Archlinux GPU stuck at 0%
Sir_Photch
Post by Sir_Photch »
Hello everyone!
Unfortunately, my GPU does not seem to start folding, as the progress-bar is stuck at 0%.
I use Archlinux with the Zen-kernel together with my AMD RX 5500 XT and the opencl-amd aur-package.
When taking a look into the GPU-Log, it shows "Configuring platform OpenCL" with no progress... Do I use a faulty driver or is my GPU not supported yet?
Re: Archlinux GPU stuck at 0%
What happens if you enter "FAHClient --lspci" in a text window?
Sir_Photch
0x8086:0x0150:0:0:0:Intel Corporation:
0x8086:0x0151:0:1:0:Intel Corporation:
0x8086:0x0162:0:2:0:Intel Corporation:
0x8086:0x1e31:0:20:0:Intel Corporation:
0x8086:0x1e3a:0:22:0:Intel Corporation:
0x8086:0x1e2d:0:26:0:Intel Corporation:
0x8086:0x1e10:0:28:0:Intel Corporation:
0x8086:0x1e16:0:28:3:Intel Corporation:
0x8086:0x1e18:0:28:4:Intel Corporation:
0x8086:0x1e1a:0:28:5:Intel Corporation:
0x8086:0x1e1e:0:28:7:Intel Corporation:
0x8086:0x1e26:0:29:0:Intel Corporation:
0x8086:0x1e44:0:31:0:Intel Corporation:
0x8086:0x1e02:0:31:2:Intel Corporation:
0x8086:0x1e22:0:31:3:Intel Corporation:
0x1002:0x1478:1:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x1479:2:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x7340:3:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0xab38:3:0:1:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1b21:0x0612:5:0:0:ASMedia Technology Inc.:
0x14e4:0x16b1:6:0:0:Broadcom Corporation:
0x1b21:0x1080:7:0:0:ASMedia Technology Inc.:
0x1b21:0x1042:9:0:0:ASMedia Technology Inc.:
Welcome to the F@H Forum Sir_Photch,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
I also assume that you have install the right set of drivers and OpenCL packages?
Sir_Photch
*********************** Log Started 2021-01-09T08:31:55Z ***********************
08:31:55:Trying to access database...
08:31:55:Successfully acquired database lock
08:31:55:Read GPUs.txt
08:31:55:Enabled folding slot 00: READY cpu:2
08:31:55:Enabled folding slot 01: READY gpu:0:Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
08:31:55:****************************** FAHClient ******************************
08:31:55:        Version: 7.6.13
08:31:55:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:55:      Copyright: 2020 foldingathome.org
08:31:55:       Homepage: https://foldingathome.org/
08:31:55:           Date: Apr 28 2020
08:31:55:           Time: 04:20:16
08:31:55:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
08:31:55:         Branch: master
08:31:55:       Compiler: GNU 8.3.0
08:31:55:        Options: -std=c++11 -ffunction-sections -fdata-sections -O3
08:31:55:                 -funroll-loops -fno-pie
08:31:55:       Platform: linux2 4.19.0-5-amd64
08:31:55:           Bits: 64
08:31:55:           Mode: Release
08:31:55:           Args: --config /etc/foldingathome/config.xml --log
08:31:55:                 /var/log/foldingathome/log.txt --log-rotate-dir
08:31:55:         Config: /etc/foldingathome/config.xml
08:31:55:******************************** CBang ********************************
08:31:55:           Date: Apr 25 2020
08:31:55:           Time: 00:07:53
08:31:55:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
08:31:55:                 -funroll-loops -fno-pie -fPIC
08:31:55:           Bits: 64
08:31:55:******************************* System ********************************
08:31:55:            CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
08:31:55:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
08:31:55:           CPUs: 4
08:31:55:         Memory: 15.52GiB
08:31:55:    Free Memory: 15.11GiB
08:31:55:        Threads: POSIX_THREADS
08:31:55:     OS Version: 5.10
08:31:55:    Has Battery: false
08:31:55:     On Battery: false
08:31:55:     UTC Offset: 1
08:31:55:            PID: 477
08:31:55:            CWD: /var/lib/private/fah
08:31:55:             OS: Linux 5.10.5-zen1-1-zen x86_64
08:31:55:        OS Arch: AMD64
08:31:55:           GPUs: 1
08:31:55:          GPU 0: Bus:3 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
08:31:55:                 5500M]
08:31:55:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
08:31:55:                 libcuda.so: cannot open shared object file: No such file or
08:31:55:                 directory
08:31:55:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:2.0 Driver:3188.4
08:31:55:******************************* libFAH ********************************
08:31:55:           Date: Apr 15 2020
08:31:55:           Time: 21:43:24
08:31:55:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:31:55:           Bits: 64
08:31:55:***********************************************************************
08:31:55:<config>
08:31:55:  <!-- Network -->
08:31:55:  <proxy v=':8080'/>
08:31:55:
08:31:55:  <!-- Slot Control -->
08:31:55:  <power v='MEDIUM'/>
08:31:55:
08:31:55:  <!-- User Information -->
08:31:55:  <passkey v='*****'/>
08:31:55:  <team v='70335'/>
08:31:55:  <user v='Christoph_Liebender'/>
08:31:55:
08:31:55:  <!-- Folding Slots -->
08:31:55:  <slot id='0' type='CPU'/>
08:31:55:  <slot id='1' type='GPU'/>
08:31:55:</config>
08:31:55:WU00:FS01:Starting
08:31:55:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
08:31:55:WU00:FS01:Started FahCore on PID 538
08:31:55:WU00:FS01:Core PID:542
08:31:55:WU00:FS01:FahCore 0x22 started
08:31:55:WU02:FS00:Starting
08:31:55:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
08:31:55:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -np 1
08:31:55:WU02:FS00:Started FahCore on PID 543
08:31:55:WU02:FS00:Core PID:547
08:31:55:WU02:FS00:FahCore 0xa7 started
08:31:56:WU00:FS01:0x22:*********************** Log Started 2021-01-09T08:31:55Z ***********************
08:31:56:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:31:56:WU00:FS01:0x22:       Core: Core22
08:31:56:WU00:FS01:0x22:       Type: 0x22
08:31:56:WU00:FS01:0x22:    Version: 0.0.13
08:31:56:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:56:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
08:31:56:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
08:31:56:WU00:FS01:0x22:       Date: Sep 19 2020
08:31:56:WU00:FS01:0x22:       Time: 01:10:35
08:31:56:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:31:56:WU00:FS01:0x22:     Branch: core22-0.0.13
08:31:56:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:31:56:WU00:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
08:31:56:WU00:FS01:0x22:             -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
08:31:56:WU00:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
08:31:56:WU00:FS01:0x22:       Bits: 64
08:31:56:WU00:FS01:0x22:       Mode: Release
08:31:56:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:31:56:WU00:FS01:0x22:             <peastman@stanford.edu>
08:31:56:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 538 -checkpoint 15
08:31:56:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
08:31:56:WU00:FS01:0x22:************************************ libFAH ************************************
08:31:56:WU00:FS01:0x22:       Date: Sep 15 2020
08:31:56:WU00:FS01:0x22:       Time: 05:14:43
08:31:56:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:31:56:WU00:FS01:0x22:     Branch: HEAD
08:31:56:WU00:FS01:0x22:************************************ CBang *************************************
08:31:56:WU00:FS01:0x22:       Time: 05:11:04
08:31:56:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:31:56:WU00:FS01:0x22:             -funroll-loops -fPIC
08:31:56:WU00:FS01:0x22:************************************ System ************************************
08:31:56:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
08:31:56:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
08:31:56:WU00:FS01:0x22:       CPUs: 4
08:31:56:WU00:FS01:0x22:     Memory: 15.52GiB
08:31:56:WU00:FS01:0x22:Free Memory: 14.98GiB
08:31:56:WU00:FS01:0x22:    Threads: POSIX_THREADS
08:31:56:WU00:FS01:0x22: OS Version: 5.10
08:31:56:WU00:FS01:0x22:Has Battery: false
08:31:56:WU00:FS01:0x22: On Battery: false
08:31:56:WU00:FS01:0x22: UTC Offset: 1
08:31:56:WU00:FS01:0x22:        PID: 542
08:31:56:WU00:FS01:0x22:        CWD: /var/lib/private/fah/work
08:31:56:WU00:FS01:0x22:************************************ OpenMM ************************************
08:31:56:WU00:FS01:0x22:   Revision: 189320d0
08:31:56:WU00:FS01:0x22:********************************************************************************
08:31:56:WU00:FS01:0x22:Project: 17315 (Run 0, Clone 1463, Gen 85)
08:31:56:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
08:31:56:WU00:FS01:0x22:Digital signatures verified
08:31:56:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:31:56:WU00:FS01:0x22:Version 0.0.13
08:31:56:WU00:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
08:31:56:WU00:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
08:31:56:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (20%) [5 total]
08:31:56:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
08:31:56:WU00:FS01:0x22:There are 3 platforms available.
08:31:56:WU00:FS01:0x22:Platform 0: Reference
08:31:56:WU00:FS01:0x22:Platform 1: CPU
08:31:56:WU00:FS01:0x22:Platform 2: OpenCL
08:31:56:WU00:FS01:0x22:  opencl-device 0 specified
08:31:56:WU02:FS00:0xa7:*********************** Log Started 2021-01-09T08:31:55Z ***********************
08:31:56:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:31:56:WU02:FS00:0xa7:       Type: 0xa7
08:31:56:WU02:FS00:0xa7:       Core: Gromacs
08:31:56:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 543 -checkpoint 15 -np 1
08:31:56:WU02:FS00:0xa7:************************************ CBang *************************************
08:31:56:WU02:FS00:0xa7:       Date: Nov 27 2019
08:31:56:WU02:FS00:0xa7:       Time: 11:26:54
08:31:56:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:31:56:WU02:FS00:0xa7:     Branch: master
08:31:56:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
08:31:56:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
08:31:56:WU02:FS00:0xa7:             -fno-pie -fPIC
08:31:56:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:31:56:WU02:FS00:0xa7:       Bits: 64
08:31:56:WU02:FS00:0xa7:       Mode: Release
08:31:56:WU02:FS00:0xa7:************************************ System ************************************
08:31:56:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
08:31:56:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
08:31:56:WU02:FS00:0xa7:       CPUs: 4
08:31:56:WU02:FS00:0xa7:     Memory: 15.52GiB
08:31:56:WU02:FS00:0xa7:Free Memory: 14.98GiB
08:31:56:WU02:FS00:0xa7:    Threads: POSIX_THREADS
08:31:56:WU02:FS00:0xa7: OS Version: 5.10
08:31:56:WU02:FS00:0xa7:Has Battery: false
08:31:56:WU02:FS00:0xa7: On Battery: false
08:31:56:WU02:FS00:0xa7: UTC Offset: 1
08:31:56:WU02:FS00:0xa7:        PID: 547
08:31:56:WU02:FS00:0xa7:        CWD: /var/lib/private/fah/work
08:31:56:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
08:31:56:WU02:FS00:0xa7:    Version: 0.0.19
08:31:56:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:56:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:31:56:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
08:31:56:WU02:FS00:0xa7:       Date: Nov 26 2019
08:31:56:WU02:FS00:0xa7:       Time: 00:41:42
08:31:56:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:31:56:WU02:FS00:0xa7:************************************ Build *************************************
08:31:56:WU02:FS00:0xa7:       SIMD: avx_256
08:31:56:WU02:FS00:0xa7:********************************************************************************
08:31:56:WU02:FS00:0xa7:Project: 16462 (Run 167, Clone 0, Gen 126)
08:31:56:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
08:31:56:WU02:FS00:0xa7:Digital signatures verified
08:31:56:WU02:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpi state.cpt -cpt 15 -nt 1
08:31:56:WU02:FS00:0xa7:Steps: first=31500000 total=250000
08:31:56:WU02:FS00:0xa7:Completed 14492 out of 250000 steps (5%)
08:32:04:WU00:FS01:0x22:Attempting to create OpenCL context:
08:32:04:WU00:FS01:0x22:  Configuring platform OpenCL
08:32:18:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
07:32:46:11:127.0.0.1:New Web session
07:34:04:FS00:Shutting core down
07:34:04:FS01:Shutting core down
07:34:04:WU00:FS01:0x22:Caught signal SIGINT(2) on PID 542
07:34:04:WU00:FS01:0x22:Exiting, please wait. . .
07:34:04:WU02:FS00:0xa7:Caught signal SIGINT(2) on PID 547
07:34:04:WU02:FS00:0xa7:Exiting, please wait. . .
07:34:05:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:34:05:WU02:FS00:Starting
07:34:05:WARNING:WU02:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail
07:34:05:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -np 1
07:34:05:WU02:FS00:Started FahCore on PID 3050
07:34:05:WU02:FS00:Core PID:3054
07:34:05:WU02:FS00:FahCore 0xa7 started
07:34:05:WU02:FS00:0xa7:*********************** Log Started 2021-01-09T07:34:05Z ***********************
07:34:05:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:34:05:WU02:FS00:0xa7:       Type: 0xa7
07:34:05:WU02:FS00:0xa7:       Core: Gromacs
07:34:05:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3050 -checkpoint 15 -np 1
07:34:05:WU02:FS00:0xa7:************************************ CBang *************************************
07:34:05:WU02:FS00:0xa7:       Date: Nov 27 2019
07:34:05:WU02:FS00:0xa7:       Time: 11:26:54
07:34:05:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:34:05:WU02:FS00:0xa7:     Branch: master
07:34:05:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
07:34:05:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
07:34:05:WU02:FS00:0xa7:             -fno-pie -fPIC
07:34:05:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
07:34:05:WU02:FS00:0xa7:       Bits: 64
07:34:05:WU02:FS00:0xa7:       Mode: Release
07:34:05:WU02:FS00:0xa7:************************************ System ************************************
07:34:05:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
07:34:05:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
07:34:05:WU02:FS00:0xa7:       CPUs: 4
07:34:05:WU02:FS00:0xa7:     Memory: 15.52GiB
07:34:05:WU02:FS00:0xa7:Free Memory: 11.70GiB
07:34:05:WU02:FS00:0xa7:    Threads: POSIX_THREADS
07:34:05:WU02:FS00:0xa7: OS Version: 5.10
07:34:05:WU02:FS00:0xa7:Has Battery: false
07:34:05:WU02:FS00:0xa7: On Battery: false
07:34:05:WU02:FS00:0xa7: UTC Offset: 1
07:34:05:WU02:FS00:0xa7:        PID: 3054
07:34:05:WU02:FS00:0xa7:        CWD: /var/lib/private/fah/work
07:34:05:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
07:34:05:WU02:FS00:0xa7:    Version: 0.0.19
07:34:05:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:34:05:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:34:05:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
07:34:05:WU02:FS00:0xa7:       Date: Nov 26 2019
07:34:05:WU02:FS00:0xa7:       Time: 00:41:42
07:34:05:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:34:06:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
07:34:06:WU02:FS00:0xa7:       Bits: 64
07:34:06:WU02:FS00:0xa7:       Mode: Release
07:34:06:WU02:FS00:0xa7:************************************ Build *************************************
07:34:06:WU02:FS00:0xa7:       SIMD: avx_256
07:34:06:WU02:FS00:0xa7:********************************************************************************
07:34:06:WU02:FS00:0xa7:Project: 16462 (Run 167, Clone 0, Gen 126)
07:34:06:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:34:06:WU02:FS00:0xa7:Digital signatures verified
07:34:06:WU02:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpi state.cpt -cpt 15 -nt 1
07:34:06:WU02:FS00:0xa7:Steps: first=31500000 total=250000
07:34:06:WU02:FS00:0xa7:Completed 17212 out of 250000 steps (6%)
07:34:19:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
07:34:31:FS00:Shutting core down
07:34:31:WU02:FS00:0xa7:Caught signal SIGINT(2) on PID 3054
07:34:31:WU02:FS00:0xa7:Exiting, please wait. . .
07:34:31:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:35:05:WU02:FS00:Starting
07:35:05:WARNING:WU02:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
07:35:05:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
07:35:05:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -np 1
07:35:05:WU02:FS00:Started FahCore on PID 3481
07:35:05:WU02:FS00:Core PID:3485
07:35:05:WU02:FS00:FahCore 0xa7 started
07:35:06:WU02:FS00:0xa7:*********************** Log Started 2021-01-09T07:35:05Z ***********************
07:35:06:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:35:06:WU02:FS00:0xa7:       Type: 0xa7
07:35:06:WU02:FS00:0xa7:       Core: Gromacs
07:35:06:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3481 -checkpoint 15 -np 1
07:35:06:WU02:FS00:0xa7:************************************ CBang *************************************
07:35:06:WU02:FS00:0xa7:       Date: Nov 27 2019
07:35:06:WU02:FS00:0xa7:       Time: 11:26:54
07:35:06:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:35:06:WU02:FS00:0xa7:     Branch: master
07:35:06:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
07:35:06:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
07:35:06:WU02:FS00:0xa7:             -fno-pie -fPIC
07:35:06:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
07:35:06:WU02:FS00:0xa7:       Bits: 64
07:35:06:WU02:FS00:0xa7:       Mode: Release
07:35:06:WU02:FS00:0xa7:************************************ System ************************************
07:35:06:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
07:35:06:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
07:35:06:WU02:FS00:0xa7:       CPUs: 4
07:35:06:WU02:FS00:0xa7:     Memory: 15.52GiB
07:35:06:WU02:FS00:0xa7:Free Memory: 11.34GiB
07:35:06:WU02:FS00:0xa7:    Threads: POSIX_THREADS
07:35:06:WU02:FS00:0xa7: OS Version: 5.10
07:35:06:WU02:FS00:0xa7:Has Battery: false
07:35:06:WU02:FS00:0xa7: On Battery: false
07:35:06:WU02:FS00:0xa7: UTC Offset: 1
07:35:06:WU02:FS00:0xa7:        PID: 3485
07:35:06:WU02:FS00:0xa7:        CWD: /var/lib/private/fah/work
07:35:06:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
07:35:06:WU02:FS00:0xa7:    Version: 0.0.19
07:35:06:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:35:06:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:35:06:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
07:35:06:WU02:FS00:0xa7:       Date: Nov 26 2019
07:35:06:WU02:FS00:0xa7:       Time: 00:41:42
07:35:06:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:35:06:WU02:FS00:0xa7:************************************ Build *************************************
07:35:06:WU02:FS00:0xa7:       SIMD: avx_256
07:35:06:WU02:FS00:0xa7:********************************************************************************
07:35:06:WU02:FS00:0xa7:Project: 16462 (Run 167, Clone 0, Gen 126)
07:35:06:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:35:06:WU02:FS00:0xa7:Digital signatures verified
07:35:06:WU02:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpi state.cpt -cpt 15 -nt 1
07:35:06:WU02:FS00:0xa7:Steps: first=31500000 total=250000
07:35:06:WU02:FS00:0xa7:Completed 17762 out of 250000 steps (7%)
07:36:53:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
07:38:55:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
07:40:58:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
07:42:39:FS00:Shutting core down
07:42:39:FS01:Shutting core down
07:42:39:WU02:FS00:0xa7:Caught signal SIGINT(2) on PID 3485
07:42:39:WU02:FS00:0xa7:Exiting, please wait. . .
07:42:40:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:42:40:WU02:FS00:Starting
07:42:40:WARNING:WU02:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail
07:42:40:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -np 1
07:42:40:WU02:FS00:Started FahCore on PID 6285
07:42:40:WU02:FS00:Core PID:6289
07:42:40:WU02:FS00:FahCore 0xa7 started
07:42:41:WU02:FS00:0xa7:*********************** Log Started 2021-01-09T07:42:40Z ***********************
07:42:41:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:42:41:WU02:FS00:0xa7:       Type: 0xa7
07:42:41:WU02:FS00:0xa7:       Core: Gromacs
07:42:41:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 6285 -checkpoint 15 -np 1
07:42:41:WU02:FS00:0xa7:************************************ CBang *************************************
07:42:41:WU02:FS00:0xa7:       Date: Nov 27 2019
07:42:41:WU02:FS00:0xa7:       Time: 11:26:54
07:42:41:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:42:41:WU02:FS00:0xa7:     Branch: master
07:42:41:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
07:42:41:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
07:42:41:WU02:FS00:0xa7:             -fno-pie -fPIC
07:42:41:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
07:42:41:WU02:FS00:0xa7:       Bits: 64
07:42:41:WU02:FS00:0xa7:       Mode: Release
07:42:41:WU02:FS00:0xa7:************************************ System ************************************
07:42:41:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
07:42:41:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
07:42:41:WU02:FS00:0xa7:       CPUs: 4
07:42:41:WU02:FS00:0xa7:     Memory: 15.52GiB
07:42:41:WU02:FS00:0xa7:Free Memory: 11.15GiB
07:42:41:WU02:FS00:0xa7:    Threads: POSIX_THREADS
07:42:41:WU02:FS00:0xa7: OS Version: 5.10
07:42:41:WU02:FS00:0xa7:Has Battery: false
07:42:41:WU02:FS00:0xa7: On Battery: false
07:42:41:WU02:FS00:0xa7: UTC Offset: 1
07:42:41:WU02:FS00:0xa7:        PID: 6289
07:42:41:WU02:FS00:0xa7:        CWD: /var/lib/private/fah/work
07:42:41:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
07:42:41:WU02:FS00:0xa7:    Version: 0.0.19
07:42:41:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:42:41:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:42:41:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
07:42:41:WU02:FS00:0xa7:       Date: Nov 26 2019
07:42:41:WU02:FS00:0xa7:       Time: 00:41:42
07:42:41:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:42:41:WU02:FS00:0xa7:************************************ Build *************************************
07:42:41:WU02:FS00:0xa7:       SIMD: avx_256
07:42:41:WU02:FS00:0xa7:********************************************************************************
07:42:41:WU02:FS00:0xa7:Project: 16462 (Run 167, Clone 0, Gen 126)
07:42:41:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:42:41:WU02:FS00:0xa7:Digital signatures verified
07:42:41:WU02:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpi state.cpt -cpt 15 -nt 1
07:42:41:WU02:FS00:0xa7:Steps: first=31500000 total=250000
07:42:41:WU02:FS00:0xa7:Completed 27122 out of 250000 steps (10%)
07:42:59:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
07:43:40:WARNING:FS01:Killing WU00
07:43:40:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:44:57:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
07:46:51:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
07:48:47:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
07:50:43:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
07:52:37:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
07:54:31:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
07:56:24:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
07:58:19:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
08:00:13:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
08:02:06:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
08:04:00:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
08:05:54:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
08:07:48:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
08:09:42:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
08:11:38:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
08:13:37:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
08:15:35:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
08:17:28:WU02:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
08:19:25:WU02:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
08:21:21:WU02:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
08:23:17:WU02:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
08:25:14:WU02:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
08:27:08:WU02:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
08:29:04:WU02:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
08:31:01:WU02:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
08:32:56:Removing old file 'configs/config-20210108-121851.xml'
08:32:56:Saving configuration to /etc/foldingathome/config.xml
08:32:56:<config>
08:32:56:  <!-- Network -->
08:32:56:  <proxy v=':8080'/>
08:32:56:
08:32:56:  <!-- Slot Control -->
08:32:56:  <power v='light'/>
08:32:56:
08:32:56:  <!-- User Information -->
08:32:56:  <passkey v='*****'/>
08:32:56:  <team v='70335'/>
08:32:56:  <user v='Christoph_Liebender'/>
08:32:56:
08:32:56:  <!-- Folding Slots -->
08:32:56:  <slot id='0' type='CPU'/>
08:32:56:  <slot id='1' type='GPU'/>
08:32:56:</config>
08:32:56:WU02:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
08:34:52:WU02:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
08:36:47:WU02:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
08:38:42:WU02:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
08:40:35:WU02:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
08:42:28:WU02:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
08:44:22:WU02:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
08:46:18:WU02:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
08:48:16:WU02:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
08:50:12:WU02:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
08:52:09:WU02:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
08:54:05:WU02:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
08:56:01:WU02:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
08:58:00:WU02:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
08:59:58:WU02:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
09:01:55:WU02:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
09:03:52:WU02:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
09:05:50:WU02:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
09:07:47:WU02:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
09:09:42:WU02:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
09:11:38:WU02:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
09:13:34:WU02:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
09:15:32:WU02:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
09:17:25:FS00:Shutting core down
09:17:25:WU00:FS01:Starting
09:17:25:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:17:25:WU00:FS01:Started FahCore on PID 40869
09:17:25:WU00:FS01:Core PID:40873
09:17:25:WU00:FS01:FahCore 0x22 started
09:17:25:WU02:FS00:0xa7:Caught signal SIGINT(2) on PID 6289
09:17:25:WU02:FS00:0xa7:Exiting, please wait. . .
09:17:26:WU00:FS01:0x22:*********************** Log Started 2021-01-09T09:17:25Z ***********************
09:17:26:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:17:26:WU00:FS01:0x22:       Core: Core22
09:17:26:WU00:FS01:0x22:       Type: 0x22
09:17:26:WU00:FS01:0x22:    Version: 0.0.13
09:17:26:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:17:26:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
09:17:26:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
09:17:26:WU00:FS01:0x22:       Date: Sep 19 2020
09:17:26:WU00:FS01:0x22:       Time: 01:10:35
09:17:26:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
09:17:26:WU00:FS01:0x22:     Branch: core22-0.0.13
09:17:26:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
09:17:26:WU00:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
09:17:26:WU00:FS01:0x22:             -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
09:17:26:WU00:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
09:17:26:WU00:FS01:0x22:       Bits: 64
09:17:26:WU00:FS01:0x22:       Mode: Release
09:17:26:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:17:26:WU00:FS01:0x22:             <peastman@stanford.edu>
09:17:26:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 40869 -checkpoint 15
09:17:26:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:17:26:WU00:FS01:0x22:************************************ libFAH ************************************
09:17:26:WU00:FS01:0x22:       Date: Sep 15 2020
09:17:26:WU00:FS01:0x22:       Time: 05:14:43
09:17:26:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
09:17:26:WU00:FS01:0x22:     Branch: HEAD
09:17:26:WU00:FS01:0x22:************************************ CBang *************************************
09:17:26:WU00:FS01:0x22:       Time: 05:11:04
09:17:26:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
09:17:26:WU00:FS01:0x22:             -funroll-loops -fPIC
09:17:26:WU00:FS01:0x22:************************************ System ************************************
09:17:26:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
09:17:26:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
09:17:26:WU00:FS01:0x22:       CPUs: 4
09:17:26:WU00:FS01:0x22:     Memory: 15.52GiB
09:17:26:WU00:FS01:0x22:Free Memory: 9.50GiB
09:17:26:WU00:FS01:0x22:    Threads: POSIX_THREADS
09:17:26:WU00:FS01:0x22: OS Version: 5.10
09:17:26:WU00:FS01:0x22:Has Battery: false
09:17:26:WU00:FS01:0x22: On Battery: false
09:17:26:WU00:FS01:0x22: UTC Offset: 1
09:17:26:WU00:FS01:0x22:        PID: 40873
09:17:26:WU00:FS01:0x22:        CWD: /var/lib/private/fah/work
09:17:26:WU00:FS01:0x22:************************************ OpenMM ************************************
09:17:26:WU00:FS01:0x22:   Revision: 189320d0
09:17:26:WU00:FS01:0x22:********************************************************************************
09:17:26:WU00:FS01:0x22:Project: 17315 (Run 0, Clone 1463, Gen 85)
09:17:26:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
09:17:26:WU00:FS01:0x22:Digital signatures verified
09:17:26:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:17:26:WU00:FS01:0x22:Version 0.0.13
09:17:26:WU00:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
09:17:26:WU00:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
09:17:26:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (20%) [5 total]
09:17:26:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
09:17:26:WU00:FS01:0x22:There are 3 platforms available.
09:17:26:WU00:FS01:0x22:Platform 0: Reference
09:17:26:WU00:FS01:0x22:Platform 1: CPU
09:17:26:WU00:FS01:0x22:Platform 2: OpenCL
09:17:26:WU00:FS01:0x22:  opencl-device 0 specified
09:17:26:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:17:26:WU02:FS00:Starting
09:17:26:WARNING:WU02:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
09:17:26:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
09:17:26:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 477 -checkpoint 15 -np 1
09:17:26:WU02:FS00:Started FahCore on PID 40877
09:17:26:WU02:FS00:Core PID:40881
09:17:26:WU02:FS00:FahCore 0xa7 started
09:17:27:WU02:FS00:0xa7:*********************** Log Started 2021-01-09T09:17:26Z ***********************
09:17:27:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:17:27:WU02:FS00:0xa7:       Type: 0xa7
09:17:27:WU02:FS00:0xa7:       Core: Gromacs
09:17:27:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 40877 -checkpoint 15 -np
09:17:27:WU02:FS00:0xa7:             1
09:17:27:WU02:FS00:0xa7:************************************ CBang *************************************
09:17:27:WU02:FS00:0xa7:       Date: Nov 27 2019
09:17:27:WU02:FS00:0xa7:       Time: 11:26:54
09:17:27:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:17:27:WU02:FS00:0xa7:     Branch: master
09:17:27:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
09:17:27:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
09:17:27:WU02:FS00:0xa7:             -fno-pie -fPIC
09:17:27:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
09:17:27:WU02:FS00:0xa7:       Bits: 64
09:17:27:WU02:FS00:0xa7:       Mode: Release
09:17:27:WU02:FS00:0xa7:************************************ System ************************************
09:17:27:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
09:17:27:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
09:17:27:WU02:FS00:0xa7:       CPUs: 4
09:17:27:WU02:FS00:0xa7:     Memory: 15.52GiB
09:17:27:WU02:FS00:0xa7:Free Memory: 9.31GiB
09:17:27:WU02:FS00:0xa7:    Threads: POSIX_THREADS
09:17:27:WU02:FS00:0xa7: OS Version: 5.10
09:17:27:WU02:FS00:0xa7:Has Battery: false
09:17:27:WU02:FS00:0xa7: On Battery: false
09:17:27:WU02:FS00:0xa7: UTC Offset: 1
09:17:27:WU02:FS00:0xa7:        PID: 40881
09:17:27:WU02:FS00:0xa7:        CWD: /var/lib/private/fah/work
09:17:27:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
09:17:27:WU02:FS00:0xa7:    Version: 0.0.19
09:17:27:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:17:27:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:17:27:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
09:17:27:WU02:FS00:0xa7:       Date: Nov 26 2019
09:17:27:WU02:FS00:0xa7:       Time: 00:41:42
09:17:27:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:17:27:WU02:FS00:0xa7:************************************ Build *************************************
09:17:27:WU02:FS00:0xa7:       SIMD: avx_256
09:17:27:WU02:FS00:0xa7:********************************************************************************
09:17:27:WU02:FS00:0xa7:Project: 16462 (Run 167, Clone 0, Gen 126)
09:17:27:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
09:17:27:WU02:FS00:0xa7:Digital signatures verified
09:17:27:WU02:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpi state.cpt -cpt 15 -nt 1
09:17:27:WU02:FS00:0xa7:Steps: first=31500000 total=250000
09:17:27:WU02:FS00:0xa7:Completed 149952 out of 250000 steps (59%)
09:17:29:WU02:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
09:17:34:WU00:FS01:0x22:Attempting to create OpenCL context:
09:17:34:WU00:FS01:0x22:  Configuring platform OpenCL
09:17:40:Removing old file 'configs/config-20210108-122154.xml'
09:17:40:Saving configuration to /etc/foldingathome/config.xml
09:17:40:<config>
09:17:40:  <!-- Network -->
09:17:40:  <proxy v=':8080'/>
09:17:40:
09:17:40:  <!-- Slot Control -->
09:17:40:  <power v='MEDIUM'/>
09:17:40:
09:17:40:  <!-- User Information -->
09:17:40:  <passkey v='*****'/>
09:17:40:  <team v='70335'/>
09:17:40:  <user v='Christoph_Liebender'/>
09:17:40:
09:17:40:  <!-- Folding Slots -->
09:17:40:  <slot id='0' type='CPU'/>
09:17:40:  <slot id='1' type='GPU'/>
09:17:40:</config>
09:19:21:WU02:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
09:21:13:WU02:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
09:23:05:WU02:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
09:24:58:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
09:26:57:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
09:28:51:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
09:30:45:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
09:32:40:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
09:34:35:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
09:36:29:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
09:38:25:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
09:40:19:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
09:42:14:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
09:44:07:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
09:46:01:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
09:47:55:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
09:49:49:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
09:51:51:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
09:53:54:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
09:55:55:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
09:57:54:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
09:59:55:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
10:02:03:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
10:04:19:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
10:06:35:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
10:08:54:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
10:11:14:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
10:13:33:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
10:16:02:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
10:18:31:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
10:20:58:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
10:23:32:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
10:26:03:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
10:28:36:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
I use the proprietary OpenCL-AMD package from the Arch-AUR-Repository. I tried different drivers but it seems to be this one, with others the GPU-status keeps displaying "Failed".
gunnarre
Post by gunnarre »
This thread should be moved from the ARM forum to the AMD forum.
edit by Mod: Done.
What happens if you run the command
clinfo
and
sudo clinfo
Sir_Photch
clinfo:
  Platform Name                                   AMD Accelerated Parallel Processing
  Platform Vendor                                 Advanced Micro Devices, Inc.
  Platform Version                                OpenCL 2.0 AMD-APP (3188.4)
  Platform Extensions                             cl_khr_icd cl_amd_event_callback
  Platform Extensions function suffix             AMD
  Device Name                                     gfx1012
  Device Vendor                                   Advanced Micro Devices, Inc.
  Device Version                                  OpenCL 2.0
  Driver Version                                  3188.4 (HSA1.1,LC)
  Device OpenCL C Version                         OpenCL C 2.0
  Device Board Name (AMD)                         Radeon RX 5500 XT
  Device PCI-e ID (AMD)                           0x7340
  Device Topology (AMD)                           PCI-E, 03:00.0
  Max compute units                               11
  SIMD per compute unit (AMD)                     4
  SIMD width (AMD)                                32
  SIMD instruction width (AMD)                    1
  Max clock frequency                             1900MHz
  Graphics IP (AMD)                               10.1
    Max number of sub-devices                     11
    Supported affinity domains                    (n/a)
  Max work item sizes                             1024x1024x1024
  Preferred work group size (AMD)                 256
  Max work group size (AMD)                       1024
sudo clinfo:
  Device Name                                     gfx1012
  SIMD width (AMD)                                32
Seems to be the same? Fyi, I needed to install clinfo seperately, but I don't think that this should be an issue.
Yeroon
Post by Yeroon »
the ocl-icd-opencl-dev package installed as well? Thats the one for ubuntu that solves some of the opencl issues, this might be it for arch https://archlinux.org/packages/extra/x86_64/ocl-icd/
Sir_Photch
Yes. I have followed the Archlinux-tutorial on setting up f@h, it says to install ocl-icd.
Unrelated to GPU issues
I would disable that slot. It's unlikely that it can meet the deadlines.
Sir_Photch
I only defined two Slots, the CPU and the GPU one, so I don't exactly get what you mean. What am I missing?
Bruce may have misinterpreted that message. You have a CPU slot set to use 2 threads, but the WU was downloaded when the setting was at 1 thread. It should be able to complete on time based on the CPU being an i7-3570K even using just a single thread. A better example of the sequence is here:
If the CPU setting is left at 2, future WUs will use 2 threads.
That message may be the result of several aspects of your setup. In any case, there are a lot of WUs that can be assigned to a system that's running with a single CPU thread and it's best do so what you can to avoiding such a combination if it results in late WU completions.
Sir_Photch
So, what exactly are you advising me to do?
bruce wrote:Unrelated to GPU issues
