140.163.4.200 trouble getting new wu
ImEscapade
Issue Getting a GPU Workload
Post by ImEscapade »
Hi, I've been folding for about a week, and have had no downtime at all for either my CPU or GPU, but suddenly today, I can't get a GPU workload at all, being told there are none for my configuration (Ryzen 7 3700x and RTX 3070). Here's the logs after I did a fresh install to try and fix the issue:
18:28:54:WU00:FS00:0xa8: On Battery: false
18:28:54:WU00:FS00:0xa8: UTC Offset: -5
18:28:54:WU00:FS00:0xa8:        PID: 6844
18:28:54:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
18:28:54:WU00:FS00:0xa8:********************************************************************************
18:28:54:WU00:FS00:0xa8:Project: 16944 (Run 15, Clone 70, Gen 15)
18:28:54:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
18:28:54:WU00:FS00:0xa8:Reading tar file core.xml
18:28:54:WU00:FS00:0xa8:Reading tar file frame15.tpr
18:28:54:WU00:FS00:0xa8:Digital signatures verified
18:28:54:WU00:FS00:0xa8:Calling: mdrun -c frame15.gro -s frame15.tpr -x frame15.xtc -cpt 15 -nt 14 -ntmpi 1
18:28:54:WU00:FS00:0xa8:Steps: first=75000000 total=80000000
18:28:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:28:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:28:55:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:28:55:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:28:55:WU00:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
18:28:55:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:28:55:ERROR:WU01:FS01:Exception: Could not get an assignment
18:29:09:Saving configuration to config.xml
18:29:09:<config>
18:29:09:  <!-- User Information -->
18:29:09:  <passkey v='*****'/>
18:29:09:  <team v='236749'/>
18:29:09:  <user v='ImEscapade'/>
18:29:09:
18:29:09:  <!-- Folding Slots -->
18:29:09:  <slot id='0' type='CPU'/>
18:29:09:  <slot id='1' type='GPU'>
18:29:09:    <pci-bus v='8'/>
18:29:09:    <pci-slot v='0'/>
18:29:09:  </slot>
18:29:09:</config>
18:29:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:29:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:29:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:29:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:29:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:29:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:29:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:29:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:29:54:ERROR:WU01:FS01:Exception: Could not get an assignment
18:31:30:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:31:31:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:31:31:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:31:31:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:31:31:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:31:31:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:31:31:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:31:32:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:31:32:ERROR:WU01:FS01:Exception: Could not get an assignment
18:33:27:WU00:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
18:34:08:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:34:08:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:34:08:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:34:08:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:34:08:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:34:09:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:34:09:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:34:09:WU01:FS01:Assigned to work server 140.163.4.200
18:34:09:WU01:FS01:Requesting new work unit for slot 01: gpu:8:0 GA104 [GeForce RTX 3070] from 140.163.4.200
18:34:09:WU01:FS01:Connecting to 140.163.4.200:8080
18:34:39:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
Is this just an issue on my end, and if so, how do I fix it? Thanks.
rickoic
Hardware configuration: eVga x299 DARK 2070 Super, eVGA 2080, eVga 1070, eVga 2080 Super
MSI x399 eVga 2080, eVga 1070, eVga 1070, GT970
Post by rickoic »
9:01:55:WU04:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
19:01:56:WU02:FS01:Connecting to assign1.foldingathome.org:80
19:01:56:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:01:56:WU02:FS01:Connecting to assign2.foldingathome.org:80
19:01:57:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:01:57:WU02:FS01:Connecting to assign3.foldingathome.org:80
19:01:57:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:01:57:WU02:FS01:Connecting to assign4.foldingathome.org:80
19:01:58:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:01:58:ERROR:WU02:FS01:Exception: Could not get an assignment
19:01:58:WU02:FS01:Connecting to assign1.foldingathome.org:80
19:01:58:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:01:58:WU02:FS01:Connecting to assign2.foldingathome.org:80
19:01:59:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:01:59:WU02:FS01:Connecting to assign3.foldingathome.org:80
19:01:59:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:01:59:WU02:FS01:Connecting to assign4.foldingathome.org:80
19:02:00:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:02:00:ERROR:WU02:FS01:Exception: Could not get an assignment
19:02:50:WU04:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
19:02:50:WU04:FS01:0x22:Average performance: 31.4182 ns/day
19:02:52:WU04:FS01:0x22:Checkpoint completed at step 1250000
19:02:58:WU02:FS01:Connecting to assign1.foldingathome.org:80
19:02:58:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:02:58:WU02:FS01:Connecting to assign2.foldingathome.org:80
19:02:59:WU02:FS01:Assigned to work server 140.163.4.200
19:02:59:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104 [GeForce RTX 2070 SUPER] from 140.163.4.200
19:02:59:WU02:FS01:Connecting to 140.163.4.200:8080
19:03:02:WU04:FS01:0x22:Saving result file ..\logfile_01.txt
19:03:02:WU04:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
19:03:02:WU04:FS01:0x22:Saving result file checkpointState.xml.bz2
19:03:02:WU04:FS01:0x22:Saving result file positions.xtc
19:03:02:WU04:FS01:0x22:Saving result file science.log
19:03:02:WU04:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:03:02:WU04:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:03:02:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17426 run:0 clone:1112 gen:145 core:0x22 unit:0x00000458000000910000441200000000
19:03:02:WU04:FS01:Uploading 17.92MiB to 206.223.170.146
19:03:02:WU04:FS01:Connecting to 206.223.170.146:8080
19:03:08:WU04:FS01:Upload 15.70%
19:03:14:WU04:FS01:Upload 34.88%
19:03:20:WU04:FS01:Upload 53.71%
19:03:20:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
19:03:20:WU02:FS01:Connecting to 140.163.4.200:80
19:03:26:WU04:FS01:Upload 72.90%
19:03:32:WU04:FS01:Upload 91.73%
19:03:34:WU04:FS01:Upload complete
19:03:34:WU04:FS01:Server responded WORK_ACK (400)
19:03:34:WU04:FS01:Final credit estimate, 150701.00 points
19:03:34:WU04:FS01:Cleaning up
19:03:55:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
19:04:35:WU02:FS01:Connecting to assign1.foldingathome.org:80
19:04:36:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:04:36:WU02:FS01:Connecting to assign2.foldingathome.org:80
19:04:36:WU02:FS01:Assigned to work server 140.163.4.200
19:04:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2070 SUPER] from 140.163.4.200
19:04:36:WU02:FS01:Connecting to 140.163.4.200:8080
19:04:50:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
19:07:12:WU02:FS01:Connecting to assign1.foldingathome.org:80
19:07:13:WU02:FS01:Assigned to work server 140.163.4.200
19:07:13:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2070 SUPER] from 140.163.4.200
19:07:13:WU02:FS01:Connecting to 140.163.4.200:8080
19:07:34:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
19:07:34:WU02:FS01:Connecting to 140.163.4.200:80
I'm folding because Dec 2005 I had radical prostate surgery.
Lost brother to spinal cancer, brother-in-law to prostate cancer.
Several 1st cousins lost and a few who have survived.
ImEscapade
Re: Issue Getting a GPU Workload
Ok, I think the issue might have been the work server my computer was trying to connect to. I pinged 140.163.4.200 and tried to connect to it in other ways, but received no response. I think that server may be down. Will update this post if I find anything else out.
Smookin_Joe
Re: 140.163.4.200 trouble getting new wu
Post by Smookin_Joe »
19:21:01:ERROR:WU02:FS02:Exception: Failed to connect to 140.163.4.200:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:21:55:WARNING:WU02:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:21:56:WARNING:WU02:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:21:56:WARNING:WU02:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:21:57:WARNING:WU02:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:21:57:ERROR:WU02:FS02:Exception: Could not get an assignment
19:24:54:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
19:25:25:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
19:28:47:WARNING:WU02:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:28:48:WARNING:WU02:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:28:48:WARNING:WU02:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:28:49:WARNING:WU02:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:28:49:ERROR:WU02:FS02:Exception: Could not get an assignment
19:35:39:WARNING:WU02:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:36:00:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
19:36:33:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
:wink:
Post by Neil-B »
This server is getting hammered at the moment I believe with the aws3 server down so the AS is farming a fair load at the server ... it may be that as soon as aws3 comes back up the pressure will reduce and normal service resume ... speculation on my part but follows pattern from past experience.
ImEscapade
Yep, that seems to be the solution. If you have an issue trying to get workloads, swap around your folding preference a bit, and it'll eventually work.
Post by Neil-B »
.200 ws is working as hard as it can trying to serve wus with aws3 down which normally serves some 50% of all wus iirc ... not only is it overloaded it is also acting i believe as the cs for aws3 and so is getting hit really hard on two fronts .. when aws3 comes back online things should improve
