WU stalled twice in a single day but WORK_ACK(400)
afkar.aulia
Post by afkar.aulia »
Not sure what the problem is, but these last 2-3 days, the WU keep getting stalled, the log no longer reports the increased percentage (usually it reports every 1% increase, but the percentage is shown to be going up while the log reports nothing), and then the work got error, it's asking the program to soft shutdown, and since it fails then hard shutdown (not sure what those mean since my laptop doesn't shutdown, so probably program shutdown), and since there are too many errors, the WU stalled, but it gives notice of WORK_ACK, which I couldn't tell whether or not my point increases, but probably someone here can check? But still, regardless of whether or not my point increases, I didn't join this program for point, so it's a bit annoying that the laptop which has been on the whole night only results in error, which is probably useless for the researchers. Can anybody tell what's going on? Nothing is changed about my laptop (although I don't know about background process), and I have folded around 60 WU before, so I don't know what is changing. My laptop is turning slow these two days, but still works fine. The only program that keeps bothering my F@H before is just Avast, but it never stalled the WU, only disturbing the core download. I often pause and resume folding, if that actually matters, since I can't have my laptop folding during important meeting. Here's the code
(edit: I just noticed from the log that it happened seven times today, I thought it only happened twice >__< )
*********************** Log Started 2021-03-10T16:37:23Z ***********************
16:37:23:Trying to access database...
16:37:26:Successfully acquired database lock
16:37:28:Read GPUs.txt
16:37:34:Enabled folding slot 00: READY cpu:2
16:37:59:****************************** FAHClient ******************************
16:37:59:        Version: 7.6.13
16:37:59:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:37:59:      Copyright: 2020 foldingathome.org
16:37:59:       Homepage: https://foldingathome.org/
16:37:59:           Date: Apr 27 2020
16:37:59:           Time: 21:21:01
16:37:59:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
16:37:59:         Branch: master
16:37:59:       Compiler: Visual C++ 2008
16:37:59:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:37:59:       Platform: win32 10
16:37:59:           Bits: 32
16:37:59:           Mode: Release
16:37:59:         Config: C:\Users\LENOVO\AppData\Roaming\FAHClient\config.xml
16:37:59:******************************** CBang ********************************
16:37:59:           Date: Apr 24 2020
16:37:59:           Time: 17:07:55
16:37:59:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
16:37:59:           Bits: 32
16:37:59:******************************* System ********************************
16:37:59:            CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
16:37:59:         CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
16:37:59:           CPUs: 2
16:37:59:         Memory: 3.89GiB
16:37:59:    Free Memory: 1.17GiB
16:37:59:        Threads: WINDOWS_THREADS
16:37:59:     OS Version: 6.2
16:37:59:    Has Battery: true
16:37:59:     On Battery: false
16:37:59:     UTC Offset: 7
16:37:59:            PID: 668
16:37:59:            CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient
16:37:59:  Win32 Service: false
16:37:59:             OS: Windows 10 Home
16:37:59:        OS Arch: AMD64
16:37:59:           GPUs: 1
16:37:59:          GPU 0: Bus:0 Slot:1 Func:0 AMD:5 [Radeon R2-R5]
16:37:59:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
16:37:59:                 specified module could not be found.
16:37:59:
16:37:59:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:2841.19
16:37:59:******************************* libFAH ********************************
16:37:59:           Date: Apr 15 2020
16:37:59:           Time: 14:53:14
16:37:59:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:37:59:           Bits: 32
16:37:59:***********************************************************************
16:41:38:<config>
16:41:38:  <!-- Folding Slot Configuration -->
16:41:38:  <cause v='COVID_19'/>
16:41:38:
16:41:38:  <!-- Network -->
16:41:38:  <proxy v=':8080'/>
16:41:38:
16:41:38:  <!-- Slot Control -->
16:41:38:  <pause-on-battery v='false'/>
16:41:38:  <power v='full'/>
16:41:38:
16:41:38:  <!-- User Information -->
16:41:38:  <passkey v='*****'/>
16:41:38:  <user v='afkar_aulia'/>
16:41:38:
16:41:38:  <!-- Folding Slots -->
16:41:38:  <slot id='0' type='CPU'/>
16:41:38:</config>
16:42:57:WU00:FS00:Starting
16:43:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
16:43:14:WU00:FS00:Started FahCore on PID 8772
16:43:31:WU00:FS00:Core PID:9804
16:43:31:WU00:FS00:FahCore 0xa7 started
16:43:33:7:127.0.0.1:New Web session
16:44:00:WU00:FS00:0xa7:*********************** Log Started 2021-03-10T16:43:59Z ***********************
16:44:07:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:44:14:WU00:FS00:0xa7:       Type: 0xa7
16:44:16:WU00:FS00:0xa7:       Core: Gromacs
16:44:21:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8772 -checkpoint 15 -np 2
16:44:29:WU00:FS00:0xa7:************************************ CBang *************************************
16:44:37:WU00:FS00:0xa7:       Date: Nov 27 2019
16:44:38:WU00:FS00:0xa7:       Time: 03:40:09
16:44:39:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
16:44:41:WU00:FS00:0xa7:     Branch: master
16:44:42:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:44:44:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:44:46:WU00:FS00:0xa7:   Platform: win32 10
16:44:47:WU00:FS00:0xa7:       Bits: 64
16:44:47:WU00:FS00:0xa7:       Mode: Release
16:44:48:WU00:FS00:0xa7:************************************ System ************************************
16:44:50:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
16:44:52:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
16:44:52:198:127.0.0.1:New Web session
16:44:54:WU00:FS00:0xa7:       CPUs: 2
16:44:54:WU00:FS00:0xa7:     Memory: 3.89GiB
16:44:54:WU00:FS00:0xa7:Free Memory: 397.38MiB
16:44:54:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:44:54:WU00:FS00:0xa7: OS Version: 6.2
16:44:54:WU00:FS00:0xa7:Has Battery: true
16:44:54:WU00:FS00:0xa7: On Battery: false
16:44:54:WU00:FS00:0xa7: UTC Offset: 7
16:44:54:WU00:FS00:0xa7:        PID: 9804
16:44:54:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
16:44:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:44:54:WU00:FS00:0xa7:    Version: 0.0.19
16:44:54:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:44:57:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:44:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:44:59:WU00:FS00:0xa7:       Date: Nov 25 2019
16:45:01:WU00:FS00:0xa7:       Time: 17:12:41
16:45:02:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
16:45:04:WU00:FS00:0xa7:     Branch: master
16:45:05:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:45:05:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:45:06:WU00:FS00:0xa7:   Platform: win32 10
16:45:07:WU00:FS00:0xa7:       Bits: 64
16:45:07:WU00:FS00:0xa7:       Mode: Release
16:45:08:WU00:FS00:0xa7:************************************ Build *************************************
16:45:10:WU00:FS00:0xa7:       SIMD: avx_256
16:45:11:WU00:FS00:0xa7:********************************************************************************
16:45:13:WU00:FS00:0xa7:Project: 17413 (Run 0, Clone 302, Gen 540)
16:45:14:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
16:45:16:WU00:FS00:0xa7:Digital signatures verified
16:45:17:WU00:FS00:0xa7:Calling: mdrun -s frame540.tpr -o frame540.trr -x frame540.xtc -cpt 15 -nt 2
16:53:51:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
17:03:51:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
17:03:58:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:03:59:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
17:03:59:WARNING:WU00:FS00:Too many errors, failing
17:04:01:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:17413 run:0 clone:302 gen:540 core:0xa7 unit:0x0000012e0000021c0000440500000000
17:04:02:WU00:FS00:Connecting to 66.170.111.50:8080
17:04:03:WU01:FS00:Connecting to assign1.foldingathome.org:80
17:04:04:WU00:FS00:Server responded WORK_ACK (400)
17:04:04:WU00:FS00:Cleaning up
17:04:05:WU01:FS00:Assigned to work server 129.32.209.201
17:04:06:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 129.32.209.201
17:04:06:WU01:FS00:Connecting to 129.32.209.201:8080
17:04:08:WU01:FS00:Downloading 6.65MiB
17:04:14:WU01:FS00:Download 67.70%
17:04:16:WU01:FS00:Download complete
17:04:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16927 run:31 clone:236 gen:123 core:0xa7 unit:0x000000ec0000007b0000421f0000001f
17:04:16:WU01:FS00:Starting
17:04:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
17:04:19:WU01:FS00:Started FahCore on PID 11652
17:04:39:WU01:FS00:Core PID:8668
17:04:39:WU01:FS00:FahCore 0xa7 started
17:04:50:WU01:FS00:0xa7:*********************** Log Started 2021-03-10T17:04:50Z ***********************
17:05:02:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:05:13:WU01:FS00:0xa7:       Type: 0xa7
17:05:18:WU01:FS00:0xa7:       Core: Gromacs
17:05:23:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11652 -checkpoint 15 -np
17:05:34:WU01:FS00:0xa7:             2
17:05:39:WU01:FS00:0xa7:************************************ CBang *************************************
17:05:50:WU01:FS00:0xa7:       Date: Nov 27 2019
17:05:56:WU01:FS00:0xa7:       Time: 03:40:09
17:05:59:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
17:06:01:WU01:FS00:0xa7:     Branch: master
17:06:02:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:06:02:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:06:03:WU01:FS00:0xa7:   Platform: win32 10
17:06:05:WU01:FS00:0xa7:       Bits: 64
17:06:06:WU01:FS00:0xa7:       Mode: Release
17:06:06:WU01:FS00:0xa7:************************************ System ************************************
17:06:07:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
17:06:08:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
17:06:09:WU01:FS00:0xa7:       CPUs: 2
17:06:09:WU01:FS00:0xa7:     Memory: 3.89GiB
17:06:10:WU01:FS00:0xa7:Free Memory: 892.35MiB
17:06:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
17:06:11:WU01:FS00:0xa7: OS Version: 6.2
17:06:12:WU01:FS00:0xa7:Has Battery: true
17:06:12:WU01:FS00:0xa7: On Battery: false
17:06:12:WU01:FS00:0xa7: UTC Offset: 7
17:06:13:WU01:FS00:0xa7:        PID: 8668
17:06:13:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
17:06:14:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:06:15:WU01:FS00:0xa7:    Version: 0.0.19
17:06:16:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:06:16:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:06:17:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
17:06:17:WU01:FS00:0xa7:       Date: Nov 25 2019
17:06:18:WU01:FS00:0xa7:       Time: 17:12:41
17:06:18:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
17:06:19:WU01:FS00:0xa7:     Branch: master
17:06:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:06:20:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:06:21:WU01:FS00:0xa7:   Platform: win32 10
17:06:21:WU01:FS00:0xa7:       Bits: 64
17:06:22:WU01:FS00:0xa7:       Mode: Release
17:06:22:WU01:FS00:0xa7:************************************ Build *************************************
17:06:23:WU01:FS00:0xa7:       SIMD: avx_256
17:06:24:WU01:FS00:0xa7:********************************************************************************
17:06:25:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
17:06:25:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
17:06:26:WU01:FS00:0xa7:Reading tar file core.xml
17:06:27:WU01:FS00:0xa7:Reading tar file frame123.tpr
17:06:27:WU01:FS00:0xa7:Digital signatures verified
17:06:28:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
17:09:51:WU01:FS00:0xa7:Steps: first=61500000 total=500000
17:14:46:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
17:24:46:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
17:25:03:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:25:05:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
17:25:06:WU01:FS00:Starting
17:25:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
17:25:08:WU01:FS00:Started FahCore on PID 424
17:25:42:WU01:FS00:Core PID:7820
17:25:42:WU01:FS00:FahCore 0xa7 started
17:26:34:WU01:FS00:0xa7:*********************** Log Started 2021-03-10T17:26:33Z ***********************
17:26:35:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:26:35:WU01:FS00:0xa7:       Type: 0xa7
17:26:40:WU01:FS00:0xa7:       Core: Gromacs
17:26:44:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 424 -checkpoint 15 -np 2
17:26:56:WU01:FS00:0xa7:************************************ CBang *************************************
17:27:07:WU01:FS00:0xa7:       Date: Nov 27 2019
17:27:12:WU01:FS00:0xa7:       Time: 03:40:09
17:27:16:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
17:27:24:WU01:FS00:0xa7:     Branch: master
17:27:29:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:27:34:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:27:43:WU01:FS00:0xa7:   Platform: win32 10
17:27:47:WU01:FS00:0xa7:       Bits: 64
17:27:51:WU01:FS00:0xa7:       Mode: Release
17:27:56:WU01:FS00:0xa7:************************************ System ************************************
17:27:57:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
17:27:58:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
17:27:59:WU01:FS00:0xa7:       CPUs: 2
17:27:59:WU01:FS00:0xa7:     Memory: 3.89GiB
17:28:00:WU01:FS00:0xa7:Free Memory: 848.80MiB
17:28:00:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
17:28:01:WU01:FS00:0xa7: OS Version: 6.2
17:28:01:WU01:FS00:0xa7:Has Battery: true
17:28:02:WU01:FS00:0xa7: On Battery: false
17:28:02:WU01:FS00:0xa7: UTC Offset: 7
17:28:03:WU01:FS00:0xa7:        PID: 7820
17:28:03:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
17:28:04:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:28:05:WU01:FS00:0xa7:    Version: 0.0.19
17:28:06:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:28:06:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:28:07:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
17:28:08:WU01:FS00:0xa7:       Date: Nov 25 2019
17:28:08:WU01:FS00:0xa7:       Time: 17:12:41
17:28:09:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
17:28:09:WU01:FS00:0xa7:     Branch: master
17:28:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:28:10:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:28:11:WU01:FS00:0xa7:   Platform: win32 10
17:28:11:WU01:FS00:0xa7:       Bits: 64
17:28:12:WU01:FS00:0xa7:       Mode: Release
17:28:12:WU01:FS00:0xa7:************************************ Build *************************************
17:28:17:WU01:FS00:0xa7:       SIMD: avx_256
17:28:18:WU01:FS00:0xa7:********************************************************************************
17:28:19:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
17:28:20:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
17:28:20:WU01:FS00:0xa7:Reading tar file core.xml
17:28:21:WU01:FS00:0xa7:Reading tar file frame123.tpr
17:28:21:WU01:FS00:0xa7:Digital signatures verified
17:28:24:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
17:31:13:WU01:FS00:0xa7:Steps: first=61500000 total=500000
17:36:13:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
17:46:13:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
17:46:23:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:46:35:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
17:46:43:WU01:FS00:Starting
17:46:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
17:47:12:WU01:FS00:Started FahCore on PID 8844
17:47:25:WU01:FS00:Core PID:9344
17:47:25:WU01:FS00:FahCore 0xa7 started
17:47:42:WU01:FS00:0xa7:*********************** Log Started 2021-03-10T17:47:42Z ***********************
17:47:43:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:47:44:WU01:FS00:0xa7:       Type: 0xa7
17:47:45:WU01:FS00:0xa7:       Core: Gromacs
17:47:45:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8844 -checkpoint 15 -np 2
17:47:47:WU01:FS00:0xa7:************************************ CBang *************************************
17:47:48:WU01:FS00:0xa7:       Date: Nov 27 2019
17:47:48:WU01:FS00:0xa7:       Time: 03:40:09
17:47:49:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
17:47:50:WU01:FS00:0xa7:     Branch: master
17:47:51:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:47:51:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:47:51:WU01:FS00:0xa7:   Platform: win32 10
17:47:52:WU01:FS00:0xa7:       Bits: 64
17:47:53:WU01:FS00:0xa7:       Mode: Release
17:47:53:WU01:FS00:0xa7:************************************ System ************************************
17:47:54:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
17:47:55:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
17:47:55:WU01:FS00:0xa7:       CPUs: 2
17:47:56:WU01:FS00:0xa7:     Memory: 3.89GiB
17:47:56:WU01:FS00:0xa7:Free Memory: 825.01MiB
17:47:57:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
17:47:57:WU01:FS00:0xa7: OS Version: 6.2
17:47:58:WU01:FS00:0xa7:Has Battery: true
17:47:58:WU01:FS00:0xa7: On Battery: false
17:47:58:WU01:FS00:0xa7: UTC Offset: 7
17:47:58:WU01:FS00:0xa7:        PID: 9344
17:47:58:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
17:47:58:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:47:58:WU01:FS00:0xa7:    Version: 0.0.19
17:47:59:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:48:00:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:48:02:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
17:48:03:WU01:FS00:0xa7:       Date: Nov 25 2019
17:48:03:WU01:FS00:0xa7:       Time: 17:12:41
17:48:04:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
17:48:04:WU01:FS00:0xa7:     Branch: master
17:48:05:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:48:06:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:48:07:WU01:FS00:0xa7:   Platform: win32 10
17:48:08:WU01:FS00:0xa7:       Bits: 64
17:48:08:WU01:FS00:0xa7:       Mode: Release
17:48:08:WU01:FS00:0xa7:************************************ Build *************************************
17:48:09:WU01:FS00:0xa7:       SIMD: avx_256
17:48:10:WU01:FS00:0xa7:********************************************************************************
17:48:11:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
17:48:12:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
17:48:12:WU01:FS00:0xa7:Reading tar file core.xml
17:48:13:WU01:FS00:0xa7:Reading tar file frame123.tpr
17:48:45:WU01:FS00:0xa7:Digital signatures verified
17:48:50:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
17:50:56:WU01:FS00:0xa7:Steps: first=61500000 total=500000
17:57:42:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
18:07:42:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
18:07:49:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:07:50:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
18:07:52:WU01:FS00:Starting
18:07:52:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
18:07:54:WU01:FS00:Started FahCore on PID 12892
18:08:27:WU01:FS00:Core PID:10456
18:08:28:WU01:FS00:FahCore 0xa7 started
18:08:33:WU01:FS00:0xa7:*********************** Log Started 2021-03-10T18:08:33Z ***********************
18:08:34:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:08:35:WU01:FS00:0xa7:       Type: 0xa7
18:08:36:WU01:FS00:0xa7:       Core: Gromacs
18:08:36:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12892 -checkpoint 15 -np
18:08:37:WU01:FS00:0xa7:             2
18:08:37:WU01:FS00:0xa7:************************************ CBang *************************************
18:08:38:WU01:FS00:0xa7:       Date: Nov 27 2019
18:08:39:WU01:FS00:0xa7:       Time: 03:40:09
18:08:39:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
18:08:40:WU01:FS00:0xa7:     Branch: master
18:08:41:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
18:08:41:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:08:42:WU01:FS00:0xa7:   Platform: win32 10
18:08:42:WU01:FS00:0xa7:       Bits: 64
18:08:43:WU01:FS00:0xa7:       Mode: Release
18:08:43:WU01:FS00:0xa7:************************************ System ************************************
18:08:44:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
18:08:46:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
18:08:46:WU01:FS00:0xa7:       CPUs: 2
18:08:47:WU01:FS00:0xa7:     Memory: 3.89GiB
18:08:47:WU01:FS00:0xa7:Free Memory: 823.95MiB
18:08:48:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
18:08:49:WU01:FS00:0xa7: OS Version: 6.2
18:08:49:WU01:FS00:0xa7:Has Battery: true
18:08:49:WU01:FS00:0xa7: On Battery: false
18:08:50:WU01:FS00:0xa7: UTC Offset: 7
18:08:51:WU01:FS00:0xa7:        PID: 10456
18:08:51:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
18:08:53:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
18:08:54:WU01:FS00:0xa7:    Version: 0.0.19
18:08:54:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:08:55:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:08:56:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
18:08:56:WU01:FS00:0xa7:       Date: Nov 25 2019
18:08:57:WU01:FS00:0xa7:       Time: 17:12:41
18:08:57:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
18:08:58:WU01:FS00:0xa7:     Branch: master
18:08:59:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
18:08:59:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:09:00:WU01:FS00:0xa7:   Platform: win32 10
18:09:01:WU01:FS00:0xa7:       Bits: 64
18:09:01:WU01:FS00:0xa7:       Mode: Release
18:09:01:WU01:FS00:0xa7:************************************ Build *************************************
18:09:03:WU01:FS00:0xa7:       SIMD: avx_256
18:09:03:WU01:FS00:0xa7:********************************************************************************
18:09:04:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
18:09:05:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
18:09:06:WU01:FS00:0xa7:Reading tar file core.xml
18:09:06:WU01:FS00:0xa7:Reading tar file frame123.tpr
18:09:07:WU01:FS00:0xa7:Digital signatures verified
18:09:07:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
18:10:58:WU01:FS00:0xa7:Steps: first=61500000 total=500000
18:18:34:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
18:27:57:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
18:28:35:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
18:28:44:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:28:45:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
18:28:46:WU01:FS00:Starting
18:28:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
18:28:46:WU01:FS00:Started FahCore on PID 14048
18:28:59:WU01:FS00:Core PID:3484
18:28:59:WU01:FS00:FahCore 0xa7 started
18:29:49:WU01:FS00:0xa7:*********************** Log Started 2021-03-10T18:29:48Z ***********************
18:30:01:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:30:13:WU01:FS00:0xa7:       Type: 0xa7
18:30:17:WU01:FS00:0xa7:       Core: Gromacs
18:30:23:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14048 -checkpoint 15 -np
18:30:34:WU01:FS00:0xa7:             2
18:30:39:WU01:FS00:0xa7:************************************ CBang *************************************
18:30:49:WU01:FS00:0xa7:       Date: Nov 27 2019
18:30:54:WU01:FS00:0xa7:       Time: 03:40:09
18:30:59:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
18:31:07:WU01:FS00:0xa7:     Branch: master
18:31:07:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
18:31:08:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:31:09:WU01:FS00:0xa7:   Platform: win32 10
18:31:09:WU01:FS00:0xa7:       Bits: 64
18:31:10:WU01:FS00:0xa7:       Mode: Release
18:31:11:WU01:FS00:0xa7:************************************ System ************************************
18:31:12:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
18:31:12:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
18:31:13:WU01:FS00:0xa7:       CPUs: 2
18:31:14:WU01:FS00:0xa7:     Memory: 3.89GiB
18:31:14:WU01:FS00:0xa7:Free Memory: 800.58MiB
18:31:15:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
18:31:15:WU01:FS00:0xa7: OS Version: 6.2
18:31:16:WU01:FS00:0xa7:Has Battery: true
18:31:16:WU01:FS00:0xa7: On Battery: false
18:31:17:WU01:FS00:0xa7: UTC Offset: 7
18:31:17:WU01:FS00:0xa7:        PID: 3484
18:31:17:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
18:31:19:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
18:31:19:WU01:FS00:0xa7:    Version: 0.0.19
18:31:20:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:31:21:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:31:21:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
18:31:22:WU01:FS00:0xa7:       Date: Nov 25 2019
18:31:22:WU01:FS00:0xa7:       Time: 17:12:41
18:31:23:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
18:31:24:WU01:FS00:0xa7:     Branch: master
18:31:24:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
18:31:24:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:31:25:WU01:FS00:0xa7:   Platform: win32 10
18:31:25:WU01:FS00:0xa7:       Bits: 64
18:31:26:WU01:FS00:0xa7:       Mode: Release
18:31:26:WU01:FS00:0xa7:************************************ Build *************************************
18:31:27:WU01:FS00:0xa7:       SIMD: avx_256
18:31:28:WU01:FS00:0xa7:********************************************************************************
18:31:29:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
18:31:29:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
18:31:30:WU01:FS00:0xa7:Digital signatures verified
18:31:31:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
18:32:28:WU01:FS00:0xa7:Steps: first=61500000 total=500000
18:39:49:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
18:49:49:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
******************************* Date: 2021-03-11 *******************************
01:47:36:218:127.0.0.1:New Web session
01:49:14:224:127.0.0.1:New Web session
03:41:16:FS00:Paused
03:41:16:FS00:Shutting core down
03:42:12:Removing old file 'configs/config-20210210-015130.xml'
03:42:12:Saving configuration to config.xml
03:42:12:<config>
03:42:12:  <!-- Folding Slot Configuration -->
03:42:12:  <cause v='COVID_19'/>
03:42:12:
03:42:12:  <!-- Network -->
03:42:12:  <proxy v=':8080'/>
03:42:12:
03:42:12:  <!-- Slot Control -->
03:42:12:  <pause-on-battery v='false'/>
03:42:12:  <power v='full'/>
03:42:12:
03:42:12:  <!-- User Information -->
03:42:12:  <passkey v='*****'/>
03:42:12:  <user v='afkar_aulia'/>
03:42:12:
03:42:12:  <!-- Folding Slots -->
03:42:12:  <slot id='0' type='CPU'>
03:42:12:    <paused v='true'/>
03:42:12:  </slot>
03:42:12:</config>
03:42:18:WARNING:FS00:Killing WU01
03:42:19:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:42:34:FS00:Unpaused
03:42:34:WU01:FS00:Starting
03:42:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
03:42:38:WU01:FS00:Started FahCore on PID 2952
03:43:03:WU01:FS00:Core PID:5956
03:43:03:WU01:FS00:FahCore 0xa7 started
03:43:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:43:13:Removing old file 'configs/config-20210210-062055.xml'
03:43:15:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T03:43:15Z ***********************
03:43:16:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:43:16:WU01:FS00:0xa7:       Type: 0xa7
03:43:16:WU01:FS00:0xa7:       Core: Gromacs
03:43:16:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2952 -checkpoint 15 -np 2
03:43:16:Saving configuration to config.xml
03:43:16:WU01:FS00:0xa7:************************************ CBang *************************************
03:43:16:<config>
03:43:16:WU01:FS00:0xa7:       Date: Nov 27 2019
03:43:16:  <!-- Folding Slot Configuration -->
03:43:16:WU01:FS00:0xa7:       Time: 03:40:09
03:43:16:  <cause v='COVID_19'/>
03:43:16:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:43:16:
03:43:16:WU01:FS00:0xa7:     Branch: master
03:43:16:  <!-- Network -->
03:43:16:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:43:16:  <proxy v=':8080'/>
03:43:16:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:43:16:
03:43:16:WU01:FS00:0xa7:   Platform: win32 10
03:43:16:  <!-- Slot Control -->
03:43:16:WU01:FS00:0xa7:       Bits: 64
03:43:16:  <pause-on-battery v='false'/>
03:43:16:WU01:FS00:0xa7:       Mode: Release
03:43:16:  <power v='full'/>
03:43:16:WU01:FS00:0xa7:************************************ System ************************************
03:43:16:
03:43:16:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
03:43:16:  <!-- User Information -->
03:43:17:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
03:43:16:  <passkey v='*****'/>
03:43:17:WU01:FS00:0xa7:       CPUs: 2
03:43:16:  <user v='afkar_aulia'/>
03:43:17:WU01:FS00:0xa7:     Memory: 3.89GiB
03:43:16:
03:43:17:WU01:FS00:0xa7:Free Memory: 741.66MiB
03:43:16:  <!-- Folding Slots -->
03:43:17:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:43:16:  <slot id='0' type='CPU'/>
03:43:18:WU01:FS00:0xa7: OS Version: 6.2
03:43:16:</config>
03:43:18:WU01:FS00:0xa7:Has Battery: true
03:43:18:WU01:FS00:0xa7: On Battery: false
03:43:18:WU01:FS00:0xa7: UTC Offset: 7
03:43:18:WU01:FS00:0xa7:        PID: 5956
03:43:18:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
03:43:18:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:43:18:WU01:FS00:0xa7:    Version: 0.0.19
03:43:18:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:43:18:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:43:18:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:43:21:WU01:FS00:0xa7:       Date: Nov 25 2019
03:43:24:WU01:FS00:0xa7:       Time: 17:12:41
03:43:26:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:43:33:WU01:FS00:0xa7:     Branch: master
03:43:37:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:43:41:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:43:47:WU01:FS00:0xa7:   Platform: win32 10
03:43:52:WU01:FS00:0xa7:       Bits: 64
03:43:56:WU01:FS00:0xa7:       Mode: Release
03:43:59:WU01:FS00:0xa7:************************************ Build *************************************
03:44:04:WU01:FS00:0xa7:       SIMD: avx_256
03:44:06:WU01:FS00:0xa7:********************************************************************************
03:44:12:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
03:44:14:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
03:44:16:WU01:FS00:0xa7:Digital signatures verified
03:44:17:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
03:53:10:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
04:03:10:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
04:03:16:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
04:03:29:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
04:03:34:WU01:FS00:Starting
04:03:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
04:03:46:WU01:FS00:Started FahCore on PID 4916
04:04:10:WU01:FS00:Core PID:14996
04:04:13:WU01:FS00:FahCore 0xa7 started
04:04:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:04:21:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T04:04:20Z ***********************
04:04:24:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:04:29:WU01:FS00:0xa7:       Type: 0xa7
04:04:31:WU01:FS00:0xa7:       Core: Gromacs
04:04:34:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4916 -checkpoint 15 -np 2
04:04:41:WU01:FS00:0xa7:************************************ CBang *************************************
04:04:47:WU01:FS00:0xa7:       Date: Nov 27 2019
04:04:49:WU01:FS00:0xa7:       Time: 03:40:09
04:04:51:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
04:04:53:WU01:FS00:0xa7:     Branch: master
04:04:56:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:04:59:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:05:04:WU01:FS00:0xa7:   Platform: win32 10
04:05:06:WU01:FS00:0xa7:       Bits: 64
04:05:08:WU01:FS00:0xa7:       Mode: Release
04:05:09:WU01:FS00:0xa7:************************************ System ************************************
04:05:14:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
04:05:16:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
04:05:20:WU01:FS00:0xa7:       CPUs: 2
04:05:21:WU01:FS00:0xa7:     Memory: 3.89GiB
04:05:26:WU01:FS00:0xa7:Free Memory: 729.99MiB
04:05:29:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
04:05:31:WU01:FS00:0xa7: OS Version: 6.2
04:05:33:WU01:FS00:0xa7:Has Battery: true
04:05:38:WU01:FS00:0xa7: On Battery: false
04:05:41:WU01:FS00:0xa7: UTC Offset: 7
04:05:42:WU01:FS00:0xa7:        PID: 14996
04:05:43:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
04:05:47:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
04:05:50:WU01:FS00:0xa7:    Version: 0.0.19
04:05:52:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:05:59:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:06:02:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
04:06:05:WU01:FS00:0xa7:       Date: Nov 25 2019
04:06:06:WU01:FS00:0xa7:       Time: 17:12:41
04:06:07:273:127.0.0.1:New Web session
04:06:09:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
04:06:12:WU01:FS00:0xa7:     Branch: master
04:06:12:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:06:12:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:06:12:WU01:FS00:0xa7:   Platform: win32 10
04:06:12:WU01:FS00:0xa7:       Bits: 64
04:06:12:WU01:FS00:0xa7:       Mode: Release
04:06:12:WU01:FS00:0xa7:************************************ Build *************************************
04:06:12:WU01:FS00:0xa7:       SIMD: avx_256
04:06:12:WU01:FS00:0xa7:********************************************************************************
04:06:12:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
04:06:13:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
04:06:15:WU01:FS00:0xa7:Digital signatures verified
04:06:16:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
04:14:17:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
04:24:17:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
04:24:19:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
04:24:24:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
04:24:26:WU01:FS00:Starting
04:24:26:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
04:24:26:WU01:FS00:Started FahCore on PID 8624
04:24:47:WU01:FS00:Core PID:12356
04:24:47:WU01:FS00:FahCore 0xa7 started
04:24:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:24:53:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T04:24:53Z ***********************
04:25:02:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:25:08:WU01:FS00:0xa7:       Type: 0xa7
04:25:09:WU01:FS00:0xa7:       Core: Gromacs
04:25:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8624 -checkpoint 15 -np 2
04:25:15:WU01:FS00:0xa7:************************************ CBang *************************************
04:25:18:WU01:FS00:0xa7:       Date: Nov 27 2019
04:25:19:WU01:FS00:0xa7:       Time: 03:40:09
04:25:21:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
04:25:24:WU01:FS00:0xa7:     Branch: master
04:25:27:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:25:29:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:25:33:WU01:FS00:0xa7:   Platform: win32 10
04:25:34:WU01:FS00:0xa7:       Bits: 64
04:25:36:WU01:FS00:0xa7:       Mode: Release
04:25:37:WU01:FS00:0xa7:************************************ System ************************************
04:25:43:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
04:25:45:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
04:25:46:WU01:FS00:0xa7:       CPUs: 2
04:25:48:WU01:FS00:0xa7:     Memory: 3.89GiB
04:25:51:WU01:FS00:0xa7:Free Memory: 1.09GiB
04:25:53:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
04:25:54:WU01:FS00:0xa7: OS Version: 6.2
04:25:55:WU01:FS00:0xa7:Has Battery: true
04:25:56:WU01:FS00:0xa7: On Battery: false
04:25:57:WU01:FS00:0xa7: UTC Offset: 7
04:25:59:WU01:FS00:0xa7:        PID: 12356
04:26:00:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
04:26:03:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
04:26:07:WU01:FS00:0xa7:    Version: 0.0.19
04:26:08:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:26:11:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:26:12:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
04:26:16:WU01:FS00:0xa7:       Date: Nov 25 2019
04:26:17:WU01:FS00:0xa7:       Time: 17:12:41
04:26:17:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
04:26:19:WU01:FS00:0xa7:     Branch: master
04:26:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:26:21:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:26:25:WU01:FS00:0xa7:   Platform: win32 10
04:26:26:WU01:FS00:0xa7:       Bits: 64
04:26:28:WU01:FS00:0xa7:       Mode: Release
04:26:30:WU01:FS00:0xa7:************************************ Build *************************************
04:26:33:WU01:FS00:0xa7:       SIMD: avx_256
04:26:35:WU01:FS00:0xa7:********************************************************************************
04:26:49:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
04:26:56:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
04:27:03:WU01:FS00:0xa7:Digital signatures verified
04:27:10:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
04:34:54:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
04:45:00:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
04:45:03:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
04:45:10:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
04:45:14:WU01:FS00:Starting
04:45:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
04:45:29:WU01:FS00:Started FahCore on PID 13440
04:45:49:WU01:FS00:Core PID:9168
04:45:49:WU01:FS00:FahCore 0xa7 started
04:45:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:46:07:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T04:46:07Z ***********************
04:46:10:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:46:13:WU01:FS00:0xa7:       Type: 0xa7
04:46:15:WU01:FS00:0xa7:       Core: Gromacs
04:46:17:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 13440 -checkpoint 15 -np
04:46:23:WU01:FS00:0xa7:             2
04:46:26:WU01:FS00:0xa7:************************************ CBang *************************************
04:46:30:WU01:FS00:0xa7:       Date: Nov 27 2019
04:46:37:WU01:FS00:0xa7:       Time: 03:40:09
04:46:41:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
04:46:51:WU01:FS00:0xa7:     Branch: master
04:46:54:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:46:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:47:09:WU01:FS00:0xa7:   Platform: win32 10
04:47:16:WU01:FS00:0xa7:       Bits: 64
04:47:23:WU01:FS00:0xa7:       Mode: Release
04:47:31:WU01:FS00:0xa7:************************************ System ************************************
04:47:51:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
04:48:04:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
04:48:13:WU01:FS00:0xa7:       CPUs: 2
04:48:17:WU01:FS00:0xa7:     Memory: 3.89GiB
04:48:24:WU01:FS00:0xa7:Free Memory: 680.35MiB
04:48:31:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
04:48:35:WU01:FS00:0xa7: OS Version: 6.2
04:48:37:WU01:FS00:0xa7:Has Battery: true
04:48:39:WU01:FS00:0xa7: On Battery: false
04:48:42:WU01:FS00:0xa7: UTC Offset: 7
04:48:45:WU01:FS00:0xa7:        PID: 9168
04:48:46:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
04:48:49:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
04:48:56:WU01:FS00:0xa7:    Version: 0.0.19
04:48:58:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:49:03:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:49:06:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
04:49:08:WU01:FS00:0xa7:       Date: Nov 25 2019
04:49:12:WU01:FS00:0xa7:       Time: 17:12:41
04:49:14:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
04:49:18:WU01:FS00:0xa7:     Branch: master
04:49:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:49:23:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:49:25:WU01:FS00:0xa7:   Platform: win32 10
04:49:26:WU01:FS00:0xa7:       Bits: 64
04:49:27:WU01:FS00:0xa7:       Mode: Release
04:49:31:WU01:FS00:0xa7:************************************ Build *************************************
04:49:38:WU01:FS00:0xa7:       SIMD: avx_256
04:49:39:WU01:FS00:0xa7:********************************************************************************
04:49:45:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
04:49:47:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
04:49:49:WU01:FS00:0xa7:Digital signatures verified
04:49:51:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
04:53:46:292:127.0.0.1:New Web session
04:56:02:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
05:06:03:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
05:06:09:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
05:06:20:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
05:06:22:WU01:FS00:Starting
05:06:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
05:06:22:WU01:FS00:Started FahCore on PID 2748
05:06:38:WU01:FS00:Core PID:13300
05:06:38:WU01:FS00:FahCore 0xa7 started
05:06:50:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T05:06:50Z ***********************
05:06:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:06:56:WU01:FS00:0xa7:       Type: 0xa7
05:07:01:WU01:FS00:0xa7:       Core: Gromacs
05:07:04:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2748 -checkpoint 15 -np 2
05:07:13:WU01:FS00:0xa7:************************************ CBang *************************************
05:07:22:WU01:FS00:0xa7:       Date: Nov 27 2019
05:07:27:WU01:FS00:0xa7:       Time: 03:40:09
05:07:33:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
05:07:41:WU01:FS00:0xa7:     Branch: master
05:07:44:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
05:07:49:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:07:59:WU01:FS00:0xa7:   Platform: win32 10
05:08:04:WU01:FS00:0xa7:       Bits: 64
05:08:06:WU01:FS00:0xa7:       Mode: Release
05:08:08:WU01:FS00:0xa7:************************************ System ************************************
05:08:15:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
05:08:18:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
05:08:22:WU01:FS00:0xa7:       CPUs: 2
05:08:24:WU01:FS00:0xa7:     Memory: 3.89GiB
05:08:25:WU01:FS00:0xa7:Free Memory: 616.92MiB
05:08:26:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
05:08:27:WU01:FS00:0xa7: OS Version: 6.2
05:08:27:WU01:FS00:0xa7:Has Battery: true
05:08:28:WU01:FS00:0xa7: On Battery: false
05:08:28:WU01:FS00:0xa7: UTC Offset: 7
05:08:29:WU01:FS00:0xa7:        PID: 13300
05:08:29:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
05:08:32:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
05:08:36:WU01:FS00:0xa7:    Version: 0.0.19
05:08:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:08:37:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:08:38:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
05:08:41:WU01:FS00:0xa7:       Date: Nov 25 2019
05:08:43:WU01:FS00:0xa7:       Time: 17:12:41
05:08:44:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
05:08:47:WU01:FS00:0xa7:     Branch: master
05:08:47:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
05:08:49:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:08:53:WU01:FS00:0xa7:   Platform: win32 10
05:08:54:WU01:FS00:0xa7:       Bits: 64
05:08:55:WU01:FS00:0xa7:       Mode: Release
05:09:00:WU01:FS00:0xa7:************************************ Build *************************************
05:09:06:WU01:FS00:0xa7:       SIMD: avx_256
05:09:06:WU01:FS00:0xa7:********************************************************************************
05:09:07:WU01:FS00:0xa7:Project: 16927 (Run 31, Clone 236, Gen 123)
05:09:08:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
05:09:08:WU01:FS00:0xa7:Digital signatures verified
05:09:09:WU01:FS00:0xa7:Calling: mdrun -s frame123.tpr -o frame123.trr -cpt 15 -nt 2
05:16:51:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
05:21:39:WU01:FS00:0xa7:Steps: first=61500000 total=500000
05:26:51:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
05:26:59:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
05:27:08:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
05:27:13:WARNING:WU01:FS00:Too many errors, failing
05:27:17:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:16927 run:31 clone:236 gen:123 core:0xa7 unit:0x000000ec0000007b0000421f0000001f
05:27:30:WU01:FS00:Connecting to 129.32.209.201:8080
05:27:31:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:27:35:WU01:FS00:Server responded WORK_ACK (400)
05:27:40:WU01:FS00:Cleaning up
05:27:45:WU00:FS00:Assigned to work server 155.247.166.219
05:27:51:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.219
05:28:00:WU00:FS00:Connecting to 155.247.166.219:8080
05:28:07:WU00:FS00:Downloading 3.13MiB
05:28:16:WU00:FS00:Download 99.77%
05:28:16:WU00:FS00:Download complete
05:28:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14188 run:0 clone:1416 gen:17 core:0xa7 unit:0x00000588000000110000376c00000000
05:28:16:WU00:FS00:Starting
05:28:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
05:28:19:WU00:FS00:Started FahCore on PID 13560
05:28:41:WU00:FS00:Core PID:10428
05:28:41:WU00:FS00:FahCore 0xa7 started
05:28:52:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T05:28:52Z ***********************
05:28:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:28:54:WU00:FS00:0xa7:       Type: 0xa7
05:28:54:WU00:FS00:0xa7:       Core: Gromacs
05:28:55:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13560 -checkpoint 15 -np
05:28:56:WU00:FS00:0xa7:             2
05:28:56:WU00:FS00:0xa7:************************************ CBang *************************************
05:28:57:WU00:FS00:0xa7:       Date: Nov 27 2019
05:28:58:WU00:FS00:0xa7:       Time: 03:40:09
05:28:58:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
05:28:59:WU00:FS00:0xa7:     Branch: master
05:29:00:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:29:00:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:29:00:WU00:FS00:0xa7:   Platform: win32 10
05:29:01:WU00:FS00:0xa7:       Bits: 64
05:29:01:WU00:FS00:0xa7:       Mode: Release
05:29:01:WU00:FS00:0xa7:************************************ System ************************************
05:29:02:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
05:29:03:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
05:29:04:WU00:FS00:0xa7:       CPUs: 2
05:29:04:WU00:FS00:0xa7:     Memory: 3.89GiB
05:29:05:WU00:FS00:0xa7:Free Memory: 838.79MiB
05:29:05:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:29:06:WU00:FS00:0xa7: OS Version: 6.2
05:29:06:WU00:FS00:0xa7:Has Battery: true
05:29:06:WU00:FS00:0xa7: On Battery: true
05:29:07:WU00:FS00:0xa7: UTC Offset: 7
05:29:07:WU00:FS00:0xa7:        PID: 10428
05:29:08:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
05:29:09:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:29:13:WU00:FS00:0xa7:    Version: 0.0.19
05:29:14:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:29:14:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:29:15:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:29:15:WU00:FS00:0xa7:       Date: Nov 25 2019
05:29:16:WU00:FS00:0xa7:       Time: 17:12:41
05:29:16:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
05:29:17:WU00:FS00:0xa7:     Branch: master
05:29:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:29:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:29:20:WU00:FS00:0xa7:   Platform: win32 10
05:29:20:WU00:FS00:0xa7:       Bits: 64
05:29:21:WU00:FS00:0xa7:       Mode: Release
05:29:21:WU00:FS00:0xa7:************************************ Build *************************************
05:29:22:WU00:FS00:0xa7:       SIMD: avx_256
05:29:23:WU00:FS00:0xa7:********************************************************************************
05:29:24:WU00:FS00:0xa7:Project: 14188 (Run 0, Clone 1416, Gen 17)
05:29:25:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
05:29:25:WU00:FS00:0xa7:Reading tar file core.xml
05:29:26:WU00:FS00:0xa7:Reading tar file frame17.tpr
05:32:53:WU00:FS00:0xa7:Digital signatures verified
05:32:55:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 2
05:38:48:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
05:42:38:WU00:FS00:0xa7:Steps: first=21250000 total=1250000
05:48:48:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
05:48:57:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
05:48:57:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
afkar.aulia
Re: WU stalled twice in a single day but WORK_ACK(400)
05:48:58:WU00:FS00:Starting
05:48:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
05:49:00:WU00:FS00:Started FahCore on PID 9448
05:49:27:WU00:FS00:Core PID:720
05:49:27:WU00:FS00:FahCore 0xa7 started
05:49:48:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T05:49:47Z ***********************
05:49:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:49:50:WU00:FS00:0xa7:       Type: 0xa7
05:49:51:WU00:FS00:0xa7:       Core: Gromacs
05:49:51:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9448 -checkpoint 15 -np 2
05:49:52:WU00:FS00:0xa7:************************************ CBang *************************************
05:49:53:WU00:FS00:0xa7:       Date: Nov 27 2019
05:49:53:WU00:FS00:0xa7:       Time: 03:40:09
05:49:54:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
05:49:55:WU00:FS00:0xa7:     Branch: master
05:49:56:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:49:56:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:49:59:WU00:FS00:0xa7:   Platform: win32 10
05:50:00:WU00:FS00:0xa7:       Bits: 64
05:50:00:WU00:FS00:0xa7:       Mode: Release
05:50:01:WU00:FS00:0xa7:************************************ System ************************************
05:50:02:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
05:50:02:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
05:50:03:WU00:FS00:0xa7:       CPUs: 2
05:50:04:WU00:FS00:0xa7:     Memory: 3.89GiB
05:50:04:WU00:FS00:0xa7:Free Memory: 839.26MiB
05:50:05:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:50:05:WU00:FS00:0xa7: OS Version: 6.2
05:50:06:WU00:FS00:0xa7:Has Battery: true
05:50:06:WU00:FS00:0xa7: On Battery: true
05:50:06:WU00:FS00:0xa7: UTC Offset: 7
05:50:06:WU00:FS00:0xa7:        PID: 720
05:50:07:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
05:50:08:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:50:08:WU00:FS00:0xa7:    Version: 0.0.19
05:50:10:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:50:11:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:50:11:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:50:12:WU00:FS00:0xa7:       Date: Nov 25 2019
05:50:13:WU00:FS00:0xa7:       Time: 17:12:41
05:50:13:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
05:50:13:WU00:FS00:0xa7:     Branch: master
05:50:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:50:17:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:50:19:WU00:FS00:0xa7:   Platform: win32 10
05:50:19:WU00:FS00:0xa7:       Bits: 64
05:50:20:WU00:FS00:0xa7:       Mode: Release
05:50:20:WU00:FS00:0xa7:************************************ Build *************************************
05:50:21:WU00:FS00:0xa7:       SIMD: avx_256
05:50:21:WU00:FS00:0xa7:********************************************************************************
05:50:22:WU00:FS00:0xa7:Project: 14188 (Run 0, Clone 1416, Gen 17)
05:50:23:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
05:50:23:WU00:FS00:0xa7:Reading tar file core.xml
05:50:24:WU00:FS00:0xa7:Reading tar file frame17.tpr
05:56:22:WU00:FS00:0xa7:Digital signatures verified
05:56:23:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 2
05:59:46:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
06:00:53:WU00:FS00:0xa7:Steps: first=21250000 total=1250000
06:09:46:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
06:10:10:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:10:11:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
06:10:12:WU00:FS00:Starting
06:10:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
06:10:12:WU00:FS00:Started FahCore on PID 5952
06:10:34:WU00:FS00:Core PID:9648
06:10:34:WU00:FS00:FahCore 0xa7 started
06:11:12:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T06:11:11Z ***********************
06:11:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:11:19:WU00:FS00:0xa7:       Type: 0xa7
06:11:19:WU00:FS00:0xa7:       Core: Gromacs
06:11:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5952 -checkpoint 15 -np 2
06:11:21:WU00:FS00:0xa7:************************************ CBang *************************************
06:11:22:WU00:FS00:0xa7:       Date: Nov 27 2019
06:11:22:WU00:FS00:0xa7:       Time: 03:40:09
06:11:23:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:11:23:WU00:FS00:0xa7:     Branch: master
06:11:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:11:29:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:11:30:WU00:FS00:0xa7:   Platform: win32 10
06:11:31:WU00:FS00:0xa7:       Bits: 64
06:11:31:WU00:FS00:0xa7:       Mode: Release
06:11:31:WU00:FS00:0xa7:************************************ System ************************************
06:11:33:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
06:11:36:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
06:11:38:WU00:FS00:0xa7:       CPUs: 2
06:11:39:WU00:FS00:0xa7:     Memory: 3.89GiB
06:11:39:WU00:FS00:0xa7:Free Memory: 840.98MiB
06:11:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
06:11:41:WU00:FS00:0xa7: OS Version: 6.2
06:11:41:WU00:FS00:0xa7:Has Battery: true
06:11:42:WU00:FS00:0xa7: On Battery: true
06:11:43:WU00:FS00:0xa7: UTC Offset: 7
06:11:43:WU00:FS00:0xa7:        PID: 9648
06:11:43:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
06:11:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:11:45:WU00:FS00:0xa7:    Version: 0.0.19
06:11:45:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:11:46:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:11:46:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:11:47:WU00:FS00:0xa7:       Date: Nov 25 2019
06:11:47:WU00:FS00:0xa7:       Time: 17:12:41
06:11:48:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:11:48:WU00:FS00:0xa7:     Branch: master
06:11:49:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:11:49:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:11:50:WU00:FS00:0xa7:   Platform: win32 10
06:11:51:WU00:FS00:0xa7:       Bits: 64
06:11:52:WU00:FS00:0xa7:       Mode: Release
06:11:52:WU00:FS00:0xa7:************************************ Build *************************************
06:11:53:WU00:FS00:0xa7:       SIMD: avx_256
06:11:54:WU00:FS00:0xa7:********************************************************************************
06:11:55:WU00:FS00:0xa7:Project: 14188 (Run 0, Clone 1416, Gen 17)
06:11:55:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:11:56:WU00:FS00:0xa7:Reading tar file core.xml
06:11:57:WU00:FS00:0xa7:Reading tar file frame17.tpr
06:16:25:WU00:FS00:0xa7:Digital signatures verified
06:16:31:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 2
06:21:10:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
06:24:37:WU00:FS00:0xa7:Steps: first=21250000 total=1250000
06:31:10:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
06:31:20:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:31:20:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
06:31:21:WU00:FS00:Starting
06:31:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
06:31:23:WU00:FS00:Started FahCore on PID 7856
06:31:48:WU00:FS00:Core PID:15020
06:31:48:WU00:FS00:FahCore 0xa7 started
06:32:19:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T06:32:18Z ***********************
06:32:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:32:21:WU00:FS00:0xa7:       Type: 0xa7
06:32:23:WU00:FS00:0xa7:       Core: Gromacs
06:32:24:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7856 -checkpoint 15 -np 2
06:32:25:WU00:FS00:0xa7:************************************ CBang *************************************
06:32:26:WU00:FS00:0xa7:       Date: Nov 27 2019
06:32:26:WU00:FS00:0xa7:       Time: 03:40:09
06:32:27:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:32:27:WU00:FS00:0xa7:     Branch: master
06:32:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:32:34:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:32:37:WU00:FS00:0xa7:   Platform: win32 10
06:32:37:WU00:FS00:0xa7:       Bits: 64
06:32:38:WU00:FS00:0xa7:       Mode: Release
06:32:38:WU00:FS00:0xa7:************************************ System ************************************
06:32:40:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
06:32:41:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
06:32:42:WU00:FS00:0xa7:       CPUs: 2
06:32:42:WU00:FS00:0xa7:     Memory: 3.89GiB
06:32:43:WU00:FS00:0xa7:Free Memory: 864.05MiB
06:32:43:WU00:
06:32:45:WU00:FS00:0xa7: OS Version: 6.2
06:32:45:WU00:FS00:0xa7:Has Battery: true
06:32:46:WU00:FS00:0xa7: On Battery: true
06:32:46:WU00:FS00:0xa7: UTC Offset: 7
06:32:47:WU00:FS00:0xa7:        PID: 15020
06:32:47:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
06:32:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:32:49:WU00:FS00:0xa7:    Version: 0.0.19
06:32:49:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:32:50:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:32:51:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:32:51:WU00:FS00:0xa7:       Date: Nov 25 2019
06:32:52:WU00:FS00:0xa7:       Time: 17:12:41
06:32:52:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:32:52:WU00:FS00:0xa7:     Branch: master
06:32:53:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:32:53:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:32:57:WU00:FS00:0xa7:   Platform: win32 10
06:32:58:WU00:FS00:0xa7:       Bits: 64
06:32:58:WU00:FS00:0xa7:       Mode: Release
06:32:59:WU00:FS00:0xa7:************************************ Build *************************************
06:32:59:WU00:FS00:0xa7:       SIMD: avx_256
06:33:00:WU00:FS00:0xa7:********************************************************************************
06:33:01:WU00:FS00:0xa7:Project: 14188 (Run 0, Clone 1416, Gen 17)
06:33:02:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:33:03:WU00:FS00:0xa7:Reading tar file core.xml
06:33:03:WU00:FS00:0xa7:Reading tar file frame17.tpr
06:37:43:WU00:FS00:0xa7:Digital signatures verified
06:37:46:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 2
06:40:21:WU00:FS00:0xa7:Steps: first=21250000 total=1250000
06:42:14:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
06:52:14:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
06:52:24:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:52:25:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
06:52:26:WU00:FS00:Starting
06:52:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
06:52:27:WU00:FS00:Started FahCore on PID 7012
06:52:51:WU00:FS00:Core PID:11580
06:52:51:WU00:FS00:FahCore 0xa7 started
06:53:09:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T06:53:09Z ***********************
06:53:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:53:12:WU00:FS00:0xa7:       Type: 0xa7
06:53:12:WU00:FS00:0xa7:       Core: Gromacs
06:53:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7012 -checkpoint 15 -np 2
06:53:14:WU00:FS00:0xa7:************************************ CBang *************************************
06:53:16:WU00:FS00:0xa7:       Date: Nov 27 2019
06:53:18:WU00:FS00:0xa7:       Time: 03:40:09
06:53:19:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:53:19:WU00:FS00:0xa7:     Branch: master
06:53:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:53:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:53:21:WU00:FS00:0xa7:   Platform: win32 10
06:53:21:WU00:FS00:0xa7:       Bits: 64
06:53:22:WU00:FS00:0xa7:       Mode: Release
06:53:22:WU00:FS00:0xa7:************************************ System ************************************
06:53:23:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
06:53:24:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
06:53:24:WU00:FS00:0xa7:       CPUs: 2
06:53:25:WU00:FS00:0xa7:     Memory: 3.89GiB
06:53:26:WU00:FS00:0xa7:Free Memory: 771.00MiB
06:53:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
06:53:26:WU00:FS00:0xa7: OS Version: 6.2
06:53:27:WU00:FS00:0xa7:Has Battery: true
06:53:27:WU00:FS00:0xa7: On Battery: true
06:53:28:WU00:FS00:0xa7: UTC Offset: 7
06:53:28:WU00:FS00:0xa7:        PID: 11580
06:53:28:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
06:53:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:53:30:WU00:FS00:0xa7:    Version: 0.0.19
06:53:30:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:53:31:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:53:31:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:53:32:WU00:FS00:0xa7:       Date: Nov 25 2019
06:53:32:WU00:FS00:0xa7:       Time: 17:12:41
06:53:33:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:53:33:WU00:FS00:0xa7:     Branch: master
06:53:34:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:53:34:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:53:35:WU00:FS00:0xa7:   Platform: win32 10
06:53:36:WU00:FS00:0xa7:       Bits: 64
06:53:37:WU00:FS00:0xa7:       Mode: Release
06:53:37:WU00:FS00:0xa7:************************************ Build *************************************
06:53:38:WU00:FS00:0xa7:       SIMD: avx_256
06:53:38:WU00:FS00:0xa7:********************************************************************************
06:53:40:WU00:FS00:0xa7:Project: 14188 (Run 0, Clone 1416, Gen 17)
06:53:40:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:53:41:WU00:FS00:0xa7:Reading tar file core.xml
06:53:42:WU00:FS00:0xa7:Reading tar file frame17.tpr
06:55:15:WU00:FS00:0xa7:Digital signatures verified
06:55:16:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 2
07:02:58:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
07:10:31:WU00:FS00:0xa7:Steps: first=21250000 total=1250000
07:12:58:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
07:13:11:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:13:12:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
07:13:13:WARNING:WU00:FS00:Too many errors, failing
07:13:13:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14188 run:0 clone:1416 gen:17 core:0xa7 unit:0x00000588000000110000376c00000000
07:13:14:WU00:FS00:Connecting to 155.247.166.219:8080
07:13:15:WU01:FS00:Connecting to assign1.foldingathome.org:80
07:13:16:WU00:FS00:Server responded WORK_ACK (400)
07:13:17:WU00:FS00:Cleaning up
07:13:18:WU01:FS00:Assigned to work server 66.170.111.50
07:13:18:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 66.170.111.50
07:13:18:WU01:FS00:Connecting to 66.170.111.50:8080
07:13:19:WU01:FS00:Downloading 7.36MiB
07:13:25:WU01:FS00:Download 60.27%
07:13:28:WU01:FS00:Download complete
07:13:28:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17410 run:0 clone:880 gen:578 core:0xa7 unit:0x00000370000002420000440200000000
07:13:29:WU01:FS00:Starting
07:13:29:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
07:13:31:WU01:FS00:Started FahCore on PID 9484
07:13:51:WU01:FS00:Core PID:5200
07:13:51:WU01:FS00:FahCore 0xa7 started
07:14:55:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T07:14:54Z ***********************
07:14:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:14:59:WU01:FS00:0xa7:       Type: 0xa7
07:14:59:WU01:FS00:0xa7:       Core: Gromacs
07:14:59:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9484 -checkpoint 15 -np 2
07:15:00:WU01:FS00:0xa7:************************************ CBang *************************************
07:15:01:WU01:FS00:0xa7:       Date: Nov 27 2019
07:15:02:WU01:FS00:0xa7:       Time: 03:40:09
07:15:03:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:15:03:WU01:FS00:0xa7:     Branch: master
07:15:03:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:15:04:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:15:04:WU01:FS00:0xa7:   Platform: win32 10
07:15:05:WU01:FS00:0xa7:       Bits: 64
07:15:05:WU01:FS00:0xa7:       Mode: Release
07:15:07:WU01:FS00:0xa7:************************************ System ************************************
07:15:09:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
07:15:09:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
07:15:10:WU01:FS00:0xa7:       CPUs: 2
07:15:10:WU01:FS00:0xa7:     Memory: 3.89GiB
07:15:11:WU01:FS00:0xa7:Free Memory: 739.37MiB
07:15:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
07:15:11:WU01:FS00:0xa7: OS Version: 6.2
07:15:11:WU01:FS00:0xa7:Has Battery: true
07:15:12:WU01:FS00:0xa7: On Battery: false
07:15:12:WU01:FS00:0xa7: UTC Offset: 7
07:15:12:WU01:FS00:0xa7:        PID: 5200
07:15:13:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
07:15:13:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:15:14:WU01:FS00:0xa7:    Version: 0.0.19
07:15:14:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:15:15:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:15:16:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:15:16:WU01:FS00:0xa7:       Date: Nov 25 2019
07:15:16:WU01:FS00:0xa7:       Time: 17:12:41
07:15:17:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:15:17:WU01:FS00:0xa7:     Branch: master
07:15:17:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:15:18:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:15:18:WU01:FS00:0xa7:   Platform: win32 10
07:15:19:WU01:FS00:0xa7:       Bits: 64
07:15:19:WU01:FS00:0xa7:       Mode: Release
07:15:19:WU01:FS00:0xa7:************************************ Build *************************************
07:15:20:WU01:FS00:0xa7:       SIMD: avx_256
07:15:20:WU01:FS00:0xa7:********************************************************************************
07:15:22:WU01:FS00:0xa7:Project: 17410 (Run 0, Clone 880, Gen 578)
07:15:22:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:15:23:WU01:FS00:0xa7:Reading tar file core.xml
07:15:24:WU01:FS00:0xa7:Reading tar file frame578.tpr
07:15:24:WU01:FS00:0xa7:Digital signatures verified
07:15:25:WU01:FS00:0xa7:Calling: mdrun -s frame578.tpr -o frame578.trr -x frame578.xtc -cpt 15 -nt 2
07:24:55:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
07:30:17:WU01:FS00:0xa7:Steps: first=72250000 total=125000
07:34:55:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
07:35:00:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:35:02:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
07:35:03:WU01:FS00:Starting
07:35:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
07:35:05:WU01:FS00:Started FahCore on PID 7012
07:35:29:WU01:FS00:Core PID:10604
07:35:29:WU01:FS00:FahCore 0xa7 started
07:35:44:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T07:35:44Z ***********************
07:35:45:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:35:45:WU01:FS00:0xa7:       Type: 0xa7
07:35:46:WU01:FS00:0xa7:       Core: Gromacs
07:35:46:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7012 -checkpoint 15 -np 2
07:35:47:WU01:FS00:0xa7:************************************ CBang *************************************
07:35:48:WU01:FS00:0xa7:       Date: Nov 27 2019
07:35:49:WU01:FS00:0xa7:       Time: 03:40:09
07:35:50:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:35:51:WU01:FS00:0xa7:     Branch: master
07:35:51:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:35:52:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:35:53:WU01:FS00:0xa7:   Platform: win32 10
07:35:55:WU01:FS00:0xa7:       Bits: 64
07:35:55:WU01:FS00:0xa7:       Mode: Release
07:35:56:WU01:FS00:0xa7:************************************ System ************************************
07:35:59:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
07:36:02:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
07:36:03:WU01:FS00:0xa7:       CPUs: 2
07:36:04:WU01:FS00:0xa7:     Memory: 3.89GiB
07:36:04:WU01:FS00:0xa7:Free Memory: 694.74MiB
07:36:05:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
07:36:06:WU01:FS00:0xa7: OS Version: 6.2
07:36:07:WU01:FS00:0xa7:Has Battery: true
07:36:08:WU01:FS00:0xa7: On Battery: false
07:36:09:WU01:FS00:0xa7: UTC Offset: 7
07:36:10:WU01:FS00:0xa7:        PID: 10604
07:36:11:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
07:36:11:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:36:14:WU01:FS00:0xa7:    Version: 0.0.19
07:36:15:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:36:16:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:36:20:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:36:21:WU01:FS00:0xa7:       Date: Nov 25 2019
07:36:22:WU01:FS00:0xa7:       Time: 17:12:41
07:36:23:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:36:24:WU01:FS00:0xa7:     Branch: master
07:36:24:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:36:25:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:36:25:WU01:FS00:0xa7:   Platform: win32 10
07:36:26:WU01:FS00:0xa7:       Bits: 64
07:36:26:WU01:FS00:0xa7:       Mode: Release
07:36:27:WU01:FS00:0xa7:************************************ Build *************************************
07:36:28:WU01:FS00:0xa7:       SIMD: avx_256
07:36:29:WU01:FS00:0xa7:********************************************************************************
07:36:30:WU01:FS00:0xa7:Project: 17410 (Run 0, Clone 880, Gen 578)
07:36:30:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:36:31:WU01:FS00:0xa7:Reading tar file core.xml
07:36:31:WU01:FS00:0xa7:Reading tar file frame578.tpr
07:36:32:WU01:FS00:0xa7:Digital signatures verified
07:36:33:WU01:FS00:0xa7:Calling: mdrun -s frame578.tpr -o frame578.trr -x frame578.xtc -cpt 15 -nt 2
07:44:37:WU01:FS00:0xa7:Steps: first=72250000 total=125000
07:45:44:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
07:55:44:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
07:55:53:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:55:57:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
07:55:58:WU01:FS00:Starting
07:55:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
07:56:01:WU01:FS00:Started FahCore on PID 14804
07:56:27:WU01:FS00:Core PID:6408
07:56:27:WU01:FS00:FahCore 0xa7 started
07:56:39:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T07:56:39Z ***********************
07:56:39:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:56:40:WU01:FS00:0xa7:       Type: 0xa7
07:56:41:WU01:FS00:0xa7:       Core: Gromacs
07:56:41:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14804 -checkpoint 15 -np
07:56:44:WU01:FS00:0xa7:             2
07:56:44:WU01:FS00:0xa7:************************************ CBang *************************************
07:56:45:WU01:FS00:0xa7:       Date: Nov 27 2019
07:56:45:WU01:FS00:0xa7:       Time: 03:40:09
07:56:46:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:56:46:WU01:FS00:0xa7:     Branch: master
07:56:47:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:56:47:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:56:48:WU01:FS00:0xa7:   Platform: win32 10
07:56:49:WU01:FS00:0xa7:       Bits: 64
07:56:49:WU01:FS00:0xa7:       Mode: Release
07:56:50:WU01:FS00:0xa7:************************************ System ************************************
07:56:50:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
07:56:51:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
07:56:52:WU01:FS00:0xa7:       CPUs: 2
07:56:52:WU01:FS00:0xa7:     Memory: 3.89GiB
07:56:53:WU01:FS00:0xa7:Free Memory: 676.30MiB
07:56:54:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
07:56:54:WU01:FS00:0xa7: OS Version: 6.2
07:56:55:WU01:FS00:0xa7:Has Battery: true
07:56:55:WU01:FS00:0xa7: On Battery: false
07:56:56:WU01:FS00:0xa7: UTC Offset: 7
07:56:56:WU01:FS00:0xa7:        PID: 6408
07:56:57:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
07:56:57:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:56:59:WU01:FS00:0xa7:    Version: 0.0.19
07:57:02:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:57:04:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:57:04:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:57:05:WU01:FS00:0xa7:       Date: Nov 25 2019
07:57:05:WU01:FS00:0xa7:       Time: 17:12:41
07:57:06:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:57:07:WU01:FS00:0xa7:     Branch: master
07:57:08:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:57:08:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:57:09:WU01:FS00:0xa7:   Platform: win32 10
07:57:09:WU01:FS00:0xa7:       Bits: 64
07:57:10:WU01:FS00:0xa7:       Mode: Release
07:57:10:WU01:FS00:0xa7:************************************ Build *************************************
07:57:11:WU01:FS00:0xa7:       SIMD: avx_256
07:57:12:WU01:FS00:0xa7:********************************************************************************
07:57:13:WU01:FS00:0xa7:Project: 17410 (Run 0, Clone 880, Gen 578)
07:57:14:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:57:18:WU01:FS00:0xa7:Reading tar file core.xml
07:57:19:WU01:FS00:0xa7:Reading tar file frame578.tpr
07:57:20:WU01:FS00:0xa7:Digital signatures verified
07:57:20:WU01:FS00:0xa7:Calling: mdrun -s frame578.tpr -o frame578.trr -x frame578.xtc -cpt 15 -nt 2
08:06:34:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
08:16:34:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
08:16:39:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
08:16:39:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
08:16:39:WU01:FS00:Starting
08:16:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
08:16:46:WU01:FS00:Started FahCore on PID 5412
08:17:09:WU01:FS00:Core PID:14368
08:17:09:WU01:FS00:FahCore 0xa7 started
08:17:17:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T08:17:16Z ***********************
08:17:23:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:17:25:WU01:FS00:0xa7:       Type: 0xa7
08:17:26:WU01:FS00:0xa7:       Core: Gromacs
08:17:28:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5412 -checkpoint 15 -np 2
08:17:29:WU01:FS00:0xa7:************************************ CBang *************************************
08:17:31:WU01:FS00:0xa7:       Date: Nov 27 2019
08:17:33:WU01:FS00:0xa7:       Time: 03:40:09
08:17:34:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:17:36:WU01:FS00:0xa7:     Branch: master
08:17:37:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:17:39:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:17:41:WU01:FS00:0xa7:   Platform: win32 10
08:17:42:WU01:FS00:0xa7:       Bits: 64
08:17:43:WU01:FS00:0xa7:       Mode: Release
08:17:44:WU01:FS00:0xa7:************************************ System ************************************
08:17:46:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
08:17:49:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
08:17:52:WU01:FS00:0xa7:       CPUs: 2
08:17:53:WU01:FS00:0xa7:     Memory: 3.89GiB
08:17:55:WU01:FS00:0xa7:Free Memory: 476.50MiB
08:17:56:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:18:00:WU01:FS00:0xa7: OS Version: 6.2
08:18:03:WU01:FS00:0xa7:Has Battery: true
08:18:03:WU01:FS00:0xa7: On Battery: false
08:18:05:WU01:FS00:0xa7: UTC Offset: 7
08:18:06:WU01:FS00:0xa7:        PID: 14368
08:18:07:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
08:18:09:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:18:10:WU01:FS00:0xa7:    Version: 0.0.19
08:18:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:18:12:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:18:13:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
08:18:15:WU01:FS00:0xa7:       Date: Nov 25 2019
08:18:17:WU01:FS00:0xa7:       Time: 17:12:41
08:18:17:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:18:19:WU01:FS00:0xa7:     Branch: master
08:18:19:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:18:21:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:18:28:WU01:FS00:0xa7:   Platform: win32 10
08:18:29:WU01:FS00:0xa7:       Bits: 64
08:18:32:WU01:FS00:0xa7:       Mode: Release
08:18:34:WU01:FS00:0xa7:************************************ Build *************************************
08:18:37:WU01:FS00:0xa7:       SIMD: avx_256
08:18:38:WU01:FS00:0xa7:********************************************************************************
08:18:40:WU01:FS00:0xa7:Project: 17410 (Run 0, Clone 880, Gen 578)
08:18:41:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
08:18:42:WU01:FS00:0xa7:Reading tar file core.xml
08:18:44:WU01:FS00:0xa7:Reading tar file frame578.tpr
08:18:45:WU01:FS00:0xa7:Digital signatures verified
08:18:46:WU01:FS00:0xa7:Calling: mdrun -s frame578.tpr -o frame578.trr -x frame578.xtc -cpt 15 -nt 2
08:27:17:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
08:30:58:WU01:FS00:0xa7:Steps: first=72250000 total=125000
08:37:17:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
08:37:21:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
08:37:23:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
08:37:24:WU01:FS00:Starting
08:37:24:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
08:37:24:WU01:FS00:Started FahCore on PID 11468
08:37:37:WU01:FS00:Core PID:11212
08:37:37:WU01:FS00:FahCore 0xa7 started
08:38:10:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T08:38:10Z ***********************
08:38:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:38:12:WU01:FS00:0xa7:       Type: 0xa7
08:38:12:WU01:FS00:0xa7:       Core: Gromacs
08:38:13:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11468 -checkpoint 15 -np
08:38:13:WU01:FS00:0xa7:             2
08:38:14:WU01:FS00:0xa7:************************************ CBang *************************************
08:38:15:WU01:FS00:0xa7:       Date: Nov 27 2019
08:38:16:WU01:FS00:0xa7:       Time: 03:40:09
08:38:16:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:38:17:WU01:FS00:0xa7:     Branch: master
08:38:17:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:38:18:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:38:18:WU01:FS00:0xa7:   Platform: win32 10
08:38:19:WU01:FS00:0xa7:       Bits: 64
08:38:19:WU01:FS00:0xa7:       Mode: Release
08:38:19:WU01:FS00:0xa7:************************************ System ************************************
08:38:20:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
08:38:21:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
08:38:21:WU01:FS00:0xa7:       CPUs: 2
08:38:22:WU01:FS00:0xa7:     Memory: 3.89GiB
08:38:22:WU01:FS00:0xa7:Free Memory: 802.81MiB
08:38:23:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:38:23:WU01:FS00:0xa7: OS Version: 6.2
08:38:23:WU01:FS00:0xa7:Has Battery: true
08:38:24:WU01:FS00:0xa7: On Battery: false
08:38:24:WU01:FS00:0xa7: UTC Offset: 7
08:38:25:WU01:FS00:0xa7:        PID: 11212
08:38:25:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
08:38:26:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:38:27:WU01:FS00:0xa7:    Version: 0.0.19
08:38:27:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:38:29:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:38:30:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
08:38:30:WU01:FS00:0xa7:       Date: Nov 25 2019
08:38:31:WU01:FS00:0xa7:       Time: 17:12:41
08:38:32:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:38:32:WU01:FS00:0xa7:     Branch: master
08:38:32:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:38:33:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:38:34:WU01:FS00:0xa7:   Platform: win32 10
08:38:34:WU01:FS00:0xa7:       Bits: 64
08:38:34:WU01:FS00:0xa7:       Mode: Release
08:38:35:WU01:FS00:0xa7:************************************ Build *************************************
08:38:35:WU01:FS00:0xa7:       SIMD: avx_256
08:38:36:WU01:FS00:0xa7:********************************************************************************
08:38:39:WU01:FS00:0xa7:Project: 17410 (Run 0, Clone 880, Gen 578)
08:38:39:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
08:38:40:WU01:FS00:0xa7:Reading tar file core.xml
08:38:40:WU01:FS00:0xa7:Reading tar file frame578.tpr
08:38:42:WU01:FS00:0xa7:Digital signatures verified
08:38:43:WU01:FS00:0xa7:Calling: mdrun -s frame578.tpr -o frame578.trr -x frame578.xtc -cpt 15 -nt 2
08:48:06:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
08:50:49:WU01:FS00:0xa7:Steps: first=72250000 total=125000
08:58:06:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
08:58:16:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
08:58:26:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
08:58:30:WARNING:WU01:FS00:Too many errors, failing
08:58:35:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:17410 run:0 clone:880 gen:578 core:0xa7 unit:0x00000370000002420000440200000000
08:58:40:WU01:FS00:Connecting to 66.170.111.50:8080
08:58:40:WU00:FS00:Connecting to assign1.foldingathome.org:80
08:58:43:WU01:FS00:Server responded WORK_ACK (400)
08:58:43:WU01:FS00:Cleaning up
08:58:46:WU00:FS00:Assigned to work server 206.223.170.146
08:58:47:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 206.223.170.146
08:58:51:WU00:FS00:Connecting to 206.223.170.146:8080
08:58:53:WU00:FS00:Downloading 31.12MiB
08:59:00:WU00:FS00:Download 14.46%
08:59:06:WU00:FS00:Download 30.13%
08:59:12:WU00:FS00:Download 46.60%
08:59:18:WU00:FS00:Download 62.47%
08:59:25:WU00:FS00:Download 63.67%
08:59:31:WU00:FS00:Download 99.22%
08:59:31:WU00:FS00:Download complete
08:59:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17231 run:2379 clone:4 gen:20 core:0xa7 unit:0x00000004000000140000434f0000094b
08:59:31:WU00:FS00:Starting
08:59:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
08:59:52:WU00:FS00:Started FahCore on PID 14484
09:00:10:WU00:FS00:Core PID:14916
09:00:10:WU00:FS00:FahCore 0xa7 started
09:00:28:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T09:00:27Z ***********************
09:00:28:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:00:29:WU00:FS00:0xa7:       Type: 0xa7
09:00:30:WU00:FS00:0xa7:       Core: Gromacs
09:00:30:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14484 -checkpoint 15 -np
09:00:31:WU00:FS00:0xa7:             2
09:00:32:WU00:FS00:0xa7:************************************ CBang *************************************
09:00:33:WU00:FS00:0xa7:       Date: Nov 27 2019
09:00:34:WU00:FS00:0xa7:       Time: 03:40:09
09:00:34:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:00:35:WU00:FS00:0xa7:     Branch: master
09:00:35:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:00:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:00:37:WU00:FS00:0xa7:   Platform: win32 10
09:00:37:WU00:FS00:0xa7:       Bits: 64
09:00:38:WU00:FS00:0xa7:       Mode: Release
09:00:38:WU00:FS00:0xa7:************************************ System ************************************
09:00:39:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
09:00:39:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
09:00:40:WU00:FS00:0xa7:       CPUs: 2
09:00:40:WU00:FS00:0xa7:     Memory: 3.89GiB
09:00:40:WU00:FS00:0xa7:Free Memory: 675.74MiB
09:00:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:00:40:WU00:FS00:0xa7: OS Version: 6.2
09:00:40:WU00:FS00:0xa7:Has Battery: true
09:00:40:WU00:FS00:0xa7: On Battery: false
09:00:40:WU00:FS00:0xa7: UTC Offset: 7
09:00:40:WU00:FS00:0xa7:        PID: 14916
09:00:41:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
09:00:42:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
09:00:44:WU00:FS00:0xa7:    Version: 0.0.19
09:00:44:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:00:45:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:00:47:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
09:00:50:WU00:FS00:0xa7:       Date: Nov 25 2019
09:00:51:WU00:FS00:0xa7:       Time: 17:12:41
09:00:51:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:00:52:WU00:FS00:0xa7:     Branch: master
09:00:55:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:00:58:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:01:03:WU00:FS00:0xa7:   Platform: win32 10
09:01:05:WU00:FS00:0xa7:       Bits: 64
09:01:06:WU00:FS00:0xa7:       Mode: Release
09:01:08:WU00:FS00:0xa7:************************************ Build *************************************
09:01:09:WU00:FS00:0xa7:       SIMD: avx_256
09:01:10:WU00:FS00:0xa7:********************************************************************************
09:01:11:WU00:FS00:0xa7:Project: 17231 (Run 2379, Clone 4, Gen 20)
09:01:12:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
09:01:12:WU00:FS00:0xa7:Reading tar file core.xml
09:01:13:WU00:FS00:0xa7:Reading tar file frame20.tpr
09:02:12:WU00:FS00:0xa7:Digital signatures verified
09:02:13:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 2
09:10:28:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
09:15:34:WU00:FS00:0xa7:Steps: first=1250000 total=62500
09:20:28:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
09:20:43:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:20:47:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
09:20:49:WU00:FS00:Starting
09:20:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
09:20:56:WU00:FS00:Started FahCore on PID 9648
09:21:17:WU00:FS00:Core PID:8936
09:21:17:WU00:FS00:FahCore 0xa7 started
09:21:23:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T09:21:23Z ***********************
09:21:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:21:25:WU00:FS00:0xa7:       Type: 0xa7
09:21:26:WU00:FS00:0xa7:       Core: Gromacs
09:21:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9648 -checkpoint 15 -np 2
09:21:27:WU00:FS00:0xa7:************************************ CBang *************************************
09:21:30:WU00:FS00:0xa7:       Date: Nov 27 2019
09:21:30:WU00:FS00:0xa7:       Time: 03:40:09
09:21:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:21:32:WU00:FS00:0xa7:     Branch: master
09:21:33:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:21:34:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:21:36:WU00:FS00:0xa7:   Platform: win32 10
09:21:37:WU00:FS00:0xa7:       Bits: 64
09:21:37:WU00:FS00:0xa7:       Mode: Release
09:21:38:WU00:FS00:0xa7:************************************ System ************************************
09:21:39:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
09:21:40:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
09:21:41:WU00:FS00:0xa7:       CPUs: 2
09:21:42:WU00:FS00:0xa7:     Memory: 3.89GiB
09:21:42:WU00:FS00:0xa7:Free Memory: 783.96MiB
09:21:43:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:21:45:WU00:FS00:0xa7: OS Version: 6.2
09:21:46:WU00:FS00:0xa7:Has Battery: true
09:21:47:WU00:FS00:0xa7: On Battery: false
09:21:47:WU00:FS00:0xa7: UTC Offset: 7
09:21:48:WU00:FS00:0xa7:        PID: 8936
09:21:48:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
09:21:49:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
09:21:50:WU00:FS00:0xa7:    Version: 0.0.19
09:21:51:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:21:52:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:21:53:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
09:21:54:WU00:FS00:0xa7:       Date: Nov 25 2019
09:21:55:WU00:FS00:0xa7:       Time: 17:12:41
09:21:57:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:22:02:WU00:FS00:0xa7:     Branch: master
09:22:03:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:22:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:22:05:WU00:FS00:0xa7:   Platform: win32 10
09:22:06:WU00:FS00:0xa7:       Bits: 64
09:22:07:WU00:FS00:0xa7:       Mode: Release
09:22:07:WU00:FS00:0xa7:************************************ Build *************************************
09:22:12:WU00:FS00:0xa7:       SIMD: avx_256
09:22:13:WU00:FS00:0xa7:********************************************************************************
09:22:15:WU00:FS00:0xa7:Project: 17231 (Run 2379, Clone 4, Gen 20)
09:22:18:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
09:22:20:WU00:FS00:0xa7:Reading tar file core.xml
09:22:22:WU00:FS00:0xa7:Reading tar file frame20.tpr
09:23:27:WU00:FS00:0xa7:Digital signatures verified
09:23:28:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 2
09:31:25:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
09:41:24:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
09:41:27:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:41:28:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
09:41:30:WU00:FS00:Starting
09:41:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
09:41:35:WU00:FS00:Started FahCore on PID 8108
09:41:58:WU00:FS00:Core PID:7280
09:41:58:WU00:FS00:FahCore 0xa7 started
09:42:04:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T09:42:04Z ***********************
09:42:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:42:04:WU00:FS00:0xa7:       Type: 0xa7
09:42:04:WU00:FS00:0xa7:       Core: Gromacs
09:42:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8108 -checkpoint 15 -np 2
09:42:04:WU00:FS00:0xa7:************************************ CBang *************************************
09:42:04:WU00:FS00:0xa7:       Date: Nov 27 2019
09:42:05:WU00:FS00:0xa7:       Time: 03:40:09
09:42:05:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:42:05:WU00:FS00:0xa7:     Branch: master
09:42:06:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:42:07:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:42:08:WU00:FS00:0xa7:   Platform: win32 10
09:42:11:WU00:FS00:0xa7:       Bits: 64
09:42:12:WU00:FS00:0xa7:       Mode: Release
09:42:12:WU00:FS00:0xa7:************************************ System ************************************
09:42:14:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
09:42:18:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
09:42:19:WU00:FS00:0xa7:       CPUs: 2
09:42:19:WU00:FS00:0xa7:     Memory: 3.89GiB
09:42:20:WU00:FS00:0xa7:Free Memory: 684.84MiB
09:42:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:42:22:WU00:FS00:0xa7: OS Version: 6.2
09:42:22:WU00:FS00:0xa7:Has Battery: true
09:42:22:WU00:FS00:0xa7: On Battery: false
09:42:24:WU00:FS00:0xa7: UTC Offset: 7
09:42:26:WU00:FS00:0xa7:        PID: 7280
09:42:27:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
09:42:28:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
09:42:30:WU00:FS00:0xa7:    Version: 0.0.19
09:42:31:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:42:32:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:42:32:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
09:42:33:WU00:FS00:0xa7:       Date: Nov 25 2019
09:42:33:WU00:FS00:0xa7:       Time: 17:12:41
09:42:33:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:42:34:WU00:FS00:0xa7:     Branch: master
09:42:34:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:42:35:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:42:36:WU00:FS00:0xa7:   Platform: win32 10
09:42:36:WU00:FS00:0xa7:       Bits: 64
09:42:38:WU00:FS00:0xa7:       Mode: Release
09:42:39:WU00:FS00:0xa7:************************************ Build *************************************
09:42:40:WU00:FS00:0xa7:       SIMD: avx_256
09:42:41:WU00:FS00:0xa7:********************************************************************************
09:42:42:WU00:FS00:0xa7:Project: 17231 (Run 2379, Clone 4, Gen 20)
09:42:44:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
09:42:45:WU00:FS00:0xa7:Reading tar file core.xml
09:42:46:WU00:FS00:0xa7:Reading tar file frame20.tpr
09:44:44:WU00:FS00:0xa7:Digital signatures verified
09:44:50:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 2
09:52:05:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
09:58:04:WU00:FS00:0xa7:Steps: first=1250000 total=62500
10:02:05:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
10:02:35:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:02:36:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
10:02:38:WU00:FS00:Starting
10:02:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
10:02:42:WU00:FS00:Started FahCore on PID 9964
10:03:03:WU00:FS00:Core PID:9164
10:03:05:WU00:FS00:FahCore 0xa7 started
10:03:09:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T10:03:09Z ***********************
10:03:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:03:14:WU00:FS00:0xa7:       Type: 0xa7
10:03:15:WU00:FS00:0xa7:       Core: Gromacs
10:03:17:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9964 -checkpoint 15 -np 2
10:03:20:WU00:FS00:0xa7:************************************ CBang *************************************
10:03:24:WU00:FS00:0xa7:       Date: Nov 27 2019
10:03:25:WU00:FS00:0xa7:       Time: 03:40:09
10:03:27:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
10:03:28:WU00:FS00:0xa7:     Branch: master
10:03:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:03:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:03:30:WU00:FS00:0xa7:   Platform: win32 10
10:03:32:WU00:FS00:0xa7:       Bits: 64
10:03:32:WU00:FS00:0xa7:       Mode: Release
10:03:33:WU00:FS00:0xa7:************************************ System ************************************
10:03:33:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
10:03:35:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
10:03:38:WU00:FS00:0xa7:       CPUs: 2
10:03:39:WU00:FS00:0xa7:     Memory: 3.89GiB
10:03:40:WU00:FS00:0xa7:Free Memory: 1.25GiB
10:03:41:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:03:42:WU00:FS00:0xa7: OS Version: 6.2
10:03:43:WU00:FS00:0xa7:Has Battery: true
10:03:44:WU00:FS00:0xa7: On Battery: false
10:03:45:WU00:FS00:0xa7: UTC Offset: 7
10:03:46:WU00:FS00:0xa7:        PID: 9164
10:03:47:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
10:03:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:03:49:WU00:FS00:0xa7:    Version: 0.0.19
10:03:50:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:03:51:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:03:53:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:03:53:WU00:FS00:0xa7:       Date: Nov 25 2019
10:03:56:WU00:FS00:0xa7:       Time: 17:12:41
10:03:58:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
10:04:00:WU00:FS00:0xa7:     Branch: master
10:04:03:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:04:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:04:06:WU00:FS00:0xa7:   Platform: win32 10
10:04:07:WU00:FS00:0xa7:       Bits: 64
10:04:08:WU00:FS00:0xa7:       Mode: Release
10:04:09:WU00:FS00:0xa7:************************************ Build *************************************
10:04:13:WU00:FS00:0xa7:       SIMD: avx_256
10:04:13:WU00:FS00:0xa7:********************************************************************************
10:04:14:WU00:FS00:0xa7:Project: 17231 (Run 2379, Clone 4, Gen 20)
10:04:15:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
10:04:15:WU00:FS00:0xa7:Reading tar file core.xml
10:04:16:WU00:FS00:0xa7:Reading tar file frame20.tpr
10:05:32:WU00:FS00:0xa7:Digital signatures verified
10:05:33:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 2
10:13:14:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
10:21:27:WU00:FS00:0xa7:Steps: first=1250000 total=62500
10:23:11:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
10:23:13:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:23:14:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
10:23:15:WU00:FS00:Starting
10:23:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
10:23:16:WU00:FS00:Started FahCore on PID 6780
10:23:24:WU00:FS00:Core PID:14788
10:23:24:WU00:FS00:FahCore 0xa7 started
10:23:31:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T10:23:31Z ***********************
10:23:32:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:23:33:WU00:FS00:0xa7:       Type: 0xa7
10:23:33:WU00:FS00:0xa7:       Core: Gromacs
10:23:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6780 -checkpoint 15 -np 2
10:23:35:WU00:FS00:0xa7:************************************ CBang *************************************
10:23:36:WU00:FS00:0xa7:       Date: Nov 27 2019
10:23:37:WU00:FS00:0xa7:       Time: 03:40:09
10:23:37:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
10:23:38:WU00:FS00:0xa7:     Branch: master
10:23:38:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:23:38:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:23:39:WU00:FS00:0xa7:   Platform: win32 10
10:23:40:WU00:FS00:0xa7:       Bits: 64
10:23:40:WU00:FS00:0xa7:       Mode: Release
afkar.aulia
Post by afkar.aulia »
10:23:41:WU00:FS00:0xa7:************************************ System ************************************
10:23:42:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
10:23:42:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
10:23:43:WU00:FS00:0xa7:       CPUs: 2
10:23:43:WU00:FS00:0xa7:     Memory: 3.89GiB
10:23:43:WU00:FS00:0xa7:Free Memory: 858.05MiB
10:23:44:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:23:44:WU00:FS00:0xa7: OS Version: 6.2
10:23:45:WU00:FS00:0xa7:Has Battery: true
10:23:45:WU00:FS00:0xa7: On Battery: false
10:23:46:WU00:FS00:0xa7: UTC Offset: 7
10:23:46:WU00:FS00:0xa7:        PID: 14788
10:23:47:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
10:23:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:23:48:WU00:FS00:0xa7:    Version: 0.0.19
10:23:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:23:49:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:23:50:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:23:50:WU00:FS00:0xa7:       Date: Nov 25 2019
10:23:50:WU00:FS00:0xa7:       Time: 17:12:41
10:23:52:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
10:23:53:WU00:FS00:0xa7:     Branch: master
10:23:53:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:23:53:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:23:54:WU00:FS00:0xa7:   Platform: win32 10
10:23:54:WU00:FS00:0xa7:       Bits: 64
10:23:55:WU00:FS00:0xa7:       Mode: Release
10:23:55:WU00:FS00:0xa7:************************************ Build *************************************
10:23:56:WU00:FS00:0xa7:       SIMD: avx_256
10:23:56:WU00:FS00:0xa7:********************************************************************************
10:23:57:WU00:FS00:0xa7:Project: 17231 (Run 2379, Clone 4, Gen 20)
10:23:58:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
10:23:58:WU00:FS00:0xa7:Reading tar file core.xml
10:23:59:WU00:FS00:0xa7:Reading tar file frame20.tpr
10:25:52:WU00:FS00:0xa7:Digital signatures verified
10:25:53:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 2
10:32:52:WU00:FS00:0xa7:Steps: first=1250000 total=62500
10:33:31:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
10:43:37:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
10:43:44:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:43:45:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
10:43:46:WARNING:WU00:FS00:Too many errors, failing
10:43:47:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:17231 run:2379 clone:4 gen:20 core:0xa7 unit:0x00000004000000140000434f0000094b
10:43:51:WU00:FS00:Connecting to 206.223.170.146:8080
10:43:51:WU01:FS00:Connecting to assign1.foldingathome.org:80
10:43:53:WU01:FS00:Assigned to work server 66.170.111.50
10:43:53:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 66.170.111.50
10:43:54:WU00:FS00:Server responded WORK_ACK (400)
10:43:54:WU01:FS00:Connecting to 66.170.111.50:8080
10:43:54:WU00:FS00:Cleaning up
10:43:56:ERROR:WU01:FS00:Exception: Server did not assign work unit
10:43:56:WU01:FS00:Connecting to assign1.foldingathome.org:80
10:43:59:WU01:FS00:Assigned to work server 206.223.170.146
10:43:59:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 206.223.170.146
10:43:59:WU01:FS00:Connecting to 206.223.170.146:8080
10:44:02:WU01:FS00:Downloading 31.10MiB
10:44:08:WU01:FS00:Download 13.46%
10:44:14:WU01:FS00:Download 30.14%
10:44:20:WU01:FS00:Download 47.02%
10:44:26:WU01:FS00:Download 63.91%
10:44:32:WU01:FS00:Download 80.59%
10:44:38:WU01:FS00:Download 97.06%
10:44:39:WU01:FS00:Download complete
10:44:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17231 run:443 clone:4 gen:30 core:0xa7 unit:0x000000040000001e0000434f000001bb
10:45:24:WU01:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
10:45:36:WU01:FS00:Connecting to cores.foldingathome.org:80
10:45:44:WU01:FS00:FahCore a7: Downloading 6.71MiB
10:45:55:WU01:FS00:FahCore a7: 80.06%
10:45:56:WU01:FS00:FahCore a7: Download complete
10:45:56:WU01:FS00:Valid core signature
10:46:01:WARNING:WU01:FS00:FahCore has not changed since last download, aborting core update
10:46:12:WU01:FS00:Starting
10:46:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
10:46:12:WU01:FS00:Started FahCore on PID 8700
10:46:33:WU01:FS00:Core PID:8516
10:46:34:WU01:FS00:FahCore 0xa7 started
10:46:44:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T10:46:43Z ***********************
10:46:44:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:46:45:WU01:FS00:0xa7:       Type: 0xa7
10:46:46:WU01:FS00:0xa7:       Core: Gromacs
10:46:46:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8700 -checkpoint 15 -np 2
10:46:47:WU01:FS00:0xa7:************************************ CBang *************************************
10:46:48:WU01:FS00:0xa7:       Date: Nov 27 2019
10:46:48:WU01:FS00:0xa7:       Time: 03:40:09
10:46:48:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
10:46:48:WU01:FS00:0xa7:     Branch: master
10:46:48:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
10:46:48:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:46:48:WU01:FS00:0xa7:   Platform: win32 10
10:46:49:WU01:FS00:0xa7:       Bits: 64
10:46:49:WU01:FS00:0xa7:       Mode: Release
10:46:49:WU01:FS00:0xa7:************************************ System ************************************
10:46:57:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
10:47:06:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
10:47:12:WU01:FS00:0xa7:       CPUs: 2
10:47:14:WU01:FS00:0xa7:     Memory: 3.89GiB
10:47:17:WU01:FS00:0xa7:Free Memory: 837.67MiB
10:47:20:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
10:47:23:WU01:FS00:0xa7: OS Version: 6.2
10:47:25:WU01:FS00:0xa7:Has Battery: true
10:47:27:WU01:FS00:0xa7: On Battery: false
10:47:30:WU01:FS00:0xa7: UTC Offset: 7
10:47:32:WU01:FS00:0xa7:        PID: 8516
10:47:35:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
10:47:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:47:50:WU01:FS00:0xa7:    Version: 0.0.19
10:47:54:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:48:00:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:48:02:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
10:48:03:WU01:FS00:0xa7:       Date: Nov 25 2019
10:48:05:WU01:FS00:0xa7:       Time: 17:12:41
10:48:06:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
10:48:10:WU01:FS00:0xa7:     Branch: master
10:48:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
10:48:11:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:48:12:WU01:FS00:0xa7:   Platform: win32 10
10:48:12:WU01:FS00:0xa7:       Bits: 64
10:48:12:WU01:FS00:0xa7:       Mode: Release
10:48:13:WU01:FS00:0xa7:************************************ Build *************************************
10:48:14:WU01:FS00:0xa7:       SIMD: avx_256
10:48:14:WU01:FS00:0xa7:********************************************************************************
10:48:15:WU01:FS00:0xa7:Project: 17231 (Run 443, Clone 4, Gen 30)
10:48:16:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
10:48:17:WU01:FS00:0xa7:Reading tar file core.xml
10:48:17:WU01:FS00:0xa7:Reading tar file frame30.tpr
10:48:20:WU01:FS00:0xa7:Digital signatures verified
10:48:20:WU01:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpt 15 -nt 2
10:53:02:WU01:FS00:0xa7:Steps: first=1875000 total=62500
10:56:40:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
11:06:41:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
11:06:49:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:07:05:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
11:07:14:WU01:FS00:Starting
11:07:18:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
11:07:53:WU01:FS00:Started FahCore on PID 11772
11:08:12:WU01:FS00:Core PID:5816
11:08:13:WU01:FS00:FahCore 0xa7 started
11:08:28:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T11:08:27Z ***********************
11:08:28:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:08:29:WU01:FS00:0xa7:       Type: 0xa7
11:08:30:WU01:FS00:0xa7:       Core: Gromacs
11:08:30:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11772 -checkpoint 15 -np
11:08:31:WU01:FS00:0xa7:             2
11:08:32:WU01:FS00:0xa7:************************************ CBang *************************************
11:08:32:WU01:FS00:0xa7:       Date: Nov 27 2019
11:08:33:WU01:FS00:0xa7:       Time: 03:40:09
11:08:33:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:08:34:WU01:FS00:0xa7:     Branch: master
11:08:34:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:08:34:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:08:35:WU01:FS00:0xa7:   Platform: win32 10
11:08:36:WU01:FS00:0xa7:       Bits: 64
11:08:36:WU01:FS00:0xa7:       Mode: Release
11:08:37:WU01:FS00:0xa7:************************************ System ************************************
11:08:37:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
11:08:38:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
11:08:39:WU01:FS00:0xa7:       CPUs: 2
11:08:39:WU01:FS00:0xa7:     Memory: 3.89GiB
11:08:39:WU01:FS00:0xa7:Free Memory: 880.26MiB
11:08:40:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:08:41:WU01:FS00:0xa7: OS Version: 6.2
11:08:41:WU01:FS00:0xa7:Has Battery: true
11:08:41:WU01:FS00:0xa7: On Battery: false
11:08:42:WU01:FS00:0xa7: UTC Offset: 7
11:08:42:WU01:FS00:0xa7:        PID: 5816
11:08:43:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
11:08:43:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:08:44:WU01:FS00:0xa7:    Version: 0.0.19
11:08:44:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:08:45:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:08:46:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:08:46:WU01:FS00:0xa7:       Date: Nov 25 2019
11:08:47:WU01:FS00:0xa7:       Time: 17:12:41
11:08:47:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:08:48:WU01:FS00:0xa7:     Branch: master
11:08:48:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:08:50:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:08:51:WU01:FS00:0xa7:   Platform: win32 10
11:08:51:WU01:FS00:0xa7:       Bits: 64
11:08:51:WU01:FS00:0xa7:       Mode: Release
11:08:52:WU01:FS00:0xa7:************************************ Build *************************************
11:08:53:WU01:FS00:0xa7:       SIMD: avx_256
11:08:53:WU01:FS00:0xa7:********************************************************************************
11:08:54:WU01:FS00:0xa7:Project: 17231 (Run 443, Clone 4, Gen 30)
11:08:55:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
11:08:56:WU01:FS00:0xa7:Reading tar file core.xml
11:08:57:WU01:FS00:0xa7:Reading tar file frame30.tpr
11:10:37:WU01:FS00:0xa7:Digital signatures verified
11:10:42:WU01:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpt 15 -nt 2
11:17:55:WU01:FS00:0xa7:Steps: first=1875000 total=62500
11:18:28:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
11:28:29:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
11:28:38:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:28:50:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
11:28:58:WU01:FS00:Starting
11:29:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
11:29:34:WU01:FS00:Started FahCore on PID 1328
11:29:50:WU01:FS00:Core PID:12700
11:29:50:WU01:FS00:FahCore 0xa7 started
11:29:57:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T11:29:57Z ***********************
11:29:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:29:59:WU01:FS00:0xa7:       Type: 0xa7
11:30:00:WU01:FS00:0xa7:       Core: Gromacs
11:30:00:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1328 -checkpoint 15 -np 2
11:30:01:WU01:FS00:0xa7:************************************ CBang *************************************
11:30:03:WU01:FS00:0xa7:       Date: Nov 27 2019
11:30:03:WU01:FS00:0xa7:       Time: 03:40:09
11:30:03:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:30:04:WU01:FS00:0xa7:     Branch: master
11:30:05:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:30:05:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:30:05:WU01:FS00:0xa7:   Platform: win32 10
11:30:06:WU01:FS00:0xa7:       Bits: 64
11:30:06:WU01:FS00:0xa7:       Mode: Release
11:30:06:WU01:FS00:0xa7:************************************ System ************************************
11:30:07:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
11:30:08:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
11:30:09:WU01:FS00:0xa7:       CPUs: 2
11:30:09:WU01:FS00:0xa7:     Memory: 3.89GiB
11:30:10:WU01:FS00:0xa7:Free Memory: 880.63MiB
11:30:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:30:11:WU01:FS00:0xa7: OS Version: 6.2
11:30:11:WU01:FS00:0xa7:Has Battery: true
11:30:12:WU01:FS00:0xa7: On Battery: false
11:30:12:WU01:FS00:0xa7: UTC Offset: 7
11:30:13:WU01:FS00:0xa7:        PID: 12700
11:30:13:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
11:30:14:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:30:15:WU01:FS00:0xa7:    Version: 0.0.19
11:30:15:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:30:17:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:30:18:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:30:18:WU01:FS00:0xa7:       Date: Nov 25 2019
11:30:19:WU01:FS00:0xa7:       Time: 17:12:41
11:30:19:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:30:20:WU01:FS00:0xa7:     Branch: master
11:30:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:30:21:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:30:21:WU01:FS00:0xa7:   Platform: win32 10
11:30:22:WU01:FS00:0xa7:       Bits: 64
11:30:22:WU01:FS00:0xa7:       Mode: Release
11:30:23:WU01:FS00:0xa7:************************************ Build *************************************
11:30:23:WU01:FS00:0xa7:       SIMD: avx_256
11:30:24:WU01:FS00:0xa7:********************************************************************************
11:30:24:WU01:FS00:0xa7:Project: 17231 (Run 443, Clone 4, Gen 30)
11:30:25:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
11:30:26:WU01:FS00:0xa7:Reading tar file core.xml
11:30:26:WU01:FS00:0xa7:Reading tar file frame30.tpr
11:32:36:WU01:FS00:0xa7:Digital signatures verified
11:32:40:WU01:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpt 15 -nt 2
11:37:47:WU01:FS00:0xa7:Steps: first=1875000 total=62500
11:39:57:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
11:49:57:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
11:50:02:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:50:03:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
11:50:04:WU01:FS00:Starting
11:50:04:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
11:50:04:WU01:FS00:Started FahCore on PID 4856
11:50:13:WU01:FS00:Core PID:6600
11:50:13:WU01:FS00:FahCore 0xa7 started
11:50:22:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T11:50:21Z ***********************
11:50:22:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:50:23:WU01:FS00:0xa7:       Type: 0xa7
11:50:24:WU01:FS00:0xa7:       Core: Gromacs
11:50:24:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4856 -checkpoint 15 -np 2
11:50:25:WU01:FS00:0xa7:************************************ CBang *************************************
11:50:26:WU01:FS00:0xa7:       Date: Nov 27 2019
11:50:26:WU01:FS00:0xa7:       Time: 03:40:09
11:50:27:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:50:27:WU01:FS00:0xa7:     Branch: master
11:50:28:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:50:28:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:50:29:WU01:FS00:0xa7:   Platform: win32 10
11:50:29:WU01:FS00:0xa7:       Bits: 64
11:50:29:WU01:FS00:0xa7:       Mode: Release
11:50:30:WU01:FS00:0xa7:************************************ System ************************************
11:50:31:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
11:50:32:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
11:50:32:WU01:FS00:0xa7:       CPUs: 2
11:50:33:WU01:FS00:0xa7:     Memory: 3.89GiB
11:50:33:WU01:FS00:0xa7:Free Memory: 922.57MiB
11:50:34:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:50:34:WU01:FS00:0xa7: OS Version: 6.2
11:50:35:WU01:FS00:0xa7:Has Battery: true
11:50:35:WU01:FS00:0xa7: On Battery: false
11:50:35:WU01:FS00:0xa7: UTC Offset: 7
11:50:37:WU01:FS00:0xa7:        PID: 6600
11:50:37:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
11:50:38:WU01:FS00:0xa7:*****
11:50:39:WU01:FS00:0xa7:    Version: 0.0.19
11:50:39:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:50:40:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:50:40:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:50:41:WU01:FS00:0xa7:       Date: Nov 25 2019
11:50:41:WU01:FS00:0xa7:       Time: 17:12:41
11:50:42:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:50:43:WU01:FS00:0xa7:     Branch: master
11:50:43:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:50:44:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:50:44:WU01:FS00:0xa7:   Platform: win32 10
11:50:45:WU01:FS00:0xa7:       Bits: 64
11:50:45:WU01:FS00:0xa7:       Mode: Release
11:50:45:WU01:FS00:0xa7:************************************ Build *************************************
11:50:46:WU01:FS00:0xa7:       SIMD: avx_256
11:50:47:WU01:FS00:0xa7:********************************************************************************
11:50:47:WU01:FS00:0xa7:Project: 17231 (Run 443, Clone 4, Gen 30)
11:50:48:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
11:50:49:WU01:FS00:0xa7:Reading tar file core.xml
11:50:49:WU01:FS00:0xa7:Reading tar file frame30.tpr
11:52:41:WU01:FS00:0xa7:Digital signatures verified
11:52:47:WU01:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpt 15 -nt 2
11:58:58:WU01:FS00:0xa7:Steps: first=1875000 total=62500
12:00:21:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
12:10:21:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
12:10:29:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
12:10:41:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
12:10:49:WU01:FS00:Starting
12:10:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
12:10:53:WU01:FS00:Started FahCore on PID 960
12:11:04:WU01:FS00:Core PID:6720
12:11:04:WU01:FS00:FahCore 0xa7 started
12:11:12:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T12:11:12Z ***********************
12:11:13:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:11:14:WU01:FS00:0xa7:       Type: 0xa7
12:11:14:WU01:FS00:0xa7:       Core: Gromacs
12:11:14:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 960 -checkpoint 15 -np 2
12:11:14:WU01:FS00:0xa7:************************************ CBang *************************************
12:11:14:WU01:FS00:0xa7:       Date: Nov 27 2019
12:11:14:WU01:FS00:0xa7:       Time: 03:40:09
12:11:14:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
12:11:15:WU01:FS00:0xa7:     Branch: master
12:11:15:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
12:11:16:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:11:17:WU01:FS00:0xa7:   Platform: win32 10
12:11:17:WU01:FS00:0xa7:       Bits: 64
12:11:18:WU01:FS00:0xa7:       Mode: Release
12:11:18:WU01:FS00:0xa7:************************************ System ************************************
12:11:19:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
12:11:20:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
12:11:21:WU01:FS00:0xa7:       CPUs: 2
12:11:21:WU01:FS00:0xa7:     Memory: 3.89GiB
12:11:21:WU01:FS00:0xa7:Free Memory: 925.78MiB
12:11:22:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
12:11:24:WU01:FS00:0xa7: OS Version: 6.2
12:11:25:WU01:FS00:0xa7:Has Battery: true
12:11:26:WU01:FS00:0xa7: On Battery: false
12:11:26:WU01:FS00:0xa7: UTC Offset: 7
12:11:27:WU01:FS00:0xa7:        PID: 6720
12:11:27:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
12:11:27:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
12:11:27:WU01:FS00:0xa7:    Version: 0.0.19
12:11:28:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:11:28:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:11:29:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
12:11:29:WU01:FS00:0xa7:       Date: Nov 25 2019
12:11:30:WU01:FS00:0xa7:       Time: 17:12:41
12:11:30:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
12:11:31:WU01:FS00:0xa7:     Branch: master
12:11:31:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
12:11:32:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:11:32:WU01:FS00:0xa7:   Platform: win32 10
12:11:33:WU01:FS00:0xa7:       Bits: 64
12:11:33:WU01:FS00:0xa7:       Mode: Release
12:11:33:WU01:FS00:0xa7:************************************ Build *************************************
12:11:34:WU01:FS00:0xa7:       SIMD: avx_256
12:11:34:WU01:FS00:0xa7:********************************************************************************
12:11:36:WU01:FS00:0xa7:Project: 17231 (Run 443, Clone 4, Gen 30)
12:11:37:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
12:11:37:WU01:FS00:0xa7:Reading tar file core.xml
12:11:38:WU01:FS00:0xa7:Reading tar file frame30.tpr
12:13:45:WU01:FS00:0xa7:Digital signatures verified
12:13:46:WU01:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpt 15 -nt 2
12:20:02:WU01:FS00:0xa7:Steps: first=1875000 total=62500
12:21:12:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
12:31:13:WU01:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
12:31:31:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
12:31:42:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
12:31:50:WARNING:WU01:FS00:Too many errors, failing
12:31:56:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:17231 run:443 clone:4 gen:30 core:0xa7 unit:0x000000040000001e0000434f000001bb
12:32:14:WU01:FS00:Connecting to 206.223.170.146:8080
12:32:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
12:32:20:WU01:FS00:Server responded WORK_ACK (400)
12:32:27:WU01:FS00:Cleaning up
12:32:32:WU00:FS00:Assigned to work server 129.32.209.201
12:32:39:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 129.32.209.201
12:32:43:WU00:FS00:Connecting to 129.32.209.201:8080
12:32:45:WU00:FS00:Downloading 6.65MiB
12:32:51:WU00:FS00:Download 54.54%
12:32:55:WU00:FS00:Download complete
12:32:56:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16927 run:29 clone:867 gen:157 core:0xa7 unit:0x000003630000009d0000421f0000001d
12:32:56:WU00:FS00:Starting
12:32:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
12:32:57:WU00:FS00:Started FahCore on PID 12872
12:33:03:WU00:FS00:Core PID:7528
12:33:03:WU00:FS00:FahCore 0xa7 started
12:33:12:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T12:33:11Z ***********************
12:33:12:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:33:13:WU00:FS00:0xa7:       Type: 0xa7
12:33:13:WU00:FS00:0xa7:       Core: Gromacs
12:33:14:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 12872 -checkpoint 15 -np
12:33:14:WU00:FS00:0xa7:             2
12:33:15:WU00:FS00:0xa7:************************************ CBang *************************************
12:33:16:WU00:FS00:0xa7:       Date: Nov 27 2019
12:33:17:WU00:FS00:0xa7:       Time: 03:40:09
12:33:17:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
12:33:18:WU00:FS00:0xa7:     Branch: master
12:33:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:33:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:33:19:WU00:FS00:0xa7:   Platform: win32 10
12:33:19:WU00:FS00:0xa7:       Bits: 64
12:33:20:WU00:FS00:0xa7:       Mode: Release
12:33:20:WU00:FS00:0xa7:************************************ System ************************************
12:33:21:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
12:33:22:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
12:33:22:WU00:FS00:0xa7:       CPUs: 2
12:33:23:WU00:FS00:0xa7:     Memory: 3.89GiB
12:33:23:WU00:FS00:0xa7:Free Memory: 945.72MiB
12:33:23:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:33:24:WU00:FS00:0xa7: OS Version: 6.2
12:33:24:WU00:FS00:0xa7:Has Battery: true
12:33:24:WU00:FS00:0xa7: On Battery: false
12:33:25:WU00:FS00:0xa7: UTC Offset: 7
12:33:25:WU00:FS00:0xa7:        PID: 7528
12:33:25:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
12:33:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:33:27:WU00:FS00:0xa7:    Version: 0.0.19
12:33:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:33:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:33:28:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:33:28:WU00:FS00:0xa7:       Date: Nov 25 2019
12:33:29:WU00:FS00:0xa7:       Time: 17:12:41
12:33:29:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
12:33:29:WU00:FS00:0xa7:     Branch: master
12:33:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:33:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:33:31:WU00:FS00:0xa7:   Platform: win32 10
12:33:31:WU00:FS00:0xa7:       Bits: 64
12:33:31:WU00:FS00:0xa7:       Mode: Release
12:33:32:WU00:FS00:0xa7:************************************ Build *************************************
12:33:33:WU00:FS00:0xa7:       SIMD: avx_256
12:33:33:WU00:FS00:0xa7:********************************************************************************
12:33:34:WU00:FS00:0xa7:Project: 16927 (Run 29, Clone 867, Gen 157)
12:33:35:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
12:33:35:WU00:FS00:0xa7:Reading tar file core.xml
12:33:37:WU00:FS00:0xa7:Reading tar file frame157.tpr
12:34:32:WU00:FS00:0xa7:Digital signatures verified
12:34:38:WU00:FS00:0xa7:Calling: mdrun -s frame157.tpr -o frame157.trr -cpt 15 -nt 2
12:35:54:WU00:FS00:0xa7:Steps: first=78500000 total=500000
12:43:11:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
12:49:56:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
12:53:12:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
12:53:21:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
12:53:33:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
12:53:42:WU00:FS00:Starting
12:53:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
12:53:58:WU00:FS00:Started FahCore on PID 7376
12:54:04:WU00:FS00:Core PID:4876
12:54:04:WU00:FS00:FahCore 0xa7 started
12:54:14:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T12:54:14Z ***********************
12:54:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:54:16:WU00:FS00:0xa7:       Type: 0xa7
12:54:16:WU00:FS00:0xa7:       Core: Gromacs
12:54:17:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7376 -checkpoint 15 -np 2
12:54:17:WU00:FS00:0xa7:************************************ CBang *************************************
12:54:18:WU00:FS00:0xa7:       Date: Nov 27 2019
12:54:18:WU00:FS00:0xa7:       Time: 03:40:09
12:54:19:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
12:54:20:WU00:FS00:0xa7:     Branch: master
12:54:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:54:24:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:54:25:WU00:FS00:0xa7:   Platform: win32 10
12:54:25:WU00:FS00:0xa7:       Bits: 64
12:54:26:WU00:FS00:0xa7:       Mode: Release
12:54:26:WU00:FS00:0xa7:************************************ System ************************************
12:54:27:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
12:54:28:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
12:54:28:WU00:FS00:0xa7:       CPUs: 2
12:54:29:WU00:FS00:0xa7:     Memory: 3.89GiB
12:54:29:WU00:FS00:0xa7:Free Memory: 929.29MiB
12:54:30:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:54:30:WU00:FS00:0xa7: OS Version: 6.2
12:54:30:WU00:FS00:0xa7:Has Battery: true
12:54:31:WU00:FS00:0xa7: On Battery: false
12:54:31:WU00:FS00:0xa7: UTC Offset: 7
12:54:32:WU00:FS00:0xa7:        PID: 4876
12:54:32:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
12:54:32:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:54:33:WU00:FS00:0xa7:    Version: 0.0.19
12:54:34:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:54:34:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:54:35:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:54:35:WU00:FS00:0xa7:       Date: Nov 25 2019
12:54:35:WU00:FS00:0xa7:       Time: 17:12:41
12:54:36:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
12:54:36:WU00:FS00:0xa7:     Branch: master
12:54:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:54:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:54:38:WU00:FS00:0xa7:   Platform: win32 10
12:54:38:WU00:FS00:0xa7:       Bits: 64
12:54:38:WU00:FS00:0xa7:       Mode: Release
12:54:38:WU00:FS00:0xa7:************************************ Build *************************************
12:54:39:WU00:FS00:0xa7:       SIMD: avx_256
12:54:39:WU00:FS00:0xa7:********************************************************************************
12:54:40:WU00:FS00:0xa7:Project: 16927 (Run 29, Clone 867, Gen 157)
12:54:41:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
12:54:41:WU00:FS00:0xa7:Digital signatures verified
12:54:42:WU00:FS00:0xa7:Calling: mdrun -s frame157.tpr -o frame157.trr -cpt 15 -nt 2
12:57:04:WU00:FS00:0xa7:Steps: first=78500000 total=500000
13:04:12:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
13:12:43:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
13:14:12:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
13:14:15:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:14:15:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
13:14:16:WU00:FS00:Starting
13:14:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
13:14:18:WU00:FS00:Started FahCore on PID 13988
13:14:48:WU00:FS00:Core PID:900
13:14:48:WU00:FS00:FahCore 0xa7 started
13:14:55:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T13:14:54Z ***********************
13:15:08:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:15:20:WU00:FS00:0xa7:       Type: 0xa7
13:15:25:WU00:FS00:0xa7:       Core: Gromacs
13:15:30:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13988 -checkpoint 15 -np
13:15:44:WU00:FS00:0xa7:             2
13:15:49:WU00:FS00:0xa7:************************************ CBang *************************************
13:15:56:WU00:FS00:0xa7:       Date: Nov 27 2019
13:15:56:WU00:FS00:0xa7:       Time: 03:40:09
13:15:57:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:15:57:WU00:FS00:0xa7:     Branch: master
13:15:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:15:58:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:15:59:WU00:FS00:0xa7:   Platform: win32 10
13:15:59:WU00:FS00:0xa7:       Bits: 64
13:15:59:WU00:FS00:0xa7:       Mode: Release
13:16:00:WU00:FS00:0xa7:************************************ System ************************************
13:16:01:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
13:16:03:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
13:16:04:WU00:FS00:0xa7:       CPUs: 2
13:16:04:WU00:FS00:0xa7:     Memory: 3.89GiB
13:16:04:WU00:FS00:0xa7:Free Memory: 965.94MiB
13:16:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:16:05:WU00:FS00:0xa7: OS Version: 6.2
13:16:05:WU00:FS00:0xa7:Has Battery: true
13:16:05:WU00:FS00:0xa7: On Battery: false
13:16:07:WU00:FS00:0xa7: UTC Offset: 7
13:16:07:WU00:FS00:0xa7:        PID: 900
13:16:07:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
13:16:08:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:16:09:WU00:FS00:0xa7:    Version: 0.0.19
13:16:09:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:16:10:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:16:10:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:16:10:WU00:FS00:0xa7:       Date: Nov 25 2019
13:16:11:WU00:FS00:0xa7:       Time: 17:12:41
13:16:11:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:16:12:WU00:FS00:0xa7:     Branch: master
13:16:12:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:16:12:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:16:13:WU00:FS00:0xa7:   Platform: win32 10
13:16:13:WU00:FS00:0xa7:       Bits: 64
13:16:14:WU00:FS00:0xa7:       Mode: Release
13:16:14:WU00:FS00:0xa7:************************************ Build *************************************
13:16:15:WU00:FS00:0xa7:       SIMD: avx_256
13:16:15:WU00:FS00:0xa7:********************************************************************************
13:16:16:WU00:FS00:0xa7:Project: 16927 (Run 29, Clone 867, Gen 157)
13:16:17:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
13:16:17:WU00:FS00:0xa7:Digital signatures verified
13:16:18:WU00:FS00:0xa7:Calling: mdrun -s frame157.tpr -o frame157.trr -cpt 15 -nt 2
13:19:31:WU00:FS00:0xa7:Steps: first=78500000 total=500000
13:24:55:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
13:34:56:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
13:35:05:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:35:18:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
13:35:27:WU00:FS00:Starting
13:35:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
13:35:51:WU00:FS00:Started FahCore on PID 112
13:35:59:WU00:FS00:Core PID:8984
13:35:59:WU00:FS00:FahCore 0xa7 started
13:36:13:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T13:36:12Z ***********************
13:36:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:36:14:WU00:FS00:0xa7:       Type: 0xa7
13:36:14:WU00:FS00:0xa7:       Core: Gromacs
13:36:14:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 112 -checkpoint 15 -np 2
13:36:15:WU00:FS00:0xa7:************************************ CBang *************************************
13:36:17:WU00:FS00:0xa7:       Date: Nov 27 2019
13:36:17:WU00:FS00:0xa7:       Time: 03:40:09
13:36:17:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:36:18:WU00:FS00:0xa7:     Branch: master
13:36:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:36:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:36:19:WU00:FS00:0xa7:   Platform: win32 10
13:36:19:WU00:FS00:0xa7:       Bits: 64
13:36:20:WU00:FS00:0xa7:       Mode: Release
13:36:20:WU00:FS00:0xa7:************************************ System ************************************
13:36:21:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
13:36:22:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
13:36:22:WU00:FS00:0xa7:       CPUs: 2
13:36:22:WU00:FS00:0xa7:     Memory: 3.89GiB
13:36:22:WU00:FS00:0xa7:Free Memory: 959.36MiB
13:36:23:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:36:24:WU00:FS00:0xa7: OS Version: 6.2
13:36:24:WU00:FS00:0xa7:Has Battery: true
13:36:24:WU00:FS00:0xa7: On Battery: false
13:36:24:WU00:FS00:0xa7: UTC Offset: 7
13:36:25:WU00:FS00:0xa7:        PID: 8984
13:36:25:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
13:36:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:36:27:WU00:FS00:0xa7:    Version: 0.0.19
13:36:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:36:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:36:28:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:36:28:WU00:FS00:0xa7:       Date: Nov 25 2019
13:36:29:WU00:FS00:0xa7:       Time: 17:12:41
13:36:29:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:36:30:WU00:FS00:0xa7:     Branch: master
13:36:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:36:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:36:31:WU00:FS00:0xa7:   Platform: win32 10
13:36:31:WU00:FS00:0xa7:       Bits: 64
13:36:32:WU00:FS00:0xa7:       Mode: Release
13:36:32:WU00:FS00:0xa7:************************************ Build *************************************
13:36:33:WU00:FS00:0xa7:       SIMD: avx_256
13:36:33:WU00:FS00:0xa7:********************************************************************************
13:36:34:WU00:FS00:0xa7:Project: 16927 (Run 29, Clone 867, Gen 157)
13:36:35:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
13:36:35:WU00:FS00:0xa7:Digital signatures verified
13:36:35:WU00:FS00:0xa7:Calling: mdrun -s frame157.tpr -o frame157.trr -cpt 15 -nt 2
13:39:00:WU00:FS00:0xa7:Steps: first=78500000 total=500000
13:46:10:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
******************************* Date: 2021-03-11 *******************************
13:56:11:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
13:56:31:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:56:45:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
13:56:52:WU00:FS00:Starting
13:56:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
13:57:29:WU00:FS00:Started FahCore on PID 11804
13:57:50:WU00:FS00:Core PID:15012
13:57:50:WU00:FS00:FahCore 0xa7 started
13:57:59:WU00:FS00:0xa7:*********************** Log Started 2021-03-11T13:57:59Z ***********************
13:58:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:58:03:WU00:FS00:0xa7:       Type: 0xa7
13:58:03:WU00:FS00:0xa7:       Core: Gromacs
13:58:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11804 -checkpoint 15 -np
13:58:04:WU00:FS00:0xa7:             2
13:58:05:WU00:FS00:0xa7:************************************ CBang *************************************
13:58:05:WU00:FS00:0xa7:       Date: Nov 27 2019
13:58:06:WU00:FS00:0xa7:       Time: 03:40:09
13:58:06:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:58:07:WU00:FS00:0xa7:     Branch: master
13:58:07:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:58:07:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:58:08:WU00:FS00:0xa7:   Platform: win32 10
13:58:08:WU00:FS00:0xa7:       Bits: 64
13:58:09:WU00:FS00:0xa7:       Mode: Release
13:58:09:WU00:FS00:0xa7:************************************ System ************************************
13:58:10:WU00:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
13:58:10:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
13:58:11:WU00:FS00:0xa7:       CPUs: 2
13:58:11:WU00:FS00:0xa7:     Memory: 3.89GiB
13:58:11:WU00:FS00:0xa7:Free Memory: 955.44MiB
13:58:12:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:58:12:WU00:FS00:0xa7: OS Version: 6.2
13:58:12:WU00:FS00:0xa7:Has Battery: true
13:58:13:WU00:FS00:0xa7: On Battery: false
13:58:13:WU00:FS00:0xa7: UTC Offset: 7
13:58:13:WU00:FS00:0xa7:        PID: 15012
13:58:14:WU00:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
13:58:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:58:18:WU00:FS00:0xa7:    Version: 0.0.19
13:58:18:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:58:19:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:58:19:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:58:19:WU00:FS00:0xa7:       Date: Nov 25 2019
13:58:20:WU00:FS00:0xa7:       Time: 17:12:41
13:58:20:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:58:21:WU00:FS00:0xa7:     Branch: master
13:58:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:58:24:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:58:25:WU00:FS00:0xa7:   Platform: win32 10
13:58:25:WU00:FS00:0xa7:       Bits: 64
13:58:26:WU00:FS00:0xa7:       Mode: Release
13:58:26:WU00:FS00:0xa7:************************************ Build *************************************
13:58:27:WU00:FS00:0xa7:       SIMD: avx_256
13:58:27:WU00:FS00:0xa7:********************************************************************************
13:58:28:WU00:FS00:0xa7:Project: 16927 (Run 29, Clone 867, Gen 157)
13:58:29:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
13:58:29:WU00:FS00:0xa7:Digital signatures verified
13:58:30:WU00:FS00:0xa7:Calling: mdrun -s frame157.tpr -o frame157.trr -cpt 15 -nt 2
14:01:07:WU00:FS00:0xa7:Steps: first=78500000 total=500000
14:07:56:WU00:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
14:16:54:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:17:56:WU00:FS00:0xa7:Watchdog shutdown failed, hard shutdown triggered
14:18:05:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:18:07:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
14:18:07:WARNING:WU00:FS00:Too many errors, failing
14:18:08:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:16927 run:29 clone:867 gen:157 core:0xa7 unit:0x000003630000009d0000421f0000001d
14:18:08:WU00:FS00:Connecting to 129.32.209.201:8080
14:18:08:WU01:FS00:Connecting to assign1.foldingathome.org:80
14:18:09:WU00:FS00:Server responded WORK_ACK (400)
14:18:09:WU00:FS00:Cleaning up
14:18:11:WU01:FS00:Assigned to work server 128.252.203.9
14:18:11:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
14:18:11:WU01:FS00:Connecting to 128.252.203.9:8080
14:18:13:ERROR:WU01:FS00:Exception: Server did not assign work unit
14:18:14:WU01:FS00:Connecting to assign1.foldingathome.org:80
14:18:15:WU01:FS00:Assigned to work server 129.32.209.204
14:18:15:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 129.32.209.204
14:18:16:WU01:FS00:Connecting to 129.32.209.204:8080
14:18:18:ERROR:WU01:FS00:Exception: Server did not assign work unit
14:19:14:WU01:FS00:Connecting to assign1.foldingathome.org:80
14:19:15:WU01:FS00:Assigned to work server 128.252.203.9
14:19:15:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
14:19:15:WU01:FS00:Connecting to 128.252.203.9:8080
14:19:16:WU01:FS00:Downloading 7.54MiB
14:19:22:WU01:FS00:Download 43.11%
14:19:27:WU01:FS00:Download complete
14:19:28:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17430 run:0 clone:481 gen:292 core:0xa7 unit:0x000001e1000001240000441600000000
14:19:46:WU01:FS00:Starting
14:19:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 2
14:20:01:WU01:FS00:Started FahCore on PID 4232
14:20:18:WU01:FS00:Core PID:3136
14:20:22:WU01:FS00:FahCore 0xa7 started
14:20:35:WU01:FS00:0xa7:*********************** Log Started 2021-03-11T14:20:34Z ***********************
14:20:47:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:20:51:WU01:FS00:0xa7:       Type: 0xa7
14:20:52:WU01:FS00:0xa7:       Core: Gromacs
14:20:52:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4232 -checkpoint 15 -np 2
14:20:53:WU01:FS00:0xa7:************************************ CBang *************************************
14:20:53:WU01:FS00:0xa7:       Date: Nov 27 2019
14:20:54:WU01:FS00:0xa7:       Time: 03:40:09
14:20:54:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:20:55:WU01:FS00:0xa7:     Branch: master
14:20:55:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
14:20:56:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:20:56:WU01:FS00:0xa7:   Platform: win32 10
14:20:56:WU01:FS00:0xa7:       Bits: 64
14:20:56:WU01:FS00:0xa7:       Mode: Release
14:20:57:WU01:FS00:0xa7:************************************ System ************************************
14:20:59:WU01:FS00:0xa7:        CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
14:20:59:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
14:21:00:WU01:FS00:0xa7:       CPUs: 2
14:21:00:WU01:FS00:0xa7:     Memory: 3.89GiB
14:21:01:WU01:FS00:0xa7:Free Memory: 963.33MiB
14:21:01:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
14:21:02:WU01:FS00:0xa7: OS Version: 6.2
14:21:02:WU01:FS00:0xa7:Has Battery: true
14:21:02:WU01:FS00:0xa7: On Battery: false
14:21:03:WU01:FS00:0xa7: UTC Offset: 7
14:21:03:WU01:FS00:0xa7:        PID: 3136
14:21:03:WU01:FS00:0xa7:        CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
14:21:04:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
14:21:05:WU01:FS00:0xa7:    Version: 0.0.19
14:21:05:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:21:06:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:21:07:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
14:21:07:WU01:FS00:0xa7:       Date: Nov 25 2019
14:21:07:WU01:FS00:0xa7:       Time: 17:12:41
14:21:08:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:21:08:WU01:FS00:0xa7:     Branch: master
14:21:09:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
14:21:09:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:21:10:WU01:FS00:0xa7:   Platform: win32 10
14:21:10:WU01:FS00:0xa7:       Bits: 64
14:21:10:WU01:FS00:0xa7:       Mode: Release
14:21:11:WU01:FS00:0xa7:************************************ Build *************************************
14:21:11:WU01:FS00:0xa7:       SIMD: avx_256
14:21:12:WU01:FS00:0xa7:********************************************************************************
14:21:13:WU01:FS00:0xa7:Project: 17430 (Run 0, Clone 481, Gen 292)
14:21:13:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
14:21:14:WU01:FS00:0xa7:Reading tar file core.xml
14:21:14:WU01:FS00:0xa7:Reading tar file frame292.tpr
14:21:14:WU01:FS00:0xa7:Digital signatures verified
14:21:15:WU01:FS00:0xa7:Calling: mdrun -s frame292.tpr -o frame292.trr -x frame292.xtc -cpt 15 -nt 2
14:24:07:WU01:FS00:0xa7:Steps: first=36500000 total=125000
14:30:29:WU01:FS00:0xa7:Watchdog triggered, requesting soft shutdown down
Re: WU stalled twice in a single day but WORK_ACK(400)
That same WU has been reissued twice ... once from you, creating an error report because it failed and once it was completed. (I can't draw any conclusions from that information.)
I'd probably just dump it and move on.
iero
Post by iero »
Are you back to normal folding now?
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
afkar.aulia
iero wrote:Are you back to normal folding now?
Not yet because my laptop is quite slow compared to most members here. Turning F@H during day only while I shut the laptop down at night would only result in incomplete WU by the deadline. I usually needs more than 30 hours for a single WU, so I have to turn it on at night.
Probably when I feel less annoyed and can turn it on at night during weekday, I'll resume folding.
One of my systems has a dual core avx_256 CPU. It runs 24x7 and can complete the WUs assigned to it within the deadline. In the past, I had a similar laptop which I left running except for brief peoprds when I needed to move it from home to the office. It, too, completed WUs by the deadline. Frequent shutdown/resume cycles tended to increase the likelihood of serious errors on both of those systems.
I'm not certain, but I suspect that FAHCore_A8 is somewhat more reliable than FAHCore_A7 in remaining error free during a shutdown/resume cycles. Unfortunaely you don't get to choose which FAHCore the next assignment will use. Gradually new projects using _A8 will replace _A7 projects as the latter are completed and new projects become more common.
afkar.aulia
Thanks for the advice. I hope it'll resolve on it's own later.
I forgot to add, that according to my own expectation of the remaining time, the work shouldn't be completed. So it's likely that WORK_ACK message is part of the problem..
