How do you add a GPU slot?
While the title isn't 100% accurate I don't know how else to word it. Basically I added the GPU, added the pci-bus, but don't know how to find pci-slot or do whatever makes the client recognize my GPU.
Re: How do you add a GPU slot?
FAH will automatically detect available slots at start-up or when you add a slot in FAHControl (Configure -> Slots -> Add -> radio button GPU -> OK -> Save).
If that fails, please post your log: viewtopic.php?p=327412&f=24#p327412 so that we can better understand your specific setup.
operating system = Linux or Windows?
In the past, the install program has been better at detecting new hardware than the Client. If it does not look like everything is just right, Uninstall F@H including data and re install, just re enter your name, Team #, and Passkey.
You only need to do so if the client appears confused.
