*********************** Log Started 2021-03-29T19:10:22Z ***********************
2021-03-29:19:10:22:************************** libFAH **************************
2021-03-29:19:10:22: Date: Oct 20 2020
2021-03-29:19:10:22: Time: 20:36:41
2021-03-29:19:10:22: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
2021-03-29:19:10:22: Branch: master
2021-03-29:19:10:22: Compiler: GNU 4.9.4
2021-03-29:19:10:22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
2021-03-29:19:10:22: -O3 -funroll-loops
2021-03-29:19:10:22: Platform: linux2 5.8.0-1-amd64
2021-03-29:19:10:22: Bits: 64
2021-03-29:19:10:22: Mode: Release
2021-03-29:19:10:22:************************ FAHClient *************************
2021-03-29:19:10:22: Version: 7.6.21
2021-03-29:19:10:22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
2021-03-29:19:10:22: Copyright: 2020 foldingathome.org
2021-03-29:19:10:22: Homepage: https://foldingathome.org/
2021-03-29:19:10:22: Time: 20:38:59
2021-03-29:19:10:22: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
2021-03-29:19:10:22: Args: --config=/etc/fahclient/config.xml --chdir=/var/lib/fahclient/
2021-03-29:19:10:22: Config: /etc/fahclient/config.xml
2021-03-29:19:10:22:************************** CBang ***************************
2021-03-29:19:10:22: Time: 18:38:01
2021-03-29:19:10:22: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
2021-03-29:19:10:22: -O3 -funroll-loops -fPIC
2021-03-29:19:10:22:************************** System **************************
2021-03-29:19:10:22: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
2021-03-29:19:10:22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
2021-03-29:19:10:22: CPUs: 64
2021-03-29:19:10:22: Memory: 125.51GiB
2021-03-29:19:10:22: Free Memory: 124.62GiB
2021-03-29:19:10:22: Threads: POSIX_THREADS
2021-03-29:19:10:22: OS Version: 4.18
2021-03-29:19:10:22: Has Battery: false
2021-03-29:19:10:22: On Battery: false
2021-03-29:19:10:22: UTC Offset: -7
2021-03-29:19:10:22: PID: 1661
2021-03-29:19:10:22: CWD: /var/lib/fahclient
2021-03-29:19:10:22: OS: Linux 4.18.0-240.1.1.el8_3.x86_64 x86_64
2021-03-29:19:10:22: OS Arch: AMD64
2021-03-29:19:10:22: GPUs: 2
2021-03-29:19:10:22: GPU 0: Bus:10 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
2021-03-29:19:10:22: GPU 1: Bus:69 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
2021-03-29:19:10:22: CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
2021-03-29:19:10:22: libcuda.so: cannot open shared object file: No such file or
2021-03-29:19:10:22: directory
2021-03-29:19:10:22:OpenCL Device 0: Platform:0 Device:0 Bus:69 Slot:0 Compute:2.0 Driver:3004.6
2021-03-29:19:10:22:OpenCL Device 1: Platform:0 Device:1 Bus:10 Slot:0 Compute:2.0 Driver:3004.6
2021-03-29:19:10:22:************************************************************
2021-03-29:19:10:22:<config>
2021-03-29:19:10:22: <!-- Error Handling -->
2021-03-29:19:10:22: <max-slot-errors v='20'/>
2021-03-29:19:10:22: <!-- Folding Core -->
2021-03-29:19:10:22: <checkpoint v='5'/>
2021-03-29:19:10:22: <!-- Folding Slot Configuration -->
2021-03-29:19:10:22: <client-type v='advanced'/>
2021-03-29:19:10:22: <cpus v='54'/>
2021-03-29:19:10:22: <disable-viz v='true'/>
2021-03-29:19:10:22: <max-packet-size v='big'/>
2021-03-29:19:10:22: <!-- GUI -->
2021-03-29:19:10:22: <gui-enabled v='false'/>
2021-03-29:19:10:22: <!-- HTTP Server -->
2021-03-29:19:10:22: <max-connect-time v='604800'/>
2021-03-29:19:10:22: <!-- Logging -->
2021-03-29:19:10:22: <log-date v='true'/>
2021-03-29:19:10:22: <!-- Remote Command Server -->
2021-03-29:19:10:22: <command-address v='127.0.0.1'/>
2021-03-29:19:10:22: <!-- Slot Control -->
2021-03-29:19:10:22: <pause-on-battery v='false'/>
2021-03-29:19:10:22: <power v='FULL'/>
2021-03-29:19:10:22: <!-- User Information -->
2021-03-29:19:10:22: <passkey v='*****'/>
2021-03-29:19:10:22: <team v='40524'/>
2021-03-29:19:10:22: <user v='Whompithian'/>
2021-03-29:19:10:22: <!-- Web Server Sessions -->
2021-03-29:19:10:22: <session-lifetime v='0'/>
2021-03-29:19:10:22: <session-timeout v='0'/>
2021-03-29:19:10:22: <!-- Work Unit Control -->
2021-03-29:19:10:22: <stall-detection-enabled v='true'/>
2021-03-29:19:10:22: <!-- Folding Slots -->
2021-03-29:19:10:22: <slot id='0' type='CPU'/>
2021-03-29:19:10:22: <slot id='1' type='GPU'>
2021-03-29:19:10:22: <pci-bus v='10'/>
2021-03-29:19:10:22: <pci-slot v='0'/>
2021-03-29:19:10:22: </slot>
2021-03-29:19:10:22: <slot id='2' type='GPU'>
2021-03-29:19:10:22: <pci-bus v='69'/>
2021-03-29:19:10:22:</config>
2021-03-29:19:10:22:Trying to access database...
2021-03-29:19:10:22:Successfully acquired database lock
2021-03-29:19:10:22:FS00:Initialized folding slot 00: cpu:54
2021-03-29:19:10:22:FS01:Initialized folding slot 01: gpu:10:0 Vega 10 XL/XT [Radeon RX Vega 56/64]
2021-03-29:19:10:22:FS02:Initialized folding slot 02: gpu:69:0 Vega 10 XL/XT [Radeon RX Vega 56/64]
2021-03-29:19:10:23:WU00:FS01:0x22:*********************** Log Started 2021-03-29T19:10:22Z ***********************
2021-03-29:19:10:23:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
2021-03-29:19:10:23:WU00:FS01:0x22: Core: Core22
2021-03-29:19:10:23:WU00:FS01:0x22: Type: 0x22
2021-03-29:19:10:23:WU00:FS01:0x22: Version: 0.0.13
2021-03-29:19:10:23:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
2021-03-29:19:10:23:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
2021-03-29:19:10:23:WU00:FS01:0x22: Homepage: https://foldingathome.org/
2021-03-29:19:10:23:WU00:FS01:0x22: Date: Sep 19 2020
2021-03-29:19:10:23:WU00:FS01:0x22: Time: 01:10:35
2021-03-29:19:10:23:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
2021-03-29:19:10:23:WU00:FS01:0x22: Branch: core22-0.0.13
2021-03-29:19:10:23:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
2021-03-29:19:10:23:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
2021-03-29:19:10:23:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
2021-03-29:19:10:23:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
2021-03-29:19:10:23:WU00:FS01:0x22: Bits: 64
2021-03-29:19:10:23:WU00:FS01:0x22: Mode: Release
2021-03-29:19:10:23:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
2021-03-29:19:10:23:WU00:FS01:0x22: <peastman@stanford.edu>
2021-03-29:19:10:23:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 1748 -checkpoint 5
2021-03-29:19:10:23:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1
2021-03-29:19:10:23:WU00:FS01:0x22: -gpu-usage 100
2021-03-29:19:10:23:WU00:FS01:0x22:************************************ libFAH ************************************
2021-03-29:19:10:23:WU00:FS01:0x22: Date: Sep 15 2020
2021-03-29:19:10:23:WU00:FS01:0x22: Time: 05:14:43
2021-03-29:19:10:23:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
2021-03-29:19:10:23:WU00:FS01:0x22: Branch: HEAD
2021-03-29:19:10:23:WU00:FS01:0x22:************************************ CBang *************************************
2021-03-29:19:10:23:WU00:FS01:0x22: Time: 05:11:04
2021-03-29:19:10:23:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
2021-03-29:19:10:23:WU00:FS01:0x22: -funroll-loops -fPIC
2021-03-29:19:10:23:WU00:FS01:0x22:************************************ System ************************************
2021-03-29:19:10:23:WU00:FS01:0x22: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
2021-03-29:19:10:23:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
2021-03-29:19:10:23:WU00:FS01:0x22: CPUs: 64
2021-03-29:19:10:23:WU00:FS01:0x22: Memory: 125.51GiB
2021-03-29:19:10:23:WU00:FS01:0x22:Free Memory: 124.41GiB
2021-03-29:19:10:23:WU00:FS01:0x22: Threads: POSIX_THREADS
2021-03-29:19:10:23:WU00:FS01:0x22: OS Version: 4.18
2021-03-29:19:10:23:WU00:FS01:0x22:Has Battery: false
2021-03-29:19:10:23:WU00:FS01:0x22: On Battery: false
2021-03-29:19:10:23:WU00:FS01:0x22: UTC Offset: -7
2021-03-29:19:10:23:WU00:FS01:0x22: PID: 1752
2021-03-29:19:10:23:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
2021-03-29:19:10:23:WU00:FS01:0x22:************************************ OpenMM ************************************
2021-03-29:19:10:23:WU00:FS01:0x22: Revision: 189320d0
2021-03-29:19:10:23:WU00:FS01:0x22:********************************************************************************
2021-03-29:19:10:23:WU00:FS01:0x22:Project: 17716 (Run 61, Clone 2, Gen 72)
2021-03-29:19:10:23:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
2021-03-29:19:10:23:WU00:FS01:0x22:Digital signatures verified
2021-03-29:19:10:23:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
2021-03-29:19:10:23:WU00:FS01:0x22:Version 0.0.13
2021-03-29:19:10:23:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
2021-03-29:19:10:23:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
2021-03-29:19:10:23:WU00:FS01:0x22: XTC frame write interval: 25000 steps (2.5%) [40 total]
2021-03-29:19:10:23:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
2021-03-29:19:10:23:WU00:FS01:0x22:There are 3 platforms available.
2021-03-29:19:10:23:WU00:FS01:0x22:Platform 0: Reference
2021-03-29:19:10:23:WU00:FS01:0x22:Platform 1: CPU
2021-03-29:19:10:23:WU00:FS01:0x22:Platform 2: OpenCL
2021-03-29:19:10:23:WU00:FS01:0x22: opencl-device 1 specified
2021-03-29:19:10:28:WU00:FS01:0x22:Attempting to create OpenCL context:
2021-03-29:19:10:28:WU00:FS01:0x22: Configuring platform OpenCL
2021-03-29:19:10:36:WU00:FS01:0x22: Using OpenCL on platformId 0 and gpu 1
2021-03-29:19:10:36:WU00:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
2021-03-29:19:18:11:WU00:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
2021-03-29:19:18:59:WU02:FS00:0xa8:Completed 45000 out of 500000 steps (9%)
2021-03-29:19:19:16:WU03:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
2021-03-29:19:19:48:WU02:FS00:0xa8:Completed 50000 out of 500000 steps (10%)
2021-03-29:19:20:37:WU02:FS00:0xa8:Completed 55000 out of 500000 steps (11%)
2021-03-29:19:21:25:WU03:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
2021-03-29:19:21:26:WU02:FS00:0xa8:Completed 60000 out of 500000 steps (12%)
2021-03-29:19:21:26:WU03:FS02:0x22:Checkpoint completed at step 50000
2021-03-29:19:22:15:WU02:FS00:0xa8:Completed 65000 out of 500000 steps (13%)
2021-03-29:19:23:04:WU02:FS00:0xa8:Completed 70000 out of 500000 steps (14%)
2021-03-29:19:23:37:WU03:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
2021-03-29:19:23:52:WU02:FS00:0xa8:Completed 75000 out of 500000 steps (15%)
2021-03-29:19:24:40:WU02:FS00:0xa8:Completed 80000 out of 500000 steps (16%)
2021-03-29:19:25:28:WU02:FS00:0xa8:Completed 85000 out of 500000 steps (17%)
2021-03-29:19:25:49:WU03:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
2021-03-29:19:26:17:WU02:FS00:0xa8:Completed 90000 out of 500000 steps (18%)
2021-03-29:19:27:05:WU02:FS00:0xa8:Completed 95000 out of 500000 steps (19%)
2021-03-29:19:27:53:WU02:FS00:0xa8:Completed 100000 out of 500000 steps (20%)
2021-03-29:19:27:59:WU03:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
2021-03-29:19:28:32:WU00:FS01:0x22:Watchdog triggered, requesting soft shutdown down
2021-03-29:19:28:41:WU02:FS00:0xa8:Completed 105000 out of 500000 steps (21%)
2021-03-29:19:29:29:WU02:FS00:0xa8:Completed 110000 out of 500000 steps (22%)
2021-03-29:19:30:08:WU03:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
2021-03-29:19:30:17:WU02:FS00:0xa8:Completed 115000 out of 500000 steps (23%)
2021-03-29:19:31:04:WU02:FS00:0xa8:Completed 120000 out of 500000 steps (24%)
2021-03-29:19:31:54:WU02:FS00:0xa8:Completed 125000 out of 500000 steps (25%)
2021-03-29:19:32:19:WU03:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
2021-03-29:19:32:20:WU03:FS02:0x22:Checkpoint completed at step 100000
2021-03-29:19:32:43:WU02:FS00:0xa8:Completed 130000 out of 500000 steps (26%)
2021-03-29:19:33:31:WU02:FS00:0xa8:Completed 135000 out of 500000 steps (27%)
2021-03-29:19:34:19:WU02:FS00:0xa8:Completed 140000 out of 500000 steps (28%)
2021-03-29:19:34:31:WU03:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
2021-03-29:19:35:06:WU02:FS00:0xa8:Completed 145000 out of 500000 steps (29%)
2021-03-29:19:35:54:WU02:FS00:0xa8:Completed 150000 out of 500000 steps (30%)
2021-03-29:19:36:41:WU03:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
2021-03-29:19:36:42:WU02:FS00:0xa8:Completed 155000 out of 500000 steps (31%)
2021-03-29:19:37:29:WU02:FS00:0xa8:Completed 160000 out of 500000 steps (32%)
2021-03-29:19:38:17:WU02:FS00:0xa8:Completed 165000 out of 500000 steps (33%)
2021-03-29:19:38:32:WU00:FS01:0x22:Watchdog shutdown failed, hard shutdown triggered
2021-03-29:19:38:54:WU03:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
2021-03-29:19:39:04:WU02:FS00:0xa8:Completed 170000 out of 500000 steps (34%)
2021-03-29:19:39:52:WU02:FS00:0xa8:Completed 175000 out of 500000 steps (35%)
2021-03-29:19:40:39:WU02:FS00:0xa8:Completed 180000 out of 500000 steps (36%)
2021-03-29:19:41:01:WU03:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
2021-03-29:19:41:26:WU02:FS00:0xa8:Completed 185000 out of 500000 steps (37%)
2021-03-29:19:42:16:WU02:FS00:0xa8:Completed 190000 out of 500000 steps (38%)
2021-03-29:19:43:05:WU02:FS00:0xa8:Completed 195000 out of 500000 steps (39%)
2021-03-29:19:43:13:WU03:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
2021-03-29:19:43:14:WU03:FS02:0x22:Checkpoint completed at step 150000
2021-03-29:19:43:53:WU02:FS00:0xa8:Completed 200000 out of 500000 steps (40%)
2021-03-29:19:44:41:WU02:FS00:0xa8:Completed 205000 out of 500000 steps (41%)
2021-03-29:19:45:21:WU03:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
2021-03-29:19:45:29:WU02:FS00:0xa8:Completed 210000 out of 500000 steps (42%)
2021-03-29:19:46:17:WU02:FS00:0xa8:Completed 215000 out of 500000 steps (43%)
2021-03-29:19:47:06:WU02:FS00:0xa8:Completed 220000 out of 500000 steps (44%)
2021-03-29:19:47:30:WU03:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
2021-03-29:19:47:53:WU02:FS00:0xa8:Completed 225000 out of 500000 steps (45%)
2021-03-29:19:48:13:WARNING:FS01:WU appears to be stalled, ending run
2021-03-29:19:48:13:FS01:Shutting core down
2021-03-29:19:48:41:WU02:FS00:0xa8:Completed 230000 out of 500000 steps (46%)
2021-03-29:19:49:14:WARNING:FS01:Killing WU00
...dozens of these...
2021-03-29:19:49:29:WARNING:FS01:Killing WU00
2021-03-29:19:49:29:WU02:FS00:0xa8:Completed 235000 out of 500000 steps (47%)
2021-03-29:19:49:39:WARNING:FS01:Killing WU00
2021-03-29:19:49:39:WU03:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
2021-03-29:19:49:40:WARNING:FS01:Killing WU00
...>100 of these...
2021-03-29:19:50:16:WARNING:FS01:Killing WU00
2021-03-29:19:50:17:WARNING:FS01:Killing WU00
2021-03-29:19:50:17:WU02:FS00:0xa8:Completed 240000 out of 500000 steps (48%)
2021-03-29:19:50:26:WARNING:FS01:Killing WU00
2021-03-29:19:50:26:Caught signal SIGTERM(15) on PID 1661
2021-03-29:19:50:26:Exiting, please wait. . .
2021-03-29:19:50:26:WU02:FS00:0xa8:Caught signal SIGTERM(15) on PID 3351
2021-03-29:19:50:26:WU02:FS00:0xa8:Exiting, please wait. . .
2021-03-29:19:50:26:WU03:FS02:0x22:Caught signal SIGTERM(15) on PID 1764
2021-03-29:19:50:26:WU03:FS02:0x22:Exiting, please wait. . .
2021-03-29:19:50:26:WU03:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
2021-03-29:19:50:27:WU02:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
2021-03-29:19:50:28:WARNING:FS01:Killing WU00
2021-03-29:19:50:28:FS02:Shutting core down
...>1,000 of these...
2021-03-29:19:51:56:WARNING:FS01:Killing WU00
2021-03-29:19:51:56:WARNING:FS02:Killing WU03
