No Points Since 3 Days
Krokette80
Post by Krokette80 »
Hallo,
can someone explain me, why i get no more points on my Linux Maschine since 2 or 3 Days?
With my Windows Maschine it works fine.
FAHClient is running as Service on Ubuntu.
Whats wrong here?
Here is the start of the service. On the beginning it runs great
*********************** Log Started 2021-04-07T17:37:13Z ***********************
17:37:13:************************* Folding@home Client *************************
17:37:13:    Website: http://folding.stanford.edu/
17:37:13:  Copyright: (c) 2009-2014 Stanford University
17:37:13:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:37:13:       Args: --child --lifeline 3600 /etc/fahclient/config.xml --run-as
17:37:13:             fahclient --pid-file=/var/run/fahclient.pid --daemon
17:37:13:     Config: /etc/fahclient/config.xml
17:37:13:******************************** Build ********************************
17:37:13:    Version: 7.4.4
17:37:13:       Date: Mar 4 2014
17:37:13:       Time: 12:02:38
17:37:13:    SVN Rev: 4130
17:37:13:     Branch: fah/trunk/client
17:37:13:   Compiler: GNU 4.4.7
17:37:13:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
17:37:13:             -fno-unsafe-math-optimizations -msse2
17:37:13:   Platform: linux2 3.2.0-1-amd64
17:37:13:       Bits: 64
17:37:13:       Mode: Release
17:37:13:******************************* System ********************************
17:37:13:        CPU: Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz
17:37:13:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
17:37:13:       CPUs: 4
17:37:13:     Memory: 188.87GiB
17:37:13:Free Memory: 5.87GiB
17:37:13:    Threads: POSIX_THREADS
17:37:13: OS Version: 5.4
17:37:13:Has Battery: false
17:37:13: On Battery: false
17:37:13: UTC Offset: 0
17:37:13:        PID: 3602
17:37:13:        CWD: /var/lib/fahclient
17:37:13:         OS: Linux 5.4.65-1-pve x86_64
17:37:13:    OS Arch: AMD64
17:37:13:       GPUs: 0
17:37:13:       CUDA: Not detected
17:37:13:***********************************************************************
17:37:13:<config>
17:37:13:  <!-- Folding Slot Configuration -->
17:37:13:  <gpu v='false'/>
17:37:13:
17:37:13:  <!-- Slot Control -->
17:37:13:  <power v='full'/>
17:37:13:
17:37:13:  <!-- User Information -->
17:37:13:  <passkey v='********************************'/>
17:37:13:  <team v=''/>
17:37:13:  <user v='Krokette81'/>
17:37:13:
17:37:13:  <!-- Folding Slots -->
17:37:13:  <slot id='0' type='CPU'/>
17:37:13:</config>
17:37:13:Switching to user fahclient
17:37:13:Trying to access database...
17:37:13:Successfully acquired database lock
17:37:13:Enabled folding slot 00: READY cpu:4
17:37:13:WU01:FS00:Starting
17:37:13:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/c        ores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8        -dir 01 -suffix 01 -version 704 -lifeline 3602 -checkpoint 15 -np 4
17:37:13:WU01:FS00:Started FahCore on PID 3611
17:37:13:WU01:FS00:Core PID:3615
17:37:13:WU01:FS00:FahCore 0xa8 started
17:37:13:WU01:FS00:0xa8:*********************** Log Started 2021-04-07T17:37:13Z        ***********************
17:37:13:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***        ************************
17:37:13:WU01:FS00:0xa8:       Core: Gromacs
17:37:13:WU01:FS00:0xa8:       Type: 0xa8
17:37:13:WU01:FS00:0xa8:    Version: 0.0.12
17:37:13:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment        .com>
17:37:13:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
17:37:13:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
17:37:13:WU01:FS00:0xa8:       Date: Jan 16 2021
17:37:13:WU01:FS00:0xa8:       Time: 19:23:19
17:37:13:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
17:37:13:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffu        nction-sections
17:37:13:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
17:37:13:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
17:37:13:WU01:FS00:0xa8:       Bits: 64
17:37:13:WU01:FS00:0xa8:       Mode: Release
17:37:13:WU01:FS00:0xa8:       SIMD: avx_256
17:37:13:WU01:FS00:0xa8:     OpenMP: ON
17:37:13:WU01:FS00:0xa8:       CUDA: OFF
17:37:13:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 704 -lifeline 3        611 -checkpoint 15 -np 4
17:37:13:WU01:FS00:0xa8:************************************ libFAH ************        ************************
17:37:13:WU01:FS00:0xa8:       Time: 19:21:38
17:37:13:WU01:FS00:0xa8:************************************ CBang *************        ************************
17:37:13:WU01:FS00:0xa8:       Time: 19:21:24
17:37:13:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie        -fPIC
17:37:13:WU01:FS00:0xa8:************************************ System ************        ************************
17:37:13:WU01:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz
17:37:13:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
17:37:13:WU01:FS00:0xa8:       CPUs: 4
17:37:13:WU01:FS00:0xa8:     Memory: 188.87GiB
17:37:13:WU01:FS00:0xa8:Free Memory: 5.86GiB
17:37:13:WU01:FS00:0xa8:    Threads: POSIX_THREADS
17:37:13:WU01:FS00:0xa8: OS Version: 5.4
17:37:13:WU01:FS00:0xa8:Has Battery: false
17:37:13:WU01:FS00:0xa8: On Battery: false
17:37:13:WU01:FS00:0xa8: UTC Offset: 0
17:37:13:WU01:FS00:0xa8:        PID: 3615
17:37:13:WU01:FS00:0xa8:        CWD: /var/lib/fahclient/work
17:37:13:WU01:FS00:0xa8:********************************************************        ************************
17:37:13:WU01:FS00:0xa8:Project: 16815 (Run 8, Clone 4, Gen 60)
17:37:13:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
17:37:13:WU01:FS00:0xa8:Digital signatures verified
17:37:13:WU01:FS00:0xa8:Calling: mdrun -c frame60.gro -s frame60.tpr -x frame60.        xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
17:37:13:WU01:FS00:0xa8:Steps: first=0 total=500000
17:37:17:WU01:FS00:0xa8:Completed 286962 out of 500000 steps (57%)
17:50:59:WU01:FS00:0xa8:Completed 290000 out of 500000 steps (58%)
18:13:48:WU01:FS00:0xa8:Completed 295000 out of 500000 steps (59%)
18:37:01:WU01:FS00:0xa8:Completed 300000 out of 500000 steps (60%)
19:01:17:WU01:FS00:0xa8:Completed 305000 out of 500000 steps (61%)
19:23:34:WU01:FS00:0xa8:Completed 310000 out of 500000 steps (62%)
19:51:22:WU01:FS00:0xa8:Completed 315000 out of 500000 steps (63%)
20:11:34:WU01:FS00:0xa8:Completed 320000 out of 500000 steps (64%)
20:33:14:WU01:FS00:0xa8:Completed 325000 out of 500000 steps (65%)
20:55:46:WU01:FS00:0xa8:Completed 330000 out of 500000 steps (66%)
21:17:40:WU01:FS00:0xa8:Completed 335000 out of 500000 steps (67%)
21:37:39:WU01:FS00:0xa8:Completed 340000 out of 500000 steps (68%)
21:53:55:WU01:FS00:0xa8:Completed 345000 out of 500000 steps (69%)
22:16:14:WU01:FS00:0xa8:Completed 350000 out of 500000 steps (70%)
22:39:19:WU01:FS00:0xa8:Completed 355000 out of 500000 steps (71%)
23:00:46:WU01:FS00:0xa8:Completed 360000 out of 500000 steps (72%)
23:22:22:WU01:FS00:0xa8:Completed 365000 out of 500000 steps (73%)
******************************* Date: 2021-04-07 *******************************
Here are Last 2 Days
I see no errors or something.
Whats the problem?
05:50:07:WU00:FS00:0xa8:*********************** Log Started 2021-04-10T05:50:06Z        ***********************
05:50:07:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***        ************************
05:50:07:WU00:FS00:0xa8:       Core: Gromacs
05:50:07:WU00:FS00:0xa8:       Type: 0xa8
05:50:07:WU00:FS00:0xa8:    Version: 0.0.12
05:50:07:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment        .com>
05:50:07:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
05:50:07:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
05:50:07:WU00:FS00:0xa8:       Date: Jan 16 2021
05:50:07:WU00:FS00:0xa8:       Time: 19:23:19
05:50:07:WU00:FS00:0xa8:   Compiler: GNU 8.3.0
05:50:07:WU00:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffu        nction-sections
05:50:07:WU00:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
05:50:07:WU00:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
05:50:07:WU00:FS00:0xa8:       Bits: 64
05:50:07:WU00:FS00:0xa8:       Mode: Release
05:50:07:WU00:FS00:0xa8:       SIMD: avx_256
05:50:07:WU00:FS00:0xa8:     OpenMP: ON
05:50:07:WU00:FS00:0xa8:       CUDA: OFF
05:50:07:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 704 -lifeline 1        3497 -checkpoint 15 -np
05:50:07:WU00:FS00:0xa8:             4
05:50:07:WU00:FS00:0xa8:************************************ libFAH ************        ************************
05:50:07:WU00:FS00:0xa8:       Time: 19:21:38
05:50:07:WU00:FS00:0xa8:************************************ CBang *************        ************************
05:50:07:WU00:FS00:0xa8:       Time: 19:21:24
05:50:07:WU00:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie        -fPIC
05:50:07:WU00:FS00:0xa8:************************************ System ************        ************************
05:50:07:WU00:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz
05:50:07:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
05:50:07:WU00:FS00:0xa8:       CPUs: 4
05:50:07:WU00:FS00:0xa8:     Memory: 188.87GiB
05:50:07:WU00:FS00:0xa8:Free Memory: 2.62GiB
05:50:07:WU00:FS00:0xa8:    Threads: POSIX_THREADS
05:50:07:WU00:FS00:0xa8: OS Version: 5.4
05:50:07:WU00:FS00:0xa8:Has Battery: false
05:50:07:WU00:FS00:0xa8: On Battery: false
05:50:07:WU00:FS00:0xa8: UTC Offset: 0
05:50:07:WU00:FS00:0xa8:        PID: 13501
05:50:07:WU00:FS00:0xa8:        CWD: /var/lib/fahclient/work
05:50:07:WU00:FS00:0xa8:********************************************************        ************************
05:50:07:WU00:FS00:0xa8:Project: 16935 (Run 1, Clone 249, Gen 63)
05:50:07:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
05:50:07:WU00:FS00:0xa8:Reading tar file core.xml
05:50:07:WU00:FS00:0xa8:Reading tar file frame63.tpr
05:50:07:WU00:FS00:0xa8:Digital signatures verified
05:50:07:WU00:FS00:0xa8:Calling: mdrun -c frame63.gro -s frame63.tpr -x frame63.        xtc -cpt 15 -nt 4 -ntmpi 1
05:50:07:WU00:FS00:0xa8:Steps: first=0 total=5000000
05:50:07:WU00:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
05:50:12:WU01:FS00:Upload 30.09%
05:50:18:WU01:FS00:Upload 60.80%
05:50:24:WU01:FS00:Upload 91.51%
05:50:26:WU01:FS00:Upload complete
05:50:26:WU01:FS00:Server responded WORK_ACK (400)
05:50:26:WU01:FS00:Final credit estimate, 2841.00 points
05:50:26:WU01:FS00:Cleaning up
06:34:49:WU00:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
******************************* Date: 2021-04-10 *******************************
07:50:15:WU00:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
08:59:12:WU00:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
09:56:55:WU00:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
11:11:18:WU00:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
12:33:53:WU00:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
13:19:26:WU00:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
14:25:21:WU00:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
14:38:53:WU00:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
14:51:25:WU00:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
15:04:21:WU00:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
15:17:05:WU00:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
15:31:53:WU00:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
15:47:02:WU00:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
16:02:56:WU00:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
16:16:24:WU00:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
16:30:59:WU00:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
16:43:22:WU00:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
16:56:18:WU00:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
17:09:09:WU00:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
17:23:56:WU00:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
17:37:02:WU00:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
17:50:04:WU00:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
18:02:03:WU00:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
18:17:41:WU00:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
18:32:57:WU00:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
18:50:59:WU00:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
19:03:54:WU00:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
19:14:43:WU00:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
19:25:32:WU00:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
19:36:10:WU00:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
19:47:20:WU00:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
19:58:57:WU00:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
20:08:42:WU00:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
20:19:23:WU00:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
20:31:36:WU00:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
20:45:25:WU00:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
20:56:42:WU00:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
21:10:59:WU00:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
21:24:26:WU00:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
21:38:12:WU00:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
21:53:34:WU00:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
22:05:53:WU00:FS00:0xa8:Completed 2150000 out of 5000000 steps (43%)
22:19:00:WU00:FS00:0xa8:Completed 2200000 out of 5000000 steps (44%)
22:32:47:WU00:FS00:0xa8:Completed 2250000 out of 5000000 steps (45%)
22:46:46:WU00:FS00:0xa8:Completed 2300000 out of 5000000 steps (46%)
23:00:51:WU00:FS00:0xa8:Completed 2350000 out of 5000000 steps (47%)
23:14:00:WU00:FS00:0xa8:Completed 2400000 out of 5000000 steps (48%)
23:26:31:WU00:FS00:0xa8:Completed 2450000 out of 5000000 steps (49%)
23:37:30:WU00:FS00:0xa8:Completed 2500000 out of 5000000 steps (50%)
23:48:11:WU00:FS00:0xa8:Completed 2550000 out of 5000000 steps (51%)
23:58:31:WU00:FS00:0xa8:Completed 2600000 out of 5000000 steps (52%)
00:10:44:WU00:FS00:0xa8:Completed 2650000 out of 5000000 steps (53%)
00:21:05:WU00:FS00:0xa8:Completed 2700000 out of 5000000 steps (54%)
00:30:44:WU00:FS00:0xa8:Completed 2750000 out of 5000000 steps (55%)
00:41:13:WU00:FS00:0xa8:Completed 2800000 out of 5000000 steps (56%)
00:50:14:WU00:FS00:0xa8:Completed 2850000 out of 5000000 steps (57%)
01:00:24:WU00:FS00:0xa8:Completed 2900000 out of 5000000 steps (58%)
01:13:16:WU00:FS00:0xa8:Completed 2950000 out of 5000000 steps (59%)
01:23:37:WU00:FS00:0xa8:Completed 3000000 out of 5000000 steps (60%)
01:34:51:WU00:FS00:0xa8:Completed 3050000 out of 5000000 steps (61%)
01:45:23:WU00:FS00:0xa8:Completed 3100000 out of 5000000 steps (62%)
01:57:03:WU00:FS00:0xa8:Completed 3150000 out of 5000000 steps (63%)
02:08:13:WU00:FS00:0xa8:Completed 3200000 out of 5000000 steps (64%)
02:18:50:WU00:FS00:0xa8:Completed 3250000 out of 5000000 steps (65%)
02:31:11:WU00:FS00:0xa8:Completed 3300000 out of 5000000 steps (66%)
******************************* Date: 2021-04-11 *******************************
02:41:43:WU00:FS00:0xa8:Completed 3350000 out of 5000000 steps (67%)
02:50:28:WU00:FS00:0xa8:Completed 3400000 out of 5000000 steps (68%)
02:59:24:WU00:FS00:0xa8:Completed 3450000 out of 5000000 steps (69%)
03:08:18:WU00:FS00:0xa8:Completed 3500000 out of 5000000 steps (70%)
03:17:28:WU00:FS00:0xa8:Completed 3550000 out of 5000000 steps (71%)
03:27:29:WU00:FS00:0xa8:Completed 3600000 out of 5000000 steps (72%)
03:40:09:WU00:FS00:0xa8:Completed 3650000 out of 5000000 steps (73%)
03:56:22:WU00:FS00:0xa8:Completed 3700000 out of 5000000 steps (74%)
04:26:27:WU00:FS00:0xa8:Completed 3750000 out of 5000000 steps (75%)
04:45:47:WU00:FS00:0xa8:Completed 3800000 out of 5000000 steps (76%)
05:00:32:WU00:FS00:0xa8:Completed 3850000 out of 5000000 steps (77%)
05:16:20:WU00:FS00:0xa8:Completed 3900000 out of 5000000 steps (78%)
05:29:59:WU00:FS00:0xa8:Completed 3950000 out of 5000000 steps (79%)
05:43:38:WU00:FS00:0xa8:Completed 4000000 out of 5000000 steps (80%)
05:56:14:WU00:FS00:0xa8:Completed 4050000 out of 5000000 steps (81%)
06:05:37:WU00:FS00:0xa8:Completed 4100000 out of 5000000 steps (82%)
06:17:38:WU00:FS00:0xa8:Completed 4150000 out of 5000000 steps (83%)
06:30:14:WU00:FS00:0xa8:Completed 4200000 out of 5000000 steps (84%)
06:39:30:WU00:FS00:0xa8:Completed 4250000 out of 5000000 steps (85%)
06:51:40:WU00:FS00:0xa8:Completed 4300000 out of 5000000 steps (86%)
07:06:15:WU00:FS00:0xa8:Completed 4350000 out of 5000000 steps (87%)
07:20:04:WU00:FS00:0xa8:Completed 4400000 out of 5000000 steps (88%)
07:32:48:WU00:FS00:0xa8:Completed 4450000 out of 5000000 steps (89%)
07:46:17:WU00:FS00:0xa8:Completed 4500000 out of 5000000 steps (90%)
07:55:41:WU00:FS00:0xa8:Completed 4550000 out of 5000000 steps (91%)
08:05:17:WU00:FS00:0xa8:Completed 4600000 out of 5000000 steps (92%)
08:16:23:WU00:FS00:0xa8:Completed 4650000 out of 5000000 steps (93%)
08:29:16:WU00:FS00:0xa8:Completed 4700000 out of 5000000 steps (94%)
08:43:01:WU00:FS00:0xa8:Completed 4750000 out of 5000000 steps (95%)
08:53:09:WU00:FS00:0xa8:Completed 4800000 out of 5000000 steps (96%)
09:02:40:WU00:FS00:0xa8:Completed 4850000 out of 5000000 steps (97%)
09:14:53:WU00:FS00:0xa8:Completed 4900000 out of 5000000 steps (98%)
09:25:11:WU00:FS00:0xa8:Completed 4950000 out of 5000000 steps (99%)
09:25:12:WU01:FS00:Connecting to 65.254.110.245:8080
09:25:12:WU01:FS00:Assigned to work server 129.32.209.204
09:25:13:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 129.        32.209.204
09:25:13:WU01:FS00:Connecting to 129.32.209.204:8080
09:25:13:WU01:FS00:Downloading 459.00KiB
09:25:13:WU01:FS00:Download complete
09:25:13:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16        935 run:23 clone:384 gen:53 core:0xa8 unit:0x00000180000000350000422700000017
09:37:20:WU00:FS00:0xa8:Completed 5000000 out of 5000000 steps (100%)
09:37:20:WU00:FS00:0xa8:Saving result file ../logfile_01.txt
09:37:20:WU00:FS00:0xa8:Saving result file frame63.gro
09:37:20:WU00:FS00:0xa8:Saving result file frame63.xtc
09:37:20:WU00:FS00:0xa8:Saving result file md.log
09:37:20:WU00:FS00:0xa8:Saving result file science.log
09:37:20:WU00:FS00:0xa8:Saving result file state.cpt
09:37:20:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
09:37:21:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:37:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project        :16935 run:1 clone:249 gen:63 core:0xa8 unit:0x000000f90000003f0000422700000001
09:37:21:WU00:FS00:Uploading 7.01MiB to 129.32.209.204
09:37:21:WU00:FS00:Connecting to 129.32.209.204:8080
09:37:21:WU01:FS00:Starting
09:37:21:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/c        ores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8        -dir 01 -suffix 01 -version 704 -lifeline 3602 -checkpoint 15 -np 4
09:37:21:WU01:FS00:Started FahCore on PID 17519
09:37:21:WU01:FS00:Core PID:17523
09:37:21:WU01:FS00:FahCore 0xa8 started
09:37:22:WU01:FS00:0xa8:*********************** Log Started 2021-04-11T09:37:21Z        ***********************
09:37:22:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***        ************************
09:37:22:WU01:FS00:0xa8:       Core: Gromacs
09:37:22:WU01:FS00:0xa8:       Type: 0xa8
09:37:22:WU01:FS00:0xa8:    Version: 0.0.12
09:37:22:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment        .com>
09:37:22:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
09:37:22:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
09:37:22:WU01:FS00:0xa8:       Date: Jan 16 2021
09:37:22:WU01:FS00:0xa8:       Time: 19:23:19
09:37:22:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
09:37:22:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffu        nction-sections
09:37:22:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
09:37:22:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
09:37:22:WU01:FS00:0xa8:       Bits: 64
09:37:22:WU01:FS00:0xa8:       Mode: Release
09:37:22:WU01:FS00:0xa8:       SIMD: avx_256
09:37:22:WU01:FS00:0xa8:     OpenMP: ON
09:37:22:WU01:FS00:0xa8:       CUDA: OFF
09:37:22:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 704 -lifeline 1        7519 -checkpoint 15 -np
09:37:22:WU01:FS00:0xa8:             4
09:37:22:WU01:FS00:0xa8:************************************ libFAH ************        ************************
09:37:22:WU01:FS00:0xa8:       Time: 19:21:38
09:37:22:WU01:FS00:0xa8:************************************ CBang *************        ************************
09:37:22:WU01:FS00:0xa8:       Time: 19:21:24
09:37:22:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie        -fPIC
09:37:22:WU01:FS00:0xa8:************************************ System ************        ************************
09:37:22:WU01:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz
09:37:22:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
09:37:22:WU01:FS00:0xa8:       CPUs: 4
09:37:22:WU01:FS00:0xa8:     Memory: 188.87GiB
09:37:22:WU01:FS00:0xa8:Free Memory: 3.14GiB
09:37:22:WU01:FS00:0xa8:    Threads: POSIX_THREADS
09:37:22:WU01:FS00:0xa8: OS Version: 5.4
09:37:22:WU01:FS00:0xa8:Has Battery: false
09:37:22:WU01:FS00:0xa8: On Battery: false
09:37:22:WU01:FS00:0xa8: UTC Offset: 0
09:37:22:WU01:FS00:0xa8:        PID: 17523
09:37:22:WU01:FS00:0xa8:        CWD: /var/lib/fahclient/work
09:37:22:WU01:FS00:0xa8:********************************************************        ************************
09:37:22:WU01:FS00:0xa8:Project: 16935 (Run 23, Clone 384, Gen 53)
09:37:22:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
09:37:22:WU01:FS00:0xa8:Reading tar file core.xml
09:37:22:WU01:FS00:0xa8:Reading tar file frame53.tpr
09:37:22:WU01:FS00:0xa8:Digital signatures verified
09:37:22:WU01:FS00:0xa8:Calling: mdrun -c frame53.gro -s frame53.tpr -x frame53.        xtc -cpt 15 -nt 4 -ntmpi 1
09:37:22:WU01:FS00:0xa8:Steps: first=0 total=5000000
09:37:22:WU01:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
09:37:27:WU00:FS00:Upload 64.21%
09:37:31:WU00:FS00:Upload complete
09:37:32:WU00:FS00:Server responded WORK_ACK (400)
09:37:32:WU00:FS00:Final credit estimate, 6467.00 points
09:37:32:WU00:FS00:Cleaning up
09:59:17:WU01:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
10:30:55:WU01:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
10:47:46:WU01:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
11:00:29:WU01:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
11:12:45:WU01:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
11:35:04:WU01:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
11:50:33:WU01:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
12:06:24:WU01:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
12:22:25:WU01:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
12:52:34:WU01:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
13:10:28:WU01:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
13:26:56:WU01:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
13:41:44:WU01:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
13:59:32:WU01:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
14:19:24:WU01:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
14:45:47:WU01:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
15:01:52:WU01:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
15:21:38:WU01:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
15:38:52:WU01:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
15:56:31:WU01:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
16:13:29:WU01:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
16:39:25:WU01:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
17:09:22:WU01:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
17:42:29:WU01:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
18:01:13:WU01:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
18:15:00:WU01:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
18:28:33:WU01:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
18:43:15:WU01:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
18:59:45:WU01:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
19:15:50:WU01:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
19:36:06:WU01:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
19:50:58:WU01:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
20:07:21:WU01:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
20:25:08:WU01:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
20:44:06:WU01:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
21:05:59:WU01:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
21:27:07:WU01:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
21:54:14:WU01:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
22:19:07:WU01:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
22:44:41:WU01:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
23:13:51:WU01:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
23:39:00:WU01:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
00:09:36:WU01:FS00:0xa8:Completed 2150000 out of 5000000 steps (43%)
00:37:10:WU01:FS00:0xa8:Completed 2200000 out of 5000000 steps (44%)
00:57:48:WU01:FS00:0xa8:Completed 2250000 out of 5000000 steps (45%)
01:21:41:WU01:FS00:0xa8:Completed 2300000 out of 5000000 steps (46%)
01:40:21:WU01:FS00:0xa8:Completed 2350000 out of 5000000 steps (47%)
02:02:28:WU01:FS00:0xa8:Completed 2400000 out of 5000000 steps (48%)
02:21:39:WU01:FS00:0xa8:Completed 2450000 out of 5000000 steps (49%)
02:41:06:WU01:FS00:0xa8:Completed 2500000 out of 5000000 steps (50%)
02:59:21:WU01:FS00:0xa8:Completed 2550000 out of 5000000 steps (51%)
******************************* Date: 2021-04-12 *******************************
03:17:12:WU01:FS00:0xa8:Completed 2600000 out of 5000000 steps (52%)
03:37:13:WU01:FS00:0xa8:Completed 2650000 out of 5000000 steps (53%)
03:56:21:WU01:FS00:0xa8:Completed 2700000 out of 5000000 steps (54%)
04:17:51:WU01:FS00:0xa8:Completed 2750000 out of 5000000 steps (55%)
04:37:37:WU01:FS00:0xa8:Completed 2800000 out of 5000000 steps (56%)
04:57:22:WU01:FS00:0xa8:Completed 2850000 out of 5000000 steps (57%)
05:16:58:WU01:FS00:0xa8:Completed 2900000 out of 5000000 steps (58%)
05:38:02:WU01:FS00:0xa8:Completed 2950000 out of 5000000 steps (59%)
05:58:49:WU01:FS00:0xa8:Completed 3000000 out of 5000000 steps (60%)
06:19:15:WU01:FS00:0xa8:Completed 3050000 out of 5000000 steps (61%)
06:37:57:WU01:FS00:0xa8:Completed 3100000 out of 5000000 steps (62%)
06:54:25:WU01:FS00:0xa8:Completed 3150000 out of 5000000 steps (63%)
07:13:10:WU01:FS00:0xa8:Completed 3200000 out of 5000000 steps (64%)
Edit:
The Folding@Home CPU Report tells me, the last upload from the Linux Machine was 2021-04-10 05:51:29
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: No Points Since 3 Days
Post by BobWilliams757 »
At times the servers that update the points and stats take some time to catch up. I'd try polling it again in a couple days. Those that have access to such information are at times busy, so hopefully someone will be along to confirm or deny the stats issue you are having. In all cases that I can remember the points catch up, but at times they have some delays.
Fold them if you get them!
Whompithian
Post by Whompithian »
Those are the important lines. As long as you see that in the logs, the servers have received your work and you will be credited. There may be a problem with point totals retrieved from F@h not displaying on your end, but your points are being counted and will show up when the problem is fixed.
iero
Post by iero »
Web control seems to be working this morning, with updated points. The Lars.system chrome extension still displays a plain "loading... - unknown team " message.
EOC stats seem to not be accurate as well, For me they are -3.000.000 points when compared to web control. [I've got 1,7M avg PPD]
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
gunnarre
Post by gunnarre »
The statistics web server URL has been rolled back to the old version, so that's why the web client is working again. But many external websites which scraped statistics are problably out of sync now. I don't know if EOC stats uses the "official" way to update statistics.
LAR folding data is probably lost for that period, because it relies on users running the dark mode web client for its data. Since the web client was broken, that data is forever lost for LAR.
EOC downloads the stats "flat files", text files that list points and WU totals for all donors and teams that are specifically created for third party stats. Those are updated every 3 hours the last I checked. The files can be downloaded by anyone.
The LAR web client was based on the open source code for Web Control from what I understand. Any fixes or changes to that would need to be picked up and distributed for it to keep working.
As I posted elsewhere to one of the many topics related to the problems caused by the new stats pages:
They are still available at https://statsbeta.foldingathome.org/ if you want to try them out. Feedback on design improvements or problem reports can be posted here - https://github.com/FoldingCommunity/fah ... front-end/.
ajm
Post by ajm »
iero wrote:Web control seems to be working this morning, with updated points. The Lars.system chrome extension still displays a plain "loading... - unknown team " message.
For the LAR_Systems' extension, you have to update it to V1.1.4
https://chrome.google.com/webstore/deta ... nicbgfahoe
iero
Post by iero »
Thanks for the tip!
GPU only
gunnarre wrote:LAR folding data is probably lost for that period, because it relies on users running the dark mode web client for its data. Since the web client was broken, that data is forever lost for LAR.
The LAR system does lack a certain degree of credibility because its inputs may lack scientific objectivity, but it's way ahead of its competitors -- considering it has the one benefit of actually working. The FAH development team has been collecting gobs of data at the server level along with performance numbers measured in ns/day. It would be nice if it were published.
Krokette80
Windows Client: Points up to date
Linux Client: Last Points from 13.04.2021. If i check the log, the last upload was today.
It has nothing to do with Windows vs. Linux. When a WU is completed, it is uploaded to a specific server... often the same Work Server that issued the project; sometimes to a Collection Server that's serving as a proxy for the Work Server. The WU is recorded and a record of the completion is constructed which must be transmitted from that server to the server that keeps track of the completions.
For some unknown reason, those completion records are not being transferred to the stats server on a regular basis.
Another Question:
Why i cant see sats on the finished is project?
https://apps.foldingathome.org/wu#proje ... =596&gen=2
here it works fine
https://apps.foldingathome.org/wu#proje ... e=4&gen=42
Same reason.
Your report would be much more useful if you reported the IP to which the WU was uploaded. Then we could send somebody out to kick that server and figure out why the transfer of those records is being delayed.
PaulTV
Post by PaulTV »
Hi,
There seem to be issues with the stats for project 16959 at the moment. None of the jobs I did for that project in the last two days or so were credited either. Your Linux machine isn't the problem here, I'm sure. My Linux server (Ubuntu) has been folding away happily for quite a while.
So this is usually the case: Work units get returned alright, and the science is being done. But the feed of the project server to the central stats server is broken, people eventually notice and start complaining, and the admins are being informed. Eventually the issue is solved, and the backlog is processed. The 'eventually' can be weeks, or sometimes even longer, but in virtually all cases it's solved and you will get the points. It has happened before, and will happen again, I'm afraid (I suppose there's no real monitoring on this part - F@h is about the science first, points come second). That's one of the reasons I'm now tracking all WUs my clients are processing and checking if returned WUs are being credited. Currently I have 16 uncredited WUs in my report, with the oldest from April 2nd.
There's a whole bunch of posts about 3rd party tools that may help if you want to do something similar, viewforum.php?f=14 (haven't checked them out myself, I put something together myself, which unfortunately is a bit hard to share).
Cheers,
Paul
Ryzen 5600X / RTX 3070 Ti / Ubuntu 22.04
Ryzen 5600 / RTX 3060 Ti / Windows 11
