:0xa7:Completed 392 out of 62500 steps (0%)
20:30:02:Saving configuration to config.xml
20:30:02:<config>
20:30:02:  <!-- Slot Control -->
20:30:02:  <power v='FULL'/>
20:30:02:
20:30:02:  <!-- User Information -->
20:30:02:  <passkey v='*****'/>
20:30:02:  <team v='234980'/>
20:30:02:  <user v='9ouv465a73iz'/>
20:30:02:
20:30:02:  <!-- Folding Slots -->
20:30:02:  <slot id='0' type='CPU'/>
20:30:02:</config>
20:30:44:WU00:FS00:0xa7:Completed 625 out of 62500 steps (1%)
20:33:05:Saving configuration to config.xml
20:33:05:<config>
20:33:05:  <!-- Folding Core -->
20:33:05:  <core-priority v='low'/>
20:33:05:
20:33:05:  <!-- Folding Slot Configuration -->
20:33:05:  <cause v='HIGH_PRIORITY'/>
20:33:05:
20:33:05:  <!-- Network -->
20:33:05:  <proxy v=':8080'/>
20:33:05:
20:33:05:  <!-- Slot Control -->
20:33:05:  <power v='FULL'/>
20:33:05:
20:33:05:  <!-- User Information -->
20:33:05:  <passkey v='*****'/>
20:33:05:  <team v='234980'/>
20:33:05:  <user v='9ouv465a73iz'/>
20:33:05:
20:33:05:  <!-- Folding Slots -->
20:33:05:  <slot id='0' type='CPU'/>
20:33:05:</config>
20:33:07:Caught signal SIGPIPE(13) on PID 89868
[91m20:33:07:ERROR:Send error: 32: Broken pipe[0m
20:34:27:WU00:FS00:0xa7:Completed 1250 out of 62500 steps (2%)
20:37:52:WU00:FS00:0xa7:Completed 1875 out of 62500 steps (3%)
20:38:50:Caught signal SIGPIPE(13) on PID 89868
[91m20:38:50:ERROR:Send error: 32: Broken pipe[0m
20:42:28:WU00:FS00:0xa7:Completed 2500 out of 62500 steps (4%)
20:47:06:WU00:FS00:0xa7:Completed 3125 out of 62500 steps (5%)
20:51:27:WU00:FS00:0xa7:Completed 3750 out of 62500 steps (6%)
20:56:15:WU00:FS00:0xa7:Completed 4375 out of 62500 steps (7%)
21:01:07:WU00:FS00:0xa7:Completed 5000 out of 62500 steps (8%)
21:02:39:FS00:Shutting core down
21:02:39:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 90130
21:02:39:WU00:FS00:0xa7:Exiting, please wait. . .
21:02:57:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:02:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:06:47:WU00:FS00:Starting
[93m22:06:47:WARNING:WU00:FS00:AS lowered CPUs from 8 to 4[0m
22:06:47:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 89868 -checkpoint 15 -np 4
22:06:47:WU00:FS00:Started FahCore on PID 91438
22:06:47:WU00:FS00:Core PID:91439
22:06:47:WU00:FS00:FahCore 0xa7 started
22:06:48:WU00:FS00:0xa7:*********************** Log Started 2021-04-26T22:06:48Z ***********************
22:06:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:06:48:WU00:FS00:0xa7:       Type: 0xa7
22:06:48:WU00:FS00:0xa7:       Core: Gromacs
22:06:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 91438 -checkpoint 15 -np
22:06:48:WU00:FS00:0xa7:             4
22:06:48:WU00:FS00:0xa7:************************************ CBang *************************************
22:06:48:WU00:FS00:0xa7:       Date: Nov 27 2019
22:06:48:WU00:FS00:0xa7:       Time: 03:26:57
22:06:48:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:06:48:WU00:FS00:0xa7:     Branch: master
22:06:48:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
22:06:48:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
22:06:48:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
22:06:48:WU00:FS00:0xa7:   Platform: darwin 19.0.0
22:06:48:WU00:FS00:0xa7:       Bits: 64
22:06:48:WU00:FS00:0xa7:       Mode: Release
22:06:48:WU00:FS00:0xa7:************************************ System ************************************
22:06:48:WU00:FS00:0xa7:        CPU: VirtualApple @ 2.50GHz
22:06:48:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
22:06:48:WU00:FS00:0xa7:       CPUs: 8
22:06:48:WU00:FS00:0xa7:     Memory: 16.00GiB
22:06:48:WU00:FS00:0xa7:Free Memory: 1.74GiB
22:06:48:WU00:FS00:0xa7:    Threads: POSIX_THREADS
22:06:48:WU00:FS00:0xa7: OS Version: 10.16
22:06:48:WU00:FS00:0xa7:Has Battery: true
22:06:48:WU00:FS00:0xa7: On Battery: false
22:06:48:WU00:FS00:0xa7: UTC Offset: -4
22:06:48:WU00:FS00:0xa7:        PID: 91439
22:06:48:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
22:06:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:06:48:WU00:FS00:0xa7:    Version: 0.0.19
22:06:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:06:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:06:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:06:48:WU00:FS00:0xa7:       Date: Nov 25 2019
22:06:48:WU00:FS00:0xa7:       Time: 16:45:06
22:06:48:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:06:48:WU00:FS00:0xa7:************************************ Build *************************************
22:06:48:WU00:FS00:0xa7:       SIMD: sse2
22:06:48:WU00:FS00:0xa7:********************************************************************************
22:06:48:WU00:FS00:0xa7:Project: 17231 (Run 5061, Clone 0, Gen 54)
22:06:48:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
22:06:48:WU00:FS00:0xa7:Digital signatures verified
22:06:48:WU00:FS00:0xa7:Calling: mdrun -s frame54.tpr -o frame54.trr -x frame54.xtc -cpi state.cpt -cpt 15 -nt 4
22:06:49:WU00:FS00:0xa7:Steps: first=3375000 total=62500
22:06:52:WU00:FS00:0xa7:Completed 5202 out of 62500 steps (8%)
22:08:45:WU00:FS00:0xa7:Completed 5625 out of 62500 steps (9%)
22:11:36:WU00:FS00:0xa7:Completed 6250 out of 62500 steps (10%)
22:14:38:WU00:FS00:0xa7:Completed 6875 out of 62500 steps (11%)
22:17:59:WU00:FS00:0xa7:Completed 7500 out of 62500 steps (12%)
22:22:32:WU00:FS00:0xa7:Completed 8125 out of 62500 steps (13%)
22:26:26:WU00:FS00:0xa7:Completed 8750 out of 62500 steps (14%)
22:30:19:WU00:FS00:0xa7:Completed 9375 out of 62500 steps (15%)
22:34:19:WU00:FS00:0xa7:Completed 10000 out of 62500 steps (16%)
22:38:26:WU00:FS00:0xa7:Completed 10625 out of 62500 steps (17%)
22:42:23:WU00:FS00:0xa7:Completed 11250 out of 62500 steps (18%)
22:46:24:WU00:FS00:0xa7:Completed 11875 out of 62500 steps (19%)
22:50:20:WU00:FS00:0xa7:Completed 12500 out of 62500 steps (20%)
22:54:24:WU00:FS00:0xa7:Completed 13125 out of 62500 steps (21%)
22:58:17:WU00:FS00:0xa7:Completed 13750 out of 62500 steps (22%)
23:02:11:WU00:FS00:0xa7:Completed 14375 out of 62500 steps (23%)
23:06:26:WU00:FS00:0xa7:Completed 15000 out of 62500 steps (24%)
23:06:31:Caught signal SIGPIPE(13) on PID 89868
23:11:03:WU00:FS00:0xa7:Completed 15625 out of 62500 steps (25%)
23:15:28:WU00:FS00:0xa7:Completed 16250 out of 62500 steps (26%)
23:19:55:WU00:FS00:0xa7:Completed 16875 out of 62500 steps (27%)
23:24:21:WU00:FS00:0xa7:Completed 17500 out of 62500 steps (28%)
23:25:48:99:127.0.0.1:New Web session
23:29:04:WU00:FS00:0xa7:Completed 18125 out of 62500 steps (29%)
23:34:00:WU00:FS00:0xa7:Completed 18750 out of 62500 steps (30%)
23:39:03:WU00:FS00:0xa7:Completed 19375 out of 62500 steps (31%)
23:43:37:WU00:FS00:0xa7:Completed 20000 out of 62500 steps (32%)
23:48:34:WU00:FS00:0xa7:Completed 20625 out of 62500 steps (33%)
23:53:38:WU00:FS00:0xa7:Completed 21250 out of 62500 steps (34%)
23:58:35:WU00:FS00:0xa7:Completed 21875 out of 62500 steps (35%)
00:03:12:WU00:FS00:0xa7:Completed 22500 out of 62500 steps (36%)
00:08:07:WU00:FS00:0xa7:Completed 23125 out of 62500 steps (37%)
00:12:30:WU00:FS00:0xa7:Completed 23750 out of 62500 steps (38%)
00:17:26:WU00:FS00:0xa7:Completed 24375 out of 62500 steps (39%)
00:22:27:WU00:FS00:0xa7:Completed 25000 out of 62500 steps (40%)
00:27:07:WU00:FS00:0xa7:Completed 25625 out of 62500 steps (41%)
00:32:01:WU00:FS00:0xa7:Completed 26250 out of 62500 steps (42%)
00:36:56:WU00:FS00:0xa7:Completed 26875 out of 62500 steps (43%)
00:41:56:WU00:FS00:0xa7:Completed 27500 out of 62500 steps (44%)
00:46:47:WU00:FS00:0xa7:Completed 28125 out of 62500 steps (45%)
00:51:43:WU00:FS00:0xa7:Completed 28750 out of 62500 steps (46%)
00:56:43:WU00:FS00:0xa7:Completed 29375 out of 62500 steps (47%)
01:01:32:WU00:FS00:0xa7:Completed 30000 out of 62500 steps (48%)
01:06:27:WU00:FS00:0xa7:Completed 30625 out of 62500 steps (49%)
01:11:31:WU00:FS00:0xa7:Completed 31250 out of 62500 steps (50%)
01:16:27:WU00:FS00:0xa7:Completed 31875 out of 62500 steps (51%)
01:21:22:WU00:FS00:0xa7:Completed 32500 out of 62500 steps (52%)
01:22:48:128:127.0.0.1:New Web session
01:26:06:WU00:FS00:0xa7:Completed 33125 out of 62500 steps (53%)
01:31:04:WU00:FS00:0xa7:Completed 33750 out of 62500 steps (54%)
01:35:52:WU00:FS00:0xa7:Completed 34375 out of 62500 steps (55%)
01:40:55:WU00:FS00:0xa7:Completed 35000 out of 62500 steps (56%)
01:45:44:WU00:FS00:0xa7:Completed 35625 out of 62500 steps (57%)
01:50:20:WU00:FS00:0xa7:Completed 36250 out of 62500 steps (58%)
01:55:05:WU00:FS00:0xa7:Completed 36875 out of 62500 steps (59%)
01:59:51:WU00:FS00:0xa7:Completed 37500 out of 62500 steps (60%)
02:04:44:WU00:FS00:0xa7:Completed 38125 out of 62500 steps (61%)
02:09:43:WU00:FS00:0xa7:Completed 38750 out of 62500 steps (62%)
02:14:39:WU00:FS00:0xa7:Completed 39375 out of 62500 steps (63%)
02:19:24:WU00:FS00:0xa7:Completed 40000 out of 62500 steps (64%)
02:24:21:WU00:FS00:0xa7:Completed 40625 out of 62500 steps (65%)
******************************* Date: 2021-04-27 *******************************
02:29:09:WU00:FS00:0xa7:Completed 41250 out of 62500 steps (66%)
02:34:00:WU00:FS00:0xa7:Completed 41875 out of 62500 steps (67%)
02:38:55:WU00:FS00:0xa7:Completed 42500 out of 62500 steps (68%)
02:43:52:WU00:FS00:0xa7:Completed 43125 out of 62500 steps (69%)
02:43:53:147:127.0.0.1:New Web session
02:48:10:WU00:FS00:0xa7:Completed 43750 out of 62500 steps (70%)
02:53:03:WU00:FS00:0xa7:Completed 44375 out of 62500 steps (71%)
02:57:41:WU00:FS00:0xa7:Completed 45000 out of 62500 steps (72%)
03:02:33:WU00:FS00:0xa7:Completed 45625 out of 62500 steps (73%)
03:06:42:WU00:FS00:0xa7:Completed 46250 out of 62500 steps (74%)
03:10:58:WU00:FS00:0xa7:Completed 46875 out of 62500 steps (75%)
03:14:55:WU00:FS00:0xa7:Completed 47500 out of 62500 steps (76%)
03:18:52:WU00:FS00:0xa7:Completed 48125 out of 62500 steps (77%)
03:23:56:WU00:FS00:0xa7:Completed 48750 out of 62500 steps (78%)
03:28:42:WU00:FS00:0xa7:Completed 49375 out of 62500 steps (79%)
03:33:39:WU00:FS00:0xa7:Completed 50000 out of 62500 steps (80%)
03:38:45:WU00:FS00:0xa7:Completed 50625 out of 62500 steps (81%)
03:43:41:WU00:FS00:0xa7:Completed 51250 out of 62500 steps (82%)
03:48:38:WU00:FS00:0xa7:Completed 51875 out of 62500 steps (83%)
03:53:15:WU00:FS00:0xa7:Completed 52500 out of 62500 steps (84%)
03:57:42:WU00:FS00:0xa7:Completed 53125 out of 62500 steps (85%)
04:02:05:WU00:FS00:0xa7:Completed 53750 out of 62500 steps (86%)
04:06:43:WU00:FS00:0xa7:Completed 54375 out of 62500 steps (87%)
04:11:05:WU00:FS00:0xa7:Completed 55000 out of 62500 steps (88%)
04:15:38:WU00:FS00:0xa7:Completed 55625 out of 62500 steps (89%)
04:19:36:WU00:FS00:0xa7:Completed 56250 out of 62500 steps (90%)
04:24:09:WU00:FS00:0xa7:Completed 56875 out of 62500 steps (91%)
04:28:25:WU00:FS00:0xa7:Completed 57500 out of 62500 steps (92%)
04:32:44:WU00:FS00:0xa7:Completed 58125 out of 62500 steps (93%)
04:37:17:WU00:FS00:0xa7:Completed 58750 out of 62500 steps (94%)
04:41:29:WU00:FS00:0xa7:Completed 59375 out of 62500 steps (95%)
04:45:35:WU00:FS00:0xa7:Completed 60000 out of 62500 steps (96%)
04:49:34:WU00:FS00:0xa7:Completed 60625 out of 62500 steps (97%)
04:53:44:WU00:FS00:0xa7:Completed 61250 out of 62500 steps (98%)
04:57:41:WU00:FS00:0xa7:Completed 61875 out of 62500 steps (99%)
04:57:42:WU01:FS00:Connecting to assign1.foldingathome.org:80
04:57:59:WU01:FS00:Assigned to work server 129.32.209.205
04:57:59:WU01:FS00:Requesting new work unit for slot 00: cpu:8 from 129.32.209.205
04:57:59:WU01:FS00:Connecting to 129.32.209.205:8080
04:58:01:WU01:FS00:Downloading 1.47MiB
04:58:02:WU01:FS00:Download complete
04:58:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16959 run:31 clone:643 gen:16 core:0xa8 unit:0x00000283000000100000423f0000001f
04:58:19:WU01:FS00:Downloading core from http://cores.foldingathome.org/osx/64bit-sse2/a8-0.0.12/Core_a8.fah
04:58:19:WU01:FS00:Connecting to cores.foldingathome.org:80
04:58:40:WU01:FS00:FahCore a8: Downloading 6.47MiB
04:58:42:WU01:FS00:FahCore a8: Download complete
04:58:48:WU01:FS00:Valid core signature
04:58:49:WU01:FS00:Unpacked 17.03MiB to cores/cores.foldingathome.org/osx/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8
05:01:48:WU00:FS00:0xa7:Completed 62500 out of 62500 steps (100%)
05:02:08:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
05:02:08:WU00:FS00:0xa7:Saving result file frame54.trr
05:02:08:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:02:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17231 run:5061 clone:0 gen:54 core:0xa7 unit:0x00000000000000360000434f000013c5
05:02:08:WU00:FS00:Uploading 18.73MiB to 206.223.170.146
05:02:08:WU01:FS00:Starting
05:02:08:WU00:FS00:Connecting to 206.223.170.146:8080
05:02:08:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 89868 -checkpoint 15 -np 8
05:02:08:WU01:FS00:Started FahCore on PID 96774
05:02:09:WU01:FS00:Core PID:96775
05:02:09:WU01:FS00:FahCore 0xa8 started
05:02:10:WU01:FS00:0xa8:*********************** Log Started 2021-04-27T05:02:10Z ***********************
05:02:10:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
05:02:10:WU01:FS00:0xa8:       Core: Gromacs
05:02:10:WU01:FS00:0xa8:       Type: 0xa8
05:02:10:WU01:FS00:0xa8:    Version: 0.0.12
05:02:10:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:02:10:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
05:02:10:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
05:02:10:WU01:FS00:0xa8:       Date: Jan 16 2021
05:02:10:WU01:FS00:0xa8:       Time: 21:22:16
05:02:10:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
05:02:10:WU01:FS00:0xa8:     Branch: master
05:02:10:WU01:FS00:0xa8:   Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
05:02:10:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
05:02:10:WU01:FS00:0xa8:             -funroll-loops -fno-pie -mmacosx-version-min=10.7
05:02:10:WU01:FS00:0xa8:   Platform: darwin 20.2.0
05:02:10:WU01:FS00:0xa8:       Bits: 64
05:02:10:WU01:FS00:0xa8:       Mode: Release
05:02:10:WU01:FS00:0xa8:       SIMD: sse2
05:02:10:WU01:FS00:0xa8:     OpenMP: ON
05:02:10:WU01:FS00:0xa8:       CUDA: OFF
05:02:10:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 96774 -checkpoint 15 -np
05:02:10:WU01:FS00:0xa8:             8
05:02:10:WU01:FS00:0xa8:************************************ libFAH ************************************
05:02:10:WU01:FS00:0xa8:       Time: 21:21:45
05:02:10:WU01:FS00:0xa8:************************************ CBang *************************************
05:02:10:WU01:FS00:0xa8:       Time: 21:21:02
05:02:10:WU01:FS00:0xa8:             -funroll-loops -fno-pie -mmacosx-version-min=10.7 -fPIC
05:02:10:WU01:FS00:0xa8:************************************ System ************************************
05:02:10:WU01:FS00:0xa8:        CPU: VirtualApple @ 2.50GHz
05:02:10:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
05:02:10:WU01:FS00:0xa8:       CPUs: 8
05:02:10:WU01:FS00:0xa8:     Memory: 16.00GiB
05:02:10:WU01:FS00:0xa8:Free Memory: 724.33MiB
05:02:10:WU01:FS00:0xa8:    Threads: POSIX_THREADS
05:02:10:WU01:FS00:0xa8: OS Version: 11.2
05:02:10:WU01:FS00:0xa8:Has Battery: true
05:02:10:WU01:FS00:0xa8: On Battery: false
05:02:10:WU01:FS00:0xa8: UTC Offset: -4
05:02:10:WU01:FS00:0xa8:        PID: 96775
05:02:10:WU01:FS00:0xa8:        CWD: /Library/Application Support/FAHClient/work
05:02:10:WU01:FS00:0xa8:********************************************************************************
05:02:10:WU01:FS00:0xa8:Project: 16959 (Run 31, Clone 643, Gen 16)
05:02:10:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
05:02:10:WU01:FS00:0xa8:Reading tar file core.xml
05:02:10:WU01:FS00:0xa8:Reading tar file frame16.tpr
05:02:10:WU01:FS00:0xa8:Digital signatures verified
05:02:10:WU01:FS00:0xa8:Calling: mdrun -c frame16.gro -s frame16.tpr -x frame16.xtc -cpt 15 -nt 8 -ntmpi 1
05:02:10:WU01:FS00:0xa8:Steps: first=40000000 total=42500000
05:02:10:WU01:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
05:02:14:WU00:FS00:Upload 42.39%
05:02:20:WU00:FS00:Upload 68.42%
05:02:26:WU00:FS00:Upload 94.45%
05:02:32:WU00:FS00:Upload complete
05:02:38:WU00:FS00:Server responded WORK_ACK (400)
05:02:38:WU00:FS00:Final credit estimate, 12675.00 points
05:02:38:WU00:FS00:Cleaning up
Abridged log file:
17:37:04:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16959 run:31 clone:643 gen:16 core:0xa8 unit:0x00000283000000100000423f0000001f
17:37:04:WU01:FS00:Uploading 5.13MiB to 129.32.209.205
17:37:10:WU01:FS00:Server responded WORK_ACK (400)
17:37:10:WU01:FS00:Final credit estimate, 22313.00 points
20:39:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17428 run:0 clone:3620 gen:442 core:0xa7 unit:0x00000e24000001ba0000441400000000
20:39:21:WU00:FS00:Uploading 10.17MiB to 128.252.203.9
20:39:43:WU00:FS00:Server responded WORK_ACK (400)
20:39:43:WU00:FS00:Final credit estimate, 4596.00 points
02:02:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:17231 run:879 clone:0 gen:68 core:0xa7 unit:0x00000000000000440000434f0000036f
02:02:13:WU01:FS00:Uploading 18.68MiB to 206.223.170.146
02:03:35:WU01:FS00:Server responded WORK_ACK (400)
02:03:35:WU01:FS00:Final credit estimate, 16110.00 points
18:40:54:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17231 run:8686 clone:4 gen:23 core:0xa7 unit:0x00000004000000170000434f000021ee
18:40:54:WU00:FS00:Uploading 18.72MiB to 206.223.170.146
18:41:16:WU00:FS00:Server responded WORK_ACK (400)
18:41:16:WU00:FS00:Final credit estimate, 9089.00 points
02:27:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16955 run:0 clone:1238 gen:2 core:0xa8 unit:0x000004d6000000020000423b00000000
02:27:13:WU01:FS00:Uploading 14.34MiB to 129.32.209.206
02:32:33:WU01:FS00:Server responded WORK_ACK (400)
02:32:33:WU01:FS00:Final credit estimate, 13676.00 points
Re: Missing or Low points?
The client software does not know how many Work Units you have done, so assumes you are getting the Quick Return Bonus.
You only get the QRB if you complete 10 WUs with an 80% success rate.
It sound like you need to finish 4 more WUs.
Foldingisfun
Ah, okay didn't know that about the client software. Thank you for clarifying!
Separately for my issue with 129.32.209.205, generally speaking what's an appropriate amount of time to wait if a WU hasn't been recorded yet before posting in the Issues with a specific server forum? 48 hours?
There is a problem associated with one or two of the Work Servers that is taking longer to fix than the "appropriate amount of time to wait"
FAH normally credits the WUs rather quickly but not always. They are, in fact, very good about eventually finding all the uncredited WUs and posting everybody's delayed points in a large batch.
