After a reinstallation of FAHClient the two slots have their statistics reversed on api
20E3ED5FACF430F4 and 21E3ED5FACF430F4 (CPU & GPU)
At each unit calculated by the GPU I have these results (only the date changes):
20E3ED5FACF430F4 xxx.xxx.xxx.163 Linux 866 2021-04-26 22:41:56 17428 NVidia GPU
This is the last calculation performed by the CPU before reinstallation:
# id, maj, cpuid, ip, slot, os, credit, last, project, pc
723, 2021-03-02 10:37:40, 20E3ED5FACF430F4, xxx.xxx.xxx.139, x86, Linux, 866, 2021-03-02 09:25:39, 17428, Ubuntu
While the total is right on stats
An idea to put everything back in order
Thks
The statistics are inverted
PhilTheNet
Re: The statistics are inverted
Problem solved by uninstalling FAHClient completely and reinstalling it
However, an upgrade is not enough
Here is
Here is
Another solution might possibly be deleting the GPU slot, adding a new CPU slot, deleting the original CPU slot and then re-adding the GPU slot. Or editing config.xml to change the slot order, after finishing all the running slots and stopping the client completely.
