Is my Nvidia GPU dying? (driver 461.09)
Nvidia driver 461.09; GPU 1660ti; FAH client 7.6.13.
GPU seems to fold for a while(~40 minutes), gets loud and reaches 81 Celcius and then temperature drops to 44 Celcius, but it doesn't seem to fold for another 40 minutes. After some time GPU again starts to fold and cycle repeats. Doesn't matter which WU is being folded.
Is my GPU dying or I just need to replace thermal paste?
Re: Is my Nvidia GPU dying? (driver 461.09)
Are you folding on Windows or Linux? Can you please post the 200 or so lines of your log, as well as the sections of the log where the GPU stops? (How-to here: viewtopic.php?p=327412)
What is the output of the command (should be available both on Windows and Linux). and
If on Windows, can you run GPU-Z and look at the sensors data?
nvidia-smi -qCode: Select all
nvidia-smi
I'm folding on Windows .
As I was looking for logs, folding again started, so I will add output later
FAH log
GPU-z sensors while folding:
nvidia-smiCode: Select all
C:\Users\PC>nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Wed Mar 17 17:40:34 2021
Driver Version : 461.09
CUDA Version : 11.2
Attached GPUs : 1
GPU 00000000:09:00.0
Product Name : GeForce GTX 1660 Ti
Product Brand : GeForce
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-8e3f54f2-71c5-2a02-58dd-284ae44e15bc
Minor Number : N/A
VBIOS Version : 90.16.29.00.94
MultiGPU Board : No
Board ID : 0x900
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.02.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x09
Device : 0x00
Domain : 0x0000
Device Id : 0x218210DE
Bus Id : 00000000:09:00.0
Sub System Id : 0x37501462
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 1316000 KB/s
Rx Throughput : 15707000 KB/s
Fan Speed : 44 %
Performance State : P2
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 6144 MiB
Used : 793 MiB
Free : 5351 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 229 MiB
Free : 27 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 1 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 42 C
GPU Shutdown Temp : 95 C
GPU Slowdown Temp : 92 C
GPU Max Operating Temp : 90 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 30.18 W
Power Limit : 120.00 W
Default Power Limit : 120.00 W
Enforced Power Limit : 120.00 W
Min Power Limit : 70.00 W
Max Power Limit : 120.00 W
Clocks
Graphics : 1500 MHz
SM : 1500 MHz
Memory : 5750 MHz
Video : 1395 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2160 MHz
SM : 2160 MHz
Memory : 6001 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 1296
Type : C+G
Name : Insufficient Permissions
Used GPU Memory : Not available in WDDM driver model
Process ID : 2776
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2020.20120.4004.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
Process ID : 5256
Type : C
Name : C:\Users\PC\AppData\Roaming\FAHClient\cores\cores.foldingathome.org\win\64bit\22-0.0.13\Core_22.fah\FahCore_22.exe
Process ID : 6364
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.WindowsCalculator_10.2101.10.0_x64__8wekyb3d8bbwe\Calculator.exe
Process ID : 6568
Type : C+G
Process ID : 7408
Type : C+G
Name : C:\Program Files\Mozilla Firefox\firefox.exe
Process ID : 7660
Type : C+G
Name : C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
Process ID : 7940
Type : C+G
Process ID : 8468
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.YourPhone_1.21021.117.0_x64__8wekyb3d8bbwe\YourPhone.exe
Process ID : 8740
Type : C+G
Process ID : 9964
Type : C+G
Process ID : 9996
Type : C+G
Name : C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\InputApp\TextInputHost.exeFAH log
16:12:41:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:12:41:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:12:42:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:12:42:ERROR:WU00:FS00:Exception: Could not get an assignment
16:15:03:WU01:FS01:0x22:Completed 637500 out of 750000 steps (85%)
16:17:25:WU01:FS01:0x22:Completed 645000 out of 750000 steps (86%)
16:17:27:WU01:FS01:0x22:Checkpoint completed at step 645000
16:22:18:FS00:Paused
16:22:18:FS01:Paused
16:22:18:FS01:Shutting core down
16:22:18:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 12920
16:22:18:WU01:FS01:0x22:Exiting, please wait. . .
16:22:28:Removing old file 'configs/config-20210310-145902.xml'
16:22:28:Saving configuration to config.xml
16:22:28:<config>
16:22:28: <!-- Slot Control -->
16:22:28: <power v='FULL'/>
16:22:28:
16:22:28: <!-- User Information -->
16:22:28: <passkey v='*****'/>
16:22:28: <team v='36816'/>
16:22:28: <user v='benas_s'/>
16:22:28:
16:22:28: <!-- Folding Slots -->
16:22:28: <slot id='0' type='CPU'>
16:22:28: <paused v='true'/>
16:22:28: </slot>
16:22:28: <slot id='1' type='GPU'>
16:22:28: </slot>
16:22:28:</config>
16:23:19:WARNING:FS01:Killing WU01
16:23:19:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:11:37:FS00:Unpaused
18:11:37:FS01:Unpaused
18:11:37:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:11:37:WU01:FS01:Starting
18:11:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4020 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:11:37:WU01:FS01:Started FahCore on PID 15832
18:11:37:WU01:FS01:Core PID:10436
18:11:37:WU01:FS01:FahCore 0x22 started
18:11:37:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:11:37:WU00:FS00:Connecting to assign2.foldingathome.org:80
18:11:38:WU01:FS01:0x22:*********************** Log Started 2021-03-15T18:11:37Z ***********************
18:11:38:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:11:38:WU01:FS01:0x22: Core: Core22
18:11:38:WU01:FS01:0x22: Type: 0x22
18:11:38:WU01:FS01:0x22: Version: 0.0.13
18:11:38:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:11:38:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
18:11:38:WU01:FS01:0x22: Homepage: https://foldingathome.org/
18:11:38:WU01:FS01:0x22: Date: Sep 19 2020
18:11:38:WU01:FS01:0x22: Time: 02:35:58
18:11:38:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:11:38:WU01:FS01:0x22: Branch: core22-0.0.13
18:11:38:WU01:FS01:0x22: Compiler: Visual C++ 2015
18:11:38:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:11:38:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
18:11:38:WU01:FS01:0x22: Platform: win32 10
18:11:38:WU01:FS01:0x22: Bits: 64
18:11:38:WU01:FS01:0x22: Mode: Release
18:11:38:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:11:38:WU01:FS01:0x22: <peastman@stanford.edu>
18:11:38:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 15832 -checkpoint 15
18:11:38:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:11:38:WU01:FS01:0x22: 0 -gpu 0
18:11:38:WU01:FS01:0x22:************************************ libFAH ************************************
18:11:38:WU01:FS01:0x22: Date: Sep 7 2020
18:11:38:WU01:FS01:0x22: Time: 19:09:56
18:11:38:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:11:38:WU01:FS01:0x22: Branch: HEAD
18:11:38:WU01:FS01:0x22:************************************ CBang *************************************
18:11:38:WU01:FS01:0x22: Time: 19:08:30
18:11:38:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:11:38:WU01:FS01:0x22:************************************ System ************************************
18:11:38:WU01:FS01:0x22: CPU: AMD Ryzen 7 3700X 8-Core Processor
18:11:38:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:11:38:WU01:FS01:0x22: CPUs: 16
18:11:38:WU01:FS01:0x22: Memory: 31.92GiB
18:11:38:WU01:FS01:0x22:Free Memory: 26.45GiB
18:11:38:WU01:FS01:0x22: Threads: WINDOWS_THREADS
18:11:38:WU01:FS01:0x22: OS Version: 6.2
18:11:38:WU01:FS01:0x22:Has Battery: false
18:11:38:WU01:FS01:0x22: On Battery: false
18:11:38:WU01:FS01:0x22: UTC Offset: 2
18:11:38:WU01:FS01:0x22: PID: 10436
18:11:38:WU01:FS01:0x22: CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
18:11:38:WU01:FS01:0x22:************************************ OpenMM ************************************
18:11:38:WU01:FS01:0x22: Revision: 189320d0
18:11:38:WU01:FS01:0x22:********************************************************************************
18:11:38:WU01:FS01:0x22:Project: 17329 (Run 0, Clone 765, Gen 64)
18:11:38:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:11:38:WU01:FS01:0x22:Digital signatures verified
18:11:38:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:11:38:WU01:FS01:0x22:Version 0.0.13
18:11:38:WU01:FS01:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
18:11:38:WU01:FS01:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
18:11:38:WU01:FS01:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
18:11:38:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
18:11:38:WU01:FS01:0x22:There are 4 platforms available.
18:11:38:WU01:FS01:0x22:Platform 0: Reference
18:11:38:WU01:FS01:0x22:Platform 1: CPU
18:11:38:WU01:FS01:0x22:Platform 2: OpenCL
18:11:38:WU01:FS01:0x22: opencl-device 0 specified
18:11:38:WU01:FS01:0x22:Platform 3: CUDA
18:11:38:WU01:FS01:0x22: cuda-device 0 specified
18:11:45:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:11:45:WU00:FS00:Connecting to assign3.foldingathome.org:80
18:11:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:11:46:WU00:FS00:Connecting to assign4.foldingathome.org:80
18:11:47:WU00:FS00:Assigned to work server 206.223.170.146
18:11:47:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 206.223.170.146
18:11:47:WU00:FS00:Connecting to 206.223.170.146:8080
18:11:48:ERROR:WU00:FS00:Exception: Server did not assign work unit
18:11:53:WU01:FS01:0x22:Attempting to create CUDA context:
18:11:53:WU01:FS01:0x22: Configuring platform CUDA
18:11:58:WU01:FS01:0x22: Using CUDA and gpu 0
18:11:58:WU01:FS01:0x22:Completed 645000 out of 750000 steps (86%)
18:12:16:Removing old file 'configs/config-20210310-161214.xml'
18:12:16:Saving configuration to config.xml
18:12:16:<config>
18:12:16: <!-- Slot Control -->
18:12:16: <power v='FULL'/>
18:12:16:
18:12:16: <!-- User Information -->
18:12:16: <passkey v='*****'/>
18:12:16: <team v='36816'/>
18:12:16: <user v='benas_s'/>
18:12:16:
18:12:16: <!-- Folding Slots -->
18:12:16: <slot id='0' type='CPU'/>
18:12:16: <slot id='1' type='GPU'/>
18:12:16:</config>
18:13:14:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:13:15:WU00:FS00:Assigned to work server 129.32.209.203
18:13:25:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 129.32.209.203
18:13:25:WU00:FS00:Connecting to 129.32.209.203:8080
18:13:25:ERROR:WU00:FS00:Exception: Server did not assign work unit
18:14:31:WU01:FS01:0x22:Completed 652500 out of 750000 steps (87%)
18:15:51:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:15:52:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:15:52:WU00:FS00:Connecting to assign2.foldingathome.org:80
18:15:53:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:15:53:WU00:FS00:Connecting to assign3.foldingathome.org:80
18:15:54:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:15:54:WU00:FS00:Connecting to assign4.foldingathome.org:80
18:15:55:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:15:55:ERROR:WU00:FS00:Exception: Could not get an assignment
18:17:02:WU01:FS01:0x22:Completed 660000 out of 750000 steps (88%)
18:17:04:WU01:FS01:0x22:Checkpoint completed at step 660000
18:19:58:WU01:FS01:0x22:Completed 667500 out of 750000 steps (89%)
18:20:06:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:20:06:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:20:06:WU00:FS00:Connecting to assign2.foldingathome.org:80
18:20:07:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:20:07:WU00:FS00:Connecting to assign3.foldingathome.org:80
18:20:08:WU00:FS00:Assigned to work server 128.252.203.9
18:20:08:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 128.252.203.9
18:20:08:WU00:FS00:Connecting to 128.252.203.9:8080
18:20:08:ERROR:WU00:FS00:Exception: Server did not assign work unit
18:22:31:WU01:FS01:0x22:Completed 675000 out of 750000 steps (90%)
18:22:33:WU01:FS01:0x22:Checkpoint completed at step 675000
18:22:59:FS00:Finishing
18:22:59:FS01:Finishing
18:24:58:WU01:FS01:0x22:Completed 682500 out of 750000 steps (91%)
18:26:57:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:26:57:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:26:57:WU00:FS00:Connecting to assign2.foldingathome.org:80
18:26:58:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:26:58:WU00:FS00:Connecting to assign3.foldingathome.org:80
18:26:58:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:26:58:WU00:FS00:Connecting to assign4.foldingathome.org:80
18:26:59:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:26:59:ERROR:WU00:FS00:Exception: Could not get an assignment
18:27:26:WU01:FS01:0x22:Completed 690000 out of 750000 steps (92%)
18:27:28:WU01:FS01:0x22:Checkpoint completed at step 690000
18:29:54:WU01:FS01:0x22:Completed 697500 out of 750000 steps (93%)
18:32:20:WU01:FS01:0x22:Completed 705000 out of 750000 steps (94%)
18:32:22:WU01:FS01:0x22:Checkpoint completed at step 705000
18:34:50:WU01:FS01:0x22:Completed 712500 out of 750000 steps (95%)
18:37:22:WU01:FS01:0x22:Completed 720000 out of 750000 steps (96%)
18:37:24:WU01:FS01:0x22:Checkpoint completed at step 720000
18:38:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:38:03:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:38:03:WU00:FS00:Connecting to assign2.foldingathome.org:80
18:38:04:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:38:04:WU00:FS00:Connecting to assign3.foldingathome.org:80
18:38:04:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:38:04:WU00:FS00:Connecting to assign4.foldingathome.org:80
18:38:05:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:38:05:ERROR:WU00:FS00:Exception: Could not get an assignment
18:40:02:WU01:FS01:0x22:Completed 727500 out of 750000 steps (97%)
18:42:43:WU01:FS01:0x22:Completed 735000 out of 750000 steps (98%)
18:42:45:WU01:FS01:0x22:Checkpoint completed at step 735000
18:45:26:WU01:FS01:0x22:Completed 742500 out of 750000 steps (99%)
18:48:08:WU01:FS01:0x22:Completed 750000 out of 750000 steps (100%)
18:48:08:WU01:FS01:0x22:Average performance: 267.492 ns/day
18:48:10:WU01:FS01:0x22:Checkpoint completed at step 750000
18:48:29:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:48:29:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
18:48:29:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
18:48:29:WU01:FS01:0x22:Saving result file positions.xtc
18:48:29:WU01:FS01:0x22:Saving result file science.log
18:48:29:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:48:30:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:48:30:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17329 run:0 clone:765 gen:64 core:0x22 unit:0x000002fd00000040000043b100000000
18:48:30:WU01:FS01:Uploading 29.23MiB to 140.163.4.200
18:48:30:WU01:FS01:Connecting to 140.163.4.200:8080
18:48:36:WU01:FS01:Upload 9.20%
18:48:42:WU01:FS01:Upload 19.67%
18:48:48:WU01:FS01:Upload 30.15%
18:48:54:WU01:FS01:Upload 40.21%
18:49:00:WU01:FS01:Upload 50.26%
18:49:06:WU01:FS01:Upload 60.52%
18:49:12:WU01:FS01:Upload 70.79%
18:49:18:WU01:FS01:Upload 81.05%
18:49:24:WU01:FS01:Upload 91.32%
18:49:29:WU01:FS01:Upload complete
18:49:29:WU01:FS01:Server responded WORK_ACK (400)
18:49:29:WU01:FS01:Final credit estimate, 159788.00 points
18:49:29:WU01:FS01:Cleaning up
18:49:42:FS00:Paused
18:49:42:FS01:Paused
18:49:53:Removing old file 'configs/config-20210310-180404.xml'
18:49:53:Saving configuration to config.xml
18:49:53:<config>
18:49:53: <!-- Slot Control -->
18:49:53: <power v='FULL'/>
18:49:53:
18:49:53: <!-- User Information -->
18:49:53: <passkey v='*****'/>
18:49:53: <team v='36816'/>
18:49:53: <user v='benas_s'/>
18:49:53:
18:49:53: <!-- Folding Slots -->
18:49:53: <slot id='0' type='CPU'>
18:49:53: <paused v='true'/>
18:49:53: </slot>
18:49:53: <slot id='1' type='GPU'>
18:49:53: </slot>
18:49:53:</config>
20:08:01:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
The client should be upgraded to 7.6.21 due to a security issue. You might want to upgrade to the newest driver from Nvidia's website as well. What does the topmost part of the log look like if you restart the FAH client? (The lines looking like these:
*********************** Log Started 2021-03-17T15:56:10Z ***********************
15:56:10: CPU: AMD Ryzen 5 3600 6-Core Processor
15:56:10: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
15:56:10: CPUs: 12
15:56:10: Memory: 15.61GiB
15:56:10: Free Memory: 2.19GiB
15:56:10: Threads: POSIX_THREADS
15:56:10: OS Version: 5.4
15:56:10: Has Battery: false
15:56:10: On Battery: false
15:56:10: UTC Offset: 1
15:56:10: PID: 368002
15:56:10: CWD: /var/lib/fahclient
15:56:10: OS: Linux 5.4.0-67-generic x86_64
15:56:10: OS Arch: AMD64
15:56:10: GPUs: 1
15:56:10: GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
15:56:10: CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:7.5 Driver:11.2
15:56:10:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:460.39
15:56:10:***********************************************************************
After restart log looks like this. But now it is folding. Maybe I should wait until it stops folding
*********************** Log Started 2021-03-17T15:59:00Z ***********************
15:59:00:Trying to access database...
15:59:00:Successfully acquired database lock
15:59:00:Read GPUs.txt
15:59:00:Enabled folding slot 00: PAUSED cpu:15 (by user)
15:59:00:Enabled folding slot 01: PAUSED gpu:0:TU116 [GeForce GTX 1660 Ti] (by user)
15:59:00:****************************** FAHClient ******************************
15:59:00: Version: 7.6.13
15:59:00: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:59:00: Copyright: 2020 foldingathome.org
15:59:00: Homepage: https://foldingathome.org/
15:59:00: Date: Apr 27 2020
15:59:00: Time: 21:21:01
15:59:00: Revision: 5a652817f46116b6e135503af97f18e094414e3b
15:59:00: Branch: master
15:59:00: Compiler: Visual C++ 2008
15:59:00: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:59:00: Platform: win32 10
15:59:00: Bits: 32
15:59:00: Mode: Release
15:59:00: Args: --open-web-control
15:59:00: Config: C:\Users\PC\AppData\Roaming\FAHClient\config.xml
15:59:00:******************************** CBang ********************************
15:59:00: Date: Apr 24 2020
15:59:00: Time: 17:07:55
15:59:00: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
15:59:00: Bits: 32
15:59:00:******************************* System ********************************
15:59:00: CPU: AMD Ryzen 7 3700X 8-Core Processor
15:59:00: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
15:59:00: CPUs: 16
15:59:00: Memory: 31.92GiB
15:59:00: Free Memory: 27.63GiB
15:59:00: Threads: WINDOWS_THREADS
15:59:00: OS Version: 6.2
15:59:00: Has Battery: false
15:59:00: On Battery: false
15:59:00: UTC Offset: 2
15:59:00: PID: 4544
15:59:00: CWD: C:\Users\PC\AppData\Roaming\FAHClient
15:59:00: Win32 Service: false
15:59:00: OS: Windows 10 Enterprise
15:59:00: OS Arch: AMD64
15:59:00: GPUs: 1
15:59:00: GPU 0: Bus:9 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 Ti]
15:59:00: CUDA Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:7.5 Driver:11.2
15:59:00:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:461.9
15:59:00:******************************* libFAH ********************************
15:59:00: Date: Apr 15 2020
15:59:00: Time: 14:53:14
15:59:00: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
15:59:00: Bits: 32
15:59:00:***********************************************************************
15:59:00:<config>
15:59:00: <!-- Slot Control -->
15:59:00: <power v='FULL'/>
15:59:00:
15:59:00: <!-- User Information -->
15:59:00: <passkey v='*****'/>
15:59:00: <team v='36816'/>
15:59:00: <user v='benas_s'/>
15:59:00:
15:59:00: <!-- Folding Slots -->
15:59:00: <slot id='0' type='CPU'>
15:59:00: <paused v='true'/>
15:59:00: </slot>
15:59:00: <slot id='1' type='GPU'>
15:59:00: </slot>
15:59:00:</config>
15:59:01:4:127.0.0.1:New Web session
15:59:32:FS00:Unpaused
15:59:32:FS01:Unpaused
15:59:32:WU01:FS01:Starting
15:59:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:59:32:WU01:FS01:Started FahCore on PID 10308
15:59:32:WU01:FS01:Core PID:7044
15:59:32:WU01:FS01:FahCore 0x22 started
15:59:32:WU00:FS00:Connecting to assign1.foldingathome.org:80
15:59:32:WU01:FS01:0x22:*********************** Log Started 2021-03-17T15:59:32Z ***********************
15:59:32:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:59:32:WU01:FS01:0x22: Core: Core22
15:59:32:WU01:FS01:0x22: Type: 0x22
15:59:32:WU01:FS01:0x22: Version: 0.0.13
15:59:32:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:59:32:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
15:59:32:WU01:FS01:0x22: Homepage: https://foldingathome.org/
15:59:32:WU01:FS01:0x22: Date: Sep 19 2020
15:59:32:WU01:FS01:0x22: Time: 02:35:58
15:59:32:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:59:32:WU01:FS01:0x22: Branch: core22-0.0.13
15:59:32:WU01:FS01:0x22: Compiler: Visual C++ 2015
15:59:32:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:59:32:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
15:59:32:WU01:FS01:0x22: Platform: win32 10
15:59:32:WU01:FS01:0x22: Bits: 64
15:59:32:WU01:FS01:0x22: Mode: Release
15:59:32:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:59:32:WU01:FS01:0x22: <peastman@stanford.edu>
15:59:32:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 10308 -checkpoint 15
15:59:32:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:59:32:WU01:FS01:0x22: 0 -gpu 0
15:59:32:WU01:FS01:0x22:************************************ libFAH ************************************
15:59:32:WU01:FS01:0x22: Date: Sep 7 2020
15:59:32:WU01:FS01:0x22: Time: 19:09:56
15:59:32:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:59:32:WU01:FS01:0x22: Branch: HEAD
15:59:32:WU01:FS01:0x22:************************************ CBang *************************************
15:59:32:WU01:FS01:0x22: Time: 19:08:30
15:59:32:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:59:32:WU01:FS01:0x22:************************************ System ************************************
15:59:32:WU01:FS01:0x22: CPU: AMD Ryzen 7 3700X 8-Core Processor
15:59:32:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
15:59:32:WU01:FS01:0x22: CPUs: 16
15:59:32:WU01:FS01:0x22: Memory: 31.92GiB
15:59:32:WU01:FS01:0x22:Free Memory: 27.59GiB
15:59:32:WU01:FS01:0x22: Threads: WINDOWS_THREADS
15:59:32:WU01:FS01:0x22: OS Version: 6.2
15:59:32:WU01:FS01:0x22:Has Battery: false
15:59:32:WU01:FS01:0x22: On Battery: false
15:59:32:WU01:FS01:0x22: UTC Offset: 2
15:59:32:WU01:FS01:0x22: PID: 7044
15:59:32:WU01:FS01:0x22: CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
15:59:32:WU01:FS01:0x22:************************************ OpenMM ************************************
15:59:32:WU01:FS01:0x22: Revision: 189320d0
15:59:32:WU01:FS01:0x22:********************************************************************************
15:59:32:WU01:FS01:0x22:Project: 17800 (Run 1, Clone 114, Gen 217)
15:59:32:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
15:59:32:WU01:FS01:0x22:Digital signatures verified
15:59:32:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:59:32:WU01:FS01:0x22:Version 0.0.13
15:59:32:WU01:FS01:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
15:59:32:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
15:59:32:WU01:FS01:0x22: XTC frame write interval: 25000 steps (0.5%) [200 total]
15:59:32:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
15:59:32:WU01:FS01:0x22:There are 4 platforms available.
15:59:32:WU01:FS01:0x22:Platform 0: Reference
15:59:32:WU01:FS01:0x22:Platform 1: CPU
15:59:32:WU01:FS01:0x22:Platform 2: OpenCL
15:59:32:WU01:FS01:0x22: opencl-device 0 specified
15:59:32:WU01:FS01:0x22:Platform 3: CUDA
15:59:32:WU01:FS01:0x22: cuda-device 0 specified
15:59:33:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:59:33:WU00:FS00:Connecting to assign2.foldingathome.org:80
15:59:33:WU01:FS01:0x22:Attempting to create CUDA context:
15:59:33:WU01:FS01:0x22: Configuring platform CUDA
15:59:33:WU00:FS00:Assigned to work server 206.223.170.146
15:59:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 206.223.170.146
15:59:33:WU00:FS00:Connecting to 206.223.170.146:8080
15:59:33:WU01:FS01:0x22: Using CUDA and gpu 0
15:59:33:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)Re: Is my Nvidia GPU dying? (driver 461.09)
Are your temps still high as we are speaking? Which model of the 1660ti are you using? 80 degrees C for 111W of power seems awfully high to me.
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
yes, they are still that high. Was folding for a year nonstop and suddenly started getting these high temps, high fan speed and occasional folding drops. Usually temp was 70C, but now its almost 80. Model is Asus 1660tiiero wrote:Are your temps still high as we are speaking? Which model of the 1660ti are you using? 80 degrees C for 111W of power seems awfully high to me.
Did you change anything on your setup? New fans? Removed fans?New case? Changed PCI-E slot? opened the card for maintenance? accidentally applied an overclock? Anything else coming to mind?
I would suggest updating to the newest drivers.
https://www.nvidia.com/en-gb/drivers/results/171591/
You should also look on the card itself for dust build up. Are you sure that the temp increase was sudden and not incremental/over time?
GPU only
Can't say this problam wasn't incremental, I just noticed it today. Haven't changed my setup for half a year. Will try open case and clean the dust, upgrade drivers and FAH client to v.21iero wrote:Did you change anything on your setup? New fans? Removed fans?New case? Changed PCI-E slot? opened the card for maintenance? accidentally applied an overclock? Anything else coming to mind?
If you are knowledgeable enough, and have the appropriate tools, I would suggest a thermal paste change as well. *** if the warranty has expired and/or there isn't a warranty sticker on your card.
In any case, waiting to hear if you found the source of your problem.
GPU only
try with the case cover off. the gpu running at 81c is normal as Nvidia just vary the speed of the fans to keep it at or below that temperature. If the fans are ramping as you say then it's probably overheating. clean out the system, make sure it has lots of fresh air.
single 1070
Also, check the fins of the heatsink. Dust can accumulate and gradually cause the heatsink's efficiency to degrade. A good treatment with canned air can help a lot.
