4.8M PPD 2080!! Project 13436
Re: 4.8M PPD 2080!! Project 13436
Enjoy the Christmas gift while it lasts ...
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
High point workunits come and go occasionally. Its just part of folding. But also be aware that the opposite will occaasionally happen to balance the scales.
In BOTH cases, it's okay to report unusually high or low PPDs but be sure to include the PRCG and a description of the hardware it's running on as well as what projects you're comparing it to.
As mentioned above, it can go either way. I had a really high PPD count on a WU a few months ago, but had another one recently that initially indicated around 40% of normal PPD. It subsequently fluctuated between that number and the PPD I would usually get. With most WUs being pretty small, it will balance out quickly.
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
Project 13436 Bonus PPD!
Not complaining, just observing nearly double "normal" PPD for this system.
Project: 13436 (Run 348, Clone 1, Gen 45)
ppd: 2,130,044
Model Name: GTX 1660 Ti
Driver Version: 450.102.04
Gpu temp: 61C
Power Draw: 114.00W
Ubuntu 18.04 LTS
ppd: 2,130,044
Gpu temp: 61C
Power Draw: 114.00W
Ubuntu 18.04 LTS
